Post by tonycamphd on Jul 6, 2014 12:14:05 GMT -6
I believe this works for one reason, and one reason only, because Rod Gervais said it does, he said that 2 layers of 5/8" sheetrock with green glue in between is the equivalent of 4 layers of 5/8" sheetrock, if true, thats amazing! So i tried to find the test data, i know i'm not the sharpest tool in the shed, but can anyone show me the baseline vs the results in this pdf? also, if anyone has personal experience with this, i'd like to hear your impressions please. My room is really very quiet, but when my neighbors slam their car doors i get a fairly large sub bass bump, it's bad news, and i'm working on a few things to rid it. thanx T its the last one on the page www.greengluecompany.com/test-data?field_test_data_page_assambly_tid=All&field_test_data_page_stc_tid=All&field_test_data_page_products_tid=All&page=2
Post by svart on Jul 6, 2014 12:36:51 GMT -6
I thought about using it, but it was cheaper to just use more drywall layers, so that's what i did.
It's an elastomeric liquid that cures sort of soft and dampens the vibrations between the panels, much like the sound control sheets they put in cars.
Also, you aren't blind or dull, there has always been very little information on actual testing of this stuff with most of the information being anecdotal.
I did find some random forum threads about folks using it and getting only a little iimprovement, with those selling it quickly swooping in to proclaim that it must not have been applied correctly, with the thread disappearing shortly thereafter. Take that as you will.
Post by mulmany on Jul 6, 2014 13:05:35 GMT -6
I was under the impression with any sort of decoupler that it was very easy to short it out. Meaning the guy who puts screws though his resilient channel or to little GG or to many screws. It really has to be done correctly and perfection must be reached or it all falls apart. I know you are capable tonycamphd to do it correctly, but what is wrong with the extra drywall? Do you need the space?
Post by jeromemason on Jul 6, 2014 13:12:02 GMT -6
If you're going to try this Tony, the way in which it is installed is a very very precise process. One little mistake, or deviation from their recommended specs and it basically ruins the whole thing. Basically it has to be put on with specific bead height and width, and when it's all done is like a giant interconnected network that distributes the vibrations all through the network to cancel them. Like others have said, one run away screw, or gap in the bead and all that money is burned into thin air.... poof.
With that said, if you follow the rules and do it right, nothing can beat that stuff, it's genius.
Post by keymod on Jul 6, 2014 13:44:05 GMT -6
Several clients of mine, for whom I have wired their home theaters - both power and audio - have asked me over the years what they can do to help isolate their rooms without any major remodeling. Many have been very pleased with the results of this: Get rubberized roll roofing material, the thicker the better ( some come with waffle pattern embossed ) and staple it over your existing drywall. Then install another layer of drywall over that, preferably of a different thickness than what's already on the wall. The rubber acts as a vibration dampener and the waffle pattern gives a slight amount of dead-airspace. The different drywall thickness won't vibrate the same as the original layer and might even help cancel out vibration transmissions. I have no scientific data to back this up, only that I seem to remember reading about this technique somewhere, perhaps in a book by Alton Everest.
Post by tonycamphd on Jul 6, 2014 14:09:31 GMT -6
Thanx Fella's, to be clear, i'm a construction contractor by trade, i've built a dozen sound proofed rehearsal spaces and studio's in my time. I've always used the multiple layers of 5/8" sheetrock method(1/2" is useless) and it works great, but if greenglue's claims are true, it's cheaper to use it, than 2 more layers of 5/8" rock, not to mentioning the physical and financial toll of installation, and loss of space. The 3 proven tenets of sound proofing are mass, decoupling, and air sealing. In the case of decoupling, one screw in the wrong spot short circuits a system and renders it useless, so when using RC8 (resilient drywall channel), one screw through the rock/channel and into the wall or stud behind it, renders the system a recoupled fail, as it now transmits vibration.
My question is more about how greenglue achieves what it claims(damping in place of mass), and where is the comparative before and after data located that proves it's claims?
Post by tonycamphd on Jul 6, 2014 14:41:11 GMT -6
Several clients of mine, for whom I have wired their home theaters - both power and audio - have asked me over the years what they can do to help isolate their rooms without any major remodeling. Many have been very pleased with the results of this: Get rubberized roll roofing material, the thicker the better ( some come with waffle pattern embossed ) and staple it over your existing drywall. Then install another layer of drywall over that, preferably of a different thickness than what's already on the wall. The rubber acts as a vibration dampener and the waffle pattern gives a slight amount of dead-airspace. The different drywall thickness won't vibrate the same as the original layer and might even help cancel out vibration transmissions. I have no scientific data to back this up, only that I seem to remember reading about this technique somewhere, perhaps in a book by Alton Everest. i don't doubt what you say here works at all, as long as it stays soft, the question is.... does the asphalt bleed through the sheetrock?
