Post by Ward on Apr 5, 2015 17:32:03 GMT -6
Just finished producing and mixing a fantastic alt-pop (new pop-rock) by a band of 18-20 year olds... and one thing the mastering engineer and I are dealing with is low-mid/mud buildup that occurs. Especially in the 170-250hz range.
I believe that the very thing we love about certain compressor's 'thickening' is the very thing that sometimes causes us headaches in final mixes or masters... that the thicking occurs in the 150-350 broader range and moire specifically the 170-250 range.
What are your thoughts on this? How do you address it? Has it been a problem for you ever? And finally, what are your thoughts on which compressors/emulators cause you the most low-mid/mud problems?
Kindest regards,.
Ward
Post by dandeurloo on Apr 5, 2015 17:40:53 GMT -6
Is this mostly Hardware or Software?
Post by mjheck on Apr 5, 2015 17:50:29 GMT -6
Chris Johnson's newish compressor "PureSquish" is the best digital compressor I've used for avoiding this problem. It also has a "bloom" slider that allows you to side chain lows as desired.
Really, I can't rave about this one enough. I'm new to the Airwindows world, but am absolutely in love with this plug in. Works on tracks or on the two, and I use it both places.
Free demo of course, like all his stuff.
MJH
Post by tonycamphd on Apr 5, 2015 21:20:02 GMT -6
for me it's keeping in mind what NEEDS to be special, if I track/mix everything with "it needs to be special" in mind, then nothing will be special. Some things need to be tracked/mixed very well and very vanilla in order to make the priorities that are supposed to pop... POP! I have a shit ton of JW Aphex 651's because they are transparent and unnoticeable, they go about their job like offensive linemen, totally underappreciated lol. Then i add the color comps to what needs to have the JUICE. If I use color comps on everything, same for eq, then nothing is special, and I end up with that mud I think you're talking about.
Post by Ward on Apr 6, 2015 6:33:10 GMT -6
It's a lot more common than you may think... and tasteful use of compression is nowhere near as common as it should be.
I have little taste.
Post by swurveman on Apr 6, 2015 8:12:17 GMT -6
I'm curious ward: What compressor are you using and what is the ratio?
As for your problem: If you don't like the low mid frequency sound after the compressor, why don't you use an EQ to reduce it?
Post by svart on Apr 6, 2015 8:34:06 GMT -6
I don't think the pros think like "oh what compressor has the least amount of low end build up" or anything like that. From what I've gathered most of the pros just go for the tone of a certain compressor or the effect it creates.
One thing I've noticed about my own mixes when I A/B them with pro mixes is how much less low end the pro mixes have than my own. Over the years I've constantly had to cut back how much low end I put in anything.
You'll read something from a noob on GS like "I put 40hz and 60hz because I wanted more low end" but from a pro you'll read something like "I cut everything below 80hz".
Because of this, I'm doing a lot more cutting of low end stuff and I think my mixes are doing a ton better. I've been hacking off bass at 80hz, kick at 60hz, guitars at 150hz, vocals at 80hz, etc. Right away things have become tighter.
Now you're asking, "what does this have to do with mud in the 125-200hz region?". Well, Right away the compressors weren't reacting nearly as much to low frequencies that didn't do much other than add excessive boominess. Because the compressors aren't compressing so hard, they aren't bringing up so much low-mids end after makeup gain.
Somehow things still sounded full and heavy, but with more definition.
I attribute this to the psychoacoustic effect of the attack/knee of the compression rather than actual low frequencies. The eardrum and small bones of the ear act like a compressor at higher dB's, so emulating that effect with a slow attack but audible compression knee seems to trick our brains into thinking it's louder (and therefore more exciting) than it is.
The SSL bus compressor has this "spank" kinda sound to it, which is probably why it's so popular in rock n' roll mixes.
Also, another thing I've gathered from interviews with pros, is that they don't seem to be afraid to EQ ruthlessly. I rarely see "I only use cutting EQ" or "I try not to use EQ at all" or anything. Seems that I see a lot more of "I turn knobs until it sounds good" stuff from the pros.
Post by Ward on Apr 6, 2015 9:24:17 GMT -6
I was fairly certain I was already amongst professional peers. (raised eyebrow smiley emoticon).
