Post by EmRR on Feb 19, 2016 6:08:57 GMT -6
If you record a stereo image of an ensemble, spot mic them, and at all try to preserve the image, you can't use LCR.
Post by jazznoise on Feb 19, 2016 6:34:25 GMT -6
So everyone records everything either in mono with strict L C R placement in mind, or in stereo with exact placement predetermined by the mic placement? Including a lack of adjustment of MS width? I can and will do MS adjustment when required, but a well recorded song is not entirely like a well planned shoot for a film. If you know the mix/edit, you know where to start. On Tuesday I was recording vocals and I knew I'd want a slightly wider vocal sound for the quiet parts, so I got our singer to double the vocal through a harmonica mic into an amp and I put a stereo delay on that. This meant the vocal had width, but it was also distinctly separate from the dry vocal. Also singing through an amp is fun.
Post by Kablam on Feb 19, 2016 15:57:11 GMT -6
