Post by brucerothwell on Jan 3, 2015 23:45:35 GMT -6
I have never used any AD/DA gear except an all-in-one "interface" that works with Pro Tools on Mac OSX. I'm looking at the Ross Martin gear, and pondering the Bare Beast and the pcm4222. I think the Bare Beast has a USB port, but not sure about the pcm4222. - Can anyone explain how these separate DAC and ADC devices interface with Pro Tools and the Mac OSX computer?
- Will I need a separate word clock device? If not, can anyone explain how those devices sync together?
Thanks!
Post by brucerothwell on Jan 4, 2015 1:03:32 GMT -6
Well, I guess I was having a "moment" when I asked all the above -- it seems this is my answer:
- Because the DAC has a USB interface, then the interface via USB to OSX/Pro Tools is handled as with any other USB device.
- The ADC won't need a clock because it is interfaced into the DAC via AES.
- Because the DAC has a clock, I should be able to select the DAC as the clocking source in the OSX Audio/Midi setup.
Is my thinking straightened out now, fellas?
(I just want to make sure before I allocate funds, that I know what all I need and do not need.)
Post by svart on Jan 4, 2015 1:06:08 GMT -6
They are AES/spdif devices. You need some kind of AES or spdif i/o on your computer.
AES and spdif have no separate clock, The clock is recovered from the digital stream itself, at the receiver side, So word clock is not needed.
The ADC is always the clock source, the DAC is always a slave.
Post by brucerothwell on Jan 4, 2015 1:20:56 GMT -6
Thanks for the info svart!
So, the RM pcm4222 ADC is always the clock source, and connects to the DAC via AES, let's say.
Then, the Bare Beast connects to the USB port on the computer.
How do I tell OSX what the clock source should be?
Post by LesC on Jan 4, 2015 1:48:20 GMT -6
Hi Bruce. First of all, welcome to RGO! Ross Martin's web site is difficult to figure out, and the photographs are low res so I can't quite make out what some of the switches and inputs/outputs are for. My understanding is that Ross makes good stuff, you can find some other Ross Martin threads on this site. I will try to answer your questions, but I personally have never used any RM stuff. So hopefully others will chime in if I'm off base about anything. The "Bare Beast", or the updated version called the "Super Beast", is a digital-to-analog convertor. Yes, it has a USB connector, but that is simply used as another digital input to convert to analog. In other words, you can have USB, or SPDIF optical, or SPDIF coax (RCA), or AES/EBU connection INTO the box, and you can get an analog out. The USB connection is NOT used as an interface for input and output to the computer, as you might be thinking. This is a stand-alone DAC only. Similarly, the PCM4222 is a stand-alond analog-to-digital convertor only. An ADC is usually used as the clock source to clock your other devices, and a DAC usually gets it's clock from whatever digital signal is feeding it. To use these ADC's and DAC's, you need to have them both plugged into another box or card that is the actual computer interface, using one of their digital connections. There are lots of such devices on the market, you can look at the RME and Lynx websites for some examples. I've only ever used RME devices, which have really good Mac and PC drivers, but there are lots of others that are less expensive to get you started. I'm not aware of any interfaces offered by Ross Martin, but I could be missing something on his website. To answer your points that I've quoted specifically: 1. Again, the DAC is not an interface in the way you're thinking, though it's USB connection can be used to convert computer output to analog. It definitely cannot be used to input audio into the computer. 2. The ADC is actually usually used to supply the clock. The PCM4222 unit has a wordclock output connection for this purpose. You may or may not need to use this connection depending on the digital out that you're using, though it never hurts to connect the wordclock output from the ADC into whichever interface you get, at least as far as I am aware. Also, if you "interface the ADC into the DAC via AES", you will be feeding an analog signal into your ADC and then getting an almost identical analog signal out of the DAC. This is not something you want, and cannot be used to feed audio into your computer. 3. Again, you would never use a DAC as a clocking source, you would use the ADC. I hope some of this helped. And I hope others chime in if I'm misunderstanding something, an unfortunately not uncommon occurrence.
Post by LesC on Jan 4, 2015 1:49:49 GMT -6
Sorry, I answered before I saw svart's reply.
Post by LesC on Jan 4, 2015 1:58:55 GMT -6
Oh, the other thing I might mention is that you should consider svart's box that he is developing. It will be a one-rack-unit ADC and DAC, and will probably be ready before Ross Martin builds you a box. You can find some threads on it here. It should be as good or better than Ross's stuff and it will look better, and it will be delivered when svart says it will be delivered. You will still need an interface to use it, same as Ross's stuff.
