Post by bikescene on Dec 25, 2023 14:29:28 GMT -6
I am planning on wiring up an XLR patch panel, and found some Gepco 61801EZ install-grade cable that I never used.
I’ve only dealt with regular thickness balanced cable before. Are there any good practices with heat shrinking/strain relief onto XLR/TRS connectors?
Post by ericn on Dec 25, 2023 14:47:09 GMT -6
Other than the fact that it’s going to be stiffer, pretty much the same.
Post by audiospecific on Dec 25, 2023 21:04:05 GMT -6
I am planning on wiring up an XLR patch panel, and found some Gepco 61801EZ install-grade cable that I never used. I’ve only dealt with regular thickness balanced cable before. Are there any good practices with heat shrinking/strain relief onto XLR/TRS connectors?
works best with Neutrick xlr nc3 type if you making patch cables with them.
