Post by sam on Jun 20, 2023 10:33:48 GMT -6
I’m a diehard NS10 guy. And I’m also a diehard “if it ain’t broke”. But I will be the first to admit I do like the sound of ATC/PMC/Amphions when I’ve been other places.
Anyone here ever just launch into a new set of speakers? How did it go? What did you grab? Better? Worse?
Post by drbill on Jun 20, 2023 10:53:49 GMT -6
I used to be an NS10 guy. Then I woke up one morning, turned them on and said "yuck! $#@!@ no" and pulled them down and never put them up again. I moved to JBL on the original LSR's mostly due to being able to get a good deal on 5.1 set due to friends at JBL. (I was doing a lot of feature film stem mixing and needed the 5.1 - and also hoped to get more into the surround CD market, but that never materialized. I worked on the original LSR's for years, and finally moved to LSR8P's a few years ago. The original LSR's were a bit hard to get used to, but after getting the hang of them, they translated sooo good on everything from IMAX films, to features, to stereo systems to new small media players. They just worked. The switch to the newer 8P's was cause I was advised to by my new (2016) room designer (Jeff Hedback). I didn't regret it. Amazing sounding speakers - both fun AND translatable. Each of these "steps" made me more creative, deliver better mixes, and made mixing more "fun" than NS10's. I could make the NS10's sing, but alas, it just wasn't fun anymore.....it was fatiguing - and after spending 10+ hours a day in front of studio monitors for decades, sometimes fun has to come first.
Post by Martin John Butler on Jun 20, 2023 11:10:46 GMT -6
NS-10's were reliable if you knew them well. If you add another pair of speakers, you can keep the NS-10's as a reference and for low level duties. It only gets tricky if you move to a self powered speaker. Going to a high end 3 way speaker was a revelation and a joy. I could now hear the mix and not the speakers. Unfortunately I had to sell my gear a while back and start again.
Post by sean on Jun 20, 2023 11:26:19 GMT -6
I’ve switched speakers a lot, and I think once you get your listening environment treated/sounding good to where you are actually hearing what the speakers are doing you can, as the good doctor said, making the switch is easier.
I just dropped a pair of Neumann KH310’s into the studio and I’m mixing a couple records next week and I’m interested in seeing how it turns out/translates. But, even just spending a day with them yesterday I can tell it’ll be a lot more enjoyable.
That’s in the actually studio…and at home the little KH80’s are the best thing I’ve found. I’ve had everything from PMC IB2S to NS10’s to Auratones and for me, in a small space, close to the speakers, not having to impress anyone, they work great.
Honestly, with NS10’s, you could just get an additional set of speakers. Best of both worlds
Post by svart on Jun 20, 2023 11:30:14 GMT -6
Yep. I bought a set of KH310D's and never looked back. Before that I used a bunch of different low/medium tier monitors as well as NS10's.
Post by ericn on Jun 20, 2023 12:00:34 GMT -6
Always best to have some time with both old and new so you can learn what both are doing right and wrong. Spend lots of time working on positioning.
Post by christopher on Jun 20, 2023 12:07:36 GMT -6
I’ve been thinking about this lately. I’m conflicted, as ALL of my fav CDs growing up were mixed on NS10s. I have to think back to before I learned to play, but I used to hear the songs on the radio and tape them on my receiver. Then I’d learn the names of the songs I’d like, get the CD. And the CD never sounded like the radio.. way less distortion, way clean and almost anemic. And with a FR that had a unique character. I had to get used this new clear CD sound vs the radio capture. And I almost never liked the CD sound at first. So I used to EQ and overdrive the CD into my cassette deck, and make an overloaded tape for my Walkman. the drive ‘into the red’ gave it the radio sound! But then as time went along, I’d listen to the CD more than cassette, and the unique clarity and FR would grow on me. -18dB RMS was common, you could crank the volume and it was really enjoyable. I’d commute as a young adult so I’d hear 2 full CDs every day. As a musician the detail felt super connected to other musicians. Freaking amazing.
