Post by mrholmes on Jul 28, 2015 8:28:27 GMT -6
A few thoughts on my latest pure ITB experience.If you work on several projects at the same time nothing can beat working ITB. I hate cascades of plug ins, and I think its faster done with real gear, but I love true total-recall. A few findings I made over the several last months which may help others too.1. Gain Staging.
UAD says that you should go with -18 dbfs with their plug ins. Some Pro-AE recommend - 20 dbfs equal to +4 dbu on the console. I go with -24 dbfs that would be about +24 dbu headroom on a real console. I am not sure; at least I believe the plug ins sound better with it? For those who never heard about it: www.soundonsound.com/sos/sep13/articles/level-headed.htm2. Mojo small layers of saturation.With real gear it was just there .It started with the console and the outboard. I just own a few pieces of real gear and I can say this. It helps if you just do not have to think about to simulate those small layers of saturation. ITB I have to think about it.... all the stages where it would happen in the real world. I use just a tat of it also on fx returns, because I think it makes the FXs come more alive. 3. Compression?John mentioned, in another thread, that software compressors do not grab the signal like real ones. I did AB this, and to my surprise he was right. Its some kind of stupid but there is something that just feels wrong with the some software compressors. I tend to choose my tools more carefully from now on. 4. Transients in general!!I think even the console shapes them off a little bit, and also the real gear with every stage it makes it more round. Not so ITB they stick into your ear. I tend to make extensive use of logics transient shaper. It sounds to me that some of the sources are covered by the peak, if you take that away a little bit, there is the true sound. I hope that inspires some RGO users to rethink mixing ITB. I want to beat this thing because I have no choice in the future. Tell us about your experience/findings mixing ITB? What helped you to come closer to the sound you used to know. I would say I am to 90% there, but yet not totally satisfied. There is maybe some magic in real gear that is not totally captured in plug ins. With this we need to use a lot of workarounds mixing ITB.
Post by winetree on Jul 28, 2015 12:34:31 GMT -6
Harrison Mixbus
Post by mrholmes on Jul 28, 2015 13:26:49 GMT -6
It seems I have to try it I hear it from everywhere use it, its easy you will love it etc…. So credit card out....
Post by ericn on Jul 28, 2015 14:51:34 GMT -6
It's the one thing that makes me consider ITB , but I still prefer a Console!
Post by mrholmes on Jul 28, 2015 16:44:19 GMT -6
It's the one thing that makes me consider ITB , but I still prefer a Console! I would too but there are things now that force me to do it ITB. If Mixbus makes live easier. Why gOing crazy with all the other cascades of plugs. If it miniMIzes the plug window war 80 $ is nothing in this case.
Post by deehope on Jul 28, 2015 20:48:56 GMT -6
I was going to start a similar thread. Pretty much asking what 3 things have changed your itb experience. 1. Headroom (-18dbf) 2. Nebula 3. This one's cheating but it's capi modules for tracking. I think i can use any plug ins after I track through these.
Post by bluenoise on Jul 28, 2015 20:54:41 GMT -6
Indeed!! IMO, ITB makes proper gain staging and great front end much more important than ever...
Post by mrholmes on Jul 29, 2015 5:53:56 GMT -6
Maybe we can set Mixbus to the list too. At the time I try to use small amounts of compression when tracking, will see if this helps the ITB mix?
Post by EmRR on Jul 29, 2015 7:28:54 GMT -6
Lots of ITB control is necessary for recall from the other direction too: clients with involved sessions who only work a couple of days at a time with breaks of a month or two between sessions. Seems to be the new norm around here.
Post by jimwilliams on Jul 29, 2015 9:31:02 GMT -6
Being the resident AFLAC (the odd duck), I never got a decent representation of stereo imaging with a digital mix platform. Everything lies flat, like on a piece of paper hanging on the wall. The analog console gives me my dimentionality, forwards, backwards, up/down and around.
Digital mixing also has a limited bandwidth and a slew rate limited by the Nyquist roll-offs of the conversion. It also has a high pass function that I don't have, the analog system is effectivly direct coupled, zero to 200k hz flat through the inputs to stereo mix with a .13 hz roll-off from a pair large caps in the current feedback hybrid sum amps. The current feedback sum amps operate with a 30 mhz bandwidth and a 2000V /us slew rate, no digital mix platform can approach that. A phase vs frequency sweep shows zero degrees of phase shift, no other analog or digital mix platform can do that. That means all frequencies are time-aligned without any ringing, square wave tilts or distortion.
