Post by viciousbliss on May 14, 2023 3:52:12 GMT -6
Recently I found some unclaimed property that I'm considering as a source of funds for some more hardware. I'm not sure how much tax I'll have to pay. When I was watching some Youtube, I asked Paul from Audio Animals what he'd recommend to go with my Fusion if I could choose 3 pieces. His recommendations were Black Box(to use in lieu of Vintage Drive), Buzz REQ(in Fusion's mid-side insert), and SPL Iron. I've just tried Black Box with Access Analog and while it was a little messy getting it to work, I heard enough to know that it was much more lively and wide than the plugin. For some reason I was getting some unpleasant distortion through AA, but if you took that out, I think the Black Box on its own sounds better than Fusion plus plugins. It definitely didn't get better when I ran the rendered AA file through Fusion or plugins. I tried turning off Vintage Drive and the Transformer while using the PA versions of Black Box, SPL PQ, and Iron and it just sounded shrill. Had much better luck putting all modules of Fusion back on, keeping Vintage Drive to a bare minimum, and then adding either DS-1 MKIII, Oxford Limiter, or Pro-L2.
In another video, someone asked Paul what mastering chain he'd build if he only had 10,000 pounds and he suggested they get all Bettermaker gear. I've seen the original mastering limiter sell for under $1000 a couple times in the completed listings. Plenty available for $2200 across multiple sites. There are some good used prices on the sold listings for a lot of stuff, but there's barely any of the lower priced inventory on Reverb. It was tough to find one website that even listed Black Box as in stock. Silver Bullet is something I'm considering along with the Portico MBP. There's not a lot of info on Iron V2 or Better Maker Mastering Limiter 2.0 either. The plugin control of Bettermaker and Wes Audio is definitely intriguing.
Having DRC2 makes me wonder how desperately I'd need to spend thousands on something like Iron. When I reread that thread I saw that Dan recommended some inexpensive Aphex compressors. Paul at Audio Animals said he loves the Fusion and Bus+ combo but was not a fan of Fusion and the Portico. But I've heard stuff on Youtube that only went through the Portico that sounded tremendous. A lot of these videos use mixes that are so good that they sound really good on any hardware they throw them at.
I'd like to try Vertigo VSM-4 again, but I'm thinking even if it's the best saturation plugin ever, it probably won't be in the same league as a Black Box hardware piece. Sa2rate 2 hardware is only $865 new and I like the plugin quite a bit. For all I know, I'd be just as satisfied with it as a Black Box.
What do you guys think of going the 500 series route? The Neve Tape 542 sounded awesome, but I've been told some Roger Mayer tape was even better. Seems a lot of hardware is made to order. Cranesong was also something I was considering, does anyone know how they are on orders these days?
Tomorrow I may try the Portico on AA and see if they will let me try the Black Box again after I had so many problems tonight. Thanks for any advice and it'll be a lot of fun to check out the recommendations.
Post by kcatthedog on May 14, 2023 4:30:08 GMT -6
What’s your actual budget?
What are you trying to achieve in your mix: dimensionality snd weight ?
If are looking used, there is a SB now in classified, they don’t come up that often used.
Now would also be a good time ti buy a used Bettermaker limiter mki as so many are on the market.
Post by thehightenor on May 14, 2023 6:53:55 GMT -6
Recently I found some unclaimed property that I'm considering as a source of funds for some more hardware. If you don't mind asking, what did you find .... a house? You've tickled my curiosity :-)
Post by viciousbliss on May 14, 2023 7:37:20 GMT -6
It’s complicated. Old investment accounts that should have gone to my siblings and I about two decades ago that my parents forgot about. There’s a little more to it than that. Budget depends on financing options too. Depending on what I elect to go with, I’ll end up financing some with other income.
I’ve never been satisfied with the ability of plugins to recreate the sounds of classic albums. And very few modern albums seem able to pull it off. Rave in Fire may have done it the best of anyone I’ve heard. When I hear the effects of Fusion and other good hardware, it’s very much a “that’s more like it” thought.
