Post by Deleted on Jan 8, 2024 19:25:11 GMT -6
Right so I'm looking to go down some sort of HDX path with either MTRX or Carbon. So, Carbon users I read the Avid Q&A which says hardware inserts are automatically compensated which is good, does this apply to ADAT as well? It seems the new Carbon expansion devices run over ADAT as well but TBH I'm not really sure what the point is? I might as well get a Cranborne 500 ADAT, consolidate all the wiring and then have a spare chassis for when I decide to add more HW in the future.
Second question is flipping between core audio, might be a silly question but I'd gather for use with Pro Tools Ultimate (which you get bundled with it YAY) it's better to disable core audio?
ADC, latency etc. is extremely important to me and is one of the reasons I bought an SSL desk. However for me nothing beat HDX for audio hence why I'm looking down that path again. MTRX seems to be more along the lines of bog standard HDX but if Carbon can do all of that then I'll go down that path.
Post by bluesholyman on Jan 8, 2024 20:55:18 GMT -6
This Carbon vs Mtrx might help. I have a Carbon - glad to answer any questions about it I can...
Post by Deleted on Jan 8, 2024 21:13:30 GMT -6
This Carbon vs Mtrx might help. I have a Carbon - glad to answer any questions about it I can... Yeah, I mean I think Carbon is the one. It seems to compensate for any HW insert delays over any channel required, I can clean up an extreme mess of cabling by purchasing a Cranborne and adding it to the ADAT ports. Also got enough left to expand into another carbon interface over AVB or ADAT, it's seriously low latency so overdubs should be a breeze and I can run "test" mixes via DSP with no overhead.
I might be getting ahead of myself here but I'm not seeing a downside? For music especially I'm not sure why I'd go down the MTRX / HDX route..
Post by Blackdawg on Jan 8, 2024 23:32:03 GMT -6
Carbon has limited I/O expansion is the main negative. You can't simply add another carbon and such. So if you don't need the full I/O than you're fine. But if you want more channels, you gotta get the true HDX card and all the toys.
Also I've never used one just the MTRX stuff and Avid I/O's and Digi 192's. Which 192's STILL work on HDX cards. I have 2 right now working flawlessly. I use the digital aes out to a HAPI and it does it's thing just right. So it's a cheap way to get some interfaces. They go for pretty cheap. The Avid I/O's are also dropping in price. If I can ever get a CAPI Sumbuss I'll just grab one of those.
Post by Deleted on Jan 9, 2024 0:28:59 GMT -6
Carbon has limited I/O expansion is the main negative. You can't simply add another carbon and such. So if you don't need the full I/O than you're fine. But if you want more channels, you gotta get the true HDX card and all the toys. On the Avid website via Carbon Control it says you can expand it to three devices for 24 analog I/O.
However it's run over ADAT and the limitations are the amount of channels. So I was just going to bypass that entire thing and get a Cranborne ADAT 500 expander. Thus far I have 3X external preamps, 4X RND Inductor EQ's, 1X Chandler Opto, 1X Acme Opto, 2X IGS Vari-Mu 500, SSL G-Bus, SSL UV, 33609 and a BM ML, Gainlabs Mastering EQ and Lexicon. Plan is to Rack the first 4 comps into the Cranborne with the EQ's in an analog loop then send it to the Carbon via ADAT, then have 2 HW loops one for the "mastering" stuff and the Lexicon / UV into the Line DB-25's. That's if I can be bothered with the Lex over plugs nowadays..
Ultimately this will take up 4 channels of ADAT and 7 I/O, there's enough to expand more via ADAT in the future but it's actually my physical room which won't allow any more really. I did buy a center rack but I've filled that up too. So for the long forseeable there won't be any more HW. I do hope it works out the way I'm planning it, please feel free to mention anything I've missed.
