Post by Tbone81 on Nov 23, 2023 12:23:34 GMT -6
I got hired for a location sound gig, coming up in about two weeks. Among other things, my job is to help my videographer partner to buy/rent a proper audio rig. I need some recommendations on workhorse gear for on location audio.
The only thing I already have is a Zoom H6 handheld recorder, and one of those cheap-ish rode camera mics (which is pretty decent, at least for sync capabilities).
I need a shotgun mic, a pair of lav mics and any other accessories to go with it (wind screens etc).
Looking at the MKH 416 and have no idea what to use for lav mics.
I need pro, broadcast quality sound. We may have to rent for this shoot but the goal is to buy something for long term.
Any recommendations?
Edit: should I look for a T powered mic?
Post by notneeson on Nov 23, 2023 12:58:48 GMT -6
I got hired for a location sound gig, coming up in about two weeks. Among other things, my job is to help my videographer partner to buy/rent a proper audio rig. I need some recommendations on workhorse gear for on location audio. The only thing I already have is a Zoom H6 handheld recorder, and one of those cheap-ish rode camera mics (which is pretty decent, at least for sync capabilities). I need a shotgun mic, a pair of lav mics and any other accessories to go with it (wind screens etc). Looking at the MKH 416 and have no idea what to use for lav mics. I need pro, broadcast quality sound. We may have to rent for this shoot but the goal is to buy something for long term. Any recommendations? Edit: should I look for a T powered mic? By far the worst sounding rigs used in that world are the wireless lavs, but they’re a necessity if you have to shoot walk and talks without a boom operator (and even then it seems to be standard to use both). The Sennheiser shotguns have an immediately recognizable “broadcast” sound. They will sound completely passable into your Zoom. I did a shoot with a Rode shotgun into one of those Zoom recorders that came out great. I have some Shure lavs, but it seems like DPA makes the really good ones. Beware of long beards when pinning the lavs to talent! 😅
Post by enlav on Nov 23, 2023 13:35:01 GMT -6
A lot will depend on the nature of the shoot, if you're going to need or be a dedicated boom op, or if you can rely on fixed c stands (interview style).
If this is primarily indoors, I'd also look at cards and hyper cards. Not to say a shotgun can't get the job done, but sometimes a 416 in particular will sound odd with cramped and echoic spaces. I've never been a good op, even when I have the script in advance. Sometimes a cardioid in tighter shots will not only sound better but help cover up a delayed turn or tilt.
Having a 416 regardless is great though. Easy to replace in emergency situations (rent), and also works for ADR in post.
Unless the lineup has improved significantly, I would steer away from the H series Zoom stuff. F series at least, but otherwise buy or rent Sound Devices.
Lavs and wireless are another can of worms. My kit was primarily sennheiser body packs and sanken cos11d's. Sometimes we'd use DPA for specific purposes like hiding mics in the frame.
If you need a boom pole, dont skimp on the pole and mount.
Some quick thoughts in-between holiday conversations. Can provide more another day.
Post by Tbone81 on Nov 23, 2023 14:18:52 GMT -6
A lot will depend on the nature of the shoot, if you're going to need or be a dedicated boom op, or if you can rely on fixed c stands (interview style). If this is primarily indoors, I'd also look at cards and hyper cards. Not to say a shotgun can't get the job done, but sometimes a 416 in particular will sound odd with cramped and echoic spaces. I've never been a good op, even when I have the script in advance. Sometimes a cardioid in tighter shots will not only sound better but help cover up a delayed turn or tilt. Having a 416 regardless is great though. Easy to replace in emergency situations (rent), and also works for ADR in post. Unless the lineup has improved significantly, I would steer away from the H series Zoom stuff. F series at least, but otherwise buy or rent Sound Devices. Lavs and wireless are another can of worms. My kit was primarily sennheiser body packs and sanken cos11d's. Sometimes we'd use DPA for specific purposes like hiding mics in the frame. If you need a boom pole, dont skimp on the pole and mount. Some quick thoughts in-between holiday conversations. Can provide more another day. Thanks, that’s very helpful. Most of the shoots are documentary style interviews, but we need to be flexible. Shots could be indoors, out doors, noisy environments, controlled studio spaces etc. That’s one of the reasons I’m not sure where to start. This is mostly corporate work but there is a little spill over into more artsy/indie videography/film making I know of the MKH 416 as being somewhat of a “standard”, so I’m guessing I can’t go wrong with one. In the past I’ve used nice handheld dynamics, Beyer m88 etc, and they’re great but I need something more purpose built for this application. We used a Beyer mc930 sdc last shoot and it just picked up way too much of the room, and it was a noisy environment. Dealing with it in post was a bitch. I’ll most likely have to stick with zoom H6 for now, but the next shoot will probably grant us a budget for a better field recorder. I’ll likely be renting half the kit for this shoot and then slowly buying the pieces we need for long term growth. Right now though the shotgun mic is a priority with the lav mics a not so close second.
