Post by Vincent R. on Jul 23, 2022 8:50:01 GMT -6
I just received mine. These things sound incredible. Basically I have (2) transformers in the path while using it in my my Link Audio SL4K-E01; a Jensen SSL style transformer and the Royal Blue's Marinair style. Dialing it in gave me something similar to my Dan Alexander, but with more low end. I have to continue playing with levels and see how best to dial it in. I have the 5db high shelf bypassed at the moment. I may switch that and play around with that at some point. I did a quick test of all my Neve Style preamps. I tried to level match them as best that I could. Each of these is a separate take, but I've tried to be as consistent as possible. Recorded these with my FleA 49.
1) Link Audio SL4K-E01 2) Link Audio SL4K-E01 with Royal Blue engaged at around 30-35%
3) AMS Neve 1073 DPX (EQ not engaged)
4) Dan Alexander 1272 Channel 2 5) Dan Alexander 1272 Channel 1 (These both sound a little different)
Post by sirthought on Jul 23, 2022 16:14:23 GMT -6
They all sound pretty close to me. The Dan Alexander might be a bit more solid on the low end. Sounds good.
Post by nudwig on Jul 23, 2022 18:16:33 GMT -6
I love the Royal Blues. If you have them in the Mr Focus you can play the presence and tilt against each other for some great tonal combos.
Post by Vincent R. on Jul 23, 2022 19:52:21 GMT -6
I love the Royal Blues. If you have them in the Mr Focus you can play the presence and tilt against each other for some great tonal combos. I thought about that.
Post by Vincent R. on Jul 23, 2022 20:02:15 GMT -6
They all sound pretty close to me. The Dan Alexander might be a bit more solid on the low end. Sounds good. My goal was to have a Neve front end with SSL for mixing. So this set up is kind of a best of both worlds, which makes me really excited.
Post by Blackdawg on Jul 24, 2022 4:33:46 GMT -6
The AMS sound the best to me personally.
But I like the Royal Blue combo as well.
Post by Vincent R. on Jul 24, 2022 6:16:45 GMT -6
The AMS sound the best to me personally. But I like the Royal Blue combo as well. In my opinion, the AMS often sits better in a mix.
Post by Blackdawg on Jul 24, 2022 13:08:57 GMT -6
The AMS sound the best to me personally. But I like the Royal Blue combo as well. In my opinion, the AMS often sits better in a mix. It has the "sounds like a record!" Sound ha
Post by Vincent R. on Jul 24, 2022 21:15:06 GMT -6
It does. I like the Dan Alexander with my FET and TLM mics when I want some more weight. It’s nice with my tube mics in a simple arranged jazz ballad too.
Post by drsax on Jul 26, 2022 11:30:53 GMT -6
The Royal Blues are fantastic. Currently running a kick drum and a snare through a Chroma/Mister Focus pair as I type this. A thing of beauty!