Post by subspace on Jan 9, 2024 1:02:00 GMT -6
You can expand Carbon by simply adding another Carbon, up to 3 total. You don't do this via ADAT, Carbon Central uses the AVB ethernet connection for expansion using either a Carbon Pre or a full Carbon booted into Pre mode. I run a pair of Carbons, the second booted as a Pre so it adds an additional 8 analog I/O. Analog insert latency is perfectly compensated with PT, ADAT latency will be compensated but any outboard converters connected won't be.
Post by Deleted on Jan 9, 2024 1:24:25 GMT -6
You can expand Carbon by simply adding another Carbon, up to 3 total. You don't do this via ADAT, Carbon Central uses the AVB ethernet connection for expansion using either a Carbon Pre or a full Carbon booted into Pre mode. I run a pair of Carbons, the second booted as a Pre so it adds an additional 8 analog I/O. Analog insert latency is perfectly compensated with PT, ADAT latency will be compensated but any outboard converters connected won't be. Thanks for that, so it might be better to get a Carbon and a Carbon Pre..
Post by thehightenor on Jan 9, 2024 2:23:24 GMT -6
You can expand Carbon by simply adding another Carbon, up to 3 total. You don't do this via ADAT, Carbon Central uses the AVB ethernet connection for expansion using either a Carbon Pre or a full Carbon booted into Pre mode. I run a pair of Carbons, the second booted as a Pre so it adds an additional 8 analog I/O. Analog insert latency is perfectly compensated with PT, ADAT latency will be compensated but any outboard converters connected won't be. Thanks for that, so it might be better to get a Carbon and a Carbon Pre.. If I ever downsize I’ve looked around for a compact solution and the Avid Carbon comes out tops. I think the whole concept is excellent. Big thumbs up from me for the Carbon!
Post by bluesholyman on Jan 9, 2024 5:58:28 GMT -6
There are more experience/advanced Carbon users here than I. My thought was if you needed Mic pre's the Carbon would be the way to go and as stated, you can run up to 3 Carbons. That ethernet connection is finicky, in that there is a specific list of supported ethernet ports supported. The built in one on (newer?) Macs is one of them and I think Sonnet makes a USB-C/TB-> Ethernet that is supported - most other ethernet dongles don't work with Carbon. A litte due diligence is required there if you aren't connecting directly to a Mac's ethernet port and using an adapter.
With my 2017 MacBook pro, I had to do Carbon -> Apple Ethernet/Thunderbolt -> Apple Thunderbolt/USB-C -> Macbook Pro. That mile long dongle chain was a bit annoying but works. With my Mini M2, I'm straight into its ethernet port and its way less dongly.
Not sure whats what on the Windows side with this.
Post by Deleted on Jan 9, 2024 7:54:16 GMT -6
There are more experience/advanced Carbon users here than I. My thought was if you needed Mic pre's the Carbon would be the way to go and as stated, you can run up to 3 Carbons. That ethernet connection is finicky, in that there is a specific list of supported ethernet ports supported. The built in one on (newer?) Macs is one of them and I think Sonnet makes a USB-C/TB-> Ethernet that is supported - most other ethernet dongles don't work with Carbon. A litte due diligence is required there if you aren't connecting directly to a Mac's ethernet port and using an adapter. With my 2017 MacBook pro, I had to do Carbon -> Apple Ethernet/Thunderbolt -> Apple Thunderbolt/USB-C -> Macbook Pro. That mile long dongle chain was a bit annoying but works. With my Mini M2, I'm straight into its ethernet port and its way less dongly. I'd just use the Carbon Pre for line ins and outs, is that possible? Yeah, I did notice the whole dongle debarcle. Fortunately I already have the TB3 - TB2 adapter for the MOTU and I managed to find somewhere with the Apple Gigabit Ethernet adapter. The Sonnet's like $250.00, mad..
