Post by Johnkenn on Sept 30, 2014 21:10:43 GMT -6
Post by matt on Oct 1, 2014 7:31:02 GMT -6
Sounds like something along the lines of the Quartet, but with T-Bolt. Maybe also with some onboard DSP - effects, amp modeling, etc, and possibly DAW integration similar to UAD.
Post by RicFoxx on Oct 1, 2014 7:40:13 GMT -6
Big hopes for this as this might be in the wheelhouse for me now that I sold the Omni.
Post by svart on Oct 1, 2014 8:01:18 GMT -6
Not sure it means anything, but they mention the preamp and the built-in mic in the singular sense.. I expect it's the Apogee Mono.. They already have a duet and a quartet, but the only single device they have is the Jam.. which lacks any features.
Post by Johnkenn on Oct 1, 2014 11:12:03 GMT -6
Whomp whomp
Post by RicFoxx on Oct 5, 2014 13:26:46 GMT -6
Looks like a 1RU box with symphony converters...could be interesting!
Post by Guitar on Oct 5, 2014 19:14:39 GMT -6
something to compete directly with Apollo? I dunno
Post by RicFoxx on Oct 5, 2014 20:38:43 GMT -6
That's what I would imagine!
Post by ericn on Oct 6, 2014 6:34:01 GMT -6
My guess and just a guess is something that replaces ensamble. With TB and USB with PT Windows support.
Post by lolo on Oct 6, 2014 8:57:33 GMT -6
Interface with windows support will be pretty cool
Post by lpedrum on Oct 6, 2014 15:47:24 GMT -6
Looking at the pics it would appear to be some sort of guitar modeler/interface and not a response to the Apollo…but tomorrow only knows.
Post by wiz on Oct 6, 2014 16:06:36 GMT -6
I thought similar, its black, so its something to do with pro tools, all apogee stuff always seems to be majority , silver.
Looks like to me a replacement idea for Eleven.
I would love it if its a step between quartet and symphony...
Post by cowboycoalminer on Oct 6, 2014 23:14:52 GMT -6
It's like the night before Christmas...
Post by wiz on Oct 7, 2014 4:20:33 GMT -6
One advantage to living in the future...
its a thunderbolt ensemble.
looks cool...
Post by RicFoxx on Oct 7, 2014 4:39:04 GMT -6
One advantage to living in the future... its a thunderbolt ensemble. looks cool... post a pic wiz!
Post by wiz on Oct 7, 2014 4:41:45 GMT -6
If you go to the apogee site... You can watch a movie 8)
Post by RicFoxx on Oct 7, 2014 5:51:42 GMT -6
cool, no availability yet?
Post by wiz on Oct 7, 2014 5:54:33 GMT -6
cool, no availability yet? I had a look about couldn't find anything at the usual suspects.....
Post by RicFoxx on Oct 7, 2014 6:09:33 GMT -6
If this sounds like the symphony...why would one by the symphony 8X8??
Post by RicFoxx on Oct 7, 2014 6:10:16 GMT -6
cool, no availability yet? I had a look about couldn't find anything at the usual suspects..... I found Oct 2014 in the first to find out email.
Post by cowboycoalminer on Oct 7, 2014 6:23:34 GMT -6
8 mic pres. A drum recorders dream. But it will be interesting to see how this shakes out. Just because the converter is the same, doesn't mean they will sound the same. The analog path to and from makes a big difference.
