Post by kcatthedog on Apr 8, 2022 11:15:57 GMT -6
was messin with a 76 clone and all button mode to explore distortion, was wondering what peeps fav plug in is for adding dirt and grit ?
Thx!
Post by drbill on Apr 8, 2022 12:06:18 GMT -6
Beyond analog, I still rely heavily on Decapitator.
Post by Blackdawg on Apr 8, 2022 12:22:12 GMT -6
2nd Decapitator
Tupe is cool too
Thanks pretty much it for ITB for me.
Post by tasteliketape on Apr 8, 2022 12:26:23 GMT -6
The above plugins and I’ll add sans amp or Nembrini PSA1000 also a Samsamp emulation
Post by drumsound on Apr 8, 2022 12:40:40 GMT -6
As above, Decapitator is used when needed. I also have had fun with SansAmp from time to time. Even the free Softube one knob thing is useful, though if you're going to automate the bypass, you also need to automate the track volume, because there's no volume compensation when the distortion is added.
Post by mcirish on Apr 8, 2022 12:47:24 GMT -6
As above, Decapitator is used when needed. I also have had fun with SansAmp from time to time. Even the free Softube one knob thing is useful, though if you're going to automate the bypass, you also need to automate the track volume, because there's no volume compensation when the distortion is added. I believe they fixed that with the side panels now. You can set input and output levels.
Post by notneeson on Apr 8, 2022 12:47:51 GMT -6
I do still sometimes use the original sansamp plugin.
But, the thing I have loved of late is driving the Fuse VCL-4 into distortion on say, a drum room, and blending that in for "edge."
Also using softube tape here and there.
Post by drumsound on Apr 8, 2022 12:54:50 GMT -6
As above, Decapitator is used when needed. I also have had fun with SansAmp from time to time. Even the free Softube one knob thing is useful, though if you're going to automate the bypass, you also need to automate the track volume, because there's no volume compensation when the distortion is added. I believe they fixed that with the side panels now. You can set input and output levels. Oh, cool. I'll check that out when my new machine is up and running.
Post by phdamage on Apr 8, 2022 13:20:49 GMT -6
Still lean on decapitator a lot - just works great, is easy to dial in and super flexible. Just got tupe, though. Have been using noiseash need preamps more and more also.
Fuse have so many great distortion plugs - dozer drive and 562A for obvious crushing, 376 is awesome for subtler jobs.
I like the nembrini sansamp sometimes and I often lean on the dirt from the uad 1073 if you push the preamp for guitar busses
Post by bradd on Apr 8, 2022 13:32:33 GMT -6
I still use Decapitator quite a bit, but lately I've been using PSP Saturator more often. It can be a bit more subtle than Decapitator.
Post by svart on Apr 8, 2022 13:53:13 GMT -6
BOD sansamp or JSTclip or Magnetite depending on the type of distortion needed.
Post by Guitar on Apr 8, 2022 13:54:19 GMT -6
Use a lot of UAD Neve 1073, Black Rooster VP73HE, Arousor
a good free one I discovered is Tritik Krush
and just any processor with an inbuilt saturation knob, tapes, etc
Post by Deleted on Apr 8, 2022 14:25:11 GMT -6
SDRR2 and Tupe
Post by ragan on Apr 8, 2022 14:36:44 GMT -6
Saturn2, Decapitator, SansAmp
Post by deaconblues on Apr 8, 2022 14:45:52 GMT -6
I’ll add to the Fuse praise, and recommend slamming audio into the limiter section of his new plate reverb with the reverb turned off. And add in sister brand NEOLD’s stuff, especially Big Al. It’s all pretty unique sounding non-linearity so I don’t get tired of it. With Softube, I’ve been building things in Amp Room lately, and am really surprised at how useful it is. UA, I dig the Neves and sometimes the V76. Still meaning to dive into BYOD that monkeyxx recommended. github.com/Chowdhury-DSP/BYOD
Post by Deleted on Apr 8, 2022 14:49:28 GMT -6
I’ll add to the Fuse praise, and recommend slamming audio into the limiter section of his new plate reverb with the reverb turned off. And add in sister brand NEOLD’s stuff, especially Big Al. It’s all pretty unique sounding non-linearity so I don’t get tired of it. With Softube, I’ve been building things in Amp Room lately, and am really surprised at how useful it is. UA, I dig the Neves and sometimes the V76. Still meaning to dive into BYOD that monkeyxx recommended. github.com/Chowdhury-DSP/BYODFuse plugs are like Kush plugs on hard drugs