This is not a noob question. This is a nitpicker's question! LOL
I employ the usual suspects. LAs, 76s, 2500s, CL1b etc... on the hardware side and usually the same (sparingly) on the plug-in side. And yes, I use the SSL buss comp and waves L1+ultramaximizer on the 2-buss in addition to hardware Focusrite red 2 and 3.
Post by ericn on Apr 6, 2015 11:01:23 GMT -6
First thought is are you using a monitor that's masking the problem? You have to hear it to solve the problem! Second is to listen for it building as you build the mix, Distortion and mud are the hardest to cure and find, Even uhber low distortion drivers like ATC or Volt have almost as much distortion in this region as a distortion pedal !
Post by tonycamphd on Apr 6, 2015 11:25:33 GMT -6
I agree with most of what svart said, one thing i certainly don't agree with, and what the majority of the accomplished mix guys i've been around...don't do... is excessive eq moves. Those same guys who tell you that, are also telling you they're mixing in the box while being interviewed in front of a 96 channel SSL console lol? I've personally seen quite the opposite in person, they use very subtle eq moves of 1-2db, same with compression, they do do(i know, i said dodo 8) eq/comp in multiple spots around a mix though. Personally I've noticed when i'm grabbing giant handfuls of eq it's a sign that 1 of 2 things is happening, a mistake in tracking is being dealt with,(most big wig mixers don't deal with this, and get almost perfectly tracked material), or i'm starting down the path toward a bloaty, smeared slicey mess ime.
I personally plug a linear phase eq on every single track of my mix template(you don't suffer the effects of latency limitations if its on every track, just bypass the ones you don't use, it does take a pretty chunky computer though), i usually bypass them on low frequency transient tracks due to pre ringing effects inherent to Linear PEQ's, and elect to use a regular HP/LP filter with a nice reso bump of some sort on those tracks. I always feel as if this LinearP filter method takes me to a starting point that sounds fresh and ready to tweak, the tracks don't sound weirdly phasey before i even start to mix, i always feel a sense of smear with standard plugin filtering. The bypass button is your best friend! 8)
Of course, to each his own skinning of the cat.
Post by svart on Apr 6, 2015 11:39:58 GMT -6
I dunno. I've seen lots of "in the studio" vids with accomplished mixers who say something like "I put a little EQ on this" and when the camera pans to that channel they have like 9dB of boost on that EQ band!
I still have to wonder if some of these mixers say one thing and then do something else.. I've always suspected it.
Post by carymiller on Apr 6, 2015 12:36:51 GMT -6
Just finished producing and mixing a fantastic alt-pop (new pop-rock) by a band of 18-20 year olds... and one thing the mastering engineer and I are dealing with is low-mid/mud buildup that occurs. Especially in the 170-250hz range. I believe that the very thing we love about certain compressor's 'thickening' is the very thing that sometimes causes us headaches in final mixes or masters... that the thicking occurs in the 150-350 broader range and moire specifically the 170-250 range. What are your thoughts on this? How do you address it? Has it been a problem for you ever? And finally, what are your thoughts on which compressors/emulators cause you the most low-mid/mud problems? Kindest regards,. Ward Hey Ward, Typically I EQ around 250Hz-300Hz out of the song lightly at various stages for many tracks in a mix. If you cut too aggressively at once stage, things start to feel "weird" and unnatural, so light cuts during tracking if possible...then on the tracks themselves before each compressor in line....light cuts again in each subgroup before each compressor...and then finally light cuts on the 2Bus before each compressor in line in whatever chain you have. I also tend to favor compressors that feature side chains when you can get them, which will allow for "keying" a tracks compression to skip a frequency range you don't want to crush. Sometimes this is the "mud-range" of 250Hz-300Hz...but it can also be lower than that in order to keep the kick drum natural (this is always program dependent.) I tend to favor the following compressors: Chandler Germanium Compressors (Matched Pair with multiple Side Chain choices & Parallel Compression), Rupert Neve Mix Buss Processor with 250Hz Side Chain. Shadow Hills Dual Vandergraph (Side Chain with 250Hz as a selection), and the Dramastic Obsidian 500 Series Version (With more Side Chain options.) I also love the D.W. Fearn VT7 with it's fixed Side Chain...though I don't know offhand where it decides to duck...it just sounds incredibly natural. Still...EQing correctly during the process makes Side Chains less and less important overall. I also tend to leave 250Hz and 300Hz in bass guitar...untouched if the bassist had a fantastic tone...as I'm cutting away other sounds in the mix, this leaves those frequencies where they sound the most natural.