Post by ericn on Nov 23, 2023 14:28:14 GMT -6
Shotguns are over used, even the Neumann Sennheiser and Sanken suffer from the fact that the lobe pattern is created by using a second element that is out of phase with input from the sides. The secret of the best film and TV sound guys is going to seam like a contradiction to everything you know Omni! On the boom pole or when it comes to lavs your talent is going to never be on axis for more than a second, so the linear phase and frequency response off axis will make you look like a genius. Omni lavs all have an HF boost get to know it , use it to your advantage. Also Omni means no proximity effect, even shotguns suffer from proximity effect, with moving talent always a problem. Most people don’t understand that on high budget projects most of the dialogue is recorded in ADR, the set audio is more of a guide.
Post by Tbone81 on Nov 23, 2023 16:25:06 GMT -6
Shotguns are over used, even the Neumann Sennheiser and Sanken suffer from the fact that the lobe pattern is created by using a second element that is out of phase with input from the sides. The secret of the best film and TV sound guys is going to seam like a contradiction to everything you know Omni! On the boom pole or when it comes to lavs your talent is going to never be on axis for more than a second, so the linear phase and frequency response off axis will make you look like a genius. Omni lavs all have an HF boost get to know it , use it to your advantage. Also Omni means no proximity effect, even shotguns suffer from proximity effect, with moving talent always a problem. Most people don’t understand that on high budget projects most of the dialogue is recorded in ADR, the set audio is more of a guide. Im wondering if a cardiod or super cardiod as good all rounder? I’m looking at the Sanken cs-1e. Most of the uses will be indoors, and a lot of it will be interview style, either boom or c stand.
Post by nudwig on Nov 23, 2023 17:48:36 GMT -6
Sennheiser 416, Sanken Omni lavs into Zaxcom self recording body packs (with a great lock to their receiver), and Sound Devices were my bread and butter over the shoulder kit back when I did location sound. Especially the Zaxcom’s as at least here in LA the bands were always getting more and more crowded and having those discrete recordings saved me on many shoots. I’m guessing the gigs I did are closer to what you’ll be doing but if Hunter is still on here he can fill you in on what the big dogs currently use.
Post by ericn on Nov 23, 2023 17:53:52 GMT -6
Shotguns are over used, even the Neumann Sennheiser and Sanken suffer from the fact that the lobe pattern is created by using a second element that is out of phase with input from the sides. The secret of the best film and TV sound guys is going to seam like a contradiction to everything you know Omni! On the boom pole or when it comes to lavs your talent is going to never be on axis for more than a second, so the linear phase and frequency response off axis will make you look like a genius. Omni lavs all have an HF boost get to know it , use it to your advantage. Also Omni means no proximity effect, even shotguns suffer from proximity effect, with moving talent always a problem. Most people don’t understand that on high budget projects most of the dialogue is recorded in ADR, the set audio is more of a guide. Im wondering if a cardiod or super cardiod as good all rounder? I’m looking at the Sanken cs-1e. Most of the uses will be indoors, and a lot of it will be interview style, either boom or c stand. The Sanken is a great mic, but what you have to understand is the advantage of Omni is the fact that the mic has the same phase and frequency response off axis, your not moving a boom to capture each voice, and with Lavs a head turn or body movement won’t be noticeable. I know I cardiods get it when Jonathan Lipp the founder of Full Compass was preaching it till I did a musical with over heads and 12 wireless lavs. Started out with cardiods, then switched to omnis and suddenly no matter where someone stood, how the moved didn’t matter and even the monitors required less EQ because no matter the angle same response! Applied it to a couple of video shoots, it was probably the biggest lesson J Lipp taught me in audio. It even applies to vocalist in the studio. I have even used this knowledge on instruments when you can hear the player moving around. Can’t tell you how many times I have been at a session switched a mic to Omni and looked like a genius. I do love Sanken though, been lusting after a lot of used COS-11D’s for the wireless system. One other tip with wireless remember digital wireless means latency so your going to probably have to offset your sync a bit, been noticing this issue all over broadcast TV lately.