I notice that on a lot of classic stuff that mixes aren’t always well-balanced. But it works because that analog gear was so forgiving. Right now I don’t have the budget for multiple real expensive things. Maybe I could swing a Black Box and a Bettermaker piece if I’m lucky. But things may change to where I can negotiate to get something more. For all I know I’d be perfectly content with Neve’s $650 500 series chasis thing and two 542 tape modules. It’s tough to say because my experience with hardware is limited to owning Fusion 11 months and a disjointed hourlong experiment with AA’s Black Box.
Post by thehightenor on May 14, 2023 12:56:29 GMT -6
It’s complicated. Old investment accounts that should have gone to my siblings and I about two decades ago that my parents forgot about. There’s a little more to it than that. Budget depends on financing options too. Depending on what I elect to go with, I’ll end up financing some with other income. I’ve never been satisfied with the ability of plugins to recreate the sounds of classic albums. And very few modern albums seem able to pull it off. Rave in Fire may have done it the best of anyone I’ve heard. When I hear the effects of Fusion and other good hardware, it’s very much a “that’s more like it” thought. I notice that on a lot of classic stuff that mixes aren’t always well-balanced. But it works because that analog gear was so forgiving. Right now I don’t have the budget for multiple real expensive things. Maybe I could swing a Black Box and a Bettermaker piece if I’m lucky. But things may change to where I can negotiate to get something more. For all I know I’d be perfectly content with Neve’s $650 500 series chasis thing and two 542 tape modules. It’s tough to say because my experience with hardware is limited to owning Fusion 11 months and a disjointed hourlong experiment with AA’s Black Box. Thanks for the insight :-) Yep, analogue magic. Every time I think it's time to downsize, go fully in the box and shrink my system .... I do an mix on my rack of high end boutique tube and solid state gear and think .... no I can't let this stuff go - it's the sound I have in my head. Even though having the money would be nice of course, having the ability to make professional sounding classic old school records is nicer.
Post by Deleted on May 14, 2023 13:01:32 GMT -6
Keep your money. You don’t need this stuff The primary purpose of the color boxes is to make records not sound plastic on crappy playback systems or just crappy playback circuitry. This includes a lot of common monitors and crappy converters.
So you distort it more! Console plugs, tube plugs, fake pres. Man I like all that shit but it’s all distortion to distort it more than the customer’s crap. A lot of it cannot equal the complex distortion in a mixer or nasty stereo compressor even if it measures clean it still has complex distortion that cannot be captured by a simplified circuit model and most multichannel interfaces are either crappy like a Focusrite or rme or pretty clean like a Lynx. So you do the producer special and stack up the plugs until the sound stops getting cooler and a lot of crappy monitoring setups encourage you to do this just like they encourage you to run stuff through analog gear that might as well be a mid guitar pedal or total mush
A mix that wasn’t terribly recorded and uses Kotelnikov GE or MDWDRC2 and a clean eq sounds rank on NS10s and cool in a car is because NS10s are high distortion speakers. If it sounds plastic on JBLs but punchy on a better system is because of the sound the JBLs are adding and terrible crossovers. All of the 305/306/308/705/708 have weird midranges because of the crossovers. Genelecs sound more like Genelecs than anything you’ll hear outside the Genelec brand too.
You can tone chase as much as you want but there’s a lot of good stuff in the box now and you no longer have to crap all over everything with something like Inflator or Waves garbage to get a consistent “more distorted than the system” distortion on all playback systems. Sure you can go to the purple background site or Reddit and hear mastering engineers defend crappy limiters and clippers and hear people crap on waves but defend the crappy well-advertised lofi plugin of the month that sounds worse than Waves Ren Maxx and a million testimonials from guys with analog hardware but 80 instances of ozone about it “sounds analog man and made me sell my hardware” then it sounds worse than an 02R or a Behringer product and looks absolutely rank in an analyzer.
