Post by bluesholyman on Apr 18, 2024 10:16:38 GMT -6
I have a PT Carbon, nothing else external/digital to that yet, but was wondering when a "better" master clock makes a real difference. Or does it?
I understand the use in a multi-slave environment and get why its needed there. In that scenario, the Carbon could be the master and probably should be absent of an "better" external clock.
So, would an external clock really add anything to an interface such as the carbon, assuming its a better and/or more accurate clock?
As always, appreciate the input.....
Post by trakworxmastering on Apr 18, 2024 10:23:48 GMT -6
An external clock just to improve the sound of a single interface? IME, no. It was a topic of much online debate years ago. 'Feels nostalgic posting about it now...
Post by copperx on Apr 18, 2024 10:31:08 GMT -6
Ah, those were the days. I remember a studio placing Atomic Clocks in an oven to get more "clock stability".
Post by bluesholyman on Apr 18, 2024 10:42:23 GMT -6
Atomic clocks bringing on the nostalgia like a warm glowy tube.....now ironic...
Post by ab101 on Apr 18, 2024 10:43:44 GMT -6
Makes me wonder if pros are using atomic clocks anymore.
Post by Shadowk on Apr 18, 2024 10:54:03 GMT -6
I have a PT Carbon, nothing else external/digital to that yet, but was wondering when a "better" master clock makes a real difference. Or does it? I understand the use in a multi-slave environment and get why its needed there. In that scenario, the Carbon could be the master and probably should be absent of an "better" external clock. So, would an external clock really add anything to an interface such as the carbon, assuming its a better and/or more accurate clock? As always, appreciate the input..... Unless you like a bit of jitter no, also the Carbon has AVB clocking so between multiple units so there's no reason to ever have an external clock. If you've got multiple disparate units that need sync'ing together that's when you'd buy a clock so they're not out of time with each other. Or I guess you could try MAC's aggregation but I'm not sure about it TBH..
Post by Tbone81 on Apr 18, 2024 11:09:30 GMT -6
Years ago I did a lot of product demos, comparing Antelope OCX and Atomic clocks in that very same scenario. A good external clock 100% makes a difference…what it won’t do is measurably improve jitter (in that specific scenario). It will change the sound however. It’s up to you to decide if you like the change. What it does is change the distortion profile caused by the jitter and that can be subjectively better sounding.
I think of it like preamps, we can look at distortion specs but that doesn’t tell you if the preamp sounds good. In fact, in many cases we like the more distorted preamps better then cleaner ones.
Post by svart on Apr 18, 2024 11:33:17 GMT -6
It won't. External clocks were used to sync a bunch of different devices. At some point people seemed to like what they did to the audio so they started using them to "fix" the sound.
But actual measurements show that external clocking, with the cable/connector/termination impairments and parasitics make EVERY external clock technically worse than internal clocking.
What I've found over the years is that deterministic phase noise is not necessarily a problem in any modern system in the sense that the primary tone of interest is quite stable with sideband power being very low and easily filtered out. Almost all sigma-delta converter ICs need 128-512fs clocking, and any residual phase noise would also be divided by those amounts before the sampling hardware sees the clock signal. Again, very, very low chance that jitter is the "cause" of a difference in sound.
However, in external WC cabling, there is a possibility of random external noise being introduced.
There's also the question of *what exactly is happening to the WC signal* once it's brought into the device.
1. Used directly.. Which would be more rare today since sigma-delta converters simply can't use the low frequencies directly. 2. Upconverted by PLL/DPLL to 128-512fs for use by the sigma-delta converters.. Which is more likely but also a worst-case scenario. 3. #2 but following the PLL is a "jitter cleaner" which is another PLL with a specific design to decouple the dirty reference clock from the output.
#2 is a bad situation alone. Taking a noisy WC signal and using it as a direct reference for a PLL would MULTIPLY the jitter by the amount that you'd need to multiply the signal to get 128-512fs for the converter clocking. Imagine multiplying your jitter 512x..
So #3 would be the only viable situation, by multiplying the WC signal up to say 100MHz with an aggressive loop filter(low pass feedback) then using that as a reference for a jitter cleaner IC that divides back down to something like 22.579Mhz for the converter ICs to use.
You can see that the converter IC clocks are now extremely decoupled from the WC input and other than being in sync, have very little to nothing in common with other devices also being clocked in a system. It also has very little to nothing to do with the quality of the WC signal.
