Post by Mister Chase on Jun 13, 2023 12:02:33 GMT -6
Post by phantom on Jun 13, 2023 12:50:17 GMT -6
I have to say, I always had a hard time comparing these purely digital eqs. Fabfilter, Kirchoff, Slate one, Crave. Even the expensive MAAT ones.
They all sound the same to me.
Fabfilter always had the best interface, tho. So I stick with them.
Post by kcatthedog on Jun 13, 2023 13:14:16 GMT -6
Hard to move away from ff: why ?
Post by Mister Chase on Jun 13, 2023 13:22:33 GMT -6
I have to say, I always had a hard time comparing these purely digital eqs. Fabfilter, Kirchoff, Slate one, Crave. Even the expensive MAAT ones. They all sound the same to me. Fabfilter always had the best interface, tho. So I stick with them. This is how I feel. It becomes about workflow. It's easy and intuitive. The differences must be slight. The nulls Dan showed in his video were very telling to me, even with Kirchoff nulling itself between an instance with the 117 mode in. lol.
Post by Mister Chase on Jun 13, 2023 13:23:32 GMT -6
Hard to move away from ff: why ? For these kind of EQs, I just can't see a reason. I do like some of the saturated hardware style ones like Slick EQ and console modeled ones. But for getting clean work done... can't beat it.
Post by nudwig on Jun 13, 2023 13:30:10 GMT -6
Was there a quick summary of his findings? End of 2021 I did a test and moved over to Kirchhoff for utility duties but in receiving a session recently with Pro Q3 I was reminded how it's still very solid. One main thing I prefer on Kirchhoff, besides what I feel is better upper mid sonics, is the more versatile dynamic eq that makes a handy de-esser/de-harsher that's quick and easy to dial in.
Post by Deleted on Jun 13, 2023 13:58:51 GMT -6
Dan Worral is being an apologist for worse sound and distortion for a plug from a company who pays him again. See his earlier comparison of Pro Q3 vs Bettermaker where Bettermaker sounded much better yet according to him it's the same. Just not true if you compared pro q 3 to the plugin alliance bettermaker plugin for an easy to demo one. They do not sound the same.
Worral is totally ignoring filter structure, phase, and impulse response. His nulltests will reveal nothing because Fabfilter Q3 uses 64-bit float precision internally yet rounds to 32-bit float for in and out. 32-bit float is still a wide enough container to contain a 24-bit signal and the thermal noise of analog equipment at 1 kHz yet a null test with a sine wave or pink noise will not reveal extremely low lever artifacts from filter structure differences, only the rounding error / noise that doesn't matter in the real world at all. Noise you might hear it with stupid random filters but it will be harder than with music with useful filters.
Then he repeats some bullshit about great gear was really great music. Yeah tell that to all the bands from the 70s to 2000s with cool music whose recordings sound like absolute crap or have no low end or the vocals are cooked. They all would've sounded better with better gear and their recordings would be more accepted by the general populace. 90s Godflesh with the 8 channel Tascam sounds like absolute crap compared to Streetcleaner and the later stuff. Tell that to an artist with interface pres that sound like plastic or dirty as hell and of course their recordings would sound much more lifelike with a clean pre or maybe better than reality with complimentary colored pre.
Worral probably uses some old Mackie at home and thinks everything more or less distorted than his preferred brand of live sound equipment chock full of textbook circuits built with the cheapest opamps you can buy by the 10s of thousands in the PRC and probably fake caps is bullshit.
Post by Mister Chase on Jun 13, 2023 14:05:49 GMT -6
Was there a quick summary of his findings? End of 2021 I did a test and moved over to Kirchhoff for utility duties but in receiving a session recently with Pro Q3 I was reminded how it's still very solid. One main thing I prefer on Kirchhoff, besides what I feel is better upper mid sonics, is the more versatile dynamic eq that makes a handy de-esser/de-harsher that's quick and easy to dial in. As I recall they mostly null - The upper limits above 10k had some differences but they still nulled to around -90db or greater. There are filter shapes that Kirchoff have based on analog designs that FF can't do but doesn't have much to do with sonic quality just filter shape. The dynamic section is another story, of course. Lots you can do there. Just saw Dan's above post - will have to defer to his knowledge about this kind of testing.
Post by Johnkenn on Jun 13, 2023 14:46:49 GMT -6
Post by Johnkenn on Jun 13, 2023 14:49:35 GMT -6
I usually use Pro-Q3 in linear mode only.
Post by Mister Chase on Jun 13, 2023 15:31:26 GMT -6
I usually use Pro-Q3 in linear mode only. I default to Natural mode, but when doing something like EQ'ing sources with bleed or something, I find linear keeps the low end intact far better. Like creating a crossover on a DI track and amped bass track. Shady shade going on, no doubt.
Post by allbuttonmode on Jun 14, 2023 1:22:49 GMT -6
I can't stand this guy's videos.