Post by subspace on Jan 9, 2024 8:18:26 GMT -6
There are more experience/advanced Carbon users here than I. My thought was if you needed Mic pre's the Carbon would be the way to go and as stated, you can run up to 3 Carbons. That ethernet connection is finicky, in that there is a specific list of supported ethernet ports supported. The built in one on (newer?) Macs is one of them and I think Sonnet makes a USB-C/TB-> Ethernet that is supported - most other ethernet dongles don't work with Carbon. A litte due diligence is required there if you aren't connecting directly to a Mac's ethernet port and using an adapter. With my 2017 MacBook pro, I had to do Carbon -> Apple Ethernet/Thunderbolt -> Apple Thunderbolt/USB-C -> Macbook Pro. That mile long dongle chain was a bit annoying but works. With my Mini M2, I'm straight into its ethernet port and its way less dongly. I'd just use the Carbon Pre for line ins and outs, is that possible? Yeah, I did notice the whole dongle debarcle. Fortunately I already have the TB3 - TB2 adapter for the MOTU and I managed to find somewhere with the Apple Gigabit Ethernet adapter. The Sonnet's like $250.00, mad.. Yes, there are only 8 analog inputs on a single Carbon or Pre, but there are separate mic connections and line in on DB25, so you can leave both connected and just select which is active on the PT mixer channel. I use the Carbons connected three different ways, straight to the built-in ethernet on a 2012 Mac Mini, via a TB2>ethernet adaptor with a 2014 15" MBP and via the TB4>TB2>ethernet adaptor chain with a 2021 16" MBP M1 Pro. There's an odd deal on Sweetwater right now for B-stock Carbons which were made with a 24-bit converter chipset rather than the 32-bit due to chip shortages. I would avoid, I got my second Carbon as B stock for $1900, so there are better deals to be found on the full spec units.
Post by bluesholyman on Jan 9, 2024 8:28:23 GMT -6
There are more experience/advanced Carbon users here than I. My thought was if you needed Mic pre's the Carbon would be the way to go and as stated, you can run up to 3 Carbons. That ethernet connection is finicky, in that there is a specific list of supported ethernet ports supported. The built in one on (newer?) Macs is one of them and I think Sonnet makes a USB-C/TB-> Ethernet that is supported - most other ethernet dongles don't work with Carbon. A litte due diligence is required there if you aren't connecting directly to a Mac's ethernet port and using an adapter. With my 2017 MacBook pro, I had to do Carbon -> Apple Ethernet/Thunderbolt -> Apple Thunderbolt/USB-C -> Macbook Pro. That mile long dongle chain was a bit annoying but works. With my Mini M2, I'm straight into its ethernet port and its way less dongly. I'd just use the Carbon Pre for line ins and outs, is that possible? Yeah, I did notice the whole dongle debarcle. Fortunately I already have the TB3 - TB2 adapter for the MOTU and I managed to find somewhere with the Apple Gigabit Ethernet adapter. The Sonnet's like $250.00, mad.. I'm about to retire some of these dongles because I just don't need them anymore - if interested reach out - it'll be cheap. I think I have a few TB2 dongles/cables laying around.
Post by Deleted on Jan 9, 2024 9:26:55 GMT -6
The Carbon is not a DAD converter. Over ADAT, unless it is pinging the round trip latency constantly, the interface cannot know the latency of the external DA and AD converters. HDX third party converters just usually copy AVID's latency to trick the HDX interfaces.
Post by lee on Jan 9, 2024 12:54:27 GMT -6
MTRX Studio is another option. Digilink + TB3 option. You get the flexibility of DADman. DANTE and DAD’s room correction is built in, and there’s no latency hit when recording. The downside is you gotta enter the insert compensation numbers manually, but maybe this will become automated with a future firmware update, idk. 16 analog I/O and you can stack them. Pretty good value if you needs lots of analog lines.
Post by maldenfilms on Jan 9, 2024 13:24:19 GMT -6
Now that I've had some experience using the Carbon for a while, I've gotta give a big thumbs up to it.
