Post by Tbone81 on Jun 1, 2023 19:51:39 GMT -6
I'm tracking a country trio this saturday. Acoustic Guitar, Vocals, Fiddle, and Upright Bass. I've never worked on this genre but have done plenty of acoustic, folk, singer songwriter etc etc. The band will be tracking live. The bass player has a pickup with DI so I'm going to take that just in case. And I planed on using a Wunder Cm7 fet on it as well. I'd like to use a second mic as well since I'm not really confident tracking an upright bass. What other mic would you use? How would a dynamic (RE20, etc) sound? The session is at Jack Pot, mic list is here: jackpotrecording.com/equipment/
Any other tips or tricks when tracking upright bass?
Thx
Post by woofhead on Jun 1, 2023 21:16:12 GMT -6
I like ribbons combined with a small diaphragm so I would rec. the AEA R44CXE they have. Usually I like a km84 pointed at the place the bassist pulls the strings about 8 to 10 inches out and the ribbon is lower approx in line with the bridge sometimes not pointed directly at the body but angled slightly in either axis, but that position can vary a lot depending on the bass, setup, and the player. I also like a dpa 4060 clip on mic instead of using the di. Is there isolation or is everyone in the same room? The null of the ribbons can of course be very useful.Good luck, Mike
Post by notneeson on Jun 1, 2023 21:17:40 GMT -6
Thx
I have had some good results with a Royer 121 on upright, for low mid richness. The cheaper 101 works well too. Have also snuck in a little of the DI hitting SSL style compression for a little snap. I feel like I also used a KM84 to good effect many years ago. When in doubt, think of it as a huge cello. Or so I tell myself.
Post by woofhead on Jun 1, 2023 21:18:17 GMT -6
also like beyer m160 in the finger position and if its all in one room this will be better for isolation but not sure they have one
Post by woofhead on Jun 1, 2023 21:22:50 GMT -6
I record a lot of jazz btw but have done this kind of combo in a folk or country idiom a couple of times for what its worth
Post by ab101 on Jun 1, 2023 21:24:18 GMT -6
I always use an sdc condenser as one of the mics. Sometimes along with an R44 type mic or other great mic for deep bass. It does not hurt to record the pickup along with it. Even if it is three tracks total, you do not have to use all three tracks. My 2 cents. I am not the expert. When I hire an upright bass player for my projects, who is often a guy who actually won a Grammy and has been playing jazz bass and folk for many decades, and he usually tell me what they have done in other studios! I have found that I am grateful I have that sdc condenser to mix in.
I am sure Jackpot knows more than me along with others on this board!
Enjoy! Sounds like fun!
Post by woofhead on Jun 1, 2023 21:26:00 GMT -6
Some of those Impulse records from the 60s used the 84 on the bass not sure which but I have heard love supreme Coltrane
Post by schmalzy on Jun 1, 2023 21:47:00 GMT -6
I used an SDC near the bridge pointing upward-ish toward wherever the player was plucking about 8 to 12 inches back to get as much detail as I could (distance depending on movement - this is a full body instrument so it's probably going to dance around a bit) and an LDC a little further back aiming to get more warmth and bump.
Take the DI. I've never regretted it. Whether an acoustic guitar, an electric guitar, or an upright bass the DI always finds a way to be useful or at least a great backup to ensure no magic performances are lost to too enthusiastic a performance with too much movement.
Post by EmRR on Jun 1, 2023 22:01:02 GMT -6
SDC omni
Post by unit7 on Jun 2, 2023 3:48:46 GMT -6
Some of those Impulse records from the 60s used the 84 on the bass not sure which but I have heard love supreme Coltrane With a high energy drummer like Elvin Jones playing in the same room you need to put that SDC (84 or whatever) wrapped in foam or hanging in rubber bands in the bridge of the bass, pointing upwards, this to avoid too much bleed of course. It works swell! I've tried SM57 in this position too as it picks up less of the room, and the result is jaw dropping. Needs a bit more eq but works surprisingly well! But if the bass is isolated my go to is a large condenser 4" in front of the bridge. If you need more detail raise it towards the players hand. I'm a fan of using only one mic and finding a sweet spot, for phase reasons. Some like it, but I usually avoid the f-holes. Many basses have a bit of extra resonance around the low C-C#-D-D# region, and in my experience that resonance is even more present around the f-holes.