Post by RicFoxx on Oct 7, 2014 6:42:03 GMT -6
Here are the spec comparisons...(Ensemble, Symphony and Apollo)
Ensemble Specs:
A/D conversion: Max input level (+4dBu ref/Mic): +20dBu Max input level (-10dBV ref): +6dBV Input impedance: 5KOhm Freq resp 20 Hz -20Khz: > +/-0.2dB (@44.1Khz) Rel. THD + N: -110dB (@ 96Khz) Dyn. Range: 119dB (A-weighted)
D/A conversion: Max output level (+4dBu ref): +20dBu Max output level (-10dBV ref): +6dBV Line output impedance: 90 Ohm Freq resp 20Hz -20 Khz: > +/- 0.05dB (@44.1Khz) Rel. THD+N : -114dB (@96khz) Dyn Range: 123dB (A-weighted) Front panel Guitar Output: impedance balanced/max level 14 dBu Max output level headphones: 19dBu Rel THD + N into 600 Ohm: -109dB Dyn Range: 120dB (A-weighted)
Symphony Specs
Analog to Digital: THD+N: -113dB @ 20dBu (0.00024%) Dynamic range: 120dB A weighted Maximum input levels: +4dB setting – 24dBu -10dB setting – +6dBV Variable gain setting – 25dB of gain Frequency response at 44.1kHz 1-20,000 Hz (+/- 0.05dB) Input impedance: 10K
Digital to Analog: THD+N: -117dB @ 20dBu (0.00014%) Dynamic Range: 129dB A weighted Max output levels – ? to +24dBu Frequency response at 44.1 kHz: dc to 20kHz (+/- 0.05dB) Output impedance: 25 Ohm Outputs are balanced through Apogee’s proprietary Perfect Symmetry Circuitry (PSC
And the Apollo's Specs
Analog I/O
Microphone Inputs 1 – 4 Jack Type XLR Female Phantom Power +48V, Switchable Dynamic Range 118 dB (A–weighting) Signal-to-Noise Ratio 118 dB (A–weighting) Total Harmonic Distortion + Noise –110 dB
Hi–Z Inputs Jack Type ¼” Male (Mono TS plug required) Dynamic Range 117 dB (A–weighting) Signal-to-Noise Ratio 117 dB (A–weighting) Total Harmonic Distortion + Noise –103 dB
Line Inputs 1 – 4 Jack Type ¼”Male TRS Balanced Dynamic Range 117 dB (A–weighting) Signal-to-Noise Ratio 117 dB (A–weighting) Total Harmonic Distortion + Noise –107 dB
Line Inputs 5 – 8 Jack Type ¼” Male TRS Balanced Dynamic Range 117 dB (A–weighting) Signal-to-Noise Ratio 117 dB (A–weighting) Total Harmonic Distortion + Noise –107 d
Line Outputs 1 – 8 Jack Type ¼” Male TRS Balanced Dynamic Range 118 dB (A–weighting) Frequency Response 20 Hz – 20 kHz, ±0.1 dB Signal-to-Noise Ratio 118 dB (A–weighting) Total Harmonic Distortion + Noise –106 dB
Monitor Outputs 1 – 2 Jack Type ¼” Male TRS Balanced Frequency Response 20 Hz – 20 kHz, ±0.1 dB Dynamic Range 115 dB (A–weighting) Signal-to-Noise Ratio 114 dB (A–weighting) Total Harmonic Distortion + Noise –103 dB
Stereo Headphone Outputs 1 & 2 Jack Type ¼” Male TRS Stereo/Unbalanced Frequency Response 20 Hz – 20 kHz, ±0.1 dB
Post by svart on Oct 7, 2014 6:49:25 GMT -6
Hmm. All hubbabaloo that and it was just an iteration of an existing product?
Post by RicFoxx on Oct 7, 2014 7:01:24 GMT -6
I really had hopes that it was a partnership with Avid and continue the Eleven Rack/HDX idea of running their plugins off of DSP. Why isn't anybody doing this (besides universal audio? ) From and engineering standpoint, is it impossible to run VST/AU plugins off of external DSP?
Post by mrholmes on Oct 7, 2014 7:02:39 GMT -6
Sounds like something along the lines of the Quartet, but with T-Bolt. Maybe also with some onboard DSP - effects, amp modeling, etc, and possibly DAW integration similar to UAD. My Hope too but smarter priced.....
