Post by RealNoob on Sept 6, 2022 17:00:05 GMT -6
I hear once you go 500, you never go back. Considering a pair of VP28s or 312s or Heiders. I did some research and unfoirtuantely am not very clear with the op amp possibilities and the general characteristics. So, here's what I want. which would be best at meeting the expectations: - Work as mic pres and on the master for color and glue
- Be able to cover cleanish territory and also push for warmth, beef on the bottom
- Open top end wether run nominally or when pushed
- Don't want the high mid harshness of Daking (on certain sources)
- Don't want the standard API hardness (again, certain sources)
- Don't want the darkness of some neve-ish pres
So, somewhere up the middle with punch and clarity but able to dig in for roundness.
Which pre and op amp? I see Process Haus and Trace Audio selling built units on Reverb. Good to buy from?
Post by smashlord on Sept 6, 2022 17:17:31 GMT -6
VP28s have a fader and HPF, which put them in front of the others, for me.
Post by fellowshiphallsound on Sept 6, 2022 17:21:03 GMT -6
I have a pair of VP-28s and use them exactly like you're planning on doing. I love em! I'd like to get a pair of Heiders too, but the VP-28s are incredible.
And Trace Audio can't be beat!
Post by tasteliketape on Sept 6, 2022 17:26:54 GMT -6
+1 on Trace audio ! Good guy great service
Post by the other mark williams on Sept 6, 2022 17:42:42 GMT -6
mdmitch2 at Resistance Audio is also a wonderful guy who builds these and also hangs out here at RGO.
Post by mdmitch2 on Sept 6, 2022 17:57:40 GMT -6
mdmitch2 at Resistance Audio is also a wonderful guy who builds these and also hangs out here at RGO. Thanks Mark! For an open top end, heft, plus line level duty, I'd recommend the Heiders. The VP28's are a little bit more rolled off on top and bottom in comparison. You can extend the top and bottom of the VP28's a bit with Red Dots or similar, but it won't quite match the extension of the Heider. The Red Dots (which are standard in the Heider) are a little less aggressive in the upper mids compared to many of the standard opamp choices, so that area is a little smoother than the typical API. The standard VP312 has plenty of extension top and bottom, but it's not made for line level processing, and lacks some of the warmth / smoothness / sparkle of the Heider and VP28.
Post by dougwendal on Sept 6, 2022 18:34:05 GMT -6
mdmitch2 at Resistance Audio is also a wonderful guy who builds these and also hangs out here at RGO. I agree. mdmitch2 is great to work with.
Post by RealNoob on Sept 6, 2022 19:06:31 GMT -6
mdmitch2 at Resistance Audio is also a wonderful guy who builds these and also hangs out here at RGO. Thanks Mark! For an open top end, heft, plus line level duty, I'd recommend the Heiders. The VP28's are a little bit more rolled off on top and bottom in comparison. You can extend the top and bottom of the VP28's a bit with Red Dots or similar, but it won't quite match the extension of the Heider. The Red Dots (which are standard in the Heider) are a little less aggressive in the upper mids compared to many of the standard opamp choices, so that area is a little smoother than the typical API. The standard VP312 has plenty of extension top and bottom, but it's not made for line level processing, and lacks some of the warmth / smoothness / sparkle of the Heider and VP28. That was my inexperienced suspicion. Thanks for that!
Post by jcoutu1 on Sept 6, 2022 19:06:59 GMT -6
mdmitch2 at Resistance Audio is also a wonderful guy who builds these and also hangs out here at RGO. I agree. mdmitch2 is great to work with. +2
Post by Bat Lanyard on Sept 6, 2022 20:26:34 GMT -6
I have a pair of Heiders that all keyboards are tracked through. They're fantastic.
Post by ericn on Sept 7, 2022 9:25:03 GMT -6
The Heiders are dangerous, you plug a mic in and you realize how many great records were done in one of Wally’s rooms.
Post by RealNoob on Sept 9, 2022 9:33:04 GMT -6
Regarding frames, I am thinking of recording pieces and master bus pieces. Some frames have linking switches. Do you experienced guys with 500 frames find yourselves patching a lot with a patch bay or reaching around for switches... do you make a lot of routing changes and if so, does that push you to lunch box configurations with a smaller frame sitting on the rack or do you guys commit to mounting in a rack?
Post by Tbone81 on Sept 9, 2022 9:56:09 GMT -6
I have everything routed to my patchbay. I mix hybrid and also try to track with as much HW as sounds good (not afraid to commit on the way in) so I have i/o normaled on the patchbay in the configuration things are most often used. Link switches are great but, for me, because of all the HW I integrate, the patchbay is the only way to go.
Now on the other hand, something like a Cranborne chassis would be awesome and would probably solve a lot of issues for me. If those had been available when I first got into 500 series I might have built my entire system around them.
