Post by wiz on Nov 9, 2014 21:50:02 GMT -6
In October 2013 I finished up a two channel preamp I had been working on whilst my shoulder healed from surgery. I took the 6 months that I couldn't play and tried to learn stuff and stay positive. I planned to design a preamp, build circuit board etc. I breadboarded up my design, nothing fancy based around a INA217 preamp IC.. and tried a heap of different ICs, mucked about with capacitors all sorts of different stuff and basically passed the time and tried to learn something. In the end I went with Jim Williams plug in preamp... which was pin compatible with what I had designed around. I also, was lucky to find a circuit board on ebay , cheap, that I could mod to suit my purpose. I built the Power supply from a walwart from jay car and a ACDC kit from JLM Audio. It turned out really well, its very very quiet. It has 2 channels, phase reverse, 48V phantom and a 20 dB pad its unbalance out on TS jack so it goes straight into my patch bay. and here is what it sounds like. I just recorded this. Its my Martin D28 mic'd with a KM84, My vocal is U87 going into my DRIP STA and the resonator is the KM84. No EQ, no verb , no nothing. Just pan . I think it sounds extremely natural. it was tracked at 96Khz/24 and bounced strait to 320K mp3 in logic. dl.dropboxusercontent.com/u/13120658/Time%20Test.mp3cheers Wiz
Post by jeromemason on Nov 10, 2014 0:06:55 GMT -6
Cool Wiz!
Post by tonycamphd on Nov 10, 2014 2:06:36 GMT -6
Most excellent as wizual! 8)
Post by Deleted on Nov 10, 2014 4:58:43 GMT -6
Hey wiz, how does it sound with your dynamic mics and higher gain?
Post by wiz on Nov 10, 2014 5:08:41 GMT -6
Hey wiz, how does it sound with your dynamic mics and higher gain? I will cut something tomorrow with a sm57 on guitar and vocal if you like?
Post by Deleted on Nov 10, 2014 5:19:10 GMT -6
Wow cool. I strongly guess your pre has lots of clean gain, so testing with dynamic mics and therefore more gain, the sonics of the pre could be judged better. I would also try the 441 or M201. Sure - it would be interesting to see what the pre makes with the SM57!
Post by wiz on Nov 10, 2014 5:24:43 GMT -6
I have a m201 I will use it on vocals and the 57 on acoustic is that what you are sort of wanting to hear?
Post by Deleted on Nov 10, 2014 6:55:33 GMT -6
Oh yes! That sounds like a good combination to hear what the pre does.
Post by jimwilliams on Nov 10, 2014 10:50:12 GMT -6
Those PIP's have a 60 db max gain using a 10 ohm gain set resistor. I also have a version 2 PIP now out. It's smaller, much lower noise and THD, it does -133 db EIN at 50 ohms. Output current is over 50 ma. IMD distortion is 1.5 PPM or .00015%. Same price, $50 each.
Post by wiz on Nov 10, 2014 17:23:13 GMT -6
Those PIP's have a 60 db max gain using a 10 ohm gain set resistor. I also have a version 2 PIP now out. It's smaller, much lower noise and THD, it does -133 db EIN at 50 ohms. Output current is over 50 ma. IMD distortion is 1.5 PPM or .00015%. Same price, $50 each. stop lap dancing in front of me jimwilliams8) cheers Wiz
Post by ericn on Nov 10, 2014 17:52:32 GMT -6
Nice Wiz ! More than once I have looked at Jim's PIPs and also thought about a couple of those modules he did for the TOFT in my Status, but I Just don't stick a mic into the thing!
Post by wiz on Nov 10, 2014 18:15:48 GMT -6
dl.dropboxusercontent.com/u/13120658/Is%20She%20Test.mp3here it is @smallbutfine Preamp ended up flat out... 57 was about 10 Inches from both sources. I ended up using SM57 for both Martin and Vocal.. my 201 is playing up, its always on snare.. and when I sang into it a couple of notes, caused distortion...weird, it wasn't so much level as I guess frequency,...so I will have to look at it. anyways... here ya go There is a reason why I own a U87 for voice. 8) same signal path .. Preamp no comp or EQ or nada on Guitar, and preamp into STA no EQ on Vocal just panned cheers Wiz
Post by Deleted on Nov 10, 2014 20:24:59 GMT -6
Nice! Really nice. Really. (Do i need another pre? No...yes? Nooo. Nooooo. Please, no.) Thank you for another DIY-GAS. BTW - Nice version of the song!
Post by jimwilliams on Nov 11, 2014 10:42:16 GMT -6
If you liked the sound of the ADA4898-2 opamps in the Ross Martin DAC, you will love the version 2 PIP, it also uses the ADA4898-2 opamp.
Post by wiz on Nov 11, 2014 17:14:10 GMT -6
If you liked the sound of the ADA4898-2 opamps in the Ross Martin DAC, you will love the version 2 PIP, it also uses the ADA4898-2 opamp. Alright jimwilliamsyou piqued my interest...I will grab one and give it a run look out for my email 8) cheers Wiz
Post by ElGato on Nov 11, 2014 18:44:27 GMT -6
Cool. Congrats.
Post by Deleted on Nov 11, 2014 21:04:27 GMT -6
Lap dancing...LOL. I had to look that one up. There is no such thing around here in germany, outside of american style tourist bars on Hamburg Sankt Pauli. Haharrr.
Post by Deleted on Nov 11, 2014 21:10:24 GMT -6
wiz, btw. the second clip is a good example for the fact, that it's mostly the source, not the mic. I like your voice, even thru an SM57, doesn't sound bad at all.