So modern converters don't need external clocking at all unless you need some semblance of sync between devices, which I don't think is necessary in any normal use case because DAWs allow you to nudge tracks to line up in phase anyway.
Post by Dan on Apr 18, 2024 11:41:04 GMT -6
the ovens and heaters were in the old high end converters to stabilize the temperature of the resistor ladders. Multi-bit delta sigma modulators got rid of the need for this.
Post by Dan on Apr 18, 2024 11:46:19 GMT -6
Years ago I did a lot of product demos, comparing Antelope OCX and Atomic clocks in that very same scenario. A good external clock 100% makes a difference…what it won’t do is measurably improve jitter (in that specific scenario). It will change the sound however. It’s up to you to decide if you like the change. What it does is change the distortion profile caused by the jitter and that can be subjectively better sounding. I think of it like preamps, we can look at distortion specs but that doesn’t tell you if the preamp sounds good. In fact, in many cases we like the more distorted preamps better then cleaner ones. yeah and is svart can explain, it doesn’t do anything at all in converters that utilize asynchronous sample rate conversion to a rate that’s not a multiple of 44.1 or 48 khz like benchcmark, apogee, crane song, and weiss. All that matters is that they get the samples in order. They ignore the clocking altogether. If they have word clock outs or options, it’s to spoof another device into thinking it’s the master clock. The asrc chips are not as good as software now but are still cleaner than the multibit delta sigma converter chips, which are still linear to their noise floor. These converters are among the best products you can buy.
Post by thehightenor on Apr 18, 2024 11:58:04 GMT -6
Without taking scientific view, just going on using my ears (crazy as that seems these days)
I clock my system from my HEDD 192 because …
Again more craziness …. it’s sounds better.
Just my 2 cents.
Post by svart on Apr 18, 2024 12:33:15 GMT -6
Without taking scientific view, just going on using my ears (crazy as that seems these days) I clock my system from my HEDD 192 because … Again more craziness …. it’s sounds better. Just my 2 cents. I don't think anybody is saying it's not different.. But I think a lot of people actually like MORE jitter than less jitter. More jitter would cause more harmonic excitement and would sound "wider" and more "full" and probably have more "detail" in the form of small amounts of distortion.
Post by Tbone81 on Apr 18, 2024 12:49:52 GMT -6
Without taking scientific view, just going on using my ears (crazy as that seems these days) I clock my system from my HEDD 192 because … Again more craziness …. it’s sounds better. Just my 2 cents. I don't think anybody is saying it's not different.. But I think a lot of people actually like MORE jitter than less jitter. More jitter would cause more harmonic excitement and would sound "wider" and more "full" and probably have more "detail" in the form of small amounts of distortion. +1 to that. That’s exactly the point I was trying to make.
Post by Shadowk on Apr 18, 2024 13:30:03 GMT -6
I don't think anybody is saying it's not different.. But I think a lot of people actually like MORE jitter than less jitter. More jitter would cause more harmonic excitement and would sound "wider" and more "full" and probably have more "detail" in the form of small amounts of distortion. +1 to that. That’s exactly the point I was trying to make. I don't think it's a secret that modern day mid to high end digital is a bit too perfect, I'm not just flapping my gums here because Fabien from Tokyo Dawn labs, Ozone etc. you name it says that you need a good dollop of harmonic distortion to even get things to translate to "lesser" systems. If you've ever gotten a wonky reproduction due to not enough of the imperfections you'll get it.
That being said you can screw things up infinitely after the conversion stage even in terms of timing so I'm not sure why you'd want your interface to do it? If you've got a very clear picture you know by the exact amount how much you should bork it. Despite Avid's "my way or the highway" in terms of setup I love my Carbon's, clean as they come.. What goes in comes out for better or worse.
Post by ab101 on Apr 18, 2024 13:39:39 GMT -6
Without taking scientific view, just going on using my ears (crazy as that seems these days) I clock my system from my HEDD 192 because … Again more craziness …. it’s sounds better. Just my 2 cents. Interesting! Great discussion with you and svart. Maybe a "jitter" plugin is in the works for those people with incredible internal clocks! Seriously, this is has been a very helpful discussion for me. In the 2000s - I liked my Aurora 16 clocked to an Antelope clock. The knowledgeable Lynx folks told me that it was not more accurate. But I suppose it was an "effect" I liked. Now with the Aurora (n), I sold my Antelope.