Post by Randge on Jul 29, 2015 9:41:21 GMT -6
I don't mind mixing ITB when my whole front end is RTZ, Edwards, Gates, Ampex and Telefunken preamps and similar caliber/quality stuff for eq and compression on the way in. I do insert hardware and commit to print once I am happy with the tone. I can always go back to the original tracks if I don't like it. I have 9 different records going on right now and ITB recall is a must. Mixing with the Smart AV console has enabled me to still have my hybrid mixing system and my analog gear at fingers touch.
Post by jazznoise on Jul 29, 2015 9:41:29 GMT -6
Editing and recall. Enough said, I think. It's a business and the editing abilities in a DAW are well worth any trade off you can name.
I think tracking with hardware is great and the closer you get it what you want before it hits the ADC the better. But that's less, to me, about 'Digital Sound' and more about not putting off decisions. The idea of DI'ing every guitar, synth pad etc. and deciding on the actual sonics after the fact drives me nuts.
Post by mrholmes on Jul 29, 2015 9:49:53 GMT -6
Being the resident AFLAC (the odd duck), I never got a decent representation of stereo imaging with a digital mix platform. Everything lies flat, like on a piece of paper hanging on the wall. The analog console gives me my dimensionality, forwards, backwards, up/down and around. Digital mixing also has a limited bandwidth and a slew rate limited by the Nyquist roll-offs of the conversion. It also has a high pass function that I don't have, the analog system is effectivly direct coupled, zero to 200k hz flat through the inputs to stereo mix with a .13 hz roll-off from a pair large caps in the current feedback hybrid sum amps. The current feedback sum amps operate with a 30 mhz bandwidth and a 2000V /us slew rate, no digital mix platform can approach that. A phase vs frequency sweep shows zero degrees of phase shift, no other analog or digital mix platform can do that. That means all frequencies are time-aligned without any ringing, square wave tilts or distortion. I would not go that far that ITB sounds totally flat, special not with the console slew-rate simulation of Airwindows in Logic. But Jim is right that its not exactly the same. But today clients want to have instant total recall. A day before mastering: "can you pull down the snare a db". I cant do this with the console because next project is already running. It pisses me the most that the ITB workflow is unnatural... hybrid is way more fun. BTW pulled the trigger on Harrison Mixbus. Lets see if this one sounds different if that brings back all three dimension... I am fine. If Mixbus is going to work the console will be a nice eye catcher.
Post by drbill on Jul 29, 2015 11:05:32 GMT -6
I agree with Randge. Well, never used the RTZ stuff, but I agree with the INTENT of his post - that quality front end alleviates a lot of the need for a console on the back side. Ronnie Capone once told me that as long as you had a great console to track with OR mix with you would be OK. You need some quality on one end or the other. Well, that was long before DAW's were even on the horizon, but I think it's a point well taken. If you have a strong front end, or are mixing hybrid, the need for a console to MIX on becomes less important sonically. The ergo's? Sure, nothing is quite like it, but it's not necessary on a sonics level.
Once upon a time I said I'd be buried beneath my console, but its been in storage since I moved, and I'm in the midst of designing a new CRM, and it doesn't look like there's going to be a console in it..... Kinda saddens me, but I think the ol girl is going to be going up FS one of these days soon.....
Post by drbill on Jul 29, 2015 11:07:26 GMT -6
As far as ITB vs. OTB sonics :
I think some people embrace ITB and find ways to make it work, and it sounds great. While others pull against it and always are longing for it to be something it is not. Those are the guys who can never seem to make it work and believe it's an inferior platform.
Post by Randge on Jul 29, 2015 13:11:23 GMT -6
As far as ITB vs. OTB sonics : I think some people embrace ITB and find ways to make it work, and it sounds great. While others pull against it and always are longing for it to be something it is not. Those are the guys who can never seem to make it work and believe it's an inferior platform. Funny enough,those are the same guys who can't program their cellphones either, Bill. I know lots of guys who are afraid of technology and resist it with every fiber of their being. Sadly, they are being left in the dust and only get to work on a certain amount of projects that are very well suited to them. I would rather be making music every day rather than sitting around hoping someone wants to make that kind of record only.
Post by Deleted on Jul 29, 2015 14:57:17 GMT -6
The 3 things that changed ITB experience the most for me: 1. Proper internal formats and mixing engines in all DAWs ~ a decade ago. Before, not all DAW sounded equal. Due to serious flaws in their digital programming i.e. no floating point formats, dithering errors etc. 2. Proper gainstaging technique used. 3. Harrison Mixbus.
