Post by mcirish on Jun 26, 2023 14:00:54 GMT -6
Any good and fairly current converter is going to be fine. I feel like this is one of those "last 1%" kind of things. Granted, I just bought another converter, even though I didn't really need to, so I'm a complete hypocrite. I'd find one that I like the user interface of and use other hardware or plugins if I need to get saturation. I'm a huge fan of Lynx. I just bought my fourth. I can't imagine the Lynx Aurora (n) being much different than the Lynx Aurora 16 I already have, but I figure I'm just future-proofing my I/O. From all my years using them, I don't think Lynx really has a sound. They are clear and fairly transparent. Personally, I wouldn't want a converter with a sound. Just for the same reason I hate tape. I want the sound going in or out to be what I heard at the time. Yes, I'm old enough to have worked on tape since the 70's. I am very happy for the advent of digital recording. heretic... I know.
Also, speaking of clocks... I can't see how an external clock would be better than the internal clock on these interfaces; unless it's poorly designed. I'm not saying it wouldn't sound different, but what is causing that difference? More jitter in the external clock? Remember, the external clock is derived from an internal clock that is running at a much higher frequency. I believe I had a talk with Paul at Lynx about that and I read something that Lavry put out to the same effect.
Post by Pueblo Audio on Jun 26, 2023 14:28:17 GMT -6
So I’m trying to wrap my head around doing this with the patchbay. If I use a half normaled config, I could route the mic into the upper back, then one signal from the upper front to Pre1 and one from lower back to Pre2, right? You don’t want to split at mic level without a dedicated transformer splitter or SS splitter. Line level is normally fine, most devices are designed with the idea the signal will be split in mind. Right, but I would go further and say you never WANT to split a mic signal ever. Not when sonics count. Mic splitter transformers (which is one of the best ways to make a mic split) effect mic performance and lack hifi response themselves. It will most likely negate/mask benefits the device you want to test/use. If you can’t tell which of two consecutive, level matched, unsplit recordings are preferred, then leave it alone. Performance changes but resolution does not. More helpful to listen for that.
Post by Chad on Jun 26, 2023 14:42:38 GMT -6
Which I now own. :-) (Just braggin' 'bout my JK hand-me-downs) You should Bragg better conversion than most realize. The DA is different but comparable to my Mytek Brooklyn. That's awesome, ericn. I have asked svart a lot of questions about his converter (and others) privately, and as friggin humble as he is, I can tell that what I have in his Svartbox should have cost me (us) about 10-15 times what it actually cost.
Post by ericn on Jun 26, 2023 15:14:06 GMT -6
You don’t want to split at mic level without a dedicated transformer splitter or SS splitter. Line level is normally fine, most devices are designed with the idea the signal will be split in mind. Right, but I would go further and say you never WANT to split a mic signal. Not if sonics count. Mic splitter transformers (which is one of the best ways to make a mic split) just don’t have beautiful response. It will negate/mask any benefits the device you want to test/use might provide. If you can’t tell which of two consecutive, level matched recordings are preferred, then leave it alone. Performance changes but resolution does not. More helpful to listen for that. Absolutely, but some of uss grew up in the world of old school live fighting over who got the non transformer split or who got the BSS splitter, Dante and other Audio over Ethernet protocols have made this somewhat easier. Of course I’ll admit something, manufacturer’s coming in saying “never split a mic signal” has always really pissed me off as both an end user and a successful gear pimp ( your in very prestigious company here). Gear design and practical use should be based on the real world needs of the customer ( first rule of any business is the customer is always right) well the customer decided around 1970 the industry standard would be split it at the mic! You could have designed consoles or pres with 4 outputs with individual trimable outputs but nobody did! Instead in the world of low dollar wedges I got those crappy Yamaha 1608s or Allen and heath. Wedges always got the transformer, Wasn’t till I got to use one of those BSS boxes that I felt special. Even today when I can do a painless split via Cobranet for FOH and monitor world I still need a traditional mic splitter for broadcast or video because they don’t carry a compatible stage box or I either don’t want to give them as little control of the network as possible, or have time. Nope instead I currently sub lease a Transformer split or I’m going to breakdown and buy a used KT square 1 32ch system. But again I can go through this system and point out that the manufacturers could have sure made this easier.
Post by nobtwiddler on Jun 26, 2023 16:15:22 GMT -6
If the split had 1 in, with two of the same transformer split outputs, then all things are equal, right.
Even if it altered the sonics a bit. At least both convertors are seeing the same input signal!
