Post by paulcheeba on Feb 10, 2024 23:32:27 GMT -6
I use the New Fangled plugs on percussive buses before I go OTB into my desk and it helps build up the volume in a healthy way than just putting one on the 2 bus and having it all collapse. I find they’re great plugs with lots of unique effects. I lreally like Acustica stuff if I’m mixing in the box. When I’m OTB I use a crazy chain of a Fairchild, Vertigo VCS, Knif Soma, Avalon or Sontec through a Liason that ends in a MAS then the Bettermaker limiter finally followed by a Rockruepel limiter into a Dangerous converter which is a dual mixing and mastering chain. Leaving no need for plug ins after.
Post by Johnkenn on Feb 11, 2024 10:57:51 GMT -6
Damn…I don’t think I’ve ever got a mix to have an RMS above -12… I’m sure that’s pre mastering though.
Post by Ted Swan on Feb 19, 2024 17:31:23 GMT -6
I have such a "mildly like / strongly hate" relationship with clippers.
I'm pretty sure I have most of them. I often end up feeling like a great limiter just sounds better doing its thing at high reduction versus getting some help from a clipper before it. That's probably not a popular opinion, but maybe since I typically mix into something like the Pro-L 2, I just get used to setting my levels in a way that it just works for me. Often a clipper before it just does things to the transients that doesn't ever feel like actual free headroom. I'm talking software clippers.
However, I've come to really really love the new UA Capitol Mastering Compressor which has a stock preset called something like Clip Capitol Converters. I don't know wtf I'm doing with this plugin. It kind of feels like the inputs and outputs are placed in weird positions. But I do know that if I add a trim before it to drive it, and a trim after to compensate, I can get some actual clipping that gives me some level, and some color that sounds super robust and like a record. I'm in love with it at the moment. If the compressor gets engaged from the input volume, it's easy enough to adjust the threshold, or keep the compression!
Post by Johnkenn on Feb 20, 2024 16:02:08 GMT -6
And after all this...I put IK Stealth (as my last limiter like I've usually done) and lo and behold - it sounds better than Ash. At least in this instance. Ash makes it louder, but Stealth has the Harmonic things that just makes it thump a little more. I'm sure it's a case by case basis.
Post by kcatthedog on Feb 21, 2024 11:20:44 GMT -6
Post by Dan on Feb 21, 2024 11:32:58 GMT -6
The new Softube Clipper is good. Like most Softube plugs excepting the Weiss and the effects, it is targted at VSTi musicians and unsuitable for mastering or multi-miced recordings with over a thousand degrees of phase shift from minimum phase anti-alias filters.
Post by Shadowk on Feb 21, 2024 12:10:58 GMT -6
I just use the clipper section in Tokyo Dawn's Limiter GE, does the job well.
Post by sentientsound on Feb 21, 2024 13:28:09 GMT -6
I'm still using Newfangled Saturate on tracks, Gold Clip on drum and music busses, and Limiter 6 GE sometimes for the LF Clip mode. Gold Clip can be cool abused in parallel too, although I just started trying that.
ASH is good but the soft/hard knee dial and metering feel off to me. Plus there's a bit of option paralysis with so many curve choices. I gotta say the clipping action is super clean when using the higher AA oversampling modes but they add a sublte change in tone/image presentation. It sometimes makes pop and electronic music sound more finished to me compared to other clippers.
OTB I'm feeling spoiled with a Hum Audio LAAL into a Lavry Savitr which can get a ton of level without much sacrifice.
BTW Schwabe Digital has a new clipper tentatively coming next month based on the FL clipper for intentionally colored processing.
Post by nicksteinborn on Feb 22, 2024 0:24:56 GMT -6
I've really been liking Flatline 2 in hybrid mode as my final loudness smasher. I tend to run Standard Clip or Flatline 1 doing a few db of clipping on the transients into Flatline 2 on hybrid. I try to get my mixes to a point that I only need to hit that final limiter with a db or two to get things rippin. Also used the original Flatline quite a bit. Probably should've went with K-clip for more variety in the clipping algos, but happy to have Flatline 2. I don't know why I still open Flatline 1 for straight clipping when I use it. I assume they're similar/the same sounding. Most clippers with a basic shape adjustment seem to null so they're all pretty interchangeable.
Post by kcatthedog on Feb 22, 2024 1:02:17 GMT -6
Thx, so what is your target for your final level ?
Post by nicksteinborn on Feb 22, 2024 2:13:09 GMT -6
Minimum -10 for a quick rough or something which half the time is barely hitting on my final limiter. For a final, I tend to try to get stuff sitting in the -8 to -6 LUFS range. This is for louder somewhat modern sounding rock/metal/punk-ish stuff.
Post by kcatthedog on Feb 22, 2024 3:48:58 GMT -6
Thank, just demoing the flatline2 and haven’t used a clipper before.
Finding less is more: I like the clipper, kinda raises the overall texture of the song, mo cravitus, but think I prefer my fab filter limiter, cleaner?
Post by kcatthedog on Feb 22, 2024 4:02:58 GMT -6
I just use the clipper section in Tokyo Dawn's Limiter GE, does the job well. @shadow thx: this looks great! Hey, wait is our Dan, this Dan ? !
Post by Shadowk on Feb 22, 2024 4:36:54 GMT -6
I just use the clipper section in Tokyo Dawn's Limiter GE, does the job well. @shadow thx: this looks great! Hey, wait is our Dan, this Dan ? Nope, will people stop confusing us just because we're both called Dan and like Tokyo Dawn?
