Post by jacobamerritt on Jul 20, 2022 14:53:21 GMT -6
Looking at an 8 track Ampex 440 1" machine... Anyone have experience? Less interested in the tape side of the machine, mostly want it for the pres. Am I looking at a maintenance nightmare? Recently maintained and in working order minus one sticky switch...
Post by Blackdawg on Jul 20, 2022 15:05:39 GMT -6
Not a ton, but I learned to cut tape on a 1/4'' 440. It was great I thought. There are better machines that handle the tape better but sound wise they are great. Didn't do a lot on it otherwise, never really used it other than transfers.
Post by drbill on Jul 20, 2022 15:15:16 GMT -6
Where's Eric??
Post by hadaja on Jul 20, 2022 15:19:44 GMT -6
Electric and company do a good ampex prem- amp based on years and hundreds of modding actual Ampex units and now making there own. Also the .locomotive audio 86b-2 is based on the Ampex unit. Having owned both units you cant wrong with either one.
Post by EmRR on Jul 20, 2022 15:45:03 GMT -6
Historically most referred to 8 track Ampex 440 1" machines as borderline on the transports ability to pull tape that wide. I dont know if anyone's come up with a beefed up mod for it, I suspect not. I may be wrong, but it seems there were issues at times with the deck plate being borderline for the weight and tension too,.......oh wait.....as pre's? Hell no. There's a million better/similar things in smaller vintage packages that make more sense. RCA, Altec, UREI, JBL, etc. I have a lovely rack of RCA's in the classifieds......
Post by hadaja on Jul 20, 2022 15:53:24 GMT -6
I like Doug’s post above. There are a lot of older pres that do sound better then the Ampex style. See if you can demo one first so you can measure whether your original expectations of the Ampex sound might be accurate. Also Doug has a wealth of knowledge, technical and real world experience in this area. So reach out to him to have a chat as he has been spot on with the advice he has given me and others on this forum. Also buying stuff from him is a breeze.
Post by jacobamerritt on Jul 20, 2022 16:11:58 GMT -6
Also, FWIW its selling for $2500... Currently in service until a different tape machine is installed...
Post by johneppstein on Jul 20, 2022 16:27:50 GMT -6
Looking at an 8 track Ampex 440 1" machine... Anyone have experience? Less interested in the tape side of the machine, mostly want it for the pres. Am I looking at a maintenance nightmare? Recently maintained and in working order minus one sticky switch... Forget it. THE WHOLE POINT of a classic tape machine is THE TOTAL EFFECT OF THE ELECTRONICS AND GOING TO TAPE!
OTHERWISE YOU ARE TOTALLY MISSING THE POINT!
Buy the machine and you'll learn. I wouldn't mind an Ampex, but I do own a Studer A800MKIII. And an MCI 2 track with 4 track electronics that I haven't bothered to finish restoring due to external problems (with money...)
And ANY tape machine is a maintainace, er, issue. It's only a problem is you're a digi-wuss.
Post by notneeson on Jul 20, 2022 16:39:24 GMT -6
Also, FWIW its selling for $2500... Currently in service until a different tape machine is installed... Had a 601 and cohabitated with two 351s, would not particularly recommend for pres but I don't have 440 experience. I suspect I'd much rather have 8 channels of Iron Age pres for the same $2500.