Post by brucerothwell on Jan 4, 2015 2:16:52 GMT -6
Thanks, LesC -- very helpful info, indeed.
I certainly now know I had need for concern, regarding the need for "something else" (a SPDIF or AES card, I suppose -- I have a Mac Pro)
I wish I could wait indefinitely for the svartIO Masterpiece (my name suggestion), but I need to get something real soon.
RM told me yesterday that he has a Bare Beast ready, and a Silent Knight (I need a dual preamp, too) -- and a pcm4222 board that he could build out for me in a matter of days. We talked about finalizing the order and him shipping mid-week next.
I guess we'll see what happens.
I've got to decide if I should go this route, or just buy a Metric Halo ULN-2, or some other 2x2 AD/DA with pres.
I'm working at 48khz, so would be fine even with some older gear.
Suggestions?
Post by LesC on Jan 4, 2015 3:17:00 GMT -6
If you need the built-in preamps, the ULN-2 will probably be great for you. I can't use it because I'm on PC, though Metric Halo is apparently going to appease the PC crowd in the near future. My personal preference is not to use built-in preamps but choose the external preamps that I want. It doesn't hurt to have the built-ins, I just don't want to pay for something I'm not going to use.
There are several really good 2x4 interfaces around, 2x6 if you count the headphone DACs. 2x4 is handy for a small studio. For example, while mixing you can use one DAC to feed an analog chain and then take the output of the analog chain back into the ADC. And you can use the other DAC for monitoring. All of these interfaces have at least one additional digital I/O, for example to connect svart's box or the RM boxes. And most of them also have an ADAT interface in case you need to expand further. In your case, since you're on a Mac, you don't really need the ADAT interface because you can use multiple USB devices using device aggregation.
The boxes I've been looking at are the Lynx Hilo, the Prism Lyra 2, the Apogee Symphony 2x6, and the Antelope Pure2. The Pure2 isn't out yet, expected within the next couple of months, and I believe it does not have an ADAT interface. All of these boxes are in comparable price ranges, more or less, and all are considered by many to be very high quality. You can find lots of info about them, Google is your friend.
Post by indiehouse on Jan 4, 2015 6:34:22 GMT -6
I wish I could wait indefinitely for the svartIO Masterpiece (my name suggestion), but I need to get something real soon. RM told me yesterday that he has a Bare Beast ready, and a Silent Knight (I need a dual preamp, too) -- and a pcm4222 board that he could build out for me in a matter of days. We talked about finalizing the order and him shipping mid-week next. I guess we'll see what happens. Just FYI, Ross seems to have a consistent history of quoting a couple weeks lead time to potential customers, when it's more like a few months or more. I gather that he doesn't keep a lot of parts stocked, and buys raw materials using cash as orders come in. Delays can happen if parts are back ordered from the manufacturer, which could take months to fill. This is just an assumption on my part, though. Case in point, I've been waiting a couple months on my PCM4222, the same unit you were quoted a couple weeks lead time (I was told it would take 2 weeks, as well). When I last asked about it, I was told he was waiting on an order of chips, but there was a delay with shipment from the manufacturer. To his credit, the units sound fantastic (I've got a Superbeast) and I don't believe he is trying to be deceitful or rip anyone off. I think lead time quotes should be more realistic, though. Expect 1-3 months. Any sooner and it'll be a nice surprise.
Post by Johnkenn on Jan 4, 2015 10:47:41 GMT -6
Thanks, LesC -- very helpful info RM told me yesterday that he has a Bare Beast read cowboycoalminer this HAS to make your blood boil.
Post by svart on Jan 4, 2015 10:58:59 GMT -6
Post by indiehouse on Jan 4, 2015 14:20:33 GMT -6
I will say, I'm super stoked for svarts new AD/DA.
I'm on the list!
Go svart!
Post by LesC on Jan 4, 2015 14:42:09 GMT -6
Thanks, LesC -- very helpful info RM told me yesterday that he has a Bare Beast read cowboycoalminer this HAS to make your blood boil. From "Black kid" at the other site: Hey guys So after my posts I sent Ross an email telling him how I felt about the situation and the 8 month wait with lack luster customer service and I also explained that people at gear sdlutz we're upset ass well he shipped the unit out the next day and also I ordered a dual bare beast and he upgraded me to a super beast which I appreciate...Maybe cowboy hasn't sent Ross an email with the requisite number of grammatical and spelling errors.