Post by Tbone81 on Nov 23, 2023 18:34:01 GMT -6
Im wondering if a cardiod or super cardiod as good all rounder? I’m looking at the Sanken cs-1e. Most of the uses will be indoors, and a lot of it will be interview style, either boom or c stand. The Sanken is a great mic, but what you have to understand is the advantage of Omni is the fact that the mic has the same phase and frequency response off axis, your not moving a boom to capture each voice, and with Lavs a head turn or body movement won’t be noticeable. I know I cardiods get it when Jonathan Lipp the founder of Full Compass was preaching it till I did a musical with over heads and 12 wireless lavs. Started out with cardiods, then switched to omnis and suddenly no matter where someone stood, how the moved didn’t matter and even the monitors required less EQ because no matter the angle same response! Applied it to a couple of video shoots, it was probably the biggest lesson J Lipp taught me in audio. It even applies to vocalist in the studio. I have even used this knowledge on instruments when you can hear the player moving around. Can’t tell you how many times I have been at a session switched a mic to Omni and looked like a genius. I do love Sanken though, been lusting after a lot of used COS-11D’s for the wireless system. One other tip with wireless remember digital wireless means latency so your going to probably have to offset your sync a bit, been noticing this issue all over broadcast TV lately. You’ve convinced me to go with Omni lavs for sure. Seems to make perfect sense. Still debating the pros and cons with a boom/shotgun mic. The Sanken cs-1e looks great. And even the Rode NTG3 seems to be highly praised. I’m almost thinking of grabbing a decent/rugged Omni sdc and a shotgun mic…figure that would cover most of my bases and allow us to really run and gun when shooting. That way I’d have a more rugged mic for outdoor shots and a nicer sounding Omni for more controlled environments. Idk…does that sound stupid? Maybe a Shure ksm141 or similar?
Post by Tbone81 on Nov 23, 2023 18:40:10 GMT -6
Sennheiser 416, Sanken Omni lavs into Zaxcom self recording body packs (with a great lock to their receiver), and Sound Devices were my bread and butter over the shoulder kit back when I did location sound. Especially the Zaxcom’s as at least here in LA the bands were always getting more and more crowded and having those discrete recordings saved me on many shoots. I’m guessing the gigs I did are closer to what you’ll be doing but if Hunter is still on here he can fill you in on what the big dogs currently use. Thank you! That’s incredibly helpful, looking into those Zazcoms right now.
Post by ericn on Nov 23, 2023 18:56:59 GMT -6
The Sanken is a great mic, but what you have to understand is the advantage of Omni is the fact that the mic has the same phase and frequency response off axis, your not moving a boom to capture each voice, and with Lavs a head turn or body movement won’t be noticeable. I know I cardiods get it when Jonathan Lipp the founder of Full Compass was preaching it till I did a musical with over heads and 12 wireless lavs. Started out with cardiods, then switched to omnis and suddenly no matter where someone stood, how the moved didn’t matter and even the monitors required less EQ because no matter the angle same response! Applied it to a couple of video shoots, it was probably the biggest lesson J Lipp taught me in audio. It even applies to vocalist in the studio. I have even used this knowledge on instruments when you can hear the player moving around. Can’t tell you how many times I have been at a session switched a mic to Omni and looked like a genius. I do love Sanken though, been lusting after a lot of used COS-11D’s for the wireless system. One other tip with wireless remember digital wireless means latency so your going to probably have to offset your sync a bit, been noticing this issue all over broadcast TV lately. You’ve convinced me to go with Omni lavs for sure. Seems to make perfect sense. Still debating the pros and cons with a boom/shotgun mic. The Sanken cs-1e looks great. And even the Rode NTG3 seems to be highly praised. I’m almost thinking of grabbing a decent/rugged Omni sdc and a shotgun mic…figure that would cover most of my bases and allow us to really run and gun when shooting. That way I’d have a more rugged mic for outdoor shots and a nicer sounding Omni for more controlled environments. Idk…does that sound stupid? Maybe a Shure ksm141 or similar? Honestly for Omni start with a simple Dynamic ENG mic like a 635a or RE50. I only recently upgraded to a Sennheiser ME62 capsule to use with the K6 that came with my used ME66.