Post by ericn on Jul 20, 2022 17:03:20 GMT -6
Where's Eric?? Right here ! OK, if your going to go the modded Ampex tape amp as a pre go tube! The 440 electronics modded as pres just haven’t impressed me, now with good heads ( not cheap because most that ended up spending a second life in home studios were aligned as often as Alaska see’s 4 days of temps above 95c ! Yup the heavy trans port plate could be better, BUT if you build a cart knowing this instead of simply copying the Ampex pressed board you can deal with it! Now even if your still going the route of using the electronics as pres why not just buy one at a time on eBay and save while leaving an old machine for someone as stupid as me? Also you have to remember these are old, old, old school transport, the remote is hard to find, it isn’t a real auto locator and if you go from FF or Rew without pressing the opposite high speed mode your going to have a bunch of tape at your feet! So why the hell do I have one? Well it was 500 for the 440-8, a 440-2 a weird console that I had found a guy who had just paid $2k for on eBay who bought the modules for 500 so essentially it was free! You want a decent cheap old deck that will work the way you want a deck to work? Buy a Revox A77. I have kept them because they are the decks I started this journey at an old radio station studio 4 blocks from my moms house, Ironically I have no feelings towards the to Ampex mixers that sound better as pres but have zero routing and if I’m going for a board from my past to go with it I would grab a Soundcraft 200. Also as far as pres Doug can correct me if I’m wrong but other than iron there is nothing in there that’s unobtainable and Nobody has tried to recreate them as a pre! You have to ask why not.
Post by jacobamerritt on Jul 20, 2022 17:07:43 GMT -6
Also, FWIW its selling for $2500... Currently in service until a different tape machine is installed... Had a 601 and cohabitated with two 351s, would not particularly recommend for pres but I don't have 440 experience. I suspect I'd much rather have 8 channels of Iron Age pres for the same $2500. Already have 4 Iron Age pres
Post by jacobamerritt on Jul 20, 2022 17:09:05 GMT -6
I would print mixes/stems to tape - but probably not track often unless the players were up to snuff
Post by ericn on Jul 20, 2022 17:18:31 GMT -6
I would print mixes/stems to tape - but probably not track often unless the players were up to snuff Then find something like a A77 or a teac, but for the most part Otaris From radio stations are the best affordable machines because every radio station had a Engineer /tech. Honestly had I been smart, I would have taken a bunch when I was selling station groups Akai DR4Ds because at the time software was to confusing for newsies and the DR4D acted like a tape deck. Of course if you want the feel of tape. with a bit of the sound, grab a RADAR 24!
Post by jacobamerritt on Jul 20, 2022 20:20:02 GMT -6
I would print mixes/stems to tape - but probably not track often unless the players were up to snuff Then find something like a A77 or a teac, but for the most part Otaris From radio stations are the best affordable machines because every radio station had a Engineer /tech. Honestly had I been smart, I would have taken a bunch when I was selling station groups Akai DR4Ds because at the time software was to confusing for newsies and the DR4D acted like a tape deck. Of course if you want the feel of tape. with a bit of the sound, grab a RADAR 24! I do love the sound of RADAR.
Post by ericn on Jul 20, 2022 20:34:38 GMT -6
Then find something like a A77 or a teac, but for the most part Otaris From radio stations are the best affordable machines because every radio station had a Engineer /tech. Honestly had I been smart, I would have taken a bunch when I was selling station groups Akai DR4Ds because at the time software was to confusing for newsies and the DR4D acted like a tape deck. Of course if you want the feel of tape. with a bit of the sound, grab a RADAR 24! I do love the sound of RADAR. And that is probably why the Ampex sees very little use, the RADAR 24/V sounds good and is just easy.
Post by jacobamerritt on Jul 20, 2022 20:44:34 GMT -6
Yeah I think you guys convinced me this is not the piece for me. I get annoyed enough keeping modern outboard gear up and running! If anyone is interested, the excellent Anne Gauthier at La La Land is selling it for $2500. For the right person its definitely a great deal! Heres the studio: La La LandTape Machine: Ampex 440 8 Track
Post by sean on Jul 20, 2022 21:50:10 GMT -6
I’m going to have a Studer A80 MKIV 2” 24 track for sale if you want a BIG tape machine. Probably the size of 3 440’s in a row haha
Post by Quint on Jul 21, 2022 8:29:43 GMT -6
Yeah I think you guys convinced me this is not the piece for me. I get annoyed enough keeping modern outboard gear up and running! If anyone is interested, the excellent Anne Gauthier at La La Land is selling it for $2500. For the right person its definitely a great deal! Heres the studio: La La LandTape Machine: Ampex 440 8 TrackMan, I really like the vibe of that studio. If I'm ever in Louisville, I'll have to check it out. As for the 440, I always wanted either an AG440 8 track or a MM1200 16 track, but I think that ship has mostly sailed for me. Using tape just seems to be such an uphill battle these days and I've got too many other irons in the fire to deal with upkeep of a tape machine at this point, unfortunately.