Post by kcatthedog on Feb 22, 2024 5:28:09 GMT -6
@shadow thx: this looks great! Hey, wait is our Dan, this Dan ? Nope, will people stop confusing us just because we're both called Dan and like Tokyo Dawn? but I thought you looked so fetching in your Tokyo Dawn outfit ! Anybody used fab filter like this:
Post by jaba on Feb 22, 2024 6:34:27 GMT -6
@shadow thx: this looks great! Hey, wait is our Dan, this Dan ? Nope, will people stop confusing us just because we're both called Dan and like Tokyo Dawn? And here I thought TDR stood for "Tokyo Dans on RGO"
Post by kcatthedog on Feb 22, 2024 6:39:49 GMT -6
^^THIS^^
Post by Dan on Feb 22, 2024 7:55:08 GMT -6
Most brick wall limiters are combination ramped volume modulators and clippers anyway. Choose a decent one like tdr limiter 6 ge (choose your own adventure limiter), ursa boost (incredibly cool but can get pumpy), pro l 2 (mostly a clipper to me), psp xenon (has long lookahead and really smooth just don’t use a and use the higher quality options), weiss ds1 plugin (more powerful than the maximizer if you know how to set with the new limiter modes but more distorted hyper aggressive peak limiter if you want the turd master) which all offer control over the lookahead and peak clipping/limiting and have fun. They’re much more powerful than naive clippers but the clippers can still be cleaner than the shit limiters.
I should add that though that too long lookaheads prevent the volume modulator part from compressing anything because it cannot move faster than the frequencies in the signal and then they just run everything up into a clipper. Reduce the lookahead of these limiters and you will reveal them for what they are: really shitty compressors so smoothed out attack wise they pump that run into clippers and many of them aren’t any better than waves l2 except for being multiband monstrosities with different behavior when triggered by different bands. They can’t detect the sharp peaks of the signal to run into the clipper anyway. They’re mostly just distortion plugins like waves l1 and l2 more than any effective peak limiter like an 1176 or other fet limiter, apogee soft limit hardware option, or a speaker protection circuit (usually a combo of super fast vca rms compressor and peak clipper).
The ones that are crazy colored distortion machines like Oxford Limiter (so fast bass is distorted and then the enhance/safe mode mode is inflator for transients), Eventide Elevate (just sounds like a fizzy guitar amp if you enable the program dependency and multiband behavior and the wave shaper at the end is lol), or Ursa Boost (hear it distort everything at 2ms lookahead and pump around like crazy at 40 ms and then the ways to shape the sound are pretty cool and you can control what hits it to clean it up or crap up the sound if you want) are more fun but still sledgehammers and end up as shitboxes or crazy colored bus processors.
Now try a mastering or really any cleaner compressor that’s functional at 1-2 ms attack and these are piece of shit. Weiss ds1, Kotelnikov, Unisum, dc8c3 on highest quality settings, almost any hardware fet/vca/pwm compressor better than a 3630 even cheap stuff and Most of these limiters are pretty trashy and pumpy.
Post by kcatthedog on Feb 22, 2024 9:00:05 GMT -6
Thx Dan, guess, you do share eloquence with that other Dan, what about the cultured Brit accent ?!
Post by ragan on Feb 22, 2024 10:43:35 GMT -6
@shadow thx: this looks great! Hey, wait is our Dan, this Dan ? Nope, will people stop confusing us just because we're both called Dan and like Tokyo Dawn? I think he meant is the other RGO Dan (noted lover of Tokyo Dawn) also Dan Worrall (the narrator).
Post by ragan on Feb 22, 2024 10:46:45 GMT -6
I don’t think I’ve ever tried the Tokyo Dawn limiter. Probably about time I did.
Post by Dan on Feb 22, 2024 11:34:47 GMT -6
I don’t think I’ve ever tried the Tokyo Dawn limiter. Probably about time I did. it's good. I mostly use the high frequency limiter module in it but the "limiter" part of it is best as a pure peak limiter ime. turn on insane quality and you can hear how the longer lookaheads smooth out and soften the sound and shorter ones grit up bass but even 3x doesn't really let you hit the excessively long times of other limiters where they start ramping down the volume long before the peaks. You have to build your own volume maximizer with the various modules though.
Post by mcirish on Feb 22, 2024 15:27:07 GMT -6
I've had the TDL limiter GE for a long time but I've never even used it. When I need clipping, I just tend to grab Standard Clip and set it to 4x-8x and I'm happy. I think I have bought at least a half dozen clippers in the last year or so. I only ever use them to control drums and percussion. I don't know why I keep buying stuff I'm never going to use. I could have paid for a very nice vacation with all the money I wasted on things I haven't even used in a session. It's a sickness. I think most of us have it here.
Post by Shadowk on Feb 22, 2024 16:35:48 GMT -6
I've had the TDL limiter GE for a long time but I've never even used it. When I need clipping, I just tend to grab Standard Clip and set it to 4x-8x and I'm happy. I think I have bought at least a half dozen clippers in the last year or so. I only ever use them to control drums and percussion. I don't know why I keep buying stuff I'm never going to use. I could have paid for a very nice vacation with all the money I wasted on things I haven't even used in a session. It's a sickness. I think most of us have it here. Well use it and see how it goes .. I limited myself to UAD and TDR so there's no waste or confusion. Rest is outboard..