Post by mrholmes on Jul 30, 2015 6:11:56 GMT -6
jimwilliams I have to apologize, I was to quick with my ITB mixing and it works for me BS talk. Yesterday I asked myself what would be so tragic to use the console for summing only. I hooked the thing up ready and played back the mix. It took me just a few adjustments and it sounded like good, and to be great it will maybe take another 30 minutes. To get at the same point pure ITB is a true fucking PAIN and you are never truly satisfied. Jim you are right that using a board for summing makes a difference in space and dimension of everything. And I am just using a crappy Allen and Heath ZED 24... I will try mixbus anyway but I have my doubts that it can do the same thing. So yeah hybrid has to be my future.
Post by EmRR on Jul 30, 2015 6:36:24 GMT -6
I almost always use the console as summing, pan, some aux sends. Sessions with 2-6 total tracks are the ones that may sound 'better' staying fully ITB, at least to my ears.
My habits are non-typical. I used to do lots of parallel bus manipulation, I haven't done that in a decade. I no longer feel it's worth the effort. I stopped printing analog pass through back, I just do it all upfront on the way in. Make it sound like a record while the band is tracking, makes life easier.
Post by Martin John Butler on Jul 30, 2015 7:51:22 GMT -6
Jim said, "Being the resident AFLAC (the odd duck), I never got a decent representation of stereo imaging with a digital mix platform. Everything lies flat, like on a piece of paper hanging on the wall. The analog console gives me my dimentionality, forwards, backwards, up/down and around."
I kinda know what you mean Jim. I've been struggling ITB at home making song demos. I do print with my preamp, (Dizengoff D4) > WA76 compressor > Apollo DAW, sometimes with a pinch of the LA2 plug but even with some out of the box processing, I've been finding it difficult to get a real stereo image. Left, right, middle is easy, but front to back ain't happening. I've seen a tutorial about using delay on one or two tracks instead of panning to move to track across the stereo field, but it was a little over my head. Every time I've experimented with parallel compression, I hear phasing issues and ultimately, don't bother with it.
uhh, mrholmes, what's Airwindows? Do I already have it in Logic?
This question is especially interesting to me because I may update my system by going from the silver to the new blackface Apollo, and I'm not sure if I should shoot for the Apollo 16, which is $500 more than the 8P. The 16 has better converters, but no preamps. I eventually think I'll end up with a soundboard, but that might be 18 months from now. Still, I'd like to be ready if I do.
Post by mrholmes on Jul 30, 2015 8:55:00 GMT -6
Jim said, "Being the resident AFLAC (the odd duck), I never got a decent representation of stereo imaging with a digital mix platform. Everything lies flat, like on a piece of paper hanging on the wall. The analog console gives me my dimentionality, forwards, backwards, up/down and around." I kinda know what you mean Jim. I've been struggling ITB at home making song demos. I do print with my preamp, (Dizengoff D4) > WA76 compressor > Apollo DAW, sometimes with a pinch of the LA2 plug but even with some out of the box processing, I've been finding it difficult to get a real stereo image. Left, right, middle is easy, but front to back ain't happening. I've seen a tutorial about using delay on one or two tracks instead of panning to move to track across the stereo field, but it was a little over my head. Every time I've experimented with parallel compression, I hear phasing issues and ultimately, don't bother with it. uhh, mrholmes, what's Airwindows? Do I already have it in Logic? This question is especially interesting to me because I may update my system by going from the silver to the new blackface Apollo, and I'm not sure if I should shoot for the Apollo 16, which is $500 more than the 8P. The 16 has better converters, but no preamps. I eventually think I'll end up with a soundboard, but that might be 18 months from now. Still, I'd like to be ready if I do. To make a long story short. There is a reason for this thread. I went in circles about the Hybrid vs. ITB thing about the wish to have everything in one computer. Some mixes turn out good ITB but sometimes, like at the moment, I do not get the dimension I want. Its not the first time, I switch on the console and it sounds much more like a record. With this Jim is right. Do what I did a few years ago. I bought 16 out converter and a Allen and Heath ZED 14. Plus two Midiverbs and a Yamaha REV 500 I had outboard before which was hardwired to my converter. So its also worth the thing if you only use the ZED 14 for summing. It sounds different.... PS: Airwindows Console is something that helps with the depth and dimension ITB. But its really nothing against the console. And the ZED 14 is a cheap console.... I mean why not buying one if it makes you happy....
Post by Martin John Butler on Jul 30, 2015 10:01:39 GMT -6
thanks mrholmes. I've got some figuring out to do..