Fast forward to today, everything has that radio sound baked in. I have to remember that’s what the non-musician, non-critical listener, non-HiFi junkie version of myself wanted. And that seems to be what everyone wants. NS10s will tear your head to bits if you put too much distortion. (I mean at least the wrong kind of distortion) I think that’s what made those clean CDs. Soooooo many monitors these days you are free to grind away and it sounds great.
Post by phdamage on Jun 20, 2023 12:26:27 GMT -6
I went from B&W matrix 805s to Dyn LYD48s about a year and a half ago. I am using Sonarworks, so that made the differences fairly minimal. Biggest thing for me was where my volume knob had to sit. the B&Ws powered by a modded Adcom 545 paired with (an admittedly stupidly overpowered) sub had a ton more headroom. The only change I had to make after the fact was to add the matching sub so I could get some headroom back.
Post by Deleted on Jun 20, 2023 13:37:21 GMT -6
You set them up, listen to some music, and just go. The biggest change is going from mixing kick and bass visually from the movement of the woofer on ns10 and Proac 100 to using your ears.
Monitors that use better drivers, eg higher end Focal and Dynaudio, ATC, Quested, and numerous passive crossover speakers will also be way less distorted than anything mass market with generic drivers. The Genelec One series for example are technically closer to Bose than a high end driver monkey coffin and many powered monitors use surround receiver and car audio chip amps.
Post by drumsound on Jun 20, 2023 14:11:52 GMT -6
I went through this last year. I know I needed more from my monitors, even though I enjoyed working on them and was making translatable mixes. My ME had little difficulty and any time I asked what he did, it was always typical and minor mastering basics. I still felt I was working harder to get what I wanted. Luckily I have a local friend who builds speakers as a 'hobby.' He generally makes larger full-range systems. I asked him about 3-ways and I went and listened to his rear speakers as a starting point. Those have a sealed woofer, along with a separate dipole dome mid and ribbon tweeter. About a month later he sent me photos of a one piece 3 way that was similar but had ribbon mid and tweeter in the dipole design along with the sealed woofer. I went over about a week later and listened to them for an hour or so and they sounded great. He'd already upgraded the woofer. We compared them to his much larger and more expensive builds and they sound REALLY similar.
Shortly after that he brought the whole system over, including a 4 channel amp for stereo mids and highs and we used the crown I was powering my Truth Audio monitors for the bass. There's a Dayton Audio controller taking care of DSP room tuning. He sent two different pink noise files to the speakers and used a calibration mic to get the system going. He came back a couple of times that week for further tweaks to really get them dialed in.
Then the fun part came. I just listened to music, mostly on CD, for the rest of the week. I brought my GF over, and we geeked out on some of our favorite records. Another friend came over with 7 of those huge CD binders and we spent an entire Saturday listening to a ton of her favorite stuff. She's a Prince completist so there was a lot of his music. She's African American, so she had a ton of stuff I didn't, and that was super eye opening as well.
I did a few tracking dates and I felt dealing with phase and polarity on drums was a little harder to get used to, but now it's not an issue.
I did a mix for a decent band I do monthly sessions with and sent it to Scott at Old Colony Mastering telling him I had new monitors and I wanted to know if he noticed any differences from other work (including by that band). The first sentence in his email return was "Yeah, you're gonna want to keep those."
Post by aremos on Jun 20, 2023 14:50:05 GMT -6
Many years ago: Had NS-10's ... Years later bought Genelec 1031's & kept the NS-10's ... Few years ago bought Dutch & Dutch 8C's & kept the NS-10's & Genelecs ... Add headphones & you can come close to something decent from the 3 sets of speakers to send off to mastering.
Post by sam on Jun 20, 2023 21:42:34 GMT -6
Many years ago: Had NS-10's ... Years later bought Genelec 1031's & kept the NS-10's ... Few years ago bought Dutch & Dutch 8C's & kept the NS-10's & Genelecs ... Add headphones & you can come close to something decent from the 3 sets of speakers to send off to mastering. Funny I was looking at the Dutch & Dutch. Something about spending 48 times as much as I spent on my NS10s and having people who own the Dutch and Dutch tell me they love my mixes really doesn’t help my decision haha
Post by aremos on Jun 20, 2023 21:50:46 GMT -6
48x's? Are you from Vietnam? Cause that would be the equivalent in Dong.