Post by phantom on Jun 14, 2023 10:13:38 GMT -6
There's a part 2 now:
Post by Deleted on Jun 14, 2023 20:25:41 GMT -6
yes ab test pointless hf boosts through lossy youtube codec that kills the high frequencies, strips out low level information, and low passes everything beneath the different anti-alias filters 🤯🔫 null null null blah blah blah all these nulls are beneath the electrical noise of some piece of your equipment in your recording and playback setups yet the plugs still sound different in the real world.
none of these guys online who want to abx tests everything instead of use it in the real world realize that even abx tests are a bias and the distortion of many pieces of equipment, processes, or codecs only hit you on long term listening. the living with it effect. there is a lot of gear or plugs that might sound acceptable on a brief 2 second listen that is hard to live with and use or listen to all the time. the demo it, like it at first, buy it, grow to hate it, and sell it a month or two later process. we've all been there.
i could also engineer an ab test with an eq that generally sounds better and measures less distorted than another sounding worse than it on a specific track. rounding errors can even make it sound warmer and there are techniques to keep the noise down. an antialias filter on an oversampled eq might dull a snare's pop but help a vocal sit. i can even engineer a test to pick out cable and dither differences and these guys would scream and dan worral would say that everyone should use a fuckin focusrite and the fabfilter bundle instead of whatever sounds best to the engineer on the specific one.
Post by Deleted on Jun 14, 2023 21:02:30 GMT -6
a real world example. i'm using the massenburg plugin eq a lot because i like that the gui is left to right and most of the q settings are sharp yet i can't even make it sound as clear sometimes at 44.1 khz sessions as at 88.2 because it oversamples x2 at 44.1 and 48 to get rid of most of the cramping. i've heard the filter darken snares at 44.1 yet not at 88.2 and to check to see if it was my converters anti-alias filters, i rendered out each online render, converted the 88.2 one to 44.1 (adds another, far steeper antialias filter), and the 44.1 khz massenburg eq one was still darker. i used the ancient oxford eq on that mix. yet on others the tdr slick eq that 4x oversamples was the best sounding eq. and i've done the notch in many eqs and tried to match it in plugin doctor quickly to get the sound just a bit better, sometimes nulled it pretty far down, yet one just sounds better so i go with it.
to say that one eq plugin where on most of the settings on it you will get cuts that will in no way resemble the other and whose workflow encourages you to be more methodical in the hope that it will pay off in the end vs one that encourages you to be very fast and make eq moves that look good and claim that they are same in the real world and sound the same is a pretty drastic claim. boost and cut until something sounds good on typical 3-5 band hardware or hardware style eqs and the curves will look like nothing you would ever make in some pro q clone. even for the massenburg eq i like, you get 5 bands per instance. 3 on the cut down to save dsp pro tools version. so you might only get a high pass, two shelves, 1 sharp bell, and one boost or cut. you might put the 3 band on a pro tools session and you're like "a high pass, a box cut, and a high shelf" on a snare and that might be all you do and move on because it sounds okay and that's all you can do without another insert but it sounds good enough vs someone with pro q trying to push up where the fundamental and wires are. maybe that might sound better but you don't have the bands for that on a 3 band eq. or maybe you are still unhappy and compare similar filters in both to see which one sounds better and then go with that one. you can easily lock yourself into some kind of path dependency even with basic tools and familiar habits.
Post by sentientsound on Jun 17, 2023 13:36:59 GMT -6
I generally like his videos - I respect the effort to which he goes in explaining things, with even pacing and accompanying examples. He also doesn't claim to be any authority on quality, generally keeps a good mood and encourages people to be respectful and reasonable in duscussions or on company promo videos...despite this it seems many people online are using his videos as definitive takes or "truth" to support their arguments. Anyway...
Kirchhoff for me is my main goto EQ, especially after experimenting with the filter settings, themes, and UX shortcuts.
I have a default preset with several types of dynamic bands there but bypassed for quick de-essing, bass resonance, mud suppression, or mid expansion. Those took a while to tune well, but can be copied-in-place quickly if I need more, or fine-tuned together.
The Sword filter is also really useful for dipping harsheness in the high mids for me.
Using this EQ in a mastering context with most adjustments within +/- 1.5dB, it does feel extremely clear to me, more so than some others.
That 117bit button is a bit silly though. I swore I could hear a more open sound on very dynamic/busy mix sections but the blind and null tests were humbling.
Post by Deleted on Jun 17, 2023 23:42:37 GMT -6
I generally like his videos - I respect the effort to which he goes in explaining things, with even pacing and accompanying examples. He also doesn't claim to be any authority on quality, generally keeps a good mood and encourages people to be respectful and reasonable in duscussions or on company promo videos...despite this it seems many people online are using his videos as definitive takes or "truth" to support their arguments. Anyway... Kirchhoff for me is my main goto EQ, especially after experimenting with the filter settings, themes, and UX shortcuts. I have a default preset with several types of dynamic bands there but bypassed for quick de-essing, bass resonance, mud suppression, or mid expansion. Those took a while to tune well, but can be copied-in-place quickly if I need more, or fine-tuned together. The Sword filter is also really useful for dipping harsheness in the high mids for me. Using this EQ in a mastering context with most adjustments within +/- 1.5dB, it does feel extremely clear to me, more so than some others. That 117bit button is a bit silly though. I swore I could hear a more open sound on very dynamic/busy mix sections but the blind and null tests were humbling. Oh he's a good presenter. He just makes some silly claims about silly plugins and silly gear and repeats internet talking points about them when this is about tone and some of us are dealing with things that are essentially just filtered, shaped distortion so whatever tone compliments them best is the one to use and this is a game of inches at some point for the more OCD of us. Kirchoff just has 117-bit to beat the PSP Master Q2 which is 80-bit, which was always a bit silly.