The converters sound incredible, the ability to track without any discernible latency is amazing (especially once you've already got a session halfway through a mix and want to punch something in), and it all just works if you're using Pro Tools. I used to obsess over latency compensation and what not, and now I don't even have to think about it. Sure, you can only monitor with AAX DSP plugins on that track to take advantage of the low/"no" latency, but I never monitor through plugins anyways. If I REALLY felt the need to, I could always use one of the Avid or Plugin Alliance ones that are, and then swap them out for something else in the mix.
Post by ericn on Jan 9, 2024 14:54:03 GMT -6
The Carbon is not a DAD converter. Over ADAT, unless it is pinging the round trip latency constantly, the interface cannot know the latency of the external DA and AD converters. HDX third party converters just usually copy AVID's latency to trick the HDX interfaces. We have a winner!
Post by audiospecific on Jan 10, 2024 4:13:22 GMT -6
Now that I've had some experience using the Carbon for a while, I've gotta give a big thumbs up to it. The converters sound incredible, the ability to track without any discernible latency is amazing (especially once you've already got a session halfway through a mix and want to punch something in), and it all just works if you're using Pro Tools. I used to obsess over latency compensation and what not, and now I don't even have to think about it. Sure, you can only monitor with AAX DSP plugins on that track to take advantage of the low/"no" latency, but I never monitor through plugins anyways. If I REALLY felt the need to, I could always use one of the Avid or Plugin Alliance ones that are, and then swap them out for something else in the mix.
Latency isn't really an issue anymore unless you are running cheap hardware and I'm still running an older Dante system at 2.5 ms and before that the RME hammerfall card was good around 5ms.
I went away with protools once you had to pay for a subscription. Because there is no advantages over other DAWs anymore after 2004.
Is any of it fully functional with other DAWS? probably not. Then in a few years from now they obsolete the hardware
Post by guitfiddler on Jan 10, 2024 6:12:49 GMT -6
The only downside is when using the preamps you can’t insert analog hardware. You have to change the inputs to mic or line. I’m not a huge fan of plugins and this seems to be AVID’s answer to a better UAD interface. A sort of compromised HDX system, however you can insert hardware via the db25. I use it for analog outboard subgroup processing, no latency at all. I noticed it right away when tracking drums. The Carbon is a very nice box. I really like mine. I can’t really say anything on the MTRX. I have read articles about it and that going full out HDX which is out of my budget. If I had the budget I would’ve went full HDX, but with the I/O required, now I’m really way out of budget
Post by Deleted on Jan 10, 2024 16:24:03 GMT -6
I'm sure there's a certain element of lazyness involved here but it's nice not to have to disable all your plugs when doing overdubs, yes it's a quick key command in some DAW's but I like to hear the effect of a take within the premise of a track to see if it fits how I believe it should post. It also really helps with CUE mixes for singers etc.
I didn't use Pro Tools for years, I went with Samplitude and that is a great DAW but interface compatability & preference brought me back to MAC during an upgrade. Nowadays, even "vanilla" pro tools is much better than it used to be. All compensations work correctly, it's really simple to use IMO, comes with a metric ton of stuff and I even like the midi editing in it. Also I always find discounts on perpetual licenses so I've never bothered with subs..
When it comes to music creation as a whole I stick with whatever gets me there the fastest, that doesn't mean it'll get someone else there faster but they can't make my music for me.
Post by Deleted on Jan 15, 2024 20:48:39 GMT -6
Right, let me start again. Here's ShadowK's usual unabashed very opinionated first impressions.
Firstly the sound.. I seem to be hopeful that one of these modern converters is going to rock my socks off but the Carbon sounds like a slightly brighter if not a bit more clearer version of my MOTU 1248, it's pretty much on par with the Aurora and simply put nothing to see here. It doesn't annoy me like one certain converter so that's fair enough, I will say the SSl Big Six sounds better than both of them but even then it's not game changing.
I must say though that said Carbon is a powerful device, I had to drop my speakers inputs by 24dB and the headphone amps on the Carbon are probably the best I've heard period.
