Post by brucerothwell on Jan 2, 2015 20:34:54 GMT -6
I have the stepped attenuator shown in the attached images.
It is my understanding that I could create a passive level control with it, with some connectors, wiring, a box and a knob.
Is that true?
If so, how would the wiring be done?
Thanks, Bruce
Post by kcatthedog on Jan 2, 2015 20:44:00 GMT -6
what shadow hill's box was this taken from ?
Post by brucerothwell on Jan 2, 2015 21:28:57 GMT -6
The Equinox.
Post by tonycamphd on Jan 2, 2015 22:15:56 GMT -6
if i'm not mistaken, thats a four channel elma attenuator with smd resistors, a great piece, what application are planning it for?
Post by brucerothwell on Jan 2, 2015 23:18:10 GMT -6
The topic of the thread is about the idea of using it to create a passive level line-level control.... Is it simple, and how can it be done?
Post by tonycamphd on Jan 2, 2015 23:52:18 GMT -6
The topic of the thread is about the idea of using it to create a passive level line-level control.... Is it simple, and how can it be done? Thank you captain obvious, hook + to +, - to -, ground to ground, put it in a box, and put a knob on it, and see what you get, simple enough for you?
Post by brucerothwell on Jan 3, 2015 0:57:51 GMT -6
I apologize if I offended thee. I am just wanting to confirm if it is even possible to add a few parts to make a simple monitor controller.
Not sure what else to say to describe the "application".
Post by Deleted on Jan 3, 2015 5:32:04 GMT -6
Monitor controller, well, that would be the "application". There could be several other uses for a line level attenuator, e.g. between a pre and following gear to drive the pre into saturation and several other tasks... So, in principle, yes, just wire it up with the connectors and put it in a nice box. Depending on which resistor values have been used, you can change the attenuation characteristics also with parallel or serial resistors (resistor network rules)...
Post by RicFoxx on Jan 3, 2015 8:08:01 GMT -6
I apologize if I offended thee. I am just wanting to confirm if it is even possible to add a few parts to make a simple monitor controller. Not sure what else to say to describe the "application". Don't take Tony the wrong way...he is a very helpful dude.
Post by brucerothwell on Jan 3, 2015 15:42:19 GMT -6
...thats a four channel elma attenuator... Makes me wonder why the Equinox needed a four channel vs a 2 channel attenuator. I suppose that for my purpose, I'll only use 2 of the channels. Any ideas on how to make best use of the other two? btw... I ran across this, which seems to spell out fairly well what the wiring would be like: I figure I might just get a nice 2U panel to build this on, instead of a "table-top", unless you guyz have a source for nice boxes with wood ends?
Post by ericn on Jan 3, 2015 16:18:22 GMT -6
4 ch attenuater = 2 ch balanced attenuater.
Post by brucerothwell on Jan 3, 2015 18:25:18 GMT -6
Ahh.
Post by Bob Olhsson on Jan 3, 2015 21:05:54 GMT -6
Beware that they place a significant demand on the line amp that is driving them and its power supply.
Post by brucerothwell on Jan 3, 2015 22:31:01 GMT -6
So, I'm thinking if I don't build something with that switch, I might sell it -- any idea what they might be worth?
