Post by indiehouse on Jun 24, 2014 13:27:52 GMT -6
How are you guys routing the signal using the VP28's on the 2 Bus? As an insert? Or are you routing out of your submaster, into the VP28's, then back into the master? Are you running any plugs after (ATR's, Bus Comp, etc)?
Post by tonycamphd on Jun 24, 2014 13:33:02 GMT -6
Direct out stereo 2 buss master, back in ADC to 2 tracks. Thats with ur buss comp in front of it though...That's how I'd do it, cept I'm planning on ML's in that position, I will also be bypassing my master fader...permanently
Post by indiehouse on Jun 24, 2014 13:45:25 GMT -6
Back in on a stereo track or two mono tracks? How do you deal with latency issues?
Post by tonycamphd on Jun 24, 2014 14:32:30 GMT -6
Back in on a stereo track or two mono tracks? How do you deal with latency issues? I'm so of the OTB mindset, I thought u we're talking about a console, even so, for final mix, I'd come out of ur daw into stereo comp, into Vp's, into an ADC, back to 2 tracks in ur daw( stereo is fine)
Post by Johnkenn on Jun 24, 2014 14:57:27 GMT -6
Back in on a stereo track or two mono tracks? How do you deal with latency issues? I'm so of the OTB mindset, I thought u we're talking about a console, even so, for final mix, I'd come out of ur daw into stereo comp, into Vp's, into an ADC, back to 2 tracks in ur daw( stereo is fine) That's the way I'm doing it. I make a "Burlprint" Audio track, route everything out at line level L&R out and then through the Burl. But then I route that Audio track to my master bus with all the other stuff on it.
Post by donr on Jun 24, 2014 15:39:09 GMT -6
I'm so of the OTB mindset, I thought u we're talking about a console, even so, for final mix, I'd come out of ur daw into stereo comp, into Vp's, into an ADC, back to 2 tracks in ur daw( stereo is fine) That's the way I'm doing it. I make a "Burlprint" Audio track, route everything out at line level L&R out and then through the Burl. But then I route that Audio track to my master bus with all the other stuff on it. Not clear on that, John. What do you use for ADC after the analog master bus if the audio's already been 'Burl'ed?
Post by Johnkenn on Jun 24, 2014 16:36:28 GMT -6
Well, there's the chance I might not be doing it the right way... I record the Burlified/vp28ed track to a stereo audio file and then it goes out to the master channel. From there, I bounce it down in PT's. Usually my master channel contains VCC, MusEQ, SPL Vitalizer (for stereo spread), UAD Ampex and then FG-x...
Post by donr on Jun 24, 2014 19:47:50 GMT -6
OK, I get it now. After the VP28 and Burl, it stays digital.
Post by tonycamphd on Jun 24, 2014 19:54:11 GMT -6
after doing what ever is clever with your tracking, i would suggest doing your mixing through your 2 buss compressor-vp28's/Missing links-ADC capture DAW-DAC-monitors. This is the most accurate(not the cheapest) way to get what you get IMO.
Post by jeromemason on Jun 24, 2014 20:29:43 GMT -6
Mine are hardwired right after my summing mixer, and after them I go to my BLA Sparrow Red, then back into PT to an Aux (master) buss. On that buss I have all my buss processing and I monitor off of that, then I route everything to an PRINT track just like John is doing when I'm ready for mix down, and then exporting that file from the region list menu.
The VP28's totally changed everything for me, I found you don't have to hit them all that hard for them to do something really nice, just basically run through them and they sound incredible. What I like about having a lot of headroom before I hit them is if I do want to add some goey saturation all I have to do is turn the output of my summing mixer up and watch my level on the Aux master. I just couldn't love those Pre's more for the buss, it's like what they were meant for honestly.
Post by wiz on Jun 25, 2014 1:09:07 GMT -6
Any chance we can hear an A B mix of these VP28s?
Post by Golgoth on Jun 2, 2016 7:58:39 GMT -6
I'd like to use VP28's on my 2 bus except I only have one at the moment and it's a black PCB one. Would it be ok to pair it up with a current rev?
Post by Johnkenn on Jun 2, 2016 8:43:10 GMT -6
Post by jsteiger on Jun 2, 2016 8:44:38 GMT -6
I'd like to use VP28's on my 2 bus except I only have one at the moment and it's a black PCB one. Would it be ok to pair it up with a current rev? Yes they will match as a pair.