Post by sam on Jun 21, 2023 12:28:42 GMT -6
48x's? Are you from Vietnam? Cause that would be the equivalent in Dong. Haha no I got my first pair of NS10s that I still use today for $250 CAD
Post by sam on Jun 21, 2023 12:29:33 GMT -6
You set them up, listen to some music, and just go. The biggest change is going from mixing kick and bass visually from the movement of the woofer on ns10 and Proac 100 to using your ears. Monitors that use better drivers, eg higher end Focal and Dynaudio, ATC, Quested, and numerous passive crossover speakers will also be way less distorted than anything mass market with generic drivers. The Genelec One series for example are technically closer to Bose than a high end driver monkey coffin and many powered monitors use surround receiver and car audio chip amps. Yeah I’ve been thinking something ATC or PMC. I dunno it’s such a tough call
Post by RealNoob on Jun 24, 2023 9:58:13 GMT -6
I’m a diehard NS10 guy. And I’m also a diehard “if it ain’t broke”. But I will be the first to admit I do like the sound of ATC/PMC/Amphions when I’ve been other places. Anyone here ever just launch into a new set of speakers? How did it go? What did you grab? Better? Worse? Consider PSI if you are shopping. I went from Presonus Scepters which I knew inside and out and translated well to PSI A21M's. Big jump but the easiest transition. The PSI's were so easy to learn. They were lean and clean (though everything was there). Issues in the mix were so easy to spot with the PSI's. However, after a few months, I had a need and had to sell them. Recently, due to financial limits, I was able to pick up Genelec 8330's and Dynaudio LYD 48's. Going back to Presonus and then to these pairs has been problematic. The Scepter 8's really are exception for the cost. Now, the Genney's are mid-forward in a non-flattering way and the Dynaudio's are a scooped. I used GLM and Sonarworks respectively and redid the settings multiple times. I use some specific reference tracks and this is the only thing that has made it work. First i doubted the Genneys', then I doubted the Lyd's, then back and forth. In the end, I have come to realize that the Genny's, though not lovable with the mid forward nature, do reveal tonality issues. For my ears, if I mix on the Genny's and the mix sounds good on both, I'm there. I can't say that it is reciprocal. They have become my NS10s. I guess my point is that it has gone both ways for me - once easy and another time, not so much. I know I won't buy Focal/Genelec/Dynaudio again unless I can extensively demo. Try PSIs.
Post by thehightenor on Jun 24, 2023 11:54:02 GMT -6
I went from TOA 265 ME to Mackie HR8's to NS10's to Klein and Hummel 0300's then finally ....
ATC 25's.
For me, the ATC 25's were literally a game changer. Finally the translation and confidence I'd been longing for mixing.
I also have a lovely pair of late 70's Auratones which I keep around as they look sooo cool :-)
Post by christophert on Jun 24, 2023 17:47:40 GMT -6
I've had 3 sets of NS10's over the years. I decided at a certain point that I wanted to look after my ears, so got rid of them for the last time. The ear fatigue was relentless when tracking and mixing almost every day of the year. I listen back to mixes from decades ago using NS10's and they are still really good. Something about NS10's that really work. But I can't mix shit if my ears are useless.
Been through so many different monitors since, and eventually landed with PSIA21m's and Dutch and Dutch 8c's - which are both sensational speakers, not tiring to use at all, and both go real low. Clients all say where are the subs ? Also really like the iLoud micro monitors for checking mixes and editing.
Post by mics on Jun 24, 2023 18:08:26 GMT -6
I love APS out of Poland. They sound great and so neutral. They also don’t break the bank!!!
Post by ericn on Jun 24, 2023 18:14:22 GMT -6
I love APS out of Poland. They sound great and so neutral. They also don’t break the bank!!! Knowing the sound of your mics, that makes total sense!
