Post by viciousbliss on Feb 27, 2023 7:09:00 GMT -6
Hi all, I was playing around with the monomaker on the Amek console along with the stereo widener. I'm not sure if it's the Lynx conversion or whatnot, but I got it to actually be a positive on my work instead of the negative that it was when I tried it before with other PA plugs. It seemed like it would always make something worse even as it fixed something else. So, I decided to dive into the subject more and came upon the Basslane Pro stuff. Ian Stewart's article: flotownmastering.com/blog/center-that-subDo you guys convert your lower frequencies to mono all that often? Seems a lot of people think it's necessary. How was this accomplished before digital? I tried the trial of Basslane and it got me better results than the Amek. I just turned off the monomaker and stereo widener on it and put Basslane Pro first in the chain. Ian doesn't mention Fusion's stereo imager, I'm guessing because it doesn't do this. Some people claim the Nugen one is just as good even though Ian says it has a big flaw. The trial versions of these Tone Projects plugs are such a pain. All this white noise and then your settings get reset when you reopen a session. It baffles me how anyone is supposed to do a serious evaluation. Ian says linear phase is necessary for this monomaker function. I read some people used Vitamin to do it in the past. Just curious what you guys think, thanks all!
Post by yewtreemagic on Feb 27, 2023 9:12:00 GMT -6
I have that article by Ian Stewart bookmarked as the best I've ever read about mono-ing the low end I do own the Nugen Monofilter, and the TDR SLickEQ Mastering Edition, and they both sound fine to me. Having said that, I very rarely use them on final mixes, as I much prefer to manually keep my bass sounds panned mostly close to the middle, on a track by track basis. It's always instructive to solo the mid and in particular the side signals while mixing though (and also very informative with commercial mixes, as you can hear a lot of tricks other people use).
Post by svart on Feb 27, 2023 9:17:52 GMT -6
Do you guys have a lot of stereo bass instruments? I only have kick and bass guitar usually and since those are both mono sources, they get centered naturally..
Post by yewtreemagic on Feb 27, 2023 9:21:27 GMT -6
My mixes are mostly the same, with mono kick and bass.
However, I do have some stereo bass instruments (Spectasonics Trilian for example), plus various other VST instruments that do bass well, but unless it's for a special effect or just for a few seconds I tend to narrow their stereo image considerably, so you can still hear the sound is in stereo, but only spread across perhaps +/-10% of central rather than +/-100%.
Post by ericn on Feb 27, 2023 10:12:48 GMT -6
Collapsing LF to mono doesn’t make sense to me, the idea that LF is “mono” ( nobody has ever been able to point me at a corner freq for this effect) is more a function of the simple radiation effect where once the wavelength is greater than the dimension of a baffle it radiates Omni and as the frequency goes down the wavelength increases so as long as 2 or more radiating surfaces are within 1 wavelength they acoustically sum. LF summed to mono sounds weird if it isn’t naturally filtered, the higher harmonics that serve to give directional cues are still stereo. ( why stereo subs work sooo much better than mono).
Yeah I grew up as a live guy in the age of the separate LF mono aux craze, but I was also the guy tasked with figuring out how to make it musically integrate with the mains and the rest of the subs ( lots of drive rack tweaking and a drive rack matrix).
Post by Ward on Feb 27, 2023 10:16:50 GMT -6
LF is omnidirectional, moreso than the rest of the audio spectrum. There's an AIR plugin called 'Center' that is crazy good for moving frequency ranges to the center or sides in a totally variable way.
Post by EmRR on Feb 27, 2023 10:25:16 GMT -6
Doing a lot of live work I frequently have large stereo low frequency mud that, while adding ambient excitement, clouds the entire image and is improved by going mono on those sources below certain frequencies. Once it bounces off the walls and comes back, it’s definitely not mono!
Post by robo on Feb 27, 2023 10:30:27 GMT -6
I use Basslane Pro at the end of my drum bus most of the time, and I frequently have mono’d ~100hz and down on masters. The main benefit to my ear is it opens up headroom, though a lot of the time the low end feels more focused as well.
I don’t think it is “necessary” in a mix context, but it is a valuable tool in the big-picture sense of maximizing headroom vs. perceived loudness.
