Post by Johnkenn on Mar 22, 2016 13:11:21 GMT -6
Man, can somebody please email those guys and beg for a mix knob on the 1176's?
Post by Johnkenn on Mar 22, 2016 13:22:55 GMT -6
Anybody want to tell me how in the world to do this in Cubase? For instance - I have a Slate drum part that I haven't broken out...because I'm getting a good sound form the Slate mixer and just don't want to bother breaking it out. How do you set up a side chain that only effects from say - 125 Hz and up? That way I could crush the drumbus with a 1176 and mix it in, but leave the kick alone. Guess I could just leave the kick in, though.
Post by jeromemason on Mar 22, 2016 15:16:47 GMT -6
Set up a mult with the compressor and blend it with the dry. Just duplicate the track, put the compressor on it and set it however you want it and then blend those together.
Post by drew571 on Mar 22, 2016 15:27:14 GMT -6
please change thread title to "Ohhhh for a mix knob/HP SC on ALL plugs..."
Post by NoFilterChuck on Mar 22, 2016 16:40:24 GMT -6
can't you just create a Bus that has an EQ on it that filters out everything below 200hz and then stick your compressor afterwards and send as needed? isn't that how they did Parallel Compression back in the day?
Post by ericn on Mar 22, 2016 17:07:37 GMT -6
Set up a mult with the compressor and blend it with the dry. Just duplicate the track, put the compressor on it and set it however you want it and then blend those together. You an always tell who was raised on a console!
Post by mrholmes on Mar 22, 2016 17:22:42 GMT -6
can't you just create a Bus that has an EQ on it that filters out everything below 200hz and then stick your compressor afterwards and send as needed? isn't that how they did Parallel Compression back in the day? IMO it always calls for phase trouble....
Post by donr on Mar 22, 2016 17:36:04 GMT -6
Why don't DAWs put wet/dry knobs in all their plug-in slots?
Post by Johnkenn on Mar 22, 2016 17:37:58 GMT -6
Set up a mult with the compressor and blend it with the dry. Just duplicate the track, put the compressor on it and set it however you want it and then blend those together. But that doesn't accomplish what I wanted...I wanted to filter out the kick...
Post by jazznoise on Mar 22, 2016 17:44:00 GMT -6
Why don't DAWs put wet/dry knobs in all their plug-in slots? Reaper does. I use it all the time, it's actually a thing I forgot about cause I use it so often. Usually much nicer than automating bypass automation too, as it can avoid buffer clicks.
Post by Johnkenn on Mar 22, 2016 18:16:32 GMT -6
can't you just create a Bus that has an EQ on it that filters out everything below 200hz and then stick your compressor afterwards and send as needed? isn't that how they did Parallel Compression back in the day? That's what I did...
Post by Johnkenn on Mar 22, 2016 18:16:54 GMT -6
Why don't DAWs put wet/dry knobs in all their plug-in slots? Touche
Post by jeromemason on Mar 22, 2016 18:27:50 GMT -6
Set up a mult with the compressor and blend it with the dry. Just duplicate the track, put the compressor on it and set it however you want it and then blend those together. But that doesn't accomplish what I wanted...I wanted to filter out the kick... Right... you don't want the kick compressed... so in the raw track it won't be. Give it a try, I like it better than using the SC on a comp, sounds more natural to me. The way that I look at things these days is they've made it easier to accomplish what I'm describing, but, if you want to use a certain compressor that doesn't offer that you'll have to revert back to the old ways.
Post by warrenfirehouse on Mar 22, 2016 19:08:29 GMT -6
What if you...
Mult to 3 stereo tracks.
First is untouched, output to 2bus.
2nd gets a hp filter plug set where you want it, then output to bus 1 and 2 (no 2bus)
3rd gets the compressor with bus 1 and 2 as the sidechain. Output to 2bus and blend with original.
With adc in protools, phase shouldnt be a problem. Not sure about cubase, but if it gets weird you could put both the eq and the comp in all mults and just bypass where you dont need them.
Post by warrenfirehouse on Mar 22, 2016 19:14:16 GMT -6
With that said, Uad should add some friggin mix knobs The mk2 1176s are probably the best plugin comps ive heard so far.
Post by NoFilterChuck on Mar 22, 2016 19:16:23 GMT -6
Perhaps you need a pair of these, as they have Wet/Dry right on 'em!
Post by iamasound on Mar 23, 2016 7:21:15 GMT -6
Why don't DAWs put wet/dry knobs in all their plug-in slots? I believe FL Studio does.
Post by ryanwestmusic on Mar 23, 2016 22:32:34 GMT -6
With that said, Uad should add some friggin mix knobs The mk2 1176s are probably the best plugin comps ive heard so far. Myself and other UA endorsees have been begging for years, but it was made clear that their philosophy was to recreate the real gear. However, we were successful in getting them to add it to the newer Fairchild emulation. You may find my presets in that one where I take full advantage of that feature. We'll keep trying!
Post by Johnkenn on Mar 23, 2016 22:36:22 GMT -6
Please do...you'd think they could put it as a hidden feature...
BTW - why in the hell won't they do the 176?
Post by ryanwestmusic on Mar 23, 2016 22:56:01 GMT -6
Please do...you'd think they could put it as a hidden feature... BTW - why in the hell won't they do the 176? My guess is that they probably just prioritized others first. I'll do some snooping.
Post by Johnkenn on Mar 23, 2016 23:07:48 GMT -6