You don’t need this stuff and probably have everything you need already to made a cool sounding mix. You just need good material to start with.
/rant
Dan
Post by drbill on May 14, 2023 14:09:25 GMT -6
Ahhhhhh....if only that was true for me Dan. I could buy a vacation home. Or maybe an exotic super car. Or vacation every year. Or buy a few 59 Les Pauls..... Unfortunately (or happily for me) the 120 channels of AD/DA, the 240 rack spaces of gear, the hundreds if not thousands of knobs and switches, and the electricity it takes to power it all up is hugely worth it to me. Sorry....ITB? Not gonna happen. Not here anyway. So...for the OP's question.....Sorry, it's to personal of a question and necessitates crawling into your brain, ears and work flow. I think you have to figure it out for yourself. For me the fusion doesn't really get it, but OUTBOARD certainly does. Try to find what works for you, or figure out what you think your missing and head that direction. It's a long journey that takes a lifetime. Buy at a discount (used is great), and don't sell unless something absolutely doesn't work for you. Pretty soon you'll have a nice collection. Good luck.
Post by viciousbliss on May 14, 2023 15:57:30 GMT -6
If we're just talking pure mixing, yeah I do it all with plugs. Fusion was better than a bunch of plugs on my sub-mixes, but I found it a bit awkward because it sounds so much different from plugins. Then there's the whole recall thing. If I were to mix with hardware added, Bettermaker or Wes Audio seems like a smart idea so that I can control it all with plugins. If stuff is tracked well with a lot of hardware, I imagine that negates the need to use a ton myself. I've played around with this song called Burning Bridges by Dark Ride from that Cambridge mixing library and I don't even use Satin on the tracks because it feels like too much. So, I go to Cranesong Phoenix there. Still use Satin on sub-mixes, but with a lot less color. Jake from Blood By Design told me he used nothing but plugs on The Ancient One. Valhalla Room, Waves, amp sims, stuff like that. His mastering guy must've soaked it with hardware. The album sounded brilliant on a Sansa Clip and Beats Ep headphones but on the Aurora N, I can hear some issues. The headphone section of the Aurora N is pretty unforgiving of bad sources. But makes great sources sound phenomenal. A lot of those 90's Black Metal albums just reveal themselves to be horrific balls of bad distortion. The best ones still hold up like Stormblast and Storm Of The Light's Bane. I tried some Gorgoroth for the first time and it was just really bad. Blizzard Beasts was another that the Lynx revealed all the flaws on.
I'll try the Portico and maybe Culture Vulture later and see how that goes. Apparently my internet upload speed is not so hot even using a wired connection with one of the more high bandwidth cables. To really thoroughly test these hardware devices, I'd have to pay Access Analog for at least $100 worth of time. I'm trying to be conservative with how much I spend on hardware. With how much GPT4 advanced over ChatGPT so quickly, I'm wondering if in a year or two we see some big breakthrough in audio tech where someone figures out how to model most any analog hardware 100% in a way that works with current computers. Or maybe some big innovation happens with home computing and we get computers 10x more powerful before I could even pay off something like an SPL Iron on layaway. It's inevitable that all this hardware will be accurately, probably within the next decade.
Anyone use Vertigo plugins? The comparison between the VSC3 plugin and hardware was impressive enough that I got the VSC3 a few weeks ago.
Post by ericn on May 14, 2023 19:58:20 GMT -6
I shall suggest what I’m surprised Bill didn’t a Silverbullet, functionally a bit of a duplicate of the Fusion, Sonically very different.