Post by Golgoth on Jun 2, 2016 8:46:48 GMT -6
Then I'll be ordering soon
Post by kilroyrock on Jun 2, 2016 8:50:07 GMT -6
I'd like to use VP28's on my 2 bus except I only have one at the moment and it's a black PCB one. Would it be ok to pair it up with a current rev? Yes they will match as a pair. Now that's service.
Post by mhbunch on Jun 2, 2016 9:32:22 GMT -6
(Logic user) i/o plugin on stereo out channel -> vp28s -> sb4000 -> nv73s -> ADC back into logic
Post by drew571 on Jun 3, 2016 11:05:05 GMT -6
I use Cubase but I have them setup as an insert in the first slot of the 2Bus. Usually have VBC or some light compression after these and finish it off with VTM. I'll just create another track with the 2bus as the source when I'm ready to print. I like it setup as an insert so I can easily bypass to hear what's happening.
Post by drew571 on Jun 3, 2016 11:05:54 GMT -6
after doing what ever is clever with your tracking, i would suggest doing your mixing through your 2 buss compressor-vp28's/Missing links-ADC capture DAW-DAC-monitors. This is the most accurate(not the cheapest) way to get what you get IMO. is there a reason you hit the vp28's after the compressor? just curious.
Post by schmalzy on Jun 6, 2016 9:16:38 GMT -6
after doing what ever is clever with your tracking, i would suggest doing your mixing through your 2 buss compressor-vp28's/Missing links-ADC capture DAW-DAC-monitors. This is the most accurate(not the cheapest) way to get what you get IMO. is there a reason you hit the vp28's after the compressor? just curious. I can't speak for tony on why he'd do that but I can take a guess because I do something similar in my 2-buss chain (my compressor is ITB at this point, though): He's probably using the compressor with a slow attack time on his 2-buss. Oftentimes, that will allow for a big transient to come through before the compressor can really compress the signal. I end up using this style of compression because, to me, it helps the drums hit harder than they seem to when using a faster attack time. On a lot of the stuff I end up mixing, I'm looking for aggressive, punchy, transient-heavy drums and this is one of the ways I try to get there. Anyway, the compressor is allowing a big transient through and squeezing the body of the sound to be more consistent...but we probably still need to rein that transient in eventually if we're looking to get an appropriate dynamic range. He's probably running it into the VP28 and pushing the level pretty hard (either on the front end or the back end - I don't know what the VP28 likes more) to get the transformer to saturate on the transients and soft limit/limit/clip them in a different manner than a compressor/limiter would do it. I like running my 2-buss out through transformers (mine are in preamps but it could be any gear with good-sounding transformers, really) for that very reason - pushing the level into that gear a little higher than what might seem normal seems to give me a little "free" saturation and transient limiting with little downside. My ears like a little saturation on the 2-buss and I can get as much as I want with this sort of signal chain. The additional benefit of some soft-clipping/limiting from the transformers is just icing on the cake.
Post by chromies on Sept 9, 2016 0:19:46 GMT -6
Putting my vp28s stepped faders on my master buss inserts was definitely an AhHa moment for me. Mix comes out of reaper onto the the zed r16 board. Master insert out goes to the vp28s then into chameleon labs 7720. Was familiar with this setup and once i added the vp28s there was much more depth width and detail. Love em!
Post by guitfiddler on Sept 11, 2016 21:01:38 GMT -6
What Op amps are you guys using in your VP28's for the Mix Buss?
Post by indiehouse on Sept 11, 2016 21:31:23 GMT -6
GAR 1731/2520 combo here. About to try a pair of SL2520's on the next project coming up next week.
Post by bluenoise on Sept 11, 2016 23:14:38 GMT -6
I have several vp28s at my own place and I have evangelized every studio I work at. I just bring them in, use them and by the time I'm done, an order is placed at capi hq. I track whatever through them. Anything. Same as with the mixbus. Every single mix goes through them right from the start. Mostly as a pt hardware insert (pre compressor) in an aux track that gets printed once I'm done, but whenever I'm summing analog, the sum goes through them before ADC. I've always used gar opamps. Always prefered the 2520/1731 combo with either litz or regular 2623s.
Post by forgotteng on Sept 12, 2016 18:33:43 GMT -6
I am running Studio One 3 as a DAW and it has a handy little plug in called pipeline that allows you to insert your analog hardware on any track. This runs out my MOTU 24Ao to my patchbay which is connected to the VP28's Then goes back into the computer through the MOTU 24Ai. I can choose whether I want to use it as an insert or record the 2 buss back in. It seems to work. Not sure if the AD/DA is hurting me or not but I have overall been happy with the MOTU AVB. At this point I am using some light compression with a Vintech 609CA before the VP28's
