Post by scumbum on Mar 21, 2016 23:21:47 GMT -6
Any tips on sound proofing a door , mainly the gaps around the door , and at the bottom .
Post by mulmany on Mar 22, 2016 9:11:52 GMT -6
You need to use a raised sill plate, so that the entire edge of the door gets sealed against the stops. Use a steel door and use magnetic seals. Those are the cheapest options.
Post by svart on Mar 22, 2016 9:32:25 GMT -6
Post by tonycamphd on Mar 22, 2016 9:53:09 GMT -6
silicone seals are best, they're smoke rated, and stop air exchange...
Post by mdmitch2 on Mar 22, 2016 12:17:16 GMT -6
Post by ericn on Mar 22, 2016 12:19:19 GMT -6
silicone seals are best, they're smoke rated, and stop air exchange... Tony is right on this one but let me add. If you have a nice solid core door that's fire rated check the tag and see if the manufacturer has a soundproofing kit!
Post by mulmany on Mar 22, 2016 12:56:30 GMT -6
Mass is still your friend after you make it air tight.
Post by drbill on Mar 22, 2016 13:04:21 GMT -6
Do not forget the jam itself. You're only as good as your weakest link....
