Post by dandeurloo on Aug 29, 2016 21:01:56 GMT -6
Hey guys, I need to get a cheap interface that has optical in. I will be using it as a catch system for mixing. So, I would prefer it to have multiple sample rates. I won't be using the actual converters in the system. That is why I need it to have Optical in. What do you guys recommend?
Post by NoFilterChuck on Aug 30, 2016 1:52:24 GMT -6
Post by jin167 on Aug 30, 2016 2:10:21 GMT -6
Post by schmalzy on Aug 30, 2016 8:03:59 GMT -6
I use this for mobile recording and it works pretty well. You'd probably want to get the updated version unless you're on a machine that's a few years old. www.sweetwater.com/store/detail/Scarlett18i6You'll probably have to get it used now since it's been replaced by two generations of 18i8 (two headphone outputs instead of one). ADAT in and SPDIF in/out. Sounds like it's in the ballpark you're looking for.
Post by chasmanian on Aug 30, 2016 8:12:13 GMT -6
Post by jcoutu1 on Aug 30, 2016 8:19:10 GMT -6
6i6 doesn't have adat. I have an 18i8 (which has adat). I used it with a SPDIF device. Worked fine at 48k, had issues at 96k for me. YMMV.
Post by chasmanian on Aug 30, 2016 8:48:48 GMT -6
roger that. I use the s/pdif on my 6i6. I know zero about adat. (hmmmm... warning: digital joke alert soooooo, if I know zero about it, that means that I know 50% about it.........because its all ones and zeros.......lol
Post by ericn on Aug 30, 2016 8:50:23 GMT -6
Used Motu or Focusbrite scarlet seam to be the best with and stable. Check the local pawnshops and Craigslist if it doesn't work you can probably sell it and break even!
Post by popmann on Aug 30, 2016 9:15:38 GMT -6
So, you'll get a lot cheaper if you can use COAX SPDIF--the standard for 2 channel digital....you can hop on Craigslist and get some interface with SPDIF for <$100. New....sure the 6i6 mentioned above is $250 new---the only ones less expensive (new) will be locked at single rates. That seems to be about the going for a SPDIF having IO box other than some units locked at 48khz.
Optical SPDIF is an oddball--it mostly will be finding an interface with ADAT that will switch to optical SPDIF in software....and hoping it will do multiple sample rates. COAX SPDIF will do whatever rate the interface is advertised to do. 44 to 192. Optical SPDIF CAN....but, it's all in the implementation of those ADAT chips and the switching, I think.
So....if you meant you just need a digital in--switch your search to COAX and save time, money, and arguably fidelity.
Post by mulmany on Aug 30, 2016 10:52:11 GMT -6
Minidsp usbMinistreamer B. Looks like it does bidirectional toslink and adat to/from usb 2.0
100 bucks!
Post by EmRR on Aug 30, 2016 12:32:37 GMT -6
I've got a functioning Alesis AI-1 that needs a new home, but that's probably not what you're after.....
Post by dandeurloo on Sept 1, 2016 7:39:13 GMT -6
I ordered a used CLARETT 2PRE. I like thunderbolt.
Thanks guys.
Post by ericn on Sept 1, 2016 8:05:41 GMT -6
I ordered a used CLARETT 2PRE. I like thunderbolt. Thanks guys. I was going to offer you my Avid Fastrack that came with my pt lic for next to nothing till I realized no optical!
Post by Guitar on Sept 3, 2016 19:37:28 GMT -6
Focusrite was my bet as well. They seem to be owning the cheap interface market segment. I use an 18i8.
Post by dandeurloo on Sept 5, 2016 9:51:38 GMT -6
I took the top off after I listened to it. I was really impressed. They did a nice job and for the most part used ok stuff in the box. It could be modded to sound better but it would take a lot of work and for my application it's not worth it. Now I need to just use it! haha