Post by Ward on Jun 2, 2023 6:32:11 GMT -6
Either a U87 or a U47FET 2 feet (I think that's 62cm) away from the instrument, aimed at the bridge. and if you get too much 'arterial spray', back away until it sounds natural.
Post by christopher on Jun 2, 2023 8:53:06 GMT -6
I’ve used RE20 right at the F hole, with di pickup as backup. The DI helped for sub bass. The RE20 had a dynamic tone I expected, it was usable. The pitch intonation on fretless was the biggest hurdle. So if I had to go back, I’d work hard to get awesome monitor feed so they have the best chance at playing up to their ability
Post by Tbone81 on Jun 2, 2023 8:54:16 GMT -6
Thanks guys, lots of good info here. To be clear, I'll be using two mics with the goal of capturing a complete sound with each mic. The primary will be the CM7 Fet because a fet47 is kind of a no brainer. The second mic will be my backup. Also will be taking the DI out.
Its undecided weather I'll have them all in the same room, separated by baffles and careful positioning, or utilizing iso rooms.
Post by svart on Jun 2, 2023 8:56:16 GMT -6
I used a Gefell M930 about 2ft from the floor and maybe 2ft back from the bass, facing up towards the place between the plucking and the fretboard. Seemed to get the most balanced tone from this particular bass. I suspect your mic will need to be around this area too, balancing the tone between the plucking, the soundholes and the fretboard.
Post by jaba on Jun 2, 2023 9:13:04 GMT -6
I second the RE20 seeing as you already have the FET47, DI, and they're playing live. It'll give you an alternate tone (depending on the songs and/or style of playing you'll likely want different tones on hand), and if bleed's potentially an issue, the RE20/DI will help a lot.
Post by woofhead on Jun 2, 2023 9:26:38 GMT -6
I used a Gefell M930 about 2ft from the floor and maybe 2ft back from the bass, facing up towards the place between the plucking and the fretboard. Seemed to get the most balanced tone from this particular bass. I suspect your mic will need to be around this area too, balancing the tone between the plucking, the soundholes and the fretboard. I want to try the m930 on bass..Have thought of it many times but those bass players are always so busy working theres not a lot of time to try stuff. Just the other day I was plotting to invite a neighbor bassist over to try some mics I haven't before and I know what they like to drink so thanks for the reminder-the 930 was one on the list.Also just got a samar mg20 I want to try
Post by ab101 on Jun 2, 2023 10:44:17 GMT -6
I used a Gefell M930 about 2ft from the floor and maybe 2ft back from the bass, facing up towards the place between the plucking and the fretboard. Seemed to get the most balanced tone from this particular bass. I suspect your mic will need to be around this area too, balancing the tone between the plucking, the soundholes and the fretboard. I want to try the m930 on bass..Have thought of it many times but those bass players are always so busy working theres not a lot of time to try stuff. Just the other day I was plotting to invite a neighbor bassist over to try some mics I haven't before and I know what they like to drink so thanks for the reminder-the 930 was one on the list.Also just got a samar mg20 I want to try I would definitely be checking out that Samar MG20. And as I said before, if you have multiple mics and/or the DI, obviously not all that has to be in the mix.
Post by EmRR on Jun 2, 2023 10:56:42 GMT -6
This lineup, you don't really need separation, you just need multiple takes to edit between. The classic 47 M7/K47 does always sound good here. Omni SDC also wins for lack of proximity effect problems, best actual low end. Need iso with a drummer? Only thing I've ever used that worked acceptably has been the Lauten LS-308. It's tricky regardless. I've tried double omni's spaced so I could use one for RX de-bleed, etc. Can get good results but not as no-brainer as the LS-308 has been. I've done a lot of rockabilly bass/drums with 2 omni's on the bass, some baffling to kill cymbal highs. Works OK. The weirder the mic pattern (LDC's....), the weirder drum bleed will be.
