Post by kcatthedog on Feb 15, 2022 5:31:27 GMT -6
Great, is the crossover set at 85 only or adjustable ?
Do you send your stereo out to the sub, it does the crossover and then you feed your satellite ( atc) from it ?
If so, do you notice any difference in the sound quality in the atc or the Adam cross over filter has no sonic effect ?
I am using a cheap surround sound sub and like the idea of a better quality small one, like you I am in a small room so don't need huge power etc..
Post by nick8801 on Feb 15, 2022 7:32:39 GMT -6
The sub has a hi-pass satellite switch at 85Hz, but the filter for the top sub frequency is variable from I think 30-150Hz. I'm running my stereo out to the sub, and then out to the amp for the speakers. I didn't notice any major change in tone, although I really didn't like what I heard in my initial listen with that hi-pass switch in. It just seemed to create a bit of disconnect between the sub and speakers, and the speakers sounded a little thin.