Post by thehightenor on Apr 18, 2024 14:35:27 GMT -6
Without taking scientific view, just going on using my ears (crazy as that seems these days) I clock my system from my HEDD 192 because … Again more craziness …. it’s sounds better. Just my 2 cents. Interesting! Great discussion with you and svart. Maybe a "jitter" plugin is in the works for those people with incredible internal clocks! Seriously, this is has been a very helpful discussion for me. In the 2000s - I liked my Aurora 16 clocked to an Antelope clock. The knowledgeable Lynx folks told me that it was not more accurate. But I suppose it was an "effect" I liked. Now with the Aurora (n), I sold my Antelope. I watched this interview with Tchad Blake and the interviewer kept asking technical questions and searching for answers on quite scientific levels …. Tchad kept shrugging his shoulders and saying, honestly I don’t know - I don’t analyse this stuff - I just go with what sounds best. The interviewer seemed quite disappointed there wasn’t a formal method to Tchad’s success. I think I fall into that camp - if it sound right - it’s right. I’m not knocking teachnicel knowledge, obviously not, I wouldn’t have great gear if it wasn’t for the likes of Dave Hill and Rupert Neve (to name but two) of this world. But what I love about creativity is, it’s very pure, you can just do it without having to “read the manual” so to speak
Post by ericn on Apr 18, 2024 14:47:53 GMT -6
if only there was a simple, fairly inexpensive way to see if your clock is a source of jitter, if only someone would build an inexpensive device to look at clock signals.
What it already exists? What you can buy one used on eBay for under $100? It’s called an Oscilloscope. Yes it’s fun to discuss this but the solution is simple and mine lives next to my Mytek.
Post by copperx on Apr 18, 2024 15:15:52 GMT -6
Huh. No sync necessary?
Recently I was trying to reamp a guitar through a digital Katana amplifer, sending the clean signal through its built-in soundcard, and then recording the miced up amp through my soundcard. The audio started to get out of sync as soon as ~10 seconds in. Luckily, I was able to fix it by lossless stretching, but I was surprised by the amount of clock drift.
Is this not a common occurrence, then, using multiple interfaces that are not clocked together?
Post by drbill on Apr 18, 2024 18:16:34 GMT -6
It becomes important when you have too much expendable cash!
Post by Shadowk on Apr 18, 2024 18:22:56 GMT -6
It becomes important when you have too much expendable cash! No it doesn't, science doesn't often change because you want it to unfortunatley.
Post by drbill on Apr 18, 2024 18:27:47 GMT -6
It becomes important when you have too much expendable cash! No it doesn't, science doesn't often change because you want it to unfortunatley. Yes it does! It becomes important when I FEEL it's important.
Post by Shadowk on Apr 18, 2024 18:50:00 GMT -6
No it doesn't, science doesn't often change because you want it to unfortunatley. Yes it does! It becomes important when I FEEL it's important. Unfortunately the laws of the universe will not agree, if you feel it's important to jump into a fire then it will most likely burn you. An idiocracy statement I know but practical sciences are generally derived from well let's face it stupid yet clever in retrospect, it's people who found out the hard way. Marie Curie for example, who knew radiation kills huh? Well we do today that's for sure. We can say it freely today but someone had to find out.
Audio is a very simple scientific premise in the grand scheme, even me the dummy here noticed the less than perfect anomaly when I was desigining equipment 20 years ago. I wish I had the successful career you had Bill, I might even trade my leftie for it but this one area where there's no real plausible arguments besides you like to damage to your signal.
Post by Tbone81 on Apr 18, 2024 19:35:34 GMT -6
External clocking is the only time that people don’t believe in “trusting your ears”, instead it’s trust the numbers. Always thought that was weird.
Post by drbill on Apr 18, 2024 20:16:58 GMT -6
Audio is a very simple scientific premise in the grand scheme, even me the dummy here noticed the less than perfect anomaly when I was desigining equipment 20 years ago. I wish I had the successful career you had Bill, I might even trade my leftie for it but this one area where there's no real plausible arguments besides you like to damage to your signal. Satire my friend. I've never use an external clock.
Post by chessparov on Apr 18, 2024 21:09:45 GMT -6
Darn. I wanted that Popcorn icon!