Post by ericn on Jun 26, 2023 16:39:22 GMT -6
If the split had 1 in, with two of the same transformer split outputs, then all things are equal, right. Even if it altered the sonics a bit. At least both convertors are seeing the same input signal! In theory yeah, in reality, even with the Jensen everyone could always hear the difference between the different the different transformer splits. Plus you’re going to have to still have something plugged into the clean split to provide phantom. Now your way was how I always did shoot outs because nobody made a great not transformer based split in less than 4 channels and I found one of those BSS’s for cheap, of course it doesn’t come with PSU and the BSS PSU costs 100 less than 16 ch with PSU!
Post by Mark Kano on Jun 26, 2023 16:54:34 GMT -6
FOR ONE PERFORMANCE, Couldn't you split the output(s) of the mic pre amp(s), and go to 2 x convertors simultaneously? Record both convertors? My Apollo is my interface and I have the Burl set up spdif in. So it’s a one or the other thing. Just curious.. are you using the spdif out on the Burl ADC for both the audio and clocking duties, or are you using both the word clock and spdif outputs separately? The reason I ask is because I was originally using only the spdif output to carry both and noticed a sonic difference when I tried clocking via the word clock output and using spdif to only carry the audio. If you haven't tried this you might also experiment with it to determine whether this makes more of a difference for you.
Post by Johnkenn on Jun 26, 2023 17:25:59 GMT -6
My Apollo is my interface and I have the Burl set up spdif in. So it’s a one or the other thing. Just curious.. are you using the spdif out on the Burl ADC for both the audio and clocking duties, or are you using both the word clock and spdif outputs separately? The reason I ask is because I was originally using only the spdif output to carry both and noticed a sonic difference when I tried clocking via the word clock output and using spdif to only carry the audio. If you haven't tried this you might also experiment with it to determine whether this makes more of a difference for you. Now that you mention it, I think when I was moving stuff around I just said screw it did SPDIF, and yanked the WC cable. Putting it back on now...although, I really don't think I've noticed anything.
Post by Ward on Jun 26, 2023 17:32:01 GMT -6
So I’m trying to wrap my head around doing this with the patchbay. If I use a half normaled config, I could route the mic into the upper back, then one signal from the upper front to Pre1 and one from lower back to Pre2, right? You don’t want to split at mic level without a dedicated transformer splitter or SS splitter. Line level is normally fine, most devices are designed with the idea the signal will be split in mind. Give me dedicated transformer isolated splits or fuggedaboutit!
Post by Johnkenn on Jun 26, 2023 17:40:48 GMT -6
My Apollo is my interface and I have the Burl set up spdif in. So it’s a one or the other thing. Just curious.. are you using the spdif out on the Burl ADC for both the audio and clocking duties, or are you using both the word clock and spdif outputs separately? The reason I ask is because I was originally using only the spdif output to carry both and noticed a sonic difference when I tried clocking via the word clock output and using spdif to only carry the audio. If you haven't tried this you might also experiment with it to determine whether this makes more of a difference for you. Well, I have zero idea whether it actually sounds better, but now that you mentioned it, and I switched back to WC...yeah definitely it's better. Power of the internet
Post by wiz on Jun 26, 2023 18:08:28 GMT -6
If you have the time do 2 takes of your normal Eagles song One on the burl via spdif to Apollo clock by the Apollo. Then second take using your Apollos converters clocked to its self. Send me the tracks and I will comp it up and post them up
Cheers
Post by Mark Kano on Jun 26, 2023 18:15:01 GMT -6
Just curious.. are you using the spdif out on the Burl ADC for both the audio and clocking duties, or are you using both the word clock and spdif outputs separately? The reason I ask is because I was originally using only the spdif output to carry both and noticed a sonic difference when I tried clocking via the word clock output and using spdif to only carry the audio. If you haven't tried this you might also experiment with it to determine whether this makes more of a difference for you. Well, I have zero idea whether it actually sounds better, but now that you mentioned it, and I switched back to WC...yeah definitely it's better. Power of the internet When I first bought the ADC I had no idea how to hook it up to my Apollo. The guy I bought it from instructed me to use the spdif out, so that’s what I initially did. Being curious, I also bought a WC cable and tried the WC out since that was an option when selecting the clock source in Luna. After going back and forth a few times I felt there was a discernible difference. Both sounded great mind you - and I’m not claiming one is necessarily better - but it was enough of a difference for me to contact Burl support to see if my ears were deceiving me, and to know what the differences were. This is the response I received… “Clocking over word clock is preferred as the audio data is not present in the clock signal as it is when sending out with SPDIF and will result in less clock noise. We usually recommend having the B2 ADC as the master clock, set to internal, especially if it is the main AD tracking device. If you plan on running it off another clock source it must be clocked over word clock and set to external.” So at least this way you know you're listening optimally (according to the manufacturer) when making a comparison.
