Post by Johnkenn on Sept 12, 2013 18:38:49 GMT -6
I just can't help myself when it comes to Helios. I know some don't care for them, but I love the cleanish with a little color, sweet passive EQ, and persnickity gain-staging...Kinda my weak spot...
Post by kcatthedog on Sept 12, 2013 19:16:59 GMT -6
if thats what floats your boat !
Post by tonycamphd on Sept 12, 2013 19:59:54 GMT -6
This is one of my most dreamed about pieces, if it's good enough for the mighty Zeppelin, i gotta try it! It's not very far down my list.
Post by scumbum on Sept 12, 2013 21:29:26 GMT -6
Post some pics , is it 500 series ?
Post by Johnkenn on Sept 12, 2013 21:32:49 GMT -6
Yeah - not vintage or anything...
Post by nobtwiddler on Sept 14, 2013 19:41:49 GMT -6
The new reissues are very close to the originals, with a lot less headaches! Helios' modules, especially the Type 69's have a beautifully clean but woody sound. Very much suited for acoustic instruments, including drums. Personally I love them on everything. A few quirks yes, but after a few days you figure them out and from then on, it's really a beautiful thing.
Post by Deleted on Sept 16, 2013 12:22:59 GMT -6
john, you ever check out Jeff's LC53A's?
Post by tonycamphd on Sept 16, 2013 14:41:47 GMT -6
every time i hear the Led Zep song, "the song remains the same", the drums sound so "thocky""woody", i cant help but tie the sound to the type 69, although this could be a completely psychosomatic condition, for all i know, those tracks may not have been recorded through the helios?
Post by Johnkenn on Sept 16, 2013 17:59:11 GMT -6
Yeah - I did...It's excellent! It was awesome on bass!
Post by Ward on Sept 16, 2013 20:11:22 GMT -6
I'm also a fan of preamps that do not cloud the sound of the microphone or the source. Clean with little color is my general approach even when using Neves and APIs - by not overloading them.
Post by Johnkenn on Sept 17, 2013 16:05:54 GMT -6
I was just testing out the pre fader reverb monitoring trick someone showed me and recorded this snippet with the Helios/Brute...I took out some 1.4kHz on the Helios - prob a touch too much. No other eq...Love it... snd.sc/1dmQEEa
Post by Ward on Sept 17, 2013 20:28:44 GMT -6
1.4 is not something you usually need to cut out of the voice as it's where a lot of the character for the voice is, and that which distinguishes it from other human voices. Woofiness is around 320-360, mud is usually around 500-600, GAKK or nasal tone is around 2k to 3k, sibilance is in the 6k range. Those are the usual targets. I like your voice a lot John, and since I'm a bit familiar with it I really hear what you're saying about the Helios 69. They're very open and uncolored.
Post by cowboycoalminer on Sept 17, 2013 20:45:29 GMT -6
I heard some of your earlier productions when you used the Helios and thought they were really good. I think I still prefer the Heritage flavor on your vocals but this here would defiantly cut through a mix better without needing much help.
Post by lolo on Sept 18, 2013 1:24:54 GMT -6
Johnkenn I was just testing out the pre fader reverb monitoring trick someone showed me and recorded this snippet with the Helios/Brute...I took out some 1.4kHz on the Helios - prob a touch too much. No other eq...Love it... snd.sc/1dmQEEa Care to elaborate on the pre fader reverb trick John
Post by Johnkenn on Sept 18, 2013 7:12:30 GMT -6
Sure...I had posted about buying a cheap hardware reverb for the headphone cue. In PT's I use the Tritone Mute plug thingy on the track I'm recording and then monitor with Maestro for zero latency. So, by creating a pre fader Reverb AUX and sending the track you're recording to it, you can still mute the channel (so there's no latency while monitoring) but also hear the software reverb. I had totally never thought about that! Saved me $150 on a cheap verb.
Post by lolo on Sept 18, 2013 19:43:15 GMT -6
Thanks.
Post by tasteliketape on Sept 19, 2013 15:04:29 GMT -6
Ok JK so you can only have two pres which ones would you pick Hertiage Helios vp28 312 or ?
Post by Johnkenn on Sept 19, 2013 16:19:05 GMT -6
Well, I'll re-phrase...My 3 desert Island pres...
VP28 Helios Type 69 Heritage 1073
All the bases covered...
Post by Deleted on Sept 19, 2013 21:52:13 GMT -6
I would love to compare that Heritage with my AML ez1073-500. I believe they both have Carnhill transformers and inductors, which is where all the sound comes from.