Post by Deleted on Feb 27, 2023 10:35:35 GMT -6
In the world of orchestras in large spaces, there's a considerable amount of stereo information at low frequencies. Objectively this sounds better and enhances your perception of spaciousness. But in the world of vinyl mastering, all of those low wavelengths were often out of phase and could kick the cutter out of the groove when mastering. And even if you managed to get some of that onto a disk, it was sometimes hard to keep the repro stylus in the groove. Many of my vinyl memories include the quarter taped to the top of the head shell. I was clearly not--and am still not--a fan of vinyl. At any rate, taking the lowest frequencies down to mono keeps those low waveforms in phase. The stylus rides up and down instead of wildly back and forth. This became part of the vocabulary of mixing, especially in more commercial forms of music.
I think there's the secondary detail that having the lows in mono gets that signal onto two speaker cones instead of just left or right. This is helpful if the audio system is a little challenged.
When those old recordings began to be repurposed for CD, things were occasionally taken in the opposite direction. Whatever phase differences still remained at lower frequencies could be exaggerated in the effort to restore some of that spaciousness. Needless to say, you had to be really careful.
Post by Tbone81 on Feb 27, 2023 11:46:53 GMT -6
Do you guys have a lot of stereo bass instruments? I only have kick and bass guitar usually and since those are both mono sources, they get centered naturally.. I was about to say the same thing, that nothing on the sides has any bass in my mixes. Then I remembered synth…and I do have plenty of songs with stereo synth bass…because sometimes it just sounds so good. Edit: forgot about stereo room mics! Doh! I have more than a few mixes where the drums are only (full range) stereo OH, plus kick.
Post by theshea on Feb 27, 2023 12:15:43 GMT -6
when doing mix/masters for my band The Shea the vinyl plant told me that everything under ~120Hz needs to be mono to prevent vinyl cutting problems. so yeah it can be important. and i made it a habit now (even if i only mix for digital release) to keep bass in check by mono-ing it. frequency depends on the instruments. most of the times i do around 90Hz.it sounds cleaner, more compact to me.
Post by thecolourfulway on Feb 27, 2023 20:57:12 GMT -6
Can’t stand the insistence on this from cutting rooms. Revolver sounds fine to me, bass is all over the bloody place, same with Blue Note
Post by viciousbliss on Feb 28, 2023 1:15:02 GMT -6
Thanks for all the replies. I'm still toying with Basslane Pro and trying to see what else I can do with some of the other stuff out there. Basslane Pro definitely has a lot more you can do with it than Monofilter or Ozone Imager. So far, it's a lot better for me than Goodhertz mid-side. These I used only in mastering. I took BP off my sub-mix auxes and used the Fusion stereo imager plugin instead. Then used BP on the mastering with MDWDRC2. It can radically change your master, the widening function does a lot and I don't think it's making it any worse. This after I had already treated it with Fusion with minimal use of the stereo imager section. Best stuff I've done so far. When I was using the monomaker on Amek console from PA, I had the stereo imager on a lot. At this point, I would say BP is far better than those PA functions. But I'm just using presets now since the limitations of the trial version would force me into writing things down or taking pictures like I have to do with Fusion. I'm not sure I would want to convert a lot of frequencies to mono without also expanding the image some. A lot to learn here...
Post by sean on Feb 28, 2023 7:17:55 GMT -6
Personally, for me, the only time I've had much luck using the "mono-maker" plug-ins is with overheads, where try as I might the low end of the kick drum isn't perfectly centered, and maybe sometimes but not always using a plug-in to help center it does the trick. I'm someone who like 80% of the sound of the drums to come from the overheads so filtering out low end and treating them more as "cymbal" microphones doesn't work for me.
Post by trakworxmastering on Feb 28, 2023 10:12:25 GMT -6
Can’t stand the insistence on this from cutting rooms. Revolver sounds fine to me, bass is all over the bloody place, same with Blue Note This. Exactly. Take a listen to "Glass Onion" by The Beatles in headphones. If they could cut low end that way in the 60s then they can do it now. Vinyl companies like to try to make things easy for themselves.
Post by dankin on Feb 28, 2023 11:55:22 GMT -6
I'm not a fan of mono-ing the low-end on the mix buss. I think the whole concept is over hyped on the internet, most likely from years of bad information on another forum. Occasionally I will do it on a synth bass if it has much modulation, but that's about it. It sounds really odd to me to hear the attack of a panned tom coming from the side, with the fundamental in the center.