Post by spindrift on Nov 23, 2023 20:55:00 GMT -6
When running handheld booms, I’ve always opted for the RCA 44BX.
Post by nudwig on Nov 23, 2023 21:04:20 GMT -6
Sennheiser 416, Sanken Omni lavs into Zaxcom self recording body packs (with a great lock to their receiver), and Sound Devices were my bread and butter over the shoulder kit back when I did location sound. Especially the Zaxcom’s as at least here in LA the bands were always getting more and more crowded and having those discrete recordings saved me on many shoots. I’m guessing the gigs I did are closer to what you’ll be doing but if Hunter is still on here he can fill you in on what the big dogs currently use. Thank you! That’s incredibly helpful, looking into those Zazcoms right now. I forgot to mention for my stick mic I'd use the AT 813a. Surprisingly good, especially in loud conventions/sporting events.
Post by the other mark williams on Nov 23, 2023 21:45:33 GMT -6
I generally prefer to have a shotgun for outdoor or big, high-ceilinged spaces. The Sennheiser 416 is a classic for a reason. Some people don't like them these days, but I still do. I actually opted for the Rode NTG3 over the 416 personally, because it sounds very, very similar, but the Rode has a slightly larger "sweet spot" that I personally find a bit more forgiving. (The counter argument to that would be that it's not quite as tight or focused as the 416, but I haven't found that to be a problem personally.) Both the 416 and the NTG3 are RF condensers, so they keep working even in very humid conditions. And the Rode is a little lighter physically.
For indoors in more normal rooms, I like a tighter cardioid generally over a shotgun. Something like the Sennheiser MKH50. If the room is really quiet and you're trying to pick up two people sitting next to one another on a couch, you can even go with a wide cardioid.
Agreed that omni lavs are a good idea to put on talent.
Zaxcom body packs are great but out of my price range, so I use a Rode Wireless Go II, though the new Wireless Pro is an even better option. Even if there are dropouts on the 2.4GHz broadcast to camera, everything gets recorded to the internal transmitters, so you're covered there. The new Wireless Pro actually records in 32-bit float, so you don't have to worry about clipping at the record stage.
I also wouldn't personally want to use a Zoom H6 -- I have before, but it's a pretty big compromise IMO. The pres aren't very good, it's kind of noisy, but maybe even more importantly, it doesn't have many great power options (IMO). If you like Zoom, the F6 is far, far superior, and can be run off of NPF batteries. I have an F6 as a backup to my Sound Devices MixPre 6 II. I like both of those units a lot, actually, and they both can record 32-bit float, as well.
I would also ask the director what they want to do about timecode. Are they planning to rely on audio sync in post? Or do they want dedicated timecode? If dedicated timecode, that's a whole 'nother set of things to think about.
You mentioned the problem in the past with extraneous noise on the external mic pickup. That's definitely always a concern, and you're right to think first of what mics might best help mitigate that. But you'll also probably end up spending time cleaning up some things in post regardless. I use a little bit of everything: iZotope RX, Acon Digital, CrumplePop, Hush Audio (one of the very best, IMO), and even the voice isolation plugins in the NLE. I'm primarily a Final Cut user these days, and the latest included voice isolation is actually very good IMO - oftentimes it's all I need. Oh, and quite a few people like the Waves Clarity Vx plugin.
Regardless of all the above, exciting news that you're working on this project! I have really grown to love production audio for picture over the past few years -- it's exciting (usually non-boring) work, and it's fun to be a part of a creative team all working to make the best production possible within all the insane limits faced in a video-centric environment. Congrats!
