Post by Quint on Jan 20, 2022 18:26:26 GMT -6
Unless someone here convinces me otherwise, I'm about to pull the trigger on a Corning optical TB3 cable. I've got a ground loop issue that I've isolated down to the copper TB cable between my PC and Apollo.
If these cables weren't $350 or more, I would have already done it, but that's a lot of money for one damn cable. On the plus side, I'd now have a MUCH longer TB cable that would give me the freedom to put my PC wherever I want.
Anyway, are there any pitfalls with these optical TB cables that I should be aware of, such as increased latency, reduced throughput, etc.?
Post by svart on Jan 20, 2022 18:53:08 GMT -6
Unless someone here convinces me otherwise, I'm about to pull the trigger on a Corning optical TB3 cable. I've got a ground loop issue that I've isolated down to the copper TB cable between my PC and Apollo. If these cables weren't $350 or more, I would have already done it, but that's a lot of money for one damn cable. On the plus side, I'd now have a MUCH longer TB cable that would give me the freedom to put my PC wherever I want. Anyway, are there any pitfalls with these optical TB cables that I should be aware of, such as increased latency, reduced throughput, etc.? 1. That's simply a ridiculous price for a cable. I have 40g cables at work that don't cost 1/10 that much. 2. The cable itself won't add any latency in terms of propagation delay through the cable unless there's some kind of data buffering or FIFO.
Post by Quint on Jan 20, 2022 20:23:15 GMT -6
Unless someone here convinces me otherwise, I'm about to pull the trigger on a Corning optical TB3 cable. I've got a ground loop issue that I've isolated down to the copper TB cable between my PC and Apollo. If these cables weren't $350 or more, I would have already done it, but that's a lot of money for one damn cable. On the plus side, I'd now have a MUCH longer TB cable that would give me the freedom to put my PC wherever I want. Anyway, are there any pitfalls with these optical TB cables that I should be aware of, such as increased latency, reduced throughput, etc.? 1. That's simply a ridiculous price for a cable. I have 40g cables at work that don't cost 1/10 that much. 2. The cable itself won't add any latency in terms of propagation delay through the cable unless there's some kind of data buffering or FIFO. 1. I don't disagree on the price being ridiculous, but that's what optical TB3 cables seem to go for. If you need to eliminate the ground loop via a non-metallic means of connection, optical seems to be the only way. What are you gonna do? I don't see any other option. On a positive note, this would afford me a 33 foot cable versus the 6 foot cable I currently have. A 60 foot cable is only another $20 or so. The conversion to and from optical must be what drives up the price, not the length. I would honestly prefer a 6 or 8 foot optical TB for a cheaper price, but these optical cables seem to be marketed to people looking for longer lengths which are apparently not possible with copper cables, and not to people who are looking to eliminate ground loops, even if elimination of a metallic connection is an ancillary benefit, and the primary reason I became interested in the first place. That is unless you know of cheaper optical TB options or some other means of eliminating the ground loop through my copper TB cable? Or are the cables you use at work copper and not optical? 2. Data buffering and things of that sort are the kinds of things I was wondering about. I have no idea if these optical cables introduce additional latency due to that sort of thing.
Post by earlevel on Jan 20, 2022 22:44:42 GMT -6
Unless someone here convinces me otherwise, I'm about to pull the trigger on a Corning optical TB3 cable. I've got a ground loop issue that I've isolated down to the copper TB cable between my PC and Apollo. If these cables weren't $350 or more, I would have already done it, but that's a lot of money for one damn cable. On the plus side, I'd now have a MUCH longer TB cable that would give me the freedom to put my PC wherever I want. Anyway, are there any pitfalls with these optical TB cables that I should be aware of, such as increased latency, reduced throughput, etc.? I don't have experience with such cables, but if it fixes the issue...For that much, I'd want to be able to return it in case the issue proved to be something else, and I see Amazon has it with free returns with Prime. Expensive, but anyone with ground loops knows it would be a bargain if it killed the hum. Are the computer and Apollo on different lines or outlets? If so have you tried running them off the same outlet or extension box? Not the easy solution for most, but I have to say that when I moved in my place, with a separate "rec room" in the backyard that become my studio, I was frequently dodging ground loops. Fortunately for me, the uninsulated walls had crap wood paneling that had to go anyway, to insulate and shore up the walls with sound deadening board and drywall, and my buddy is an electrician. With the walls bare to the studs, he added a subpanel, pulled better wire from the main panel, and wired new outlets with conduit. Just basic stuff, nothing special, Home Depot. Decades later, I've still not run into a ground loop. but I feel still sorry for people who have them.
Post by yewtreemagic on Jan 21, 2022 11:02:31 GMT -6
Unless someone here convinces me otherwise, I'm about to pull the trigger on a Corning optical TB3 cable. I've got a ground loop issue that I've isolated down to the copper TB cable between my PC and Apollo. Sadly, data connections between a computer and external audio interface (whether it be USB, Firewire or Thunderbolt) are quite often responsible for completing a ground loop, and it's always reassuring to track down a cable that completes the ground loop and causes problems. However, you don't necessarily have to break the loop at that point - as long as the loop is broken the problems should still go away. Sometimes it can be significantly cheaper to break the loop(s) via balanced audio connections where available, or failing that, to introduce transformer isolators in your audio chain, such as this one: www.soundonsound.com/reviews/art-dti..or the ART Cleanbox II artproaudio.com/product/cleanbox-ii-hum-eliminator/
Post by timcampbell on Jan 21, 2022 11:12:37 GMT -6
For that price I'd try to run down the ground loop first. Very often it is sheilding between the 2 units.Have you tried another cable? Is the cable sheilded? Is the sheild connected at both ends? Are the sheilds connected on both units?
Post by Quint on Jan 21, 2022 11:40:19 GMT -6
For that price I'd try to run down the ground loop first. Very often it is sheilding between the 2 units.Have you tried another cable? Is the cable sheilded? Is the sheild connected at both ends? Are the sheilds connected on both units? All of my audio interconnections already have the shields on the input end lifted. Also, everything in my racks is isolated from one another, so there's no path for ground loops there either. I have no idea about the specificities of shielding on my TB cable. I just know that, when I unplug it, the ground loop stops. Unfortunately, it just comes down to the TB connection. So I'm really just focused on trying to determine if there are any pitfalls with optical TB cable, such as added latency or things of that nature.
Post by kcatthedog on Jan 22, 2