Post by Johnkenn on Oct 18, 2023 16:41:29 GMT -6
Or where do you start cutting and the slope? I've always done a pretty sharp cut starting at around 35Hz...I guess I should just use my ears (the horror) but are people cutting higher than that?
Post by ericn on Oct 18, 2023 17:14:26 GMT -6
Or where do you start cutting and the slope? I've always done a pretty sharp cut starting at around 35Hz...I guess I should just use my ears (the horror) but are people cutting higher than that? I prefer a gentle slope for guess what ? Less phase problems unless the filter is phase corrected The point is by ear but I never have pushed below 25HZ. 25 with a phase corrected 48 db per octave slams the subs. A good learning experience is to listen to a bunch of stuff you like with 1/6 octave RTA FFT app so you can see what works for you. Once again (I should get a commission or an endorsement deal at least ) AudioTools should be on every AE’s phone!
Post by nobtwiddler on Oct 18, 2023 17:25:04 GMT -6
John send a copy to me, I'm setting up my new space in Hartsville, and need to work on a few things to get the room in check... Would love to have some unfamiliar tracks to work on!
It could be a good thing for both of us?
Post by Johnkenn on Oct 18, 2023 19:00:30 GMT -6
John send a copy to me, I'm setting up my new space in Hartsville, and need to work on a few things to get the room in check... Would love to have some unfamiliar tracks to work on! It could be a good thing for both of us? I could send you a mix without vox if that is good.
Post by copperx on Oct 18, 2023 19:35:51 GMT -6
Or where do you start cutting and the slope? I've always done a pretty sharp cut starting at around 35Hz...I guess I should just use my ears (the horror) but are people cutting higher than that? I prefer a gentle slope for guess what ? Less phase problems unless the filter is phase corrected The point is by ear but I never have pushed below 25HZ. 25 with a phase corrected 48 db per octave slams the subs. A good learning experience is to listen to a bunch of stuff you like with 1/6 octave RTA FFT app so you can see what works for you. Once again (I should get a commission or an endorsement deal at least ) AudioTools should be on every AE’s phone! What's an example of a phase corrected lo cut filter?
Post by ericn on Oct 18, 2023 19:50:44 GMT -6
I prefer a gentle slope for guess what ? Less phase problems unless the filter is phase corrected The point is by ear but I never have pushed below 25HZ. 25 with a phase corrected 48 db per octave slams the subs. A good learning experience is to listen to a bunch of stuff you like with 1/6 octave RTA FFT app so you can see what works for you. Once again (I should get a commission or an endorsement deal at least ) AudioTools should be on every AE’s phone! What's an example of a phase corrected lo cut filter? Some digital software and hardware based filters correct for the associated phase shift. The example I use are the BSS WHISEWORKS Neville Thiele method.
Post by Pueblo Audio on Oct 18, 2023 20:16:05 GMT -6
Cut or, preferably, tailor low frequencies as needed; only when those frequencies need tailoring.
If they are ok then do nothing.
Simple
Post by Johnkenn on Oct 18, 2023 21:16:55 GMT -6
You know - maybe the question is more like what is “flub” in a kick? That’s the only thing that’s going to reach down that low for me. (No moogs or sub bass).
Post by notneeson on Oct 18, 2023 21:30:33 GMT -6
You know - maybe the question is more like what is “flub” in a kick? That’s the only thing that’s going to reach down that low for me. (No moogs or sub bass). I would tend go even a little lower than 35, but I think you are in the right ballpark. I also tend to use a gentler slope since I’m not really in a position to monitor super accurately that low. I’ll be on big ATCs in a killer room at the end of the month if you want another guinea pig.
Post by Pueblo Audio on Oct 18, 2023 21:34:57 GMT -6
You know - maybe the question is more like what is “flub” in a kick? That’s the only thing that’s going to reach down that low for me. (No moogs or sub bass). Ah, like this specific question better. Truly, kicks have very LITTLE extreme low end content in nature. If you are catching extreme sub content, it is due to poor directional mic placement; LF air gusts (wind) compounded by proximity effect. IOW, Synthesized by the mistakes in recording process. Though my day job is mastering, I still pledge that the recording phase is king. Closest phase to the artists, after all. Now, If that phase went wrong then re-record. If the discipline doesn’t exist for that then try to address as best one can in the mix. If discovered in mastering then RECALL the mix. Don’t panic! Don’t make poor choices at the mastering facility if the longevity of royalty potentials would be compromised.
Post by paulcheeba on Oct 19, 2023 0:01:22 GMT -6
Yes about 30hz.
Post by frans on Oct 19, 2023 2:33:16 GMT -6
I'd also start at 30 Hz and hear what it sounds like. Usually my mixes don't have too much sub as i check for that on the channels, better to get that right befor it hits the bus. Not all lowcuts sound fine to me - i can remember one instance when i recorded solo flute that had its sound changed when i inserted a lowcut around 50Hz that "should" have done nothing two octaves up... and there was a software by zynaptiq (unfilter) that had the most neutral lowcut in there and i spoke to them please, pleeeease make that lowcut a dedicated plugin.. which he never did, allthough a few people came to him that asked for it. I had a few mastering engineers ask me if i can leave in stuff around 30 Hz, so they can tailor that - i get it, as my monitoring goes well below 30 and it's a nice sound if there's some energy down there.
Post by jaba on Oct 19, 2023 6:55:11 GMT -6
I rarely do. I'm surprised it's that common. I tend to just deal with the individual tracks when and if they need it.