Post by Tbone81 on Nov 23, 2023 22:27:32 GMT -6
I generally prefer to have a shotgun for outdoor or big, high-ceilinged spaces. The Sennheiser 416 is a classic for a reason. Some people don't like them these days, but I still do. I actually opted for the Rode NTG3 over the 416 personally, because it sounds very, very similar, but the Rode has a slightly larger "sweet spot" that I personally find a bit more forgiving. (The counter argument to that would be that it's not quite as tight or focused as the 416, but I haven't found that to be a problem personally.) Both the 416 and the NTG3 are RF condensers, so they keep working even in very humid conditions. And the Rode is a little lighter physically. For indoors in more normal rooms, I like a tighter cardioid generally over a shotgun. Something like the Sennheiser MKH50. If the room is really quiet and you're trying to pick up two people sitting next to one another on a couch, you can even go with a wide cardioid. Agreed that omni lavs are a good idea to put on talent. Zaxcom body packs are great but out of my price range, so I use a Rode Wireless Go II, though the new Wireless Pro is an even better option. Even if there are dropouts on the 2.4GHz broadcast to camera, everything gets recorded to the internal transmitters, so you're covered there. The new Wireless Pro actually records in 32-bit float, so you don't have to worry about clipping at the record stage. I also wouldn't personally want to use a Zoom H6 -- I have before, but it's a pretty big compromise IMO. The pres aren't very good, it's kind of noisy, but maybe even more importantly, it doesn't have many great power options (IMO). If you like Zoom, the F6 is far, far superior, and can be run off of NPF batteries. I have an F6 as a backup to my Sound Devices MixPre 6 II. I like both of those units a lot, actually, and they both can record 32-bit float, as well. I would also ask the director what they want to do about timecode. Are they planning to rely on audio sync in post? Or do they want dedicated timecode? If dedicated timecode, that's a whole 'nother set of things to think about. You mentioned the problem in the past with extraneous noise on the external mic pickup. That's definitely always a concern, and you're right to think first of what mics might best help mitigate that. But you'll also probably end up spending time cleaning up some things in post regardless. I use a little bit of everything: iZotope RX, Acon Digital, CrumplePop, Hush Audio (one of the very best, IMO), and even the voice isolation plugins in the NLE. I'm primarily a Final Cut user these days, and the latest included voice isolation is actually very good IMO - oftentimes it's all I need. Oh, and quite a few people like the Waves Clarity Vx plugin. Regardless of all the above, exciting news that you're working on this project! I have really grown to love production audio for picture over the past few years -- it's exciting (usually non-boring) work, and it's fun to be a part of a creative team all working to make the best production possible within all the insane limits faced in a video-centric environment. Congrats! Bro, this is solid gold here. Thank you, 🙏 much appreciated. I was leaning towards the NTG3 already, based off reviews, so I think I’ll probably go that direction. I might have to rent the lavs, not sure what our equipment budget is, but I’ll look into those body packs. Yeah I hear ya on the Zoom H6, but it’s what I got so that’s that….until the next shoot maybe when we can buy more gear. I’ll have to pick your brain in the near future regarding restoration software. I use izotope RX and it worked for the last shoot, but goddam it wasn’t fun. It was an interview in a Diner and there was a range hood that was crazy loud. It worked out, but barely. But I wasn’t doing sound on that gig, I just did the post. I guess I got to work on my chops lol.
Post by Blackdawg on Nov 24, 2023 2:15:28 GMT -6
Ahh production audio. One of the most underrated black arts in audio. I love doing it.
If your renting, heres what I'd get.
Mixpre6 II DPA4017a for your mic. Sounds way better than a 416 and can work indoors and outdoors really well. Get wind protection(a ryocote blimp) and dead cat to go with it. DPA4060a for the lavs. Very small, easy to hide, and sound better than anything else out there.
You'll need microdot adapters to whatever transmitters you want to us(Sennheiser/LEctor/Shure/Wiseycom)
Im a Lectrosonics guy personally.
You may want to get a Timecode unit to sync stuff, a mixpre 6II can generate Timecode or recieve it. You'll also need the correct cabling to do this with the right device you pick. VERY important.
In more shoots, Audio is responisble for sync. That means you're responisble for making sure the camera gets a feed from you and timecode. You really need to know the camera being used to do this well and how they plan to shoot it. This will drive your gear choice be it a wireless timecode and audio hop setup, or if you can just cable it. obviously one is much cheaper and takes less coordination with gear choice, cabling, power, and wireless coordination.
Post clean up tools are SCARY good now. In the last year alone the voice cleaning software area has been flooded with good options. But, please don't lean on that crutch. As a Production mixer and Post mixer, it pays BIG to have clean audio up front(just like music). Especially when it comes to time. But if you have to use those tools, don't get carried away and over cook. Very tempting too.
