Post by Tbone81 on Feb 13, 2023 12:45:17 GMT -6
So I'm doing some remote work off my laptop and I need a brick wall limiter. The stock Pro Tools Plugins are fine for my needs but I need a dedicated limiter. Essentially I need L2 but for various reasons I'm not going down the waves route.
So what simple, straight forward, free (or near it) brick wall limiters are people using?
Post by Deleted on Feb 13, 2023 13:01:29 GMT -6
TDR Limiter 6 GE is the best limiter at limiting still.
Free? ReaLimit in Reaper. Reaper also has the best free mastering compressor not Kotelnikov, Master Tom.
Post by tasteliketape on Feb 13, 2023 13:18:54 GMT -6
Post by Blackdawg on Feb 13, 2023 13:23:25 GMT -6
Honestly the Avid Pro Limiter if you have the Avid plugin bundle works good. It's not stellar, but it works great. It sees heavy use from me at times and in tons of post houses.
Just set the release time right, auto is not good sounding. and you won't want to slam into it. But for catching occasional overs it works just fine.
Post by Tbone81 on Feb 13, 2023 13:44:21 GMT -6
Honestly the Avid Pro Limiter if you have the Avid plugin bundle works good. It's not stellar, but it works great. It sees heavy use from me at times and in tons of post houses. Just set the release time right, auto is not good sounding. and you won't want to slam into it. But for catching occasional overs it works just fine. Thanks, I'll have to see if thats in my avid download bundle (I'm sure it is).
Post by Ward on Feb 13, 2023 14:08:48 GMT -6
Nobody yet suggested the cracked versions?
Post by Johnkenn on Feb 13, 2023 16:30:51 GMT -6
Hard to beat L2 for convenience.
Post by Tbone81 on Feb 13, 2023 18:01:51 GMT -6
Hard to beat L2 for convenience. I know, waves is just such a hassle. I just cant bring myself to do it.
Post by explorer on Feb 13, 2023 18:09:02 GMT -6
Post by Blackdawg on Feb 13, 2023 18:10:48 GMT -6
first 2 are not AAX format so can't use in protools.
Post by nudwig on Feb 13, 2023 18:35:10 GMT -6
TDR Limiter 6 GE is the best limiter at limiting still. Free? ReaLimit in Reaper. Reaper also has the best free mastering compressor not Kotelnikov, Master Tom. I love this limiter. Especially the HF Lim section which is functioning as my poor-man's Maselec MDS-2.
Post by Tbone81 on Feb 13, 2023 20:47:38 GMT -6
Ok, so I downloaded the Pro Limiter from Avid. Problem solved. Thanks guys.
Post by Blackdawg on Feb 13, 2023 23:59:12 GMT -6
Ok, so I downloaded the Pro Limiter from Avid. Problem solved. Thanks guys. plus dsp, if you use hdx anyways