Post by Johnkenn on Jan 4, 2015 15:08:12 GMT -6
Maybe he will post something here
Post by LesC on Jan 4, 2015 15:48:56 GMT -6
I clarified my previous post. That was posted at the other site not by cowboy, but by "Black kid". I just found it interesting that this guy says he complained via email to Ross, and Ross sent him an upgraded unit the next day.
Post by brucerothwell on Jan 4, 2015 16:46:45 GMT -6
1. Again, the DAC is not an interface in the way you're thinking, though it's USB connection can be used to convert computer output to analog. It definitely cannot be used to input audio into the computer. Interesting... I emailed RM also, about how the Bare Beast and the pcm4222 interface to the computer, figuring he ought to know how his own gear is designed to work, and this was his response:
Then I sent another email with this question: "And you confirm the USB port on the Bare Beast is bidirectional, allowing for stereo audio playback and recording, when the pcm4222 is connected to the Bare Beast via AES?" He responded:
Post by Johnkenn on Jan 4, 2015 17:28:40 GMT -6
I'm not familiar with all the RM acronyms and models, but I'm not aware of one that will allow the audio to be inputed to the computer via USB. I could be wrong, though. If it were me and I was starting with the ADC and DAC, I would just buy a cheap Presonus/Focusrite/etc. interface and go audio into the RM ADC-->SPDIF into Focusrite and then SPDIF/digital out to the RM DAC... But if it was me, I'd buy svart's unit and call it a day. (Still need another interface to get into the computer though)
Post by ericn on Jan 4, 2015 17:36:18 GMT -6
Even if what RM says is true, I can guarantee if I were to do as JK says and pick up a Used $100 USB / FW or Tbolt box at my local Pawn shop with AES / Spidif, I will have drivers into the future! Plus I get a couple of extra Utility I / O !
Post by Johnkenn on Jan 4, 2015 17:39:06 GMT -6
I use my Apollo like this. Burl on the way in, RM DAC on the way out. It's a UAD Dongle. Although, I have 4 mic pres if I need them and I can use UAD plugs on the way in if I want (I never do though).
Post by jcoutu1 on Jan 4, 2015 17:51:08 GMT -6
I'm not familiar with all the RM acronyms and models, but I'm not aware of one that will allow the audio to be inputed to the computer via USB. I could be wrong, though. If it were me and I was starting with the ADC and DAC, I would just buy a cheap Presonus/Focusrite/etc. interface and go audio into the RM ADC-->SPDIF into Focusrite and then SPDIF/digital out to the RM DAC... But if it was me, I'd buy svart's unit and call it a day. (Still need another interface to get into the computer though) I have a Focusrite 18i8 that I use with my e-kit. I'm planning on getting a Svart ad/da to use as my 2-mix capture and DAC to monitors via SPDIF to the Focusrite.
Post by LesC on Jan 4, 2015 18:22:39 GMT -6
Then I sent another email with this question: "And you confirm the USB port on the Bare Beast is bidirectional, allowing for stereo audio playback and recording, when the pcm4222 is connected to the Bare Beast via AES?" He responded: Holy cow, I apologize if I misled you! I've never heard of a DA box that does this, and it certainly isn't clear to me from Ross' website. So maybe you can do what you were intending to do, and if that doesn't work, then you can always add one of the interfaces that the guys mentioned above.
Post by Johnkenn on Jan 4, 2015 18:53:25 GMT -6
Oh - duh...apparently I have the Bare Beast. So, when you connect it via the USB, you have the option of using it as the "Output" in your system. Maybe when you connect the 4222 AD to the Bare Beast you get a full fledged interface connected to the computer? But then, where's the software and routing? I have no idea.
Post by LesC on Jan 4, 2015 21:08:51 GMT -6
Oh - duh...apparently I have the Bare Beast. So, when you connect it via the USB, you have the option of using it as the "Output" in your system. Maybe when you connect the 4222 AD to the Bare Beast you get a full fledged interface connected to the computer? But then, where's the software and routing? I have no idea. It makes me feel better that I'm not the only one totally confused by RM offerings. It's probably a good thing, if people actually realized what these products are capable of, maybe the backlog would be years instead of months.