My other tip is obviously to get this all days before the shoot and get comfortable with it and check it all works how you want it to. Nothing is worse than stalling a shoot over not having one small cable or something.
AND practice hiding your lavs. This is a skill that takes years of just practice to get consistent good results to hide lavs that sound good and don't generate noise. So be sure to practice that. Also mounting lavs comes with its own assortment of accessories(tapes, mole skins, concealers, furs, stickies, ect).
Post by enlav on Nov 24, 2023 11:22:19 GMT -6
Plenty of great advice since my last post so I'll just add some comments and afterthoughts: Regarding Omni vs. Directional Lavs - Unless you have some specific purpose or situation for the directional lavs, I would always go omni. It allows for (generally) more flexible placement and positioning of the microphone. Body pack recorders are also an excellent point from Nudwig - I know of some low budget filmmakers that have foregone wireless entirely for the sake of saving a penny. Just be sure to slate/clap often... Wireless Notes - Nudwig, notneeson and Blackdawg all have great points I want to further emphasize. - Bad wireless is literally the worst. Bad/noisy companders, noisy transmission, constant fear of dropouts or interference. If you can't afford to use decent kits, or if you're shooting in a particularly troublesome wireless environment, self-recording body packs can be godsends, but be sure to slate/clapperboard often (redundant advice). I haven't done much since auto-sync software has made some big strides in availbility, but I imagine it's not fool proof yet, so plan accordingly. If you like Zoom, the F6 is far, far superior, and can be run off of NPF batteries. I have an F6 as a backup to my Sound Devices MixPre 6 II. I like both of those units a lot, actually, and they both can record 32-bit float, as well. I'm in love with that F6 now. The fact you can just load it into a fanny pack style case (assuming it doesn't pull your pants down) makes my back/shoulders feel better already. AND practice hiding your lavs. This is a skill that takes years of just practice to get consistent good results to hide lavs that sound good and don't generate noise. So be sure to practice that. Also mounting lavs comes with its own assortment of accessories(tapes, mole skins, concealers, furs, stickies, ect). Quoted to further emphasize. Even in instances where mics can be shown, certain garments/clothing really dont't allow for a good way to attach a lav, and in those cases, it can be better to just hide it anyways.
When running handheld booms, I’ve always opted for the RCA 44BX. I once used an AT4050 for a very particularly troublesome room against the advice of a mentor. I thought "Well, they boomed HUGE/heavy mic's back in the day on set, so this can't be that bad... right?"
Post by ericn on Nov 24, 2023 12:47:17 GMT -6
One thing to always remember when using wireless even with the best wireless, your clear wireless frequencies are not static, even if you have a spectrum analyzer your not going to catch a police walkie-talkie that’s out of spec. Understand the frequency band your choice of wireless operates in. Traditional UHF analog are based around TV ch, modern digital are based around the Frequency band used for WI-FI. I just spent an hour on the phone trying to explain why trying to use 12 ch of digital wireless in a hospital was a no go from the get go.
Post by Blackdawg on Nov 24, 2023 13:28:58 GMT -6
Also I just want to say, because it's funny and super true and annoying, is that production audio is kind of unknown because the cost of entry is a whole new level of insane. Makes even mastering gear look cheap.
Blows my mind.
Though in the past 2-5 years there have been some cool strides in the prosummer market but still. 3k a channel for wireless or more. All the custom cabling and power stuff. Time code stuff. Crazy shit. But very cool too.