Post by nudwig on Sept 9, 2022 11:16:55 GMT -6
mdmitch2 at Resistance Audio is also a wonderful guy who builds these and also hangs out here at RGO. Thanks Mark! For an open top end, heft, plus line level duty, I'd recommend the Heiders. The VP28's are a little bit more rolled off on top and bottom in comparison. You can extend the top and bottom of the VP28's a bit with Red Dots or similar, but it won't quite match the extension of the Heider. The Red Dots (which are standard in the Heider) are a little less aggressive in the upper mids compared to many of the standard opamp choices, so that area is a little smoother than the typical API. The standard VP312 has plenty of extension top and bottom, but it's not made for line level processing, and lacks some of the warmth / smoothness / sparkle of the Heider and VP28. Sadly I've only used CAPI's once in a session and the only direct CAPI comparison I've heard was a YouTube video (that I believe Johnkenn did) but is the rolled off comment for the normal VP28 and/or the Platinum as well? Just curious really as in that video the Heider and pVP28 were my favs and didn't really catch the platinum VP28 rolling off too much.
Post by Johnkenn on Sept 9, 2022 11:36:12 GMT -6
Yeah, I'd say the platinum VP28's might be a little darker than the Heiders. I think of the Heiders as fast and punchy.
Post by bchurch on Sept 9, 2022 12:18:50 GMT -6
I have everything routed to my patchbay. I mix hybrid and also try to track with as much HW as sounds good (not afraid to commit on the way in) so I have i/o normaled on the patchbay in the configuration things are most often used. Link switches are great but, for me, because of all the HW I integrate, the patchbay is the only way to go. I was using the Switchcraft 9625, but once I migrated to an interface with 32x32 i/o, I just have everything running to that. If I tracked more, I'd still be using patchbays, but 99% of my projects are edit/mix - so running from hardware inserts from the DAW suits me fine. And what OP said about "once you go 500..." - well, yeah, there are some advantages and disadvantages. 220mA at 16v can be a bit limiting for thirsty circuits and that can cost you headroom. It's amazing how much people are jamming onto those 1.5x5 faceplates - I'm thinking of things like the SSL SiX that trade on giving you on an "okay" preamp, a barebones EQ and compressor, where it might be better to get the versatility of a dedicated pre, eq, and comp. But yeah, as my humble NYC space is light on room, I do love my 500 racks - it'd take me a second 16 space rack to house all of those modules in a standard 19" footprint. Luckily, we have country and western here.
Post by RealNoob on Sept 10, 2022 8:33:49 GMT -6
I just grabbed an RND 10 space - it was b stock and has a power switch. Also grabbed an Elysia Xpressor - bstock again and good price. Heiders will be next month.
Post by paulnajar on Oct 6, 2022 2:22:13 GMT -6
I can openly recommend the VP28 litz with CAPI’s own CA 0252 DOA’s. I built 4 of these to replace an API 3124+ and am very happy.
I had already built some CA0252’s to run as DOA’s on colour cards so was familiar and happy with them.
I tried the CA 0252’s in the 3124 as well and the most noticeable difference was the CPAI DOAs went hotter before noticeable distortion than the API 2520’s. I have also tried the VP28’s with LTLO Rogue 5 DOA’s and they were cleaner than the CAPI DOA’s. Nice but different.
Overall the VP28 with the config above sounds a little less of the API mid forward thing but rich and bigger - and perhaps a bit smoother. To me it makes them more usable on a broader range of sources. For example I would rarely consider recoding a vocal through a API 512 pre and would generally go for a Lola or a MA5 or even an Avalon 737 tube pre, the vp28 has me thinking it could be more useful for this. Mixing groups or mix bus through them they also sound great. While my intention was to replace the API 3124 sound in my pres collection the vp28 has done that with some extra range in the deal.
Post by paulnajar on Oct 6, 2022 2:31:58 GMT -6
I have everything routed to my patchbay. I mix hybrid and also try to track with as much HW as sounds good (not afraid to commit on the way in) so I have i/o normaled on the patchbay in the configuration things are most often used. Link switches are great but, for me, because of all the HW I integrate, the patchbay is the only way to go. Now on the other hand, something like a Cranborne chassis would be awesome and would probably solve a lot of issues for me. If those had been available when I first got into 500 series I might have built my entire system around them. That’s what I’ve done. I have 3 Cranborne 500Adat racks all connected to a RME Madiface via their ADI648. I still have everything on the patchbay like you for ultimate flexibility. Link switches seeem like a nice idea but to take advantage of them you have to order your modules as a mono signal path which is the opposite of what I find I want when I’m mixing so for this reason the link switches rarely get used and all patching is on the patchbay. There are two things where I think the Cranborne racks could be better. The slot bypass switches are on the inside backplate so to access them you physically need to remove the module. I would happily forgo the front panel link switch to put the slot bypass switch in it’s place. Second thing is I wish the Insert send/ returns were balanced.