Post by thehightenor on May 15, 2023 1:38:28 GMT -6
Ahhhhhh....if only that was true for me Dan. I could buy a vacation home. Or maybe an exotic super car. Or vacation every year. Or buy a few 59 Les Pauls..... Unfortunately (or happily for me) the 120 channels of AD/DA, the 240 rack spaces of gear, the hundreds if not thousands of knobs and switches, and the electricity it takes to power it all up is hugely worth it to me. Sorry....ITB? Not gonna happen. Not here anyway. So...for the OP's question.....Sorry, it's to personal of a question and necessitates crawling into your brain, ears and work flow. I think you have to figure it out for yourself. For me the fusion doesn't really get it, but OUTBOARD certainly does. Try to find what works for you, or figure out what you think your missing and head that direction. It's a long journey that takes a lifetime. Buy at a discount (used is great), and don't sell unless something absolutely doesn't work for you. Pretty soon you'll have a nice collection. Good luck. Yep me too. It might work for Dan, but to my ears software doesn’t get within a country mile of the sounds I can get from my hardware, be it tracking, mixing or mastering. A second hand Porche Panamera would be nice though!. Not that my wife would let me buy one if I cashed in my hardware LOL.
Post by Deleted on May 15, 2023 11:11:41 GMT -6
A ton of utilitarian analog gear is discontinued and nothing new is being designed because analog gear has mostly become retro fetishism and distortion vision quests for rich hobbyists outside of a couple of select modern pieces that do things that purely digital comps haven’t bothered with yet. The retro stuff just isn’t very flexible. One or two trick ponies.
Analog might get you want you want faster if you say, want an ssl bus, smart research is still there but it has improved circuitry so obviously the distortion vision quester won’t be 100% satisfied until he has a ssl g384fx or x-logic with decayed out of spec parts in it if the 23 year old fresh out of college buyer has even heard an ssl branded ssl bus today off of YouTube. if you want a clean vca there are the fmr, elysia, dangerous, and daking right now but people aren’t buying those because theyre not hyped to 11 on the internet and they fetishize gear that does something very colored (either by tone, distortion, or action), don’t record or mix anyone else’s music, and like older records for the music even if everything that had to be heavily processed on them was mostly janky sounding. Making someone else’s snare janky sounding? Ugh…
Take a common compressor on a snare. It can be 1176, distressor, or dbx 160 anything you want really that’s full range and flexible. Either you want some overshoot for a harder hit or to even it out. You do that but say the high frequencies, the snare wires, tend to be damped by the compressor more than you want. So the tone chaser uses the 1176 or dbx 160 for more attack but the wires get quieter which is a bit ridiculous. And often the snare bottom sucks or there isn’t one to be processed independently.
One solution to use a high frequency shelf before will trigger more compression on the snare wire. A shelf afterward raises the already over modulated wires and bleed. Shit it sounds bade? What to do?
If fresh engineer got a purple mc77 instead of a pure 1176 clone or a distressor or dbx 160 or whatever is hyped as a great snare compressor,, he could just use a sidechain insert but he didn’t buy that because of decades old forum discussion, price, the sound wasn’t to his taste, and it’s not what people used 30-50 years ago back when artists practiced and prepared more before going in the studio so they needed less processing or someone else played somebody else’s drum kit on the record. So fresh engineer abandons the tone chasing and uses a compressor with side chain you try the sidechain insert (or dip switches like a bss dpr) to make it so the wires won’t trigger the compressor. It still might not work well.
If it doesn’t, then it’s time for gross multiband phase shifted madness, frequency specific behavior digital compressors like Kotelnikov and Unisum, or vca compressors with high frequency expansion built in. The aforementioned Aphex Expressor is discontinued but there’s none of the holy grail distortion there. The Drawmer DL251 is supposedly still made but it’s harder to find used than a DL241 and again no magic box distortion. U-he Presswerk has a high frequency expander built in too but it’s 130 bucks and our fresh engineer won’t pay over 30 bucks for a plug and can’t even set his 1176 clone so Presswerk and Unisum are beyond him.
Oh but we know fresh engineer he tracked the snare through the 1176 clone. So the wires are just fucked and he has a damped, distorted drum to mix and probably just distort more to make it sound cool and nothing like the snare. Maybe his drummer will be okay with an industrial sounding drum or a sample.
