Post by kcatthedog on Apr 12, 2024 17:52:56 GMT -6
Post by copperx on Apr 12, 2024 19:01:34 GMT -6
Paper cones!
Post by andersmv on Apr 12, 2024 19:26:11 GMT -6
I don't know if that was meant in shock/disgust or excitement . It's not always a bad things, Barefoot did it on their Footprint 01 woofers and they sounded great. We'll just have to wait and see how Kali implemented it here.
Post by veggieryan on Apr 12, 2024 19:48:36 GMT -6
Nice to see an innovative passive monitor design and paper cones usually just sound better to my ears.
The tweeter sounds interesting too:
Post by kcatthedog on Apr 13, 2024 3:25:36 GMT -6
I’ll definitely demo these, but with amp I wonder if they will be more expensive then the new barefoot 3 active.
Post by ericn on Apr 13, 2024 8:57:24 GMT -6
The Amp requirements make me a bit nervous, So even in single amp mode these need a DSP profile? 3 ohms I know it’s a nominal rating but guys what that tells me is it’s really a 2 ohm load all over the place, but the lower the impendance the more current your going to draw at wattage. No limiter or no warranty, not a problem we have racks of amps that fit the bill in the live rig, non of the amps that end up on monitors here are going to have limiters, are they that fragile?
If I really need a specific amp. Package it and call it an active system.
Post by Dan on Apr 13, 2024 11:59:14 GMT -6
The Amp requirements make me a bit nervous, So even in single amp mode these need a DSP profile? 3 ohms I know it’s a nominal rating but guys what that tells me is it’s really a 2 ohm load all over the place, but the lower the impendance the more current your going to draw at wattage. No limiter or no warranty, not a problem we have racks of amps that fit the bill in the live rig, non of the amps that end up on monitors here are going to have limiters, are they that fragile? If I really need a specific amp. Package it and call it an active system. They want to get bass out of a 5” woofer and need to limit that coax assembly. Genelec limits the crap out of their coaxial mid/tweeter assembly.
Post by ericn on Apr 13, 2024 13:37:51 GMT -6
The Amp requirements make me a bit nervous, So even in single amp mode these need a DSP profile? 3 ohms I know it’s a nominal rating but guys what that tells me is it’s really a 2 ohm load all over the place, but the lower the impendance the more current your going to draw at wattage. No limiter or no warranty, not a problem we have racks of amps that fit the bill in the live rig, non of the amps that end up on monitors here are going to have limiters, are they that fragile? If I really need a specific amp. Package it and call it an active system. They want to get bass out of a 5” woofer and need to limit that coax assembly. Genelec limits the crap out of their coaxial mid/tweeter assembly. I know things are just simpler if you start with decent drivers!
Post by kcatthedog on Apr 13, 2024 14:04:10 GMT -6
This is the first set in the new line. In the video they talk about other models and active, beg an 8 inch woofer is in the works.
Post by Martin John Butler on Apr 13, 2024 18:47:53 GMT -6
At 2G's with no amp, there's a lot of great quality competition out there.
Post by ericn on Apr 13, 2024 20:40:02 GMT -6
At 2G's with no amp, there's a lot of great quality competition out there. 4K for monitors and power isn’t cheap. I keep looking at Dirac and I’m looking for something to use in the new bedroom. Now I was looking at a pair of Passive HHB circle / Harbeth’s for $200. Now for 4K I could get one hell of an amp.
Post by Dan on Apr 13, 2024 20:56:38 GMT -6
At 2G's with no amp, there's a lot of great quality competition out there. 4K for monitors and power isn’t cheap. I keep looking at Dirac and I’m looking for something to use in the new bedroom. Now I was looking at a pair of Passive HHB circle / Harbeth’s for $200. Now for 4K I could get one hell of an amp. That's more money than Focal and ATC and unlike Focal and ATC, Kali is using generic drivers.
Post by kcatthedog on Apr 14, 2024 8:08:14 GMT -6
And more then the new barefoot 3 and dyn lyd48, both active: I’d find it hard to buy the kali, unless they really blew my doors off .
