Post by Ned Ward on May 22, 2022 19:34:25 GMT -6
I'm no Norm Abram, but in my home studio, the corner with my Tremolux was always kind of a mess; the wooden box to the right of the amp is actually a bookcase with my younger daughter's piano music, which she can't really get to. Now, she's got access to her music, my amp is right there, and I now have a top shelf for more gear. Or a plant which my wife is suggesting... This was my first time using Kreg pocket screws; wood is 3/4" plywood and 1x2 finishing strips. It's basically 2 boxes screwed on top of each other. Lots of sanding, staining, satin polyurethane, more sanding, etc. Happy with how it came out. If I were doing it again (and will be on the right side): - water-based stain and poly - cleanup is a LOT easier.
- I don't have a lot of room, but if there was a way to sand and stain before assembly I think it would look better.
- While this is 18" deep, I could stick with 12" hardwood boards and go for a better grade wood.
- I need a nice hunk of masonite or plywood as a stable base to cut on; was using an old cabinet door (2x4') and wasn't the best.
- Would have pocket screwed the face frame together, and then pocket screwed it to the carcass.
- Would have made it slightly narrower, as 4' is pretty wide and there's a lot of negative space on either side of the amp.
For the right side, it's about elevating a Dr. Z MAZ 18 Jr and a Princeton Reverb, but also adding 8-10 units of rack space underneath the Princeton. At least now I have the tools for it - thankful my old Dewalt cordless drill battery died as I ended up getting a Ryobi drill, nailer, circular saw and the Kreg cross-cut jig. May get their orbital sander next for the next one...
Post by Ned Ward on May 23, 2022 16:06:20 GMT -6
I also should have let it set outside for another day, but that's what open windows and fans are for...
Post by ericn on Jun 1, 2022 21:48:25 GMT -6
Looks good Ned, Go take a look at the Kreg track saw. My table saw is now for sale.
Post by Ned Ward on Jun 3, 2022 10:12:23 GMT -6
Eric - you read my mind; I have the cross-cut sled, so I already have the base on my cordless saw. Worth getting for sure. I did see a "this old house" episode where Tom Silva glued two pieces of 1/2" ply together with the top piece narrower, and then ran the saw down each side, left hand and right hand to make a DIY track sled for either side of a circular. The Kreg track saw base is $100, so easy purchase.
I'm not at the level of doing enough carpentry to need a real track saw; will report back how the Kreg one works when I do the next project.