Post by ericn on Nov 24, 2023 13:33:22 GMT -6
Ahh production audio. One of the most underrated black arts in audio. I love doing it. If your renting, heres what I'd get. Mixpre6 II DPA4017a for your mic. Sounds way better than a 416 and can work indoors and outdoors really well. Get wind protection(a ryocote blimp) and dead cat to go with it. DPA4060a for the lavs. Very small, easy to hide, and sound better than anything else out there. You'll need microdot adapters to whatever transmitters you want to us(Sennheiser/LEctor/Shure/Wiseycom) Im a Lectrosonics guy personally. You may want to get a Timecode unit to sync stuff, a mixpre 6II can generate Timecode or recieve it. You'll also need the correct cabling to do this with the right device you pick. VERY important. In more shoots, Audio is responisble for sync. That means you're responisble for making sure the camera gets a feed from you and timecode. You really need to know the camera being used to do this well and how they plan to shoot it. This will drive your gear choice be it a wireless timecode and audio hop setup, or if you can just cable it. obviously one is much cheaper and takes less coordination with gear choice, cabling, power, and wireless coordination. Post clean up tools are SCARY good now. In the last year alone the voice cleaning software area has been flooded with good options. But, please don't lean on that crutch. As a Production mixer and Post mixer, it pays BIG to have clean audio up front(just like music). Especially when it comes to time. But if you have to use those tools, don't get carried away and over cook. Very tempting too. My other tip is obviously to get this all days before the shoot and get comfortable with it and check it all works how you want it to. Nothing is worse than stalling a shoot over not having one small cable or something. AND practice hiding your lavs. This is a skill that takes years of just practice to get consistent good results to hide lavs that sound good and don't generate noise. So be sure to practice that. Also mounting lavs comes with its own assortment of accessories(tapes, mole skins, concealers, furs, stickies, ect). It’s funny how manny newbies think they don’t need timecode because you can manually line things up in post, well till you show them how much easier and consistent it is just to offset time code.
Post by Blackdawg on Nov 24, 2023 14:44:33 GMT -6
Ahh production audio. One of the most underrated black arts in audio. I love doing it. If your renting, heres what I'd get. Mixpre6 II DPA4017a for your mic. Sounds way better than a 416 and can work indoors and outdoors really well. Get wind protection(a ryocote blimp) and dead cat to go with it. DPA4060a for the lavs. Very small, easy to hide, and sound better than anything else out there. You'll need microdot adapters to whatever transmitters you want to us(Sennheiser/LEctor/Shure/Wiseycom) Im a Lectrosonics guy personally. You may want to get a Timecode unit to sync stuff, a mixpre 6II can generate Timecode or recieve it. You'll also need the correct cabling to do this with the right device you pick. VERY important. In more shoots, Audio is responisble for sync. That means you're responisble for making sure the camera gets a feed from you and timecode. You really need to know the camera being used to do this well and how they plan to shoot it. This will drive your gear choice be it a wireless timecode and audio hop setup, or if you can just cable it. obviously one is much cheaper and takes less coordination with gear choice, cabling, power, and wireless coordination. Post clean up tools are SCARY good now. In the last year alone the voice cleaning software area has been flooded with good options. But, please don't lean on that crutch. As a Production mixer and Post mixer, it pays BIG to have clean audio up front(just like music). Especially when it comes to time. But if you have to use those tools, don't get carried away and over cook. Very tempting too. My other tip is obviously to get this all days before the shoot and get comfortable with it and check it all works how you want it to. Nothing is worse than stalling a shoot over not having one small cable or something. AND practice hiding your lavs. This is a skill that takes years of just practice to get consistent good results to hide lavs that sound good and don't generate noise. So be sure to practice that. Also mounting lavs comes with its own assortment of accessories(tapes, mole skins, concealers, furs, stickies, ect). It’s funny how manny newbies think they don’t need timecode because you can manually line things up in post, well till you show them how much easier and consistent it is just to offset time code. Yeah and even then it's only mostly accurate. It's not locked dead accurate until you've run genlock to everything too. But usually timecode alone works well enough. Especially for single camera shoots or two. But more than that and running absolute ref to everything is important.
Post by nnajar on Nov 25, 2023 18:30:44 GMT -6
The standard in that world Is dpa 406x lavs and lectrosonics wireless. Schoeps mk41 on the boom for interiors.
Post by phdamage on Nov 25, 2023 21:14:54 GMT -6
+1 for Sound Devices. I use my MixPre3 for my steady podcast gigs. rock solid. only caveat, it eats batteries like crazy and/or needsan annoying and expensive proprietary ac adapter.
Post by the other mark williams on Nov 25, 2023 21:26:50 GMT -6
+1 for Sound Devices. I use my MixPre3 for my steady podcast gigs. rock solid. only caveat, it eats batteries like crazy and/or needsan annoying and expensive proprietary ac adapter. Can't the 3 use the NPF battery sled? That's what I use on my MP6. Two NP970s will power it just about all day.
Post by phdamage on Nov 25, 2023 21:29:36 GMT -6
Perhaps. I only have the regular ass battery sled. I don’t need to be mobile with it so I just bought the pricey wall wart