Anyway, getting a bunch of retro stuff or tone chaser for your perfect tone won’t necessarily solve your problems in the way that more flexible equipment can, much of that is discontinued, and what’s in the box is more advanced than almost all of what you can easily purchase now unless you get some crazy Elysia rack or something that rivals it but that sort of gear is far from simple and might have distortion you don’t want.
Post by drbill on May 15, 2023 11:22:10 GMT -6
Wow. Retro fetishism eh?? You obviously have put some thought into this and are very passionately anti-outboard / analog. Seems to be all about compressors and distortion for you as you contemplate analog gear. I'm just naturally curious - how much outboard, and what type of outboard do you own? Also, you do metal if I recall, right?
Post by jaba on May 15, 2023 12:30:46 GMT -6
Tools are tools. Use what works for you. For their sound yes, but never discount workflow. Whatever keeps your head in the game is invaluable, likely more than Gear A vs Gear B.
I'm damn happy with what I can do ITB and zero complaints from clients. I'm also lucky to have spent countless hours surrounded by classic outboard/ tape routed through a killer console so appreciate the hell out of that stuff too. Currently looking at getting some vibey outboard for my home mixing because in the end I know it inspires new sounds, I love a certain amount of hands-on interaction, and I can track through it which will make mixing easier and faster.
People convinced that the new retro-FET clone will solve all their problems will never go away. That's fine, all the power to them. Me, I'm going to try to get inspired and get better with whatever tools do that for me.
Post by Deleted on May 15, 2023 12:59:21 GMT -6
Wow. Retro fetishism eh?? You obviously have put some thought into this and are very passionately anti-outboard / analog. Seems to be all about compressors and distortion for you as you contemplate analog gear. I'm just naturally curious - how much outboard, and what type of outboard do you own? Also, you do metal if I recall, right? i am not anti outboard or anti analog. I am anti the top selling compressors on B&H and Sweetwater, anti what is hyped on gearslutz, and Very anti what is advertised on gearslutz. If you can find a bunch of flexible gear or buy separate X, Y, Z to do X, Y, and Z that’s cool but I find I can still manipulate flexible tools to do more of what I want most of the time. The problem is most of them sound like garbage and are built cheap from IC example builds and circuit and dsp textbooks. And they’re harder to learn most of the time. Like parametric eqs with constant q that have limited headroom or poor circuitry and suck on boost or dynamic processors that suck when sped up or dug in. the most bare bones of those flexible one that I’ve liked are the old Oxford Dynamics and the recent Art Limiter and the others just get even crazier. Sonnox doesn’t even tell users outright that it’s a multifx processor with a single vca modulating the audio in the end and I learned things about the art limiter from the mxr 136 manual that aren’t in the clone’s manual. I don’t use any analog compressors anymore to mix. I still have an RNC in a closet and have had a 160a and some other junk I never touched on a mix but Neither were ever really that much better than plugs even if all the 160 plugs suck. RNC kinda sucks too outside of super nice mode or basic envelope shaping duties and Presswerk and Molot killed a lot of desire to use it and buy others when I bought them a few years ago. If you want the stupid dbx 160 transient for example, the old free Molot always had more control and better tone. I switched to apogee symphony desktop from a multichannel motu AVB rig. Huge upgrade but only 2i 2out. I hated the motu inputs anyway and never used them for inserts when I realized the ouput circuitry was so much clearer than the input. If I had the ins or a real symphony rack mount or something, I’d take an Aphex Expressor or two, maybe some modern vcas and cool eqs with fun inductor shelves and maybe a weird bus comp or flexible two bus distortion thing to patch in early and work around to get some ballistics gel and ride faders into. I still want to pull some underrated stuff out of live racks but A lot of what I see is beat to hell or is crap or reverb pricing has made it way too much money even on Facebook marketplace. The expressor is better than Presswerk much of the time for that high frequency expansion effect because there’s no phase shifted top end and less distortion. A sort of small mixer would also be cool like an expanded version Of that Alice thing or a