Post by Ward on Feb 28, 2023 12:20:41 GMT -6
Respectfully, let's just a moment for some math/s questions
1. Low end is what? 20-100hz? 2. Any higher? 3. Ok what is the wave length of a 20hz wave? 4. How about a 30, a 40, a 50 and so on . . . ? 5. Stereo on anything below 50hz stays stereo for (about 15 milliseconds) how long? (before it goes omnidirectional) 6. What happens to it then? 7. Is there a possibility of phase cancelation with two competing sources of the same program material? 8. Is it better to let every room the material is heard in choose how the bottom will bloom, or should you decide for yourself? 9. And why is your answer to 7 better?
Answer the old geezer's questions and then let's talk to Vicious Bliss again.
Post by EmRR on Feb 28, 2023 13:05:33 GMT -6
Yes for sure there’s cancellation with stereo synths if vinyl mastering decides to narrow the image. Or big ambiences.
There’s no telling what bloom will occur in any listening condition.
We always read about the auto-variable EQ used in cutting, that must still be in use.
Post by thehightenor on Feb 28, 2023 13:19:48 GMT -6
I sometimes go the opposite way and try to make the bass guitar have some stereo width by sending some signal to a Roland Dimension D or similar effect albeit high passed to some degree to stop it sounding muddy.
Post by notneeson on Feb 28, 2023 13:41:01 GMT -6
I don’t see this as something the mix engineer needs to worry about. It’s hard enough to nail the low end in a mix, tying your hands further is anti-creative.
Post by Deleted on Feb 28, 2023 13:43:03 GMT -6
Respectfully, let's just a moment for some math/s questions 1. Low end is what? 20-100hz? 2. Any higher? 3. Ok what is the wave length of a 20hz wave? 4. How about a 30, a 40, a 50 and so on . . . ? 5. Stereo on anything below 50hz stays stereo for (about 15 milliseconds) how long? (before it goes omnidirectional) 6. What happens to it then? 7. Is there a possibility of phase cancelation with two competing sources of the same program material? 8. Is it better to let every room the material is heard in choose how the bottom will bloom, or should you decide for yourself? 9. And why is your answer to 7 better? Answer the old geezer's questions and then let's talk to Vicious Bliss again. 1. Low end is what? 20-100hz? 2. Any higher? Close enough 3. Ok what is the wave length of a 20hz wave? 4. How about a 30, a 40, a 50 and so on . . . ? Trick question. Wavelength depends on the medium. But the calculation is easy if you think in frequency terms. The period for a complete cycle comes from dividing 1000 by the frequency in Hz. So a 20 Hz sine wave will have a period of 50 ms. 5. Stereo on anything below 50hz stays stereo for (about 15 milliseconds) how long? (before it goes omnidirectional) No reason for it ever to go omnidirectional (which isn't quite the right term). A signal of any frequency is likely to lose its sense of direction over time, but that doesn't mean it's the same in all channels. See the next answer. 6. What happens to it then? 7. Is there a possibility of phase cancelation with two competing sources of the same program material? Phase cancellation is unavoidable in a real space. The distance to any reflecting surface is unlikely to be a perfect multiple of a wavelength, so the bounces will cause some cancellation. But the key thing is that there are thousands of cancellations going on all at once. The average frequency response in a decent space will remain remarkably consistent. This sort of very common phase cancellation has another name: reverb. 8. Is it better to let every room the material is heard in choose how the bottom will bloom, or should you decide for yourself? I think not. It's always best to mix in a neutral room. Proper calibration in the listener space is pretty rare, but whenever it does happen, the response should be in the rough neighborhood of what the mixing space gave you. Outside of that, there's not really a way to compensate at that late stage in the chain. 9. And why is your answer to 7 better? Because it's a truthful answer ;-)
Post by Ward on Feb 28, 2023 14:36:05 GMT -6
Respectfully, let's just a moment for some math/s questions 1. Low end is what? 20-100hz? 2. Any higher? 3. Ok what is the wave length of a 20hz wave? 4. How about a 30, a 40, a 50 and so on . . . ? 5. Stereo on anything below 50hz stays stereo for (about 15 milliseconds) how long? (before it goes omnidirectional) 6. What happens to it then? 7. Is there a possibility of phase cancelation with two competing sources of the same program material? 8. Is it better to let every room the material is heard in choose how the bottom will bloom, or should you decide for yourself? 9. And why is your answer to 7 better? Answer the old geezer's questions and then let's talk to Vicious Bliss again. 