Post by gouge on Jul 6, 2014 16:23:14 GMT -6
My studio is all green glue which was recommended by the local guru.
gg works better than not using it on freq above bass regions. So it scores higher on the averaged sound reduction figure. Where it falls down is bass freq. It does not perform better there. Unless the product has been reworked since the test data i remember from when i designed my studio.
it is particularly effective in existing fitouts because you gain decoupling without lose of floor space and only get the negative 3 leaf effect on the really low freq. Like below 150hz.
if i were building from scratch i wouldn't use it. You will be hard pressed beating a double wall setup with 2 layers of high density sheeting and insulation per leaf.
Post by keymod on Jul 6, 2014 19:13:12 GMT -6
Several clients of mine, for whom I have wired their home theaters - both power and audio - have asked me over the years what they can do to help isolate their rooms without any major remodeling. Many have been very pleased with the results of this: Get rubberized roll roofing material, the thicker the better ( some come with waffle pattern embossed ) and staple it over your existing drywall. Then install another layer of drywall over that, preferably of a different thickness than what's already on the wall. The rubber acts as a vibration dampener and the waffle pattern gives a slight amount of dead-airspace. The different drywall thickness won't vibrate the same as the original layer and might even help cancel out vibration transmissions. I have no scientific data to back this up, only that I seem to remember reading about this technique somewhere, perhaps in a book by Alton Everest. i don't doubt what you say here works at all, as long as it stays soft, the question is.... does the asphalt bleed through the sheetrock? AFAIK, there are a few types of the roll roofing that are rubberized and/or all rubber, so no asphalt at all. There are some specialty "Acoustical Supply" places that sell a rubber material for this same purpose, though mostly for flooring between apartments. But the rubberized roofing material is virtually the same material except at a much lower cost.
Post by gouge on Jul 6, 2014 19:24:16 GMT -6
Me personally, I wouldn't use or specify any material unless it comes with test data. It is not worth wasting money on.
most acoustic materials aren't rated for bass freq because they are sold specifically for commercial and industrial use where the freq of concern are more low to upper mids.
Post by Deleted on Jul 6, 2014 19:59:42 GMT -6
What's the proper way to do this? would just applying green glue to an existing sheet of drywall and using it to add another be a good home studio mod or would it be a waste? Could this be a good Gobo add-on where you do one side with like a QRD and then green glue a double drywalled box with 703 in? Thing would be pretty heavy though.
Post by tonycamphd on Jul 6, 2014 20:15:07 GMT -6
to be honest, i'm wary of this product, 1st i'm a licensed GC, i've been at this for 25 years, i'm not easily fooled. i've been trying to find explanations of how this stuff works today, and i'm having to search too hard, generally if something is legit, it's easy to get plenty of data on it's efficacy, snake oil usually comes in mysterious claims of grandeur, what i was able to realize, is it has poor performance at low frequencies, the main reason for me to use it. keymod i'm not sure of any roofing that contains zero asphalt? I know that dynamat has no asphalt, and is butyl based, but talk about expensive! I can tell you that any membrane that remains supple between layers of drywall will damp, to what degree and the differences being worth a shit between materials? i can't be sure. I do KNOW that with proper installation, multiple layers of rock, with air tight joints and decoupling are going to work every time. the whole "use 3 huge tubes of greenglue per sheet" @$20 a tube really fucked me off smh. i could still change my mind if the legit data was put under my nose.
Post by tonycamphd on Jul 6, 2014 20:20:02 GMT -6
What's the proper way to do this? would just applying green glue to an existing sheet of drywall and using it to add another be a good home studio mod or would it be a waste? Could this be a good Gobo add-on where you do one side with like a QRD and then green glue a double drywalled box with 703 in? Thing would be pretty heavy though. not useful at all on a gobo, just use the back panel of the qrd to mount your 703, GG is made to be used on room structures as a system, sound proofing is all about systems, not piecemeal. Greenglue is ridiculously expensive if used in the manner they suggest.