modernized old school Tascam but balanced but it would need to have a lot of insert points to go in and out of the daw more while summing and push the circuitry of while keeping the digital options. There are so many cool tones and processors that only work easily without heavy editing in the present with a digital workflow and stuff like sidechained dynamic eqs and automation of processors to carve out space in a way that the AI stuff like trackspacer and soothe can’t. Or recordings of guys stomping on pedal boards and you can edit and process everything differently. Think like gates on live sound mics or multiband stuff on a digital live console but this is in a daw and the processing doesn’t suck. Nova GE has an unintended use as a wicked channel strip for example that kills anything you can get in a console (or a channel strip plugin) at the cost of latency. I mostly do metal and don’t use samples really at all unless they’re rendered into the track already. I found years ago that most of the “metal” drum samples itb sound awful unless heavily processed and the software doesn’t want you to extract the individual hits easily if only a few midi velocity ranges sound good. I might as well process it myself. And can get a pretty wide varieties of tone now itb even if I gravitate towards certain workflows with certain routings and plugs. I can already get too much “digital artifact free” distortion. Something like that pulsar 8200 already sounded like it had too much distortion when boosting heavily while not being distorted enough if you get my drift. And don’t believe anyone who says big boosts aren’t realistic uses. I like cassette stuff. Big bass or treble shelf fed into something that eats bass or treble can sound extremely cool. Just like big wide bell like on a proportional eq into something that will saturate it off or saturated or clipped off compressor overshoots sounding big. The Sonnox transient shapers even encourage you to do this because it’s all built in.
Post by viciousbliss on May 15, 2023 14:43:26 GMT -6
Dan, do you do a lot of mastering?
I found a Black Box in stock, anyone think I should try to snag it?
Post by drbill on May 15, 2023 15:10:38 GMT -6
Wow. Retro fetishism eh?? You obviously have put some thought into this and are very passionately anti-outboard / analog. Seems to be all about compressors and distortion for you as you contemplate analog gear. I'm just naturally curious - how much outboard, and what type of outboard do you own? Also, you do metal if I recall, right? i am not anti outboard or anti analog. I am anti the top selling compressors on B&H and Sweetwater, anti what is hyped on gearslutz, and Very anti what is advertised on gearslutz. . OK. Just trying to understand you as my experience is pretty different - both in terms of analog gear and in terms of the music we do. Specifically if you can, what are those top selling and/or hyped on GS compressors that you really don't like?
Post by copperx on May 15, 2023 16:09:41 GMT -6
Not that my wife would let me buy one if I cashed in my hardware LOL. At least hardware doesn't depreciate as quickly as a car! Although, if you're lucky, the resale prices keep up with inflation, which is slightly better than keeping the cash under the mattress. But I love compound interest more than I love hardware (and I love hardware).
Post by viciousbliss on May 15, 2023 21:03:18 GMT -6
Youtube started playing me this Audio Animals video about why they choose certain analog gear and he mentioned how if the UnFairchild costs 14k and makes that back in two months that it's worth its weight in gold. And he mentioned that they get at least two emails a day requesting to have tracks run through it. I'm guessing that the month mark may have been just a random timeframe he tossed out there, but I'm definitely curious what the general odds are to earn a return on investment for a piece. Later on in the video he mentions that hardware versions of stuff like these PA plugins are great enticements for producers who use the plugins. When I took a quick look at websites for studios near me, I don't see any of the latest and greatest gear listed. Or a lot of holy grail type stuff that people want to use. Seems like a lot of studios splurge at the beginning and don't continually add stuff. Where they really come up short is on marketing and branding. After viewing all those sites, I couldn't tell anyone much about their respective brands or why I'd want to choose them. Now plugin companies, they really excel at branding. Slate and Waves have such tremendous branding that they're probably household names even for people who don't do audio as a hobby or profession.