Post by svart on Apr 6, 2015 13:25:57 GMT -6
In regard to bass guitar, I almost always find a resonant peak somewhere in the 100-200hz range. I typically hunt for it with narrow boost and snuff it about 3-6dB with narrow cut before compression. Couple this with a cut below 80hz-ish and I've not had nearly as much trouble with bass guitar as I have been having in the past.
Post by carymiller on Apr 6, 2015 14:39:35 GMT -6
I dunno. I've seen lots of "in the studio" vids with accomplished mixers who say something like "I put a little EQ on this" and when the camera pans to that channel they have like 9dB of boost on that EQ band! I still have to wonder if some of these mixers say one thing and then do something else.. I've always suspected it. Successful engineers do that ALL the time...especially back before the days of the internet when they closely guarded their secrets for job security. As for larger EQ boosts...sometimes you need to do it. There's just no getting around it...but it should ONLY be for repairing something that wasn't recorded well enough from the start to fit the mix.
Post by carymiller on Apr 6, 2015 14:40:58 GMT -6
In regard to bass guitar, I almost always find a resonant peak somewhere in the 100-200hz range. I typically hunt for it with narrow boost and snuff it about 3-6dB with narrow cut before compression. Couple this with a cut below 80hz-ish and I've not had nearly as much trouble with bass guitar as I have been having in the past. See I find I have have to do very little EQ on a bass track if it's cut well from the start with a good signal chain...and I'm tailoring the mix to leave a space for the bass to sit. But still...a little EQ will still probably happen by the end.
Post by jeromemason on Apr 6, 2015 14:48:38 GMT -6
I've had that happen on vocals.... other stuff too, hardware or software, still puts that crud in there. Two ways I've always dealt with it, one was using a multi band compressor, the other was eq'in into and out of the compressor, especially if it's hardware. I'm starting to really like Randge philosophy on not using much compression, kind of goes against the grain of the first guy that taught me, but hearing some mixes of his and how open and large they sound, it's undeniable. That's off the rabbit trail, but worth mentioning, doesn't really help you right now though. Sure know what you're talking about though, either don't compress as much and ride the fader, or subtract pre/post comp with an eq. I say pre/post because if you hit the compressor raw it's still going to do the same thing, even if you're pulling it out post, the "flavor" of that mud so to speak is still there, but, if you can take that away before you hit it and give more headroom to the freq's you want it won't. At least, that's always worked for me.
Post by swurveman on Apr 6, 2015 16:46:17 GMT -6
I dunno. I've seen lots of "in the studio" vids with accomplished mixers who say something like "I put a little EQ on this" and when the camera pans to that channel they have like 9dB of boost on that EQ band! I still have to wonder if some of these mixers say one thing and then do something else.. I've always suspected it. Me too. I was reading from the old magazine "Recording Engineer and Producer" and the engineer for an En Vogue record says on their album he boosted vocals with a GML EQ +9dB at 16k, +3 at 10k, +2 at 1.2k, +2 at 200 and +2 at 80. He says he uses narrow Q's, but +9dB is + 9 dB! He goes on saying "no wonder I use a deeser". No shit. And yeah, they were tracking to tape-with a Tfunk ELA M 250 no less-, but all you have to do is listen to pop vocals-which are even brighter than they were when En Vogue was around- and you know they're boosting the shit out of vocal EQ's.
Post by Randge on Apr 7, 2015 0:08:11 GMT -6
Automating an extra hr instead of compression smashing everything into a hole is how I want to live. Maybe try cutting your compression usage in half and do some automating and see what it sounds like to you would be my recommendation.
Post by carymiller on Apr 7, 2015 0:25:51 GMT -6
Automating an extra hr instead of compression smashing everything into a hole is how I want to live. Maybe try cutting your compression usage in half and do some automating and see what it sounds like to you would be my recommendation. +!! Honestly automation or even manual fader riding makes a HUGE difference section to section in a song when you're getting to the final mix/master.
