Post by EmRR on Oct 8, 2015 8:53:23 GMT -6
Yeah, routing looks at each piece as separate. Interface. Computer. AVB Mixer. AVB streams. Makes more sense if you think about it as a network, as if you had multiple AVB devices and computers placed around a stadium complex at great distance. Shrink that thought process to a single unit in your office and it adds up.
Post by tasteliketape on Oct 27, 2015 10:10:24 GMT -6
Anyone want to enlighten me on routing a motu 16a to pro tool 12? I can monitor outs 1 &2 I can monitor input to record I can't monitor the input when record mode but I can see the record input and record but I can't hear the track while recording Hope that makes sense coz my head is fried I've tried so many set up
Post by jdc on Oct 27, 2015 11:32:03 GMT -6
Do you have input monitoring selected in pro tools? here's a cheesy video explaining it:
Post by tasteliketape on Oct 27, 2015 11:57:41 GMT -6
Yes I see input in record mode or with input mon. But i cant hear it I can't do exactly what the vidio says I can
Post by jdc on Oct 27, 2015 12:13:04 GMT -6
are you on pro tools 12.1? if you don't see the green "I" to press on your channels try pressing alt+K on your keyboard. that should enable input monitoring
Post by tasteliketape on Oct 27, 2015 12:21:34 GMT -6
The input button is there lights up I did a track with the input button in but couldn't hear it but went ahead and recorded guitar without hearing just to check recording then did another track same way without hearing . Could not hear either track while recording (2 t racks done separate) both play back I have mixbuss also and I can record and playback just fine with it
Post by porkyman on Oct 27, 2015 12:27:19 GMT -6
you dont even need input monitoring if youre hardware monitoring, or routing the signal back out. the track should actually be muted or youll hear two signals slightly delayed.
in routing window:
1. route "analog in" (horizontal) 1-16 to "to computer" (vertical) 1-16. 1 in to 1 out. 2 in to 2 out etc. this send your hardware inputs to PT's inputs.
2, route "from computer" (horizontal) 3-16 to "analog out" (vertical) 3-16. this sends PT's outs to hardware outs.
3. route Mix Main" (horizontal) L/R to "Analog out" (vertical) 1-2. this sends your monitor mix from PT 1-2 outputs to your hardwares 1-2 outputs.
4. under "to computer" (vertical) is "Mix In.) route the the track you wish to direct monitor to any available ln. ex. "analog in" (horizontal) 3-4 to "mix in" (vertical) 3-4. this send hardware input directly to hardware output.
In mixing window:
1. select the tracks you wish to monitor under "MIXER INPUTS." for this ex. you should select "ANALOG 3-4" this will allow you to control the level of the track you want to direct monitor.
2. press the little matrix symbol above the "Main Mix" slider. select Analog 1-2. this makes analog 1-2 hardware your main output.
hope thats more clear.
Post by tasteliketape on Oct 27, 2015 13:32:11 GMT -6
Thanks for the help guys but i think i give up works with all but pro tools
Post by tasteliketape on Oct 27, 2015 14:02:18 GMT -6
Well i guess i do need avid support they are stumped they took control of my mac and still can't figure it out at least I'm not as stupid as i was beginning to think i was ( no need for comments lol) Sincerely thank you guys for trying
Post by stratboy on Oct 27, 2015 15:29:29 GMT -6
Well i guess i do need avid support they are stumped they took control of my mac and still can't figure it out at least I'm not as stupid as i was beginning to think i was ( no need for comments lol) Sincerely thank you guys for trying When you solve it ple let us know. I just ordered mine and am reading this thread with great interest.
Post by tasteliketape on Oct 27, 2015 17:11:48 GMT -6
Avid after 4 hours fixed it they just said they trashed pro tools and reinstalled it also said there was a known bug in the meters of pro tools 12. 1 doesn't effect the interface though. Long story short I'm a happy camper
Post by tasteliketape on Oct 27, 2015 17:50:42 GMT -6
quote]When you solve it ple let us know. I just ordered mine and am reading this thread with great interest. [/quote]
after settling down from 4 day of messing with this my final thought is set up would have been very easy if pro tools had acted like it should have
