Post by mobeach on Jul 26, 2015 8:17:12 GMT -6
Post by tonycamphd on Jul 26, 2015 8:31:02 GMT -6
Never tried one, I use an old SVT, dandeurloo is coming out with more Zod tube DI's soon, I'm on that list, they are seriously bad! Ask RicFoxx what he thinks about his?
Post by jsteiger on Jul 26, 2015 10:57:06 GMT -6
Never tried one, I use an old SVT, dandeurloo is coming out with more Zod tube DI's soon, I'm on that list, they are seriously bad! Ask RicFoxx what he thinks about his? If I were to spend money on a DI right now it would be Dan's Zod. The biggest problem with them is getting enough of the custom transformers to keep up with the demand.
Post by mobeach on Jul 26, 2015 12:05:33 GMT -6
$600 as opposed to $200, I'll probably check out the Ampeg for now, as I need something now
Post by ericn on Jul 26, 2015 12:26:53 GMT -6
For $200 grab something like a used countryman for less than $100 or the half rack Summit for around $2225
Post by keymod on Jul 26, 2015 14:01:09 GMT -6
Sansamp?
Post by jcoutu1 on Jul 26, 2015 14:41:22 GMT -6
What kind of head are you using? Does that have a built in DI?
Post by winetree on Jul 26, 2015 15:12:55 GMT -6
My Ampeg SVT amp head has a balanced transformer direct output, built in for direct recording. Just plug into the amp and use the E.Q., ultra high and low switches, etc, it sends out the signal right after the preamp stage.
Post by RicFoxx on Jul 26, 2015 15:32:28 GMT -6
Dan's DI is as good as it gets and worth the wait.
Post by winetree on Jul 26, 2015 15:57:29 GMT -6
Dan's DI is as good as it gets and worth the wait. Not saying Dan's D.I. isn't great, but this available for the same price and you get a preamp also. dizengoffaudio.com/?page_id=83
Post by RicFoxx on Jul 26, 2015 15:59:58 GMT -6
Dan's DI is as good as it gets and worth the wait. Not saying Dan's D.I. isn't great, but this available for the same price and you get a preamp also. dizengoffaudio.com/?page_id=83I have D4 also and absolutely love it!
Post by mobeach on Jul 26, 2015 19:03:58 GMT -6
What kind of head are you using? Does that have a built in DI? Gallien Krueger Fusion 550, it has a direct out with a send control and pre/post
Post by jcoutu1 on Jul 26, 2015 19:41:08 GMT -6
What kind of head are you using? Does that have a built in DI? Gallien Krueger Fusion 550, it has a direct out with a send control and pre/post Well, bada bing. How's that sound? If that's the sound you're using live, why not in the studio too. Save yourself $200 unless you're specifically looking for an Ampeg sound.
Post by Ward on Jul 26, 2015 19:49:10 GMT -6
AS nice as this is... you guys just WAIT until you hear what;s coming down the pipe!! I'm working with an electronic designer on the ULTIMATE tube DI/Pre for bass guitar. It will be similar to the Avalon in application but have presets like SVT, V3b, V4b, Flip-top 15, Flip-Top18 and Blackface Bassman... along with a bias control, variable impedence control and other things.
Right now, it would blow your mind!!
We're talking to certain manufacturers about bringing it to market. So just hold on!!
Post by mobeach on Jul 26, 2015 20:10:46 GMT -6
Gallien Krueger Fusion 550, it has a direct out with a send control and pre/post Well, bada bing. How's that sound? If that's the sound you're using live, why not in the studio too. Save yourself $200 unless you're specifically looking for an Ampeg sound. I wasn't sure if there's issues running an amp with tubes with no load on it.
Post by jcoutu1 on Jul 26, 2015 20:32:12 GMT -6
Well, bada bing. How's that sound? If that's the sound you're using live, why not in the studio too. Save yourself $200 unless you're specifically looking for an Ampeg sound. I wasn't sure if there's issues running an amp with tubes with no load on it. Hybrid right? I imagine it's not an issue. My old SWR was good to go. I'd check the manual, but most likely won't be an issue.
Post by Johnkenn on Jul 27, 2015 12:09:40 GMT -6
Fans was really impressively. Little more expensive than I can afford right now for a di though. It if you want something that sounds great - it definitely fits the bill.
That Tonecraft Di looks fantastic too. Only for the serious though at $1200
Post by mobeach on Jul 27, 2015 13:26:05 GMT -6
A little too rich for my blood.
Post by jfoc on Jul 27, 2015 14:38:52 GMT -6
Post by odyssey76 on Jul 27, 2015 15:58:28 GMT -6
mobeach - looks like you're getting a lot of pricey suggestions! I agree with Eric - Country Type 85. What do you have for preamps. Type 85 through a nice preamp is great........
Post by mobeach on Jul 27, 2015 16:05:20 GMT -6
mobeach - looks like you're getting a lot of pricey suggestions! I agree with Eric - Country Type 85. What do you have for preamps. Type 85 through a nice preamp is great........ I'm going to try out the direct out on my Gallien Krueger then make a decision from there. I haven't used my amp for recording since Hardware was my recording platform. I think I remember it being a little noisy when I dialed in the settings I wanted, but I'll try it again.
Post by mulmany on Jul 27, 2015 16:31:28 GMT -6
I was really happy with the Bo Hansen DI'S I just built. I sat down to test it out and just kept playing. With it before the VP28 was very nice, gave a nice warm aggressive tone!
In contrast my Type 85 was more sparkly/crispy, less inspiring, and less amp like.
I play a '72 Ampeg V4-B with an active Yamaha Tr-4b.
Post by b1 on Jul 27, 2015 16:45:49 GMT -6
I know this is more than you want to spend, but I love the A-Design REDDI Tube DI for Bass, Guitar, & Pedal Steel. Personally, I wouldn't use another Tube DI, that I know of at this point. Great for DI recording or dual DI + Mic-ed Amp with the thru jack. Inspired by the Ampeg B-15 Single - $745.00 adesignsaudio.com/reddi-all-tube-direct-box.htmDouble - $1200.00 adesignsaudio.com/reddi-v2.htm
Post by LesC on Jul 27, 2015 16:53:54 GMT -6
Fans was really impressively. Little more expensive than I can afford right now for a di though. It if you want something that sounds great - it definitely fits the bill. That Tonecraft Di looks fantastic too. Only for the serious though at $1200 What does that mean? Is "Fans" a type of DI? I couldn't get anywhere with google.
Post by Johnkenn on Jul 27, 2015 16:55:36 GMT -6
Dan's DI. Fat-fingered it.