Post by Guitar on Apr 8, 2022 14:59:52 GMT -6
I’ll add to the Fuse praise, and recommend slamming audio into the limiter section of his new plate reverb with the reverb turned off. And add in sister brand NEOLD’s stuff, especially Big Al. It’s all pretty unique sounding non-linearity so I don’t get tired of it. With Softube, I’ve been building things in Amp Room lately, and am really surprised at how useful it is. UA, I dig the Neves and sometimes the V76. Still meaning to dive into BYOD that monkeyxx recommended. github.com/Chowdhury-DSP/BYODBYOD needs an update for bugs, and so on, but it's fantastic! Softube Amp Room is the dark horse amp sim for me. I've only got it recently, but it kind of upset my other amp sim habits, I reach for it now. Feels more like my real amps, or something. More artifacts, more things "wrong" (right) about it. It's more chunky and ugly and I need that. Boss Katana head into a wolfbox DI is also a really convincing guitar sound, but that's hardware. But it's also not an amp sim, nor a tube amp. I have strange dreams of Kemper being "the one" ever since I saw Pat Metheny playing with one... but I can't afford that so Katana it shall be.
Post by deaconblues on Apr 8, 2022 15:01:58 GMT -6
I’ll add to the Fuse praise, and recommend slamming audio into the limiter section of his new plate reverb with the reverb turned off. And add in sister brand NEOLD’s stuff, especially Big Al. It’s all pretty unique sounding non-linearity so I don’t get tired of it. With Softube, I’ve been building things in Amp Room lately, and am really surprised at how useful it is. UA, I dig the Neves and sometimes the V76. Still meaning to dive into BYOD that monkeyxx recommended. github.com/Chowdhury-DSP/BYODFuse plugs are like Kush plugs on hard drugs Yeah, but specifically the kind sold out of briefcases…not the stuff from the streets that’s been stepped on 5 times.
Post by wiz on Apr 8, 2022 16:47:58 GMT -6
I mainly use logics distortion plug in….and it is used on bass guitar to get it to be heard in the mix…not like you would use distortion on say electric guitar
Cheers
Post by tkaitkai on Apr 8, 2022 21:37:08 GMT -6
Fuse VPRE-2C is crazy good. Probably the most convincing "analog-ish" distortion I've heard ITB. Aside from that, I have WAY too many distortion plugs. I often forget which ones I like and end up defaulting back to the easy stuff — FF Saturn, Sonimus Britson (output compensation on, FAT mode, fader resolution at 2x, crank until satisfied), Waves Manny Marroquin + MDMX... I'm already forgetting some! The new Audiority Pyros looks REALLY cool: Guitar Krush is one of my favorite bitcrushers. A secret weapon for sure.
Post by Johnkenn on Apr 8, 2022 22:15:09 GMT -6
Soundtoys Devil Loc Deluxe is cool. UAD 610 A. UAD Helios.
Post by drumsound on Apr 8, 2022 23:01:32 GMT -6
I mainly use logics distortion plug in….and it is used on bass guitar to get it to be heard in the mix…not like you would use distortion on say electric guitar Cheers Wiz I usually go for the Tchad Blake bass preset in Decapitator for that same vibe. It sometimes feels like cheating it works so well without even tweaking about 75% of the time.
Post by Guitar on Apr 8, 2022 23:19:07 GMT -6
That's our Tchad! Lol.
Post by Deleted on Apr 9, 2022 1:01:55 GMT -6
Dirtbox compressors: Vulf when it works Presswerk and Molot with saturation cranked up on their highest quality settings. You might need to enable a slight lookahead to make Presswerk smash. Molot hit it hot and crank saturation with a sub 1ms attack on insane. Limiter is a soft clipper too. It turns into a gritty pancake. Kush Silika is crazy cool. Fuse VCL-373 is just nuts. This thing is fricking nuts. 2.5s dual release is the fastest and nuttiest release. The new PSP Impressor can really smash snares into metallic dust.
Post by theshea on Apr 9, 2022 1:38:04 GMT -6
SDRR2 and Softube saturation knob (new version!). that combination gets me everywhere.