Post by drbill on Jul 30, 2015 10:27:19 GMT -6
Jim said, "Being the resident AFLAC (the odd duck), I never got a decent representation of stereo imaging with a digital mix platform. Everything lies flat, like on a piece of paper hanging on the wall. The analog console gives me my dimentionality, forwards, backwards, up/down and around." I kinda know what you mean Jim. I've been struggling ITB at home making song demos. I do print with my preamp, (Dizengoff D4) > WA76 compressor > Apollo DAW, sometimes with a pinch of the LA2 plug but even with some out of the box processing, I've been finding it difficult to get a real stereo image. Left, right, middle is easy, but front to back ain't happening. I've seen a tutorial about using delay on one or two tracks instead of panning to move to track across the stereo field, but it was a little over my head. Every time I've experimented with parallel compression, I hear phasing issues and ultimately, don't bother with it. uhh, mrholmes, what's Airwindows? Do I already have it in Logic? This question is especially interesting to me because I may update my system by going from the silver to the new blackface Apollo, and I'm not sure if I should shoot for the Apollo 16, which is $500 more than the 8P. The 16 has better converters, but no preamps. I eventually think I'll end up with a soundboard, but that might be 18 months from now. Still, I'd like to be ready if I do. To make a long story short. There is a reason for this thread. I went in circles about the Hybrid vs. ITB thing about the wish to have everything in one computer. Some mixes turn out good ITB but sometimes, like at the moment, I do not get the dimension I want. Its not the first time, I switch on the console and it sounds much more like a record. With this Jim is right. Do what I did a few years ago. I bought 16 out converter and a Allen and Heath ZED 14. Plus two Midiverbs and a Yamaha REV 500 I had outboard before which was hardwired to my converter. So its also worth the thing if you only use the ZED 14 for summing. It sounds different.... PS: Airwindows Console is something that helps with the depth and dimension ITB. But its really nothing against the console. And the ZED 14 is a cheap console.... I mean why not buying one if it makes you happy.... Speaking towards mixing only - not tracking which is a completely different ball game - this has not been my experience. I mix on average at least 20 pieces of music a month. This month I have to fly back east to mix a huge project for Disney. They are paying all my expenses and a silly daily rate that I couldn't turn down. They gave me a choice : I've got an HDX rig or a V series Neve to do it on. I'll be using the HDX rig. In my own studio, summing out to a console was easy for me. The DAW was normaled via my patch bay to the console, the console was normaled back into the DAW, I had 32 channels of i/o on the DAW and 48 / 96 channels on the console with 12 stereo returns for FX. The console was AUTOMATED. All my outboard was normaled to aux sends/returns or easily patched into inserts. Super easy to make the decision to go OTB and thru the mixer if I wanted to. But the mixer was CLEAN. D&R clean. And my experience was it wasn't adding enough most of the time to go to the hassle of exiting the DAW. So I've gone hybrid, with some CHOICE pieces (not all analog is good stuff guys) and I'm happy with that. Happier and mixing better than when I went OTB. If I had an older 2488 or 8068, yeah, I'd probably use it for summing OTB SOMETIMES. But I don't think a console is "the magic answer". There are other ways to accomplish the same result. Some of which I've had the pleasure of being involved with during their development. Don't get me wrong, I love consoles dearly. But in 2015, there's little time, room or money for them in most peoples business, workflow or lives. They are mostly a dream way of working that harkens back to an era that's passed, and most likely will never return. (Although I sadly wish it would.) And honestly, I don't think they are necessary anymore for "mixing". As I said earlier, tracking is another story completely. I'm doing better mixes now that I ever did on the console. And to make matters even more confusing, this "console / OTB" thing has gotten so out of control that people think think that summing thru ANY crappy console will make their mixes better. This is crazy. I'd much rather mix ITB than thru the majority of cheap consoles people are raving about these days. Actually, SOME people NEED a console to mix. They are old school to the bone. I get that and it's cool. But I don't believe that it is a stock "your mixes will be better" answer to peoples mixes that don't meet their expectation. What will get you there? Learning to mix different and better. Good luck - that's a lifelong journey. I'm still trying to get better with every mix.
Post by drbill on Jul 30, 2015 10:53:34 GMT -6
PS - the most transforming and amazing difference I have ever heard in any of my studio's?
The day I removed the console and racks completely for tenting for termites, and then returned the PT rig and one set of speakers for some quickie mix fixes right before my move.
OMG - the difference in sound was so startling that I completely thought I was in a different room. Rack clutter and consoles HUGELY affect the sound of every room. Almost always in a negative way. This is being considered heavily in the design of my new room.
Post by Martin John Butler on Jul 30, 2015 12:42:17 GMT -6
Yep, even a monitor in the middle of the soundstage has a negative impact.