Anyway, this actually spurred me on to fix the SSL's hissy L channel and because of that things have changed slightly. Instead of selling the SSL I'm now going to incorporate it into my setup, use the Carbon for tracking and initial mixes then use the SSL as an "insert" to mix with. Next up, as this is an Avid & Apple device the costs don't stop at just the interface, you will need some DB25's (I spoke with the stellar people at Lynx Custom to get these) plus either the expensive Sonnet or something like an Apple TB3 > TB2 > Ethernet dongle however you do get Pro Tools Ultimate PLUS a one year sub included and some free plugs. If you look at the cost of a HDX PCI-E plus Ultimate perpetual it seems like bargain of the year in comparison even if it's not.
When it comes to the DSP well I've seen a lot of great plugs available in AAX DSP and even if it is "dead" I don't believe it matters. Let's face it the Carbon suits a very niche market where you want time aligned HW inserts for Pro Tools and some DSP for tracking or overdub purposes. When it comes to final mixes then there's a lot of competition but for tracking I don't believe the Carbon can be beat. It does appear truly latency free due to the mixer being extended to the devices DSP architecture itself and there's a level of consistency when playing that's impressive.
This doesn't apply to VI's though but in that instance there's only output latency to be concerned with, after some testing with NI synths plus a kit or two there's no issues, the problem is going to come down to guitar players using VST's which requires a full round trip. If you do decide to go Carbon then you might want to consider an Axe FX or IK Tonex but if you can afford a Carbon then it's not an issue really is it?
All in it's a great device and certainly has advantages but you'd have to be a Pro Tools fan and want like me to use plugins to emulate a final mix to fill in the gaps. Otherwise the SSL will pretty much do the exact same job if you have some external HW and another DAW. The one defining factor is overdubs, however I got away with about 30 plugs before the Carbon reached its DSP limit so a final mix would still have to be considered carefully.
Post by subspace on Jan 16, 2024 13:44:44 GMT -6
I spent MLK day wiring my two Carbons into the patchbay, four Dsubs normalled to the Trident's channel inputs and bus outputs. Had been mainly using the primary Carbon's monitor outs to feed the monitor controller and the line i/o for inserts, but wanted a default tracking patch where all the inputs come up on a fader on the desk with sub-ms latency. Man it's nice to get back to working like that, can really hammer the Trident's line in gains for drum shells/speaker cones with the Carbon outs.
Post by guitfiddler on Jan 16, 2024 18:47:33 GMT -6
It would be really cool to have a Carbon/Protools thread on going
Post by Deleted on Jan 16, 2024 18:54:19 GMT -6
It would be really cool to have a Carbon/Protools thread on going Yeah, I might start a new one.. There's plenty to talk about at least when it comes to Carbon, even from a plugin side.
Post by Deleted on Jan 22, 2024 18:09:06 GMT -6
Updated on last page, testing done and we're all good.
Post by wiz on Jan 22, 2024 18:31:38 GMT -6
Sorry but, after a lot of testing the SSL is just so much better sounding than the Carbon it's not even funny. They put $100K's worth of live tech in it? Yeah I believe, at this point I'm half tempted to return the Carbon and choose a new DAW.. Whatever works. For those who think it's a cheap chinese board, please continue to shoot yourself in the foot by thinking that.
Yeah, I also bet the SSL as a mixing desk screw's the signals in ways only SSL engineers comprehend but it sounds wide, clear and euphoric as heck so ahh well and I've heard many a boring desk or console in my time. This ain't one of them..
Sure, if I didn't have to repair or replace bits of the SSL every six months I'd be delighted but it's proving once again to be the thing to beat. Johnkenn , I'd be interested in your opinions on this as it's beaten out everything I have thus far.
If you think for a second I don't actually buy and test this stuff, well, sorry for the state of my studio but here's some proof.
Any chance of hearing the two Mixes? Cheers Wiz
