Post by kidvybes on Jan 17, 2015 10:03:05 GMT -6
Press Release: WOLFF/LINDELL WL-3 Paul Wolff joins the Lindell team to create the WL-3, a 500 Series complete console channel strip. It features a transformer couple mic and line preamp, a VCA dynamic section with a mix knob for parallel compression, a 3-band Equalizer, High-pass Filter and an output fader that feeds a transformer balanced output stage. Wolff (API and Tonelux) brought his past experience of console designs, all packed into one 500 series module. It’s a breakthrough product in the 500 Series range. Come see it at the NAMM show 2015! Hall A booth 6905. Attachments:
Post by Randge on Jan 17, 2015 11:21:03 GMT -6
It will be interesting to put this up side by side with the Ingram MPA575.
R
Post by jcoutu1 on Jan 17, 2015 11:42:01 GMT -6
Press Release: WOLFF/LINDELL WL-3 Paul Wolff joins the Lindell team to create the WL-3, a 500 Series complete console channel strip. It features a transformer couple mic and line preamp, a VCA dynamic section with a mix knob for parallel compression, a 3-band Equalizer, High-pass Filter and an output fader that feeds a transformer balanced output stage. Wolff (API and Tonelux) brought his past experience of console designs, all packed into one 500 series module. It’s a breakthrough product in the 500 Series range. Come see it at the NAMM show 2015! Hall A booth 6905. Looks great. I love my Wolff designed TX5C pair.
Post by ericn on Jan 17, 2015 15:49:20 GMT -6
I want to see the inside! Paul is known for Discrete op amps!
Post by Deleted on Jan 17, 2015 21:11:08 GMT -6
Whoah - is Lindell going pro?
Post by miscend on Aug 13, 2015 15:02:17 GMT -6
When is this out?