Post by notneeson on Jul 21, 2022 9:31:28 GMT -6
Last time I cut to 2” was an an mm1200 with a 16 track head stack. So much fun.
Post by Hewdie on Jul 21, 2022 13:24:07 GMT -6
Looking at an 8 track Ampex 440 1" machine... Anyone have experience? Less interested in the tape side of the machine, mostly want it for the pres. Am I looking at a maintenance nightmare? Recently maintained and in working order minus one sticky switch... Hi all, New member here. Long story short: musician, songwriter, based in Europe. I became a recording engineer by default because I was the only bandmember interested in the recording side of things. Parenthood made me decide to retire from the road. I no longer have a commercial facility, but I do take on paid projects from time to time. Anyway...I own a AG 440C-8. It's a beautifully engineered tape machine, but the transport is clunky. The motors are not powerful enough to pull heavy reels of 1" tape. When it worked, I loved it, but after too many mid-session breakdowns and expensive repairs I gave up using my 440 for tape recording. I considered selling the Ampex, but I kept it for the electronics modules. They're discreet, and have transformer balanced inputs. I rout stereo mixes through the modules, and individual tracks too. Sometimes use them as preamps. It's a very colored sound, with rolled off high frequencies and a substantial boost of the low mids. Cool, if that's what you're after. I like it on my own music, but a recent client of mine disliked what it did to his tracks. For the asking price I don't know whether I would buy that 440 for the electronics alone. I think the true potential of that machine is in the combination of the electronics and the tape. But then you would have to deal with that less than ideal tape transport and other maintenance issues. And new 1" tape is expensive... Hewdie
Post by stratboy on Jul 21, 2022 22:02:18 GMT -6
Welcome to RGO, Hewdie! Glad you’re here.
Post by johneppstein on Jul 22, 2022 13:07:27 GMT -6
I’m going to have a Studer A80 MKIV 2” 24 track for sale if you want a BIG tape machine. Probably the size of 3 440’s in a row haha I may be selling my A800 MKIII. Haven't decided yet, but maintenance is becoming a problem for me due to medical issues and my outside Studer tech is probably retiring...
Post by drumsound on Jul 22, 2022 14:20:18 GMT -6
I’m going to have a Studer A80 MKIV 2” 24 track for sale if you want a BIG tape machine. Probably the size of 3 440’s in a row haha I may be selling my A800 MKIII. Haven't decided yet, but maintenance is becoming a problem for me due to medical issues and my outside Studer terch is probably retiring... That's going to be the biggest issue for tape machine owners in the next 10ish years. The cats that KNOW and can work on them are retiring (or passing on) and many haven't passed on a ton of knowledge. Some have, and that's great, but there isn't a large group of younger people who want/need that knowledge.
deif
Junior Member
Post by deif on Jul 22, 2022 17:33:52 GMT -6
Experience? yeah, the IK Multimedia plugin sounds nice.
I'm being facetious
Post by jacobamerritt on Jul 24, 2022 12:16:18 GMT -6
For anyone interested, from the owner selling for $2500:
Def helpful if you have a tech in town or in surrounding areas if little things arises but haven’t had issues aside from the odd scratchy pot de-oxing since getting it repaired 2 years ago. Capstan motor was updated pre me getting it, and the tech that worked on it installed it correctly when i took possession if the machine.