Post by Deleted on May 16, 2023 0:43:41 GMT -6
i am not anti outboard or anti analog. I am anti the top selling compressors on B&H and Sweetwater, anti what is hyped on gearslutz, and Very anti what is advertised on gearslutz. . OK. Just trying to understand you as my experience is pretty different - both in terms of analog gear and in terms of the music we do. Specifically if you can, what are those top selling and/or hyped on GS compressors that you really don't like? the clones and specifically the electrify your drums and voice stuff in general, eg many 1176, distressor, other bad fets, ssl clones abused, rnd silk, inflator, and other gear/plugs that are pretty much a distortion pedal. you get the distortion that makes it sit with guitars but then you also get that "fake" sound. producers always abuse these to make the absolute dumbest sounding tracks.
if i'm going to crap on some drums, i usually prefer straight brown crap like vintage warmer sometimes, formerly blockfish, vulf which emulates the boss vinyl sim comp, old vca comps can be nasty cool. some 1176 have the lofi brown stewed reduction warmth with the zing too and not too white plastic trash bag of a tone on the transients but the emulation plugs sure as hell don't. i like something to make it gel, sit, and be noticeable without popping out in front of the speakers so much. no stadium rock or plastic false sounds. sometimes even "self-erasing" the transients with non cartoon tape plugs / cassettes or soft clipping tubes / tube plugs works better than compressors and digital lets this be fine tuned. no upward expansion, upward compression, resonant filters, or compressor overshoot needed to save instruments with the waveform emulsified in tracking.
Post by thehightenor on May 16, 2023 1:09:19 GMT -6
Not that my wife would let me buy one if I cashed in my hardware LOL. At least hardware doesn't depreciate as quickly as a car! Although, if you're lucky, the resale prices keep up with inflation, which is slightly better than keeping the cash under the mattress. But I love compound interest more than I love hardware (and I love hardware). Oh yes, the power of compound interest!! If I’d put every dollar I’ve ever spent on studio gear (hardware and software) into an extra pension fund (or better still a extra property) then I’d be so much better off financially than I am now! But I’ve been lucky and I’ve done ok for myself anyway, so in my case I’ve been able to have a fun journey and not hate myself too much about the amount of money I’ve spent. I also have the world’s most understanding wife …. Mrs hightenor is definitely a unicorn
Post by vvvooojjj on May 16, 2023 2:34:47 GMT -6
This might be a tad boring suggestion but I'd recommended a new pair of speakers depending on what you are using at the moment. All of these are great (I own two from the list): D&D 8C, Amphion Two18+subs, Genelec 8361, ATC SCM45A, Kii Three. You do need Trinnov with some of them. Then a (DIY) cloud, traps for the first reflections and something behind you back depending on your room and you are good to go. AMaybe add two PSI AVAA for tightening the sub information. This is the route I would go.
If you really want some hardware this depends a lot. For processing stems and individual tracks Overstayer Modular Channel would work. For two bus anything goes from your choice of SSL type comp, Api 2500, Maselec MLA-3, Thermionic Phoenix, Gyraf G24 etc... Then an eq from Api, Thermionic Culture, Knif, Gyraf... You also need a good AD/DA if you go that route.
Post by viciousbliss on May 16, 2023 15:10:15 GMT -6
I'm not in a place where I can really do acoustic treatment and use monitors. VSX has always given me balanced mixes using plugins. Guys like B0se and Jantex have made some big claims about how useful the Archon ATC mid-fields are. Looking at the 200 VSX reviews, a few others said the same thing. Don at our place here also vouched for VSX. Conversion was one of the first things I took care of by getting the Aurora N. After watching some more Audio Animals videos, I see that those guys have succeeded using ideas that I've had in my mind to do for years. I'm going to make a pitch to a couple people to help me get some credit so maybe I can go a little bigger and get something like an UnFairchild. Maybe get this Black Box and some Bettermaker thing. It's not a high risk scenario since hardware retains so much of its value. Plus I have a Deltronics location not far from where I live that fixes old gear by Eventide and other notable audio companies. I think I can hook up 4 pieces to my Aurora N and one to Fusion, so, I'm not looking to utilize more than that at the moment.
