Post by ragan on Apr 28, 2024 23:54:12 GMT -6
Anyone using a MacBook Air for actual audio/DAW stuff? Looks like we’re on M3 now (I haven’t really been paying attention).
I want an audio laptop for doing stuff while I’m traveling and/or remote tracking at the cabin.
The MacBook Airs are pretty reasonable now.
My main interface is a Symphony MKII and it’s Mac only. Obviously the Airs aren’t the highest horsepower machines out there, but I’m also not using a bunch of VI/DSP hog stuff.
Post by Blackdawg on Apr 29, 2024 0:08:25 GMT -6
Its the same horse power as a mac mini and macbook. Plenty of power for any daw of your choice. Don't worry about it. Same rules apply, get as much RAM as you can afford/offered. And you'll be good.
Post by the other mark williams on Apr 29, 2024 0:44:04 GMT -6
Its the same horse power as a mac mini and macbook. Plenty of power for any daw of your choice. Don't worry about it. Same rules apply, get as much RAM as you can afford/offered. And you'll be good. yep. +1.
Post by wiz on Apr 29, 2024 1:31:25 GMT -6
Its the same horse power as a mac mini and macbook. Plenty of power for any daw of your choice. Don't worry about it. Same rules apply, get as much RAM as you can afford/offered. And you'll be good. I have a M1 Mac mini, 512HD... 8G ram and I get by fine... just another opinion cheers Wiz
nas
Post by nas on Apr 29, 2024 4:34:34 GMT -6
I am also pondering this question Air vs Pro. The main consideration I think is what does your work require? Are you using a lot of plugins and tons of tracks? Then good multicore CPU performance is a consideration. Do you need to run lots of VI 's and synths? - say for a film score. Then you would need a lot of RAM, disk speed, and disk space for sample streaming in addition to good multicore performance. Although of course you could use an external SSD for samples.
For my workflow primarily as a composer, the latter is important. So a MacBook Air - even maxed out with 24GB of RAM is not really enough... and by the time you do the upgrade you're not that far off in price from getting an entry level 14" MacBook Pro.
So I guess the answer is whatever your workflow and performance requirements are (as well as your screen size preference). An entry to mid level MacBook Air for basically running a DAW and a descent number of tracks and plugins and not trying to do the next Blade Runner score... then you should be ok with an Air.
One thing to keep in mind is the chassis size with respect to proper cooling and how much you will be taxing the CPU. You don't want fans goin off all the time if you're using a MacBook Pro (Air has no fans I think) and then take a performance hit due to thermal throttling. So that's also worth considering
Anyway, hope that helps.
Post by kcatthedog on Apr 29, 2024 6:49:35 GMT -6
Careful jumping on a m3, there are known throttling issues with the M series not assigning cores consistently.
Some are getting m2 instead.
Post by ragan on Apr 29, 2024 8:55:04 GMT -6
My main use cases would be being able to comp/edit while I'm on flights and then doing simple overdubs at the cabin or other locations. I print a lot of hardware and don't use a huge amount of DSP so none of this is will be all that computationally expensive. Drawn to the Air for its price and form factor.
This would not be my main studio machine. I have the last Intel iMac they made, maxed out, and I'll be using it as the main studio machine for several more years.
Post by kcatthedog on Apr 29, 2024 9:23:11 GMT -6
You should be good, as the performance cores would theoretically only be needed with higher dsp/memory demand.
nas
Post by nas on Apr 29, 2024 9:24:26 GMT -6
My main use cases would be being able to comp/edit while I'm on flights and then doing simple overdubs at the cabin or other locations. I print a lot of hardware and don't use a huge amount of DSP so none of this is will be all that computationally expensive. Drawn to the Air for its price and form factor. This would not be my main studio machine. I have the last Intel iMac they made, maxed out, and I'll be using it as the main studio machine for several more years. Yes the M3 MacBook Air should be more than enough for this type of use, especially if you're coming from an older Intel laptop or getting the Air as a second editing machine. The ARM Macs are really a huge leap forward compared to the older Intel ones and you can get a lot more horsepower out of these, even with the older M1 laptops.