Post by Johnkenn on Jun 26, 2023 19:16:29 GMT -6
If you have the time do 2 takes of your normal Eagles song One on the burl via spdif to Apollo clock by the Apollo. Then second take using your Apollos converters clocked to its self. Send me the tracks and I will comp it up and post them up Cheers Wiz I'm gonna do it...just trying to get motivated.
Post by wiz on Jun 26, 2023 19:24:07 GMT -6
If you have the time do 2 takes of your normal Eagles song One on the burl via spdif to Apollo clock by the Apollo. Then second take using your Apollos converters clocked to its self. Send me the tracks and I will comp it up and post them up Cheers Wiz I'm gonna do it...just trying to get motivated. Go John he's our man... if he can't do it..... well.. I guess someone else will...8)
Post by kcatthedog on Jun 27, 2023 9:00:49 GMT -6
^^This^^ a scream !
Post by Johnkenn on Jun 27, 2023 12:47:47 GMT -6
So here we go...I just did a take through the Burl with the Burl clock and one through the Apollo with the Apollo clock. Here's a mashup of the two. First phrase starts with one AD and then the next phrase is the other AD and so on...Really, not a ton of difference. I'll post the separate files too, but wanted to see how people heard the comp first. When you hear the two separate files, you can pick out differences. COMP - drive.google.com/file/d/1IF2Q3kngvUm3qkSx723nr7zKau2G-GsH/view?usp=sharing
Post by Johnkenn on Jun 27, 2023 12:51:47 GMT -6
Post by Martin John Butler on Jun 27, 2023 13:47:35 GMT -6
I'd guess B is the Burl. A has a midrange push that's slightly annoying. That said, A may actually be more accurate, just not as pleasing. Also, within a track, that mid push might help with intelligibility.
I don't hear the Apollo honk after getting the BLA mods, it's more like a Dangerous Music tone now.
Post by nick8801 on Jun 27, 2023 14:44:00 GMT -6
A is Apollo B is Burl? B sounds so much less sibilant to me. More muscular. If I'm wrong, then the Apollo has come a long way!
Post by wiz on Jun 27, 2023 15:03:33 GMT -6
I would guess A is Burl B is Apollo. I think you could use either in a finished mix and with music going comp and not have a problem…..A could also be proximity effect difference I am hearing.
It’s a very good example of the very small differences in converters for the money vs say taking the cash difference and purchasing another high quality microphone or preamp for the front end.
Cheers
Post by BenjaminAshlin on Jun 27, 2023 15:47:17 GMT -6
So here we go...I just did a take through the Burl with the Burl clock and one through the Apollo with the Apollo clock. Here's a mashup of the two. First phrase starts with one AD and then the next phrase is the other AD and so on...Really, not a ton of difference. I'll post the separate files too, but wanted to see how people heard the comp first. When you hear the two separate files, you can pick out differences. COMP - drive.google.com/file/d/1IF2Q3kngvUm3qkSx723nr7zKau2G-GsH/view?usp=sharingAre these different takes? I'm surprised they sound this different TBH!
Post by Johnkenn on Jun 27, 2023 16:27:53 GMT -6
So here we go...I just did a take through the Burl with the Burl clock and one through the Apollo with the Apollo clock. Here's a mashup of the two. First phrase starts with one AD and then the next phrase is the other AD and so on...Really, not a ton of difference. I'll post the separate files too, but wanted to see how people heard the comp first. When you hear the two separate files, you can pick out differences. COMP - drive.google.com/file/d/1IF2Q3kngvUm3qkSx723nr7zKau2G-GsH/view?usp=sharingAre these different takes? I'm surprised they sound this different TBH! Yes. Different takes
Post by Ward on Jun 27, 2023 16:28:37 GMT -6
I'd guess B is the Burl. A has a midrange push that's slightly annoying. That said, A may actually be more accurate, just not as pleasing. Also, within a track, that mid push might help with intelligibility. I don't hear the Apollo honk after getting the BLA mods, it's more like a Dangerous Music tone now. Your brutally blunt and frank honesty gets me right in the feels. Seriously. Don't ever change.
Post by Johnkenn on Jun 27, 2023 16:28:47 GMT -6
It’s really hard to tell what’s what in that mashup, though.
Post by Johnkenn on Jun 27, 2023 16:29:54 GMT -6
Both of these tales could use some eq love, of course.
