Post by Quint on Nov 25, 2016 17:36:49 GMT -6
Has anybody bought the Heritage Audio OST-10 and, if so, what's your opinion on it? I had considered picking up a Lindell 510 because the price ($399) is really cheap but then I'm inclined to think you're likely getting what you pay for (cheap parts, internal switching psu, etc.).
I suppose the main debate for me comes down to getting a second rack with a linear psu like the one in with my BAE rack or going for something a little cheaper like the Heritage which, though it's psu is external, is still a switching psu (as I understand it). Apparently the Heritage has additional filtering/regulation inside the rack but I don't know to what extent that is truly making a difference or not.
Any thoughts? I'm also open to other 10 or 11 space options in the same price range ($699) as the Heritage. Maybe some Black Friday deal I'm unaware of?
Post by sozocaps on Nov 25, 2016 21:30:21 GMT -6
Had a Lindell was HORRIBLE, have the OST-10 PERFECT... but I have a Lindell 6 which is just fine...
Post by Quint on Nov 25, 2016 21:48:10 GMT -6
Had a Lindell was HORRIBLE, have the OST-10 PERFECT... but I have a Lindell 6 which is just fine... What made the Lindell 510 horrible but the Lindell 6 space rack fine? And the OST-10 perfect?
Post by ragan on Nov 25, 2016 22:35:24 GMT -6
I have a Heritage OST-4 that's been great. I actually ordered an OST-10 thinking I was going to sell some pres and go much more into 500 series land but by the time it showed up I had changed my mind and returned it.
But anyway, the OST-4 is great.
Post by Quint on Nov 25, 2016 23:06:47 GMT -6
I have a Heritage OST-4 that's been great. I actually ordered an OST-10 thinking I was going to sell some pres and go much more into 500 series land but by the time it showed up I had changed my mind and returned it. But anyway, the OST-4 is great. Does the OST-4 have the same psu as the OST-10? Just curious. I'm inclined to think the Heritage racks are as good as any but I still feel the need to ask...
Post by ragan on Nov 25, 2016 23:19:48 GMT -6
I have a Heritage OST-4 that's been great. I actually ordered an OST-10 thinking I was going to sell some pres and go much more into 500 series land but by the time it showed up I had changed my mind and returned it. But anyway, the OST-4 is great. Does the OST-4 have the same psu as the OST-10? Just curious. I'm inclined to think the Heritage racks are as good as any but I still feel the need to ask... That is a good question. I never opened my OST-10 so I don't actually know.
Post by wiz on Nov 25, 2016 23:46:12 GMT -6
This is good to hear.. I am getting close to buying the ost4
Post by sozocaps on Nov 26, 2016 8:58:25 GMT -6
Had a Lindell was HORRIBLE, have the OST-10 PERFECT... but I have a Lindell 6 which is just fine... What made the Lindell 510 horrible but the Lindell 6 space rack fine? And the OST-10 perfect? The 10 space screw holes are aluminum with a helicoil and will strip ( the 6 has steel inserts) (the heritage is steel) and it would not power all 10 of my heritage modules when I turn phantom power on
Post by Quint on Nov 26, 2016 12:51:29 GMT -6
What made the Lindell 510 horrible but the Lindell 6 space rack fine? And the OST-10 perfect? The 10 space screw holes are aluminum with a helicoil and will strip ( the 6 has steel inserts) (the heritage is steel) and it would not power all 10 of my heritage modules when I turn phantom power on Fair enough. You've confirmed my fears on the Lindell 510.
Post by jcoutu1 on Nov 26, 2016 13:14:07 GMT -6
What made the Lindell 510 horrible but the Lindell 6 space rack fine? And the OST-10 perfect? The 10 space screw holes are aluminum with a helicoil and will strip ( the 6 has steel inserts) (the heritage is steel) and it would not power all 10 of my heritage modules when I turn phantom power on The steel inserts on my 6 space Lindell came unglued from place and are screwed up. Unit works fine, but screwing in the modules isn't right.
Post by Quint on Nov 26, 2016 14:32:04 GMT -6
So can anybody speak on specifics concerning the psu in the OST-10? How might it compare to a linear psu like the one with my BAE?
Post by jeremygillespie on Nov 26, 2016 20:01:34 GMT -6
My move when I've outgrown my 6 space API Lunchbox will definitely be to build one of Jeff's. They look pretty badass.
Post by sozocaps on Nov 26, 2016 22:02:26 GMT -6
The 10 space screw holes are aluminum with a helicoil and will strip ( the 6 has steel inserts) (the heritage is steel) and it would not power all 10 of my heritage modules when I turn phantom power on The steel inserts on my 6 space Lindell came unglued from place and are screwed up. Unit works fine, but screwing in the modules isn't right. There is a slit In the top so you can carefully hammer them back tight... yup stinks but works then add a dab of crazy glue
Post by sozocaps on Nov 26, 2016 22:03:31 GMT -6
So can anybody speak on specifics concerning the psu in the OST-10? How might it compare to a linear psu like the one with my BAE? Don't know but mine is FILLED and works GREAT and NO noise
Post by rowmat on Nov 28, 2016 3:48:01 GMT -6
We have two of Jeff's Capi VPR 11 space racks and a dual VPR floor mount linear power supply. If you can DIY then it's a no brainer.
Post by Quint on Nov 28, 2016 8:42:35 GMT -6
We have two of Jeff's Capi VPR 11 space racks and a dual VPR floor mount linear power supply. If you can DIY then it's a no brainer. If I didn't already have the one rack I undoubtedly would be doing exactly as you suggest.