Post by drbill on Apr 29, 2024 10:09:39 GMT -6
Longtime Air user here. I would say that connectivity would/will be your major concern. As others have said, max out the RAM and Storage and you should be OK.
Post by Johnkenn on Apr 29, 2024 10:47:24 GMT -6
Look into like a refurbed or use M2 MBA. Would imagine 2 is better than one and I use the M1 every day with the Studio…but it has 32gb Ram.
Post by ragan on Apr 29, 2024 10:52:16 GMT -6
Yeah I was thinking about that (used/refurb) from like OWC or something.
Post by kcatthedog on Apr 29, 2024 11:27:02 GMT -6
Apple also sell refurbed/ Reboxed with full warranty.
Post by ericn on Apr 29, 2024 11:59:00 GMT -6
If portability is a priority you can’t beat the Air. In fact the form factor of the air is so damn addictive it’s probably why I’m still running an Intel machine.
Definitely spend the money on a machine with 32GB of memory, with Apple set on soldering in the ram and a sort of forced profit center it’s a pain but there is no going back.
Post by gravesnumber9 on Apr 29, 2024 12:53:14 GMT -6
15" Macbook Air M2 is the best laptop I've ever owned. Not the most powerful. Not the most portable. Not the most anything specific... just the best all around laptop I've ever owned.
And I use it all the time for tracking. It's absurdly overpowered for that task (all live instruments, a few plugins). It actually handles basic video editing pretty well too. I can render a lot of the Fusion effects from DaVinci Resolve in realtime (camera shake, etc) though the lighting effects do slow it down.
But the form factor is just perfect. I got mine with 1tb hard drive and 24gb RAM. Highly recommended.
EDIT: Except as Dr Bill mentioned for the connectivity. Sucks for that. Dongle city over here.
Post by antipodesjosh on Apr 30, 2024 4:29:30 GMT -6
I have an M1 MBP and one of the last top-of-the-line intel iMacs with 40gb RAM. I don’t notice a ton of difference between them in everyday use with Logic.
M series chips are pretty amazing, just make sure you get at least 16gb RAM.
Post by kcatthedog on Apr 30, 2024 4:58:06 GMT -6
No noise from fans vs actual processing: agreed on the 16 gig, but wiz keeps trucking along, I think with 8 ?
Post by gravesnumber9 on Apr 30, 2024 10:36:35 GMT -6
I have an M1 MBP and one of the last top-of-the-line intel iMacs with 40gb RAM. I don’t notice a ton of difference between them in everyday use with Logic. M series chips are pretty amazing, just make sure you get at least 16gb RAM. My "desktop" (is a Mac Mini really a desktop?) is a Mini M1 with 16gb and it runs nicely. It's not as good for video processing as the M2 Air but I can so some pretty heavy mixing/plugins/VI stuff on it before it starts grinding down.
Post by ragan on May 4, 2024 12:58:10 GMT -6
Ordered a refurbished 15” M2 from Apple. Thanks for the insights everyone.
nas
Post by nas on May 4, 2024 13:26:29 GMT -6
In a few online tests I've seen, the M2's actually perform better than the newer M3's for DAW use - so you should be quite happy with your refurbished M2 MacBook Air.
Post by gravesnumber9 on May 4, 2024 14:09:06 GMT -6
Ordered a refurbished 15” M2 from Apple. Thanks for the insights everyone. I think you're gonna love it.
Post by kcatthedog on May 4, 2024 14:34:23 GMT -6
Sounds: great !
Post by Johnkenn on May 4, 2024 20:18:36 GMT -6
Look into like a refurbed or use M2 MBA. Would imagine 2 is better than one and I use the M1 every day with the Studio…but it has 32gb Ram. Doh. Forgot I had a MBA M2 laptop lol. Well, didn’t forget I had a laptop…guess I didn’t really think about it because I’ve never done music on it. I would probably think about going with 16gb ram - but yeah, it would probably work great.
Post by ragan on May 4, 2024 20:38:26 GMT -6
The refurb Air I ordered has 16g RAM and 1TB SSD.
