Post by lpedrum on Sept 12, 2023 19:47:48 GMT -6
The Rule Tec Pultec plugin gets a lot of love here on RGO. Is it still the best out there? Noise Ash is having a Fall sale right now.
Post by notneeson on Sept 12, 2023 21:41:03 GMT -6
The Rule Tec Pultec plugin gets a lot of love here on RGO. Is it still the best out there? Noise Ash is having a Fall sale right now. I like it a lot, still.
Post by phdamage on Sept 12, 2023 22:47:12 GMT -6
Literally forgot I had it. This thread did remind me to try it. Haven’t used it in a good while
Post by ragan on Sept 12, 2023 23:04:51 GMT -6
It's still my favorite
Post by theshea on Sept 13, 2023 0:08:55 GMT -6
yes. i still use it in my mixes and it does what it does very well. but i haven‘t compared it to other newer plugs. are there newer pultec plugs?
Post by the other mark williams on Sept 13, 2023 0:11:39 GMT -6
yes. i still use it in my mixes and it does what it does very well. but i haven‘t compared it to other newer plugs. are there newer pultec plugs? There always are…
Post by kcatthedog on Sept 13, 2023 4:09:21 GMT -6
Its very good and excellent value on sale
Post by Vincent R. on Sept 13, 2023 4:09:43 GMT -6
It’s good. I’m still not sure it’s as good as the UAD Pultec, but it’s comparable. Remember to flip the analogue button.
Post by Deleted on Sept 13, 2023 10:25:29 GMT -6
TDR SlickEQ M sounds better than any Pultec.
I use PSP NobleQex when I want gritty oatmeal mush and Apogee Pulse Pultecs when I want warm brown mush. I’m sure you can use the Pulsar Massive Passive to get glycerin mush.
Post by svart on Sept 13, 2023 12:01:23 GMT -6
I still put both RuleTec EQs on my master bus every single time.
Post by jaba on Sept 13, 2023 12:54:00 GMT -6
Curious about the Rule Tec but I also feel I've got enough options. Acustica Purple does the job but these days I usually just use the Pultec settings on Equilibrium (curves are good, get the tone elsewhere).
Nothing I've used nails the real deal but even then I could live without it, though sometimes it really can't be beat.
Post by craigmorris74 on Sept 13, 2023 15:24:12 GMT -6
I like the Rule Tec. I was surprised how little harmonic content it adds, even compared to a solid state Pultec.
Post by nudwig on Sept 13, 2023 16:17:05 GMT -6
My favorite Pultec plugins are the Apogee Pultecs, to my ears more vibe and oomph than the RuleTec
Post by nomatic on Sept 14, 2023 6:30:33 GMT -6
Still Love it.... This with the Make Believe Sontec and the crave Eq get me there...
Post by copperx on Sept 14, 2023 15:22:54 GMT -6
I've been searching for a Pultec EQ with zero latency to use in the master buss, but so far the UAD, Bettermaker, Noise Ash all add some latency. That's unacceptable for the master bus. Has anyone found anything with zero latency?
Post by sirthought on Sept 14, 2023 15:28:57 GMT -6
I like the Rule-Tec, but prefer the UAD. I'm not sure if I tried any other than Waves, which I don't do business with now.
iZotope's vintage EQ is supposed to be Pultec curves. I just don't reach for it as often.
Post by mhbunch on Sept 15, 2023 9:00:12 GMT -6
Still using the Ruletec and Noiseash neve plugs everyday. Prefer them to UAD, waves etc. The ruletec sounds more like my SS pultec than any other plug I’ve heard.
Post by drumsound on Sept 16, 2023 23:42:45 GMT -6
Still using the Ruletec and Noiseash neve plugs everyday. Prefer them to UAD, waves etc. The ruletec sounds more like my SS pultec than any other plug I’ve heard. Have you worked with their RND Portico EQ, the 533? I'm curious about it.
Post by Deleted on Sept 17, 2023 10:34:50 GMT -6
I've been searching for a Pultec EQ with zero latency to use in the master buss, but so far the UAD, Bettermaker, Noise Ash all add some latency. That's unacceptable for the master bus. Has anyone found anything with zero latency? every modern mixer in the digital era where you can monitor the storage medium disagrees with you there. Anything good on the mix bus causes latency through lookaheads or anti-alias filters. Hardware inserts add even more latency.
Post by seawell on Sept 17, 2023 11:02:26 GMT -6
I've been searching for a Pultec EQ with zero latency to use in the master buss, but so far the UAD, Bettermaker, Noise Ash all add some latency. That's unacceptable for the master bus. Has anyone found anything with zero latency? Acustica Purple ZL versions should work for what you're looking for. They are also my favorite sounding Pultec plug-ins 👍🏼
Post by kcatthedog on Sept 18, 2023 4:21:56 GMT -6
How is that plug in affected by the new upgrade cost decision ?
Post by seawell on Sept 18, 2023 9:29:16 GMT -6
How is that plug in affected by the new upgrade cost decision ? I haven't followed what's going on there so I'm not sure. I will say I purchased it on version 1 and have gotten free upgrades to version 3.5 so far.
Post by kcatthedog on Sept 18, 2023 10:09:22 GMT -6
A seems to be introducing a cost for upgrades. I don’t own any so have no insights into it, other than the thread .
Post by the other mark williams on Sept 18, 2023 10:29:14 GMT -6
A seems to be introducing a cost for upgrades. I don’t own any so have no insights into it, other than the thread . It's not so much a cost for upgrades (at least from what I've seen/heard), it's that they may have just decided to STOP updating certain products altogether. So if your personal favorite Acqua hasn't yet made the leap to their newest tech, you can't necessarily count on it ever doing so. This would be a change from the way things have historically been done at Acustica. Though to be honest, the way they've historically done things has never made that much sense. It's also possible that Giancarlo means something different than how folks are interpreting him. I frequently read his explanations about something and walk away a bit more confused. It seems like a lot gets lost in translation for me with Acustica.
