Post by guitfiddler on May 26, 2023 12:34:58 GMT -6
Anyone know a good reasonable tech? I want to use these two units
Post by jmoose on May 26, 2023 18:58:25 GMT -6
What's wrong with them?
Maybe you'll have better luck then me... about 10-12 years ago I bought an R7 that was said to be in perfect shape... and it was. For the first hour... then all the fun started. Display went blank, glitchy audio etc.
At the time nobody wanted to touch it saying there were no parts or schematics available. Based on a friends experience with an APR 24 I wasn't shocked.
Ended up getting a refund. Buzzmer because it really is a great reverb.
Post by guitfiddler on May 26, 2023 19:21:48 GMT -6
They are making a really bad scratchy static sound. I was told to put pads under the board because of the weight of the components. Seems that just might be the issue? Not sure though. These units sounded great at one time
Post by mcirish on May 26, 2023 20:11:13 GMT -6
If I'm thinking of the same pieces, I fixed about six of them two years ago. They have copper buss bars that run over the top of the pcb. In all cases, the solder was bad and I had to resolder those bars. They all needed new batteries and one needed a display. Kind of time consuming.
Post by ericn on May 27, 2023 17:53:01 GMT -6
Good luck, Sony, digital and support are contradictons.
Post by mcirish on May 28, 2023 20:35:09 GMT -6
I believe I found some schematics somewhere, but can't be sure. I can dive into the depths of my work drive and see if I can find anything if you'd like.
Post by guitfiddler on May 29, 2023 18:52:50 GMT -6
I believe I found some schematics somewhere, but can't be sure. I can dive into the depths of my work drive and see if I can find anything if you'd like. That would be very helpful, I would really appreciate that. Thanks
Post by mcirish on May 30, 2023 12:32:47 GMT -6
I believe I found some schematics somewhere, but can't be sure. I can dive into the depths of my work drive and see if I can find anything if you'd like. That would be very helpful, I would really appreciate that. Thanks Send me a PM with your email and I will send what I have on those units.
Post by guitfiddler on May 30, 2023 16:47:19 GMT -6
That would be very helpful, I would really appreciate that. Thanks Send me a PM with your email and I will send what I have on those units. Thanks
Post by mcirish on May 31, 2023 12:51:20 GMT -6
I posted a link to everything I have for the Sony in PM. Hope it goes well. I did fix a lot of those. Most problems were bad solder on buss bars. battery and a bad display on one.
