Mic cases
Sept 14, 2015 18:07:25 GMT -6
via mobile
Post by ben on Sept 14, 2015 18:07:25 GMT -6
Anyone know a source to get inexpensive mic cases for Mics like the apex/matachung type? I've looked everywhere and I can't seem to find any that are the right size. I need 4 apex style and 3 with the u87/67 bodies and power supplies. I'll even take them blank and cut the foam.
Post by jazznoise on Sept 14, 2015 18:27:54 GMT -6
Post by kcatthedog on Sept 14, 2015 19:12:49 GMT -6
Mic cases
Sept 14, 2015 19:54:39 GMT -6
via mobile
Post by ben on Sept 14, 2015 19:54:39 GMT -6
Jazz: the box is not tall enough to fit the shock mount
Kcat: I've already gotten the wood cases and did get them from Chung. I need a case for the mic, ps, shock and cable.
Thanks tho.
Post by jazznoise on Sept 15, 2015 3:52:08 GMT -6
Even with the shockmounts lying on there side? Either way you can get deeper flight cases and fill them out with ELE foam to taste. Just have to do the annoying bit and put them all down and measure them!
Post by horvitz on Sept 15, 2015 4:02:55 GMT -6
If you want cheap, I've used cases from Harbor Freight with those square foam inserts that you pull out in the shape of whatever you want to put in. If you want nice, try a gun shop. Attachments:
Mic cases
Sept 15, 2015 10:07:18 GMT -6
via mobile
Post by mulmany on Sept 15, 2015 10:07:18 GMT -6
Look at vanguard cases on amazon. They have lots of different sizes, you may have to go the their website and get the exact model # then go back to Amazon.
Post by Deleted on Sept 20, 2015 1:17:53 GMT -6
Professional camera cases for the serious photo and video guys mostly do a good job for tube mics with PSU and shockmount as well.
Post by jayson on Sept 20, 2015 7:55:50 GMT -6
Sounds like you might be looking for something more like a Pelican 1600 or even a 1650 if you're wanting to include all the fixin's like cables, shock mounts and power supplies, etc. Check eBay; There's always people blowing them out, I've seen them go for like $60 to $100. My boss buy 'em by the gross! I think Tundra makes some pretty decent equivalents. The caveat of buying used is that you might have to clean the exterior and-or re-foam the interior. Depending on who had the case last, that can be a formidable task sometimes. I've discovered just how cool products like WD-40 and 90% isopropyl alcohol can be in cutting down that pass-time. Foam should be pretty cheap right now since it's tied to the price of crude-oil. I've had great luck with this place if you want to pick up foam: www.thefoamfactory.com/acousticfoam/acousticfoam.htmlLots of selection and even a fair amount of some presentable acoustic solutions (hence THAT link!) Happy Hunting!
Mic cases
Sept 26, 2015 16:52:43 GMT -6
via mobile
Post by ericn on Sept 26, 2015 16:52:43 GMT -6
Look at Seahorse cases can't say it enough !