1. Low end is what? 20-100hz? 2. Any higher? Close enough 3. Ok what is the wave length of a 20hz wave? 4. How about a 30, a 40, a 50 and so on . . . ? Trick question. Wavelength depends on the medium. But the calculation is easy if you think in frequency terms. The period for a complete cycle comes from dividing 1000 by the frequency in Hz. So a 20 Hz sine wave will have a period of 50 ms. 5. Stereo on anything below 50hz stays stereo for (about 15 milliseconds) how long? (before it goes omnidirectional) No reason for it ever to go omnidirectional (which isn't quite the right term). A signal of any frequency is likely to lose its sense of direction over time, but that doesn't mean it's the same in all channels. See the next answer. 6. What happens to it then? 7. Is there a possibility of phase cancelation with two competing sources of the same program material? Phase cancellation is unavoidable in a real space. The distance to any reflecting surface is unlikely to be a perfect multiple of a wavelength, so the bounces will cause some cancellation. But the key thing is that there are thousands of cancellations going on all at once. The average frequency response in a decent space will remain remarkably consistent. This sort of very common phase cancellation has another name: reverb. 8. Is it better to let every room the material is heard in choose how the bottom will bloom, or should you decide for yourself? I think not. It's always best to mix in a neutral room. Proper calibration in the listener space is pretty rare, but whenever it does happen, the response should be in the rough neighborhood of what the mixing space gave you. Outside of that, there's not really a way to compensate at that late stage in the chain. 9. And why is your answer to 7 better? Because it's a truthful answer ;-) GReat answers . . . with regards to 8, I was referencing listening environments. And certainly, yes your answers are truthful. Clearly, I'm in the "sum the low end to mono from 80hz down" camp. But I welcome other proffesional opinions and appreciate yours!
Post by Deleted on Feb 28, 2023 16:33:25 GMT -6
In my first response on this thread, I wasn't intending to render an artistic opinion on low-end mono. That's up to the discretion of the mixer and/or producer. I just wanted to give some context on why vinyl mastering engineers prefer it. They're simply trying to make a disk work on the broadest set of turntables they can. It's true that a number of recordings from the 60s had stuff spread all over they place. But it's also been made clear by George Martin (and later Giles Martin) that the intent was mono and the labels forced them to spread stuff around--even when it didn't make a whole lot of musical sense. I had a Parlophone pressing of Sgt Pepper back in the day and it hopped around on every turntable I tried it with. I'm quite sure it was the LF stuff going out of phase and kicking the stylus out.
The artistic choice to do this can be an interesting one. Normally, given what I do, I prefer that natural width that can come at low frequencies. But just a few days ago, I had a concert to master with kick drums in a chamber music piece. Two drums, played by two players were both on the same side of the soundstage. It sounded horrible. So I used the multiband imager in Ozone to mono-ize the LF and get most of the drum energy back in the center. Not natural in this context, but absolutely necessary. You'll sometimes hear a lot of hooey about us classical guys being purists of some sort. We just want to seem like purists ;-)
Post by viciousbliss on Mar 13, 2023 16:43:54 GMT -6
I've been using Basslane Pro for a week or so and it's really allowed me to reshape the stereo image in a way that just works. The Clarity in the low end preset is a good starting point. It's sort of the same idea as what PA does, just implemented tons better. PA doesn't have mono recovery or linear phase. With BP, I can mono the lows and then add all this other stuff that just works better than the limited stereo imaging function of the PA stuff. It definitely has that very clean linear phase sound, but I'm not hearing any weird artifacts or anything. You can overdo things, but it becomes very obvious.
Post by schmalzy on Mar 13, 2023 23:54:14 GMT -6
Looking for a plugin to do this sort of thing? Boz Digital Labs makes Bark of Dog. It's a slightly resonant (or not depending on your tweaks) high pass filter similar to the hardware (and UAD plugin) Voice of God. Bark's cool because it can work in stereo or on either part of an M/S signal. Plus it's free and the resonance (or lack of) is adjustable.
I don't have a ton of low, low stuff on my sides. Mostly downtuned guitars and toms but the low guitars are often high-passed to relieve the woofiness anyway. Sometimes synths and sound design. For sounds that are not center-panned I'm mostly choosing them for their ability to provide size/space on top of their specific timbre/role. Low frequencies don't tend to satisfy me in that way. Plus I always feel the low frequencies punch better when they're mono. That's probably phase-related.
I really dislike the feeling I get when a mix makes me feel like one of my ears is heavier. If the weight/size/power of a mix is off-kilter, my whole listening experience is off kilter and I find myself twisting my head. Of course, this is a super useful idea when it's in agreement with the emotional content of a song...but if you want me to listen to it for more than 30 seconds it had better pay off in a big way!
