COIL AUDIO CA-286 & CA-70 Multitrack Clips
Jul 18, 2016 1:00:39 GMT -6
jsteiger, noah shain, and 3 more like this
Post by Coil Audio on Jul 18, 2016 1:00:39 GMT -6
Hey there RGO - thought it might be fun to post some 96/24 audio clips of some drums we recorded recently at the ARC studio (Omaha, NE) with the 12-channels of CA-286 and CA-70 modules that reside there. There are 2 sets of audio here - One set is utilizing 100% CA-286s on every mic and the other about 80% CA-70s and a few CA-286s on Front of Kit/Room mics. Each set is approx 30-40 seconds long which is just enough time to get an idea of how these things work. No compression or EQ was used - and the gain staging is good enough that you can pull the PT/DAW fader down on all the tracks to -10 or so and it should sound good enough for review. The drumkit was a late 60's Ludwig - nothing fancy. Funky old Zildjian cymbals - etc. The mic'ing was pretty basic as well with the exception of a Stager SR1A ribbon mic placed over the kick drum for fun (great mic btw). The track list for each mic looks something like this and denotes placement, mic used, and coil pre used for each set - (panning is also noted)
1. Kick - Subkick - (CA-XXX)
2. KickIn - AKG D12 - (CA-XXX)
3. SnareTop - AKG C61 - (CA-XXX)
4. SnareBottom - Neumann KM56 - (CA-XXX)
5. FloorTomL - Josephson E22 - (CA-XXX)
6. RackTomR - Josephson E22 - (CA-XXX)
7. OverHeadL - Neumann SM69 - (CA-XXX)
8. OverHeadR - Neumann SM69 - (CA-XXX)
9. OverTheKit - Stager SR1A - (CA-XXX)
10. FrontOfKit - Neumann U47 - (CA-XXX)
11. RoomL - Josephson C617 - (CA-XXX)
12. RoomR - Josephson C617 - (CA-XXX)
To reiterate: all audio is at 96kHz/24bit - MIC ->COIL PRE ->DIGIDESIGN 192 i/o -> PT10HD - No compression or EQ. Download, unzip, and choose which set you'd like to hear and import the .WAV audio into your DAW of choice. Make sure and pull down all the track faders to -10 (at least in PT) and crank your monitors up !
Coil Audio Drums 9624
(approx. 200+MB)
Let us know if there is anything wrong with the link or any questions you might have regarding the session/mic placements etc. Of course any and all commentary is welcome and feel free to swear. Thanks RGO!
(approx. 200+MB)