Post by ericn on Oct 19, 2023 7:19:56 GMT -6
You know - maybe the question is more like what is “flub” in a kick? That’s the only thing that’s going to reach down that low for me. (No moogs or sub bass). Ah, like this specific question better. Truly, kicks have very LITTLE extreme low end content in nature. If you are catching extreme sub content, it is due to poor directional mic placement; LF air gusts (wind) compounded by proximity effect. IOW, Synthesized by the mistakes in recording process. Though my day job is mastering, I still pledge that the recording phase is king. Closest phase to the artists, after all. Now, If that phase went wrong then re-record. If the discipline doesn’t exist for that then try to address as best one can in the mix. If discovered in mastering then RECALL the mix. Don’t panic! Don’t make poor choices at the mastering facility if the longevity of royalty potentials would be compromised. What he said with one other factor, the instrument itself plus a bit of position in the room. This is where a great drum tech is worth their weight in gold. Drums and particularly kick are so mechanical that you need someone who knows how to tweak everything from the beater to the head. I’ll admit I suck at it. The other thing is it can be how the monitor presents it.
Post by Ward on Oct 19, 2023 7:35:56 GMT -6
Varies from 29.7hz to 35hz on the low end. Sharp 24db/octave.
And on the top, 16.1khz since hardly any humans past 16 years of age can hear 16khz anyhow. (I'm still fortunate enough to be able to hear up to 16.4khz but that won't last forever)
Save the audio real estate for better things.
Post by Deleted on Oct 19, 2023 8:57:26 GMT -6
30-60 hz. Pass filter varies.
Post by ericn on Oct 19, 2023 10:51:05 GMT -6
After some thought, a very practical guideline would be an octave above the -3 dB drop off of your monitoring system. If you are mastering and you can’t hear any LF garbage I’m going to be really, really pissed if I can! Nothing worse than working in the kitchen playing tunes in the apartment and all of sudden having to kill the subs!
Post by copperx on Oct 19, 2023 11:33:00 GMT -6
Nothing worse than working in the kitchen playing tunes in the apartment and all of sudden having to kill the subs! Absolutely. I'd rather kill the mastering engineer.
Post by Deleted on Oct 19, 2023 11:48:12 GMT -6
After some thought, a very practical guideline would be an octave above the -3 dB drop off of your monitoring system. If you are mastering and you can’t hear any LF garbage I’m going to be really, really pissed if I can! Nothing worse than working in the kitchen playing tunes in the apartment and all of sudden having to kill the subs! I cut where the mixer cannot hear or judge it. Works like a charm. Just ask him what he mixed it down on and you're good to go half the time.
Post by Deleted on Oct 19, 2023 11:53:01 GMT -6
Varies from 29.7hz to 35hz on the low end. Sharp 24db/octave. And on the top, 16.1khz since hardly any humans past 16 years of age can hear 16khz anyhow. (I'm still fortunate enough to be able to hear up to 16.4khz but that won't last forever) Save the audio real estate for better things. The 40 hz and 15 khz filters on a v76 work great for the real world. The plugs are convenient. I love the Neold v76u73 and will even turn down the gain all the way on it and hit it soft with a trim just for the filters and a minute bit of fat.
Post by theshea on Oct 19, 2023 11:56:21 GMT -6
if i don‘t like the music i lo cut at 22khz.
Post by ericn on Oct 19, 2023 11:57:57 GMT -6
Nothing worse than working in the kitchen playing tunes in the apartment and all of sudden having to kill the subs! Absolutely. I'd rather kill the mastering engineer. Yeah, funny enough on Monday I was talking to this guy who was bragging about his “ Mastering” setup telling me about his B&W’s thinking I would be impressed, 800 series? Nope there cheapest little desk tops that do almonds nothing below 60hz I would be better off mastering in the Tesla🤪
Post by Ward on Oct 19, 2023 12:13:54 GMT -6
I sped read this post snip and read: BMW . . . . mumble mumble . . . TESLA
Post by jaba on Oct 19, 2023 12:54:41 GMT -6
Curious about why you're all doing this. Is this more an ITB thing?
I understand the idea of getting rid of stuff most people can't hear or most systems can't reproduce, but why not do that on the channels? Most things are going to be hi-passed much higher (vocals, guitars, etc) with only a few instruments going deep down.
Is there a benefit to one master HPF for the whole mix as opposed to each track getting it's own? I know when I use HPFs I pretty much end up with different points for all the low stuff (kick, bass, synths), if I'm using them at all.
Is there a benefit to using both, assuming the channel's filters aren't gentle slopes starting really low?
Post by ericn on Oct 19, 2023 13:00:58 GMT -6
Curious about why you're all doing this. Is this more an ITB thing? I understand the idea of getting rid of stuff most people can't hear or most systems can't reproduce, but why not do that on the channels? Most things are going to be hi-passed much higher (vocals, guitars, etc) with only a few instruments going deep down. Is there a benefit to one master HPF for the whole mix as opposed to each track getting it's own? I know when I use HPFs I pretty much end up with different points for all the low stuff (kick, bass, synths), if I'm using them at all. Is there a benefit to using both, assuming the channel's filters aren't gentle slopes starting really low? From my perspective a number of reasons. 1. Better safe than sorry 2. If I do both even less LF crap. 3. From analog days verbs and buss processing can introduce or bring back some of it.