Post by mcirish on Jun 2, 2023 13:59:59 GMT -6
I track upright very often. I started with a CM7GS 18" out from the f hole that's away from the player. After a few years, I switched to a beyerdynamic MC930. The last two were variation. Two weeks ago I used an R84A at 18". It was a bit too big sounding and not so balanced. I then stuck a Line Audio Omni one in some foam and set it into the tailpiece. I rolled off the super lows on that and mixed it with the R84A. Came out very nice.
Post by Ward on Jun 2, 2023 15:41:11 GMT -6
Hmmm.
I have several Gefell 930s and Beyer 930s Both entirely different mics. Next time I have to record a ‘canoe’ I’ll try them if time permits.
Post by mattiesmith on Jun 2, 2023 16:15:06 GMT -6
Ok, I popped on to reply to another thread, but saw this and wanted to chime in. There are a myriad of ways to capture an upright and get a good tone. From my past experience, the trick is really to get a good representation that sits in the mix-and-has bleed. More times than not when I’ve encountered this type of outfit, they either prefer to track together, or they simply just performed better when tracking together. At this point, options become much more limited. I used to-(take a DI feed if they have one on the bass), wrap a towel around a good dynamic and fit in the bridge aimed up at the frets(I think I used a Beyer X3 for this), and use an Omni SDC up on the instrument. As Doug pointed out, bleed is going to happen- make it good bleed. The SDC can get close without proximity, and the HF pickup will actually be pretty directional. At the very least, make a solid plan on how to get the sound with everyone together so you are not caught off guard in that event.
Post by rowmat on Jun 2, 2023 16:26:04 GMT -6
Here’s an old photo of a Flea 47 Classic and a Neumann KM84. Ribbons combined with SDC’s also work. Just check the phase. Another great upright bass mic is the Neumann U77 (hard to find) but that is great on just about anything.
Post by ericn on Jun 2, 2023 17:49:38 GMT -6
If you are going to reach for anything but an Omni on bass you really have to know your mics and their proximity effect, otherwise you either end up with a boom or an unexpected dip all of a sudden. I really like medium diaphragm condensers on upright. A lot of live guys and some studio guys seam to be happy to treat Bass more like a single note instrument rather than take the time to dial it in and get recognizable pitch.
Post by sean on Jun 2, 2023 20:57:54 GMT -6
I’ve really come across two different bass tones: the bluegrass “thump” (Barry Bales, Dennis Crouch, Mike Bub) which is usually heavily dampened (pillow in the bridge to mute resonance/cut sustain) and/or gut strings. The other is what I call “lead bass” like Edgar Meyer, Paul Kowart, or Todd Phillips. More open, more throaty, usually steel string.
The thump is comes from down on the F hole/around the bridge and the “detail” I find is above the F hole on the part of the bass near the high strings. Over the neck is usually just clacking/more noise than you’ll want, too close to the right hand fingers and it might have too much “pluck” or the sound of the strings being pulled…but that upper bout that’s exposed usually sounds great.
So, that’s usually where I put the mics. Omni is great. I usually like to use a multi pattern because sometimes cardioid is better. Maybe try a pair of their U47 style microphones so you can easily A/B Omni and cardioid.
But it really is all about the instrument and the player if it sounds good. Have the player move around the room and play and find a place where the instruments speaks and sounds even. Some instruments as mentioned have really loud “woof” tones and some have notes that are just totally dead.
Post by the other mark williams on Jun 2, 2023 21:11:29 GMT -6
Everybody has said such good things here, but I'll just add one more thought that I don't recall anyone mentioning:
I think it's important to determine what role the attack of the upright plays in a given band, and to make sure and capture that. What I mean is that I've seen some bluegrass situations where the person playing upright is actually a key component of the "percussion" in the band - they're actually using their fingers to attack the instrument in such a way as to keep time for the band in lieu of any other obvious "percussion". In those instances, it may be necessary to put an extra mic up near the fingers just to capture that slap. Then you can use something like spiff to get rid of everything but the attack on that mic and blend it in to taste.
It's not the most usual situation, but I've seen/heard it before.