Post by gouge on Apr 7, 2015 6:18:14 GMT -6
I dunno. I've seen lots of "in the studio" vids with accomplished mixers who say something like "I put a little EQ on this" and when the camera pans to that channel they have like 9dB of boost on that EQ band! I still have to wonder if some of these mixers say one thing and then do something else.. I've always suspected it. Me too. I was reading from the old magazine "Recording Engineer and Producer" and the engineer for an En Vogue record says on their album he boosted vocals with a GML EQ +9dB at 16k, +3 at 10k, +2 at 1.2k, +2 at 200 and +2 at 80. He says he uses narrow Q's, but +9dB is + 9 dB! He goes on saying "no wonder I use a deeser". No shit. And yeah, they were tracking to tape-with a Tfunk ELA M 250 no less-, but all you have to do is listen to pop vocals-which are even brighter than they were when En Vogue was around- and you know they're boosting the shit out of vocal EQ's. +9db at 16k is not that big a deal because it's up in the air band and the ear is less sensitive in that range. bigger boosts in the high freq are also used to achive smaller flatter boosts through the upper mids. kinda heading towards a shelf.
Post by gouge on Apr 7, 2015 6:25:39 GMT -6
whilst not a pro. ;-)
I use that mud point on the compressors as a signal to back off. it's program dependent.
another thing I've noticed with layering instruments is the mud keeps creeping in. even if I high pass each channel on say guitars by the time I've run 3-4 tracks to the buss it can also do with some further HP. concerned with too much filtering, in more recent times I've been just strapping a hp across the buss. like a 10band stereo eq or some other piece of gear with a hp filter.
one comp I've noticed that doesn't introduce mud is the purple action.
Post by dandeurloo on Apr 7, 2015 8:18:26 GMT -6
Just finished producing and mixing a fantastic alt-pop (new pop-rock) by a band of 18-20 year olds... and one thing the mastering engineer and I are dealing with is low-mid/mud buildup that occurs. Especially in the 170-250hz range. I believe that the very thing we love about certain compressor's 'thickening' is the very thing that sometimes causes us headaches in final mixes or masters... that the thicking occurs in the 150-350 broader range and moire specifically the 170-250 range. What are your thoughts on this? How do you address it? Has it been a problem for you ever? And finally, what are your thoughts on which compressors/emulators cause you the most low-mid/mud problems? Kindest regards,. Ward Ward with out hearing the track it is hard to say. Assuming your not crushing the tracks with to much compression overall. My guess is that your using software comps. I hear that kind of ugly build up and smear much more often with software. Specially plugs that are pretending to have analog vibe to them. I find that most software saturation on plugs is awful at that kind of build up. That thick build up can also be heard in most alt rock - metal records where they over compress in general. That is part of that awful snare sound that we where talking about in another thread. Man I hate that sound. It is a cheap trick to make records sound rich, powerful and dense. It really just sounds brutally ugly. I know a ton of those guys are boosting the 350hz down on snares to get that sound. The other thing I noticed was when I was tracking in to small of a room I was getting a strange build up in my tracks around 180. I had to contently be tacking a little out in that range due to the room. Could that be part of it?
Post by Randge on Apr 7, 2015 8:52:24 GMT -6
Much of the music I do requires making a zone for a male singer from 150 to 275. So, I am thinning the instruments in that area and flattering the singer there.
Post by Ward on Apr 7, 2015 9:27:44 GMT -6
I really only started this thread so that we might share stories, problems found and sorted, and techniques for dealing with an oft-overlooked problem. One of the discussions we have yet to have is about pre-EQing versus post-EQing the signal. Notch or bandpass before compression or after compression? What are your collective thoughts? (btw, Randge, nice last post there!)
Post by Randge on Apr 7, 2015 9:52:38 GMT -6
I tend to filter before compression and will only shelf up after a compressor. I try not to shelf at all unless absolutely needed. I feel like a cohesiveness between instruments can get lost and do my damn-dest to catch it at the source while recording. That said, rules are made to be broken as needed.