Post by Deleted on Jul 6, 2014 20:23:20 GMT -6
Fair enough Ward I also would echo your sentiments about is likely being snake oil. My understanding of isolation is that it has to be room within a room and I can't imagine that a glue is going to tame low end but I don't know anything about the product whatsoever, I've just read stuff on forums about it. I think one of the big studios in town did their construction with it but I've never been there.
Post by tonycamphd on Jul 6, 2014 20:29:09 GMT -6
Fair enough Ward I also would echo your sentiments about is likely being snake oil. My understanding of isolation is that it has to be room within a room and I can't imagine that a glue is going to tame low end but I don't know anything about the product whatsoever, I've just read stuff on forums about it. I think one of the big studios in town did their construction with it but I've never been there. I'm Tony lol, but wards a great guy so i don't mind 8) I don't doubt GG works, it's just really expensive to use in the manner they suggest, besides this, there is no substitution for mass, 3-4 layers of 5/8" rock will stop the entire frequency spectrum dead in it's tracks by virtue of it's weight(5/8" 12' sheetrock is 105 lbs a piece, its loaded with fiberglass as well, 1/2' has none, and isn't even 25% as effective as 5/8"). Been there, done that.
Post by winetree on Jul 6, 2014 21:25:04 GMT -6
My understanding is GG is a damping compound and not a soundproofing compound. I agree that GG is expensive. But what's the cost and weight of 2 extra layers of drywall. Let alone the cost of labor to install the 2 extra layers. I don't think ceiling or wall iso clips can even support 4 layers. I used GG between the extra layer of drywall I applied to the outer shell of the new tracking room and I can hear the damping effect when hitting the walls. The inside walls will have iso clips, hat channel, and 2 layers of dry wall with GG. Double walls are not possible. No green glue is not the solo answer to soundproofing but only a part of a system in the quest for noise reduction, that I'm willing to pay.
Post by gouge on Jul 7, 2014 0:10:22 GMT -6
I'm on the road currently bur I'll look up the test data once i get home. I can't imagine 2 layers and gg would be equivalent to 4 layers.
one a side note getting 4 layers supported resiliently can be done.
Post by tonycamphd on Jul 7, 2014 1:16:10 GMT -6
i guess that 2 layers with gg is claimed to be = to 4 without, but not on the low end, which is the only reason to use 3 to 4 layers of 5/8" IMV
Post by ericn on Jul 7, 2014 13:26:51 GMT -6
Post by tonycamphd on Jul 7, 2014 14:23:59 GMT -6
Thanx Eric, that link is on my first post, I'm looking for the baseline for comparison...haven't found it.
Post by Deleted on Jul 7, 2014 14:34:20 GMT -6
Sorry I need to pop in more often. Sorry Tony!
Post by ericn on Jul 7, 2014 15:05:34 GMT -6
Ah Yeah that's all they seam to have, for the money I think I would go with either a traditional limp mass or more layers of dry wall! It would be interesting to see what this stuff is like 10-12 years down the line . I know people who swear by it but I haven't used it. I also wonder How it works with calked joints. I always worry about, the area where you know there could already be problems!
Post by gouge on Jul 7, 2014 16:39:27 GMT -6
The base line can be found in the Canadian standards or bbc papers. In Australia the red book has test data. I have the docs but am still on the road.
Post by winetree on Jul 7, 2014 16:56:45 GMT -6
You stagger the joints on the drywall layers and only need to caulk the seams of the last layer, using tape and mud or Acoustic caulk and tape. You also leave a 1/8" to 1/4" gap around the edges and fill those in with foam rope and then acoustic caulk on top of that. GG also makes a none harding acoustic caulk for these purposes.
Post by ericn on Jul 7, 2014 17:45:07 GMT -6
You stagger the joints on the drywall layers and only need to caulk the seams of the last layer, using tape and mud or Acoustic caulk and tape. You also leave a 1/8" to 1/4" gap around the edges and fill those in with foam rope and then acoustic caulk on top of that. GG also makes a none harding acoustic caulk for these purposes. My problem in my loft which has 2 layers of 5/8 screwed and glued on 2/4 metal studs with a blown foam is the floor and ceiling Joints where the acustical Caulk originally used as well as that which fills gaps between walls and concrete pillars has suffered break Down! In one area where we re did some work on our own and purchased our own supplies no problem. But I still find areas where the caulk is breaking down and it always seams like its in an area where caulk met glue, so I always am interested in this relationship after pulling molding and re caulking at my expense because I know in the other units they have used generic caulk. I have even done the other side of my connecting walls in my neighbors units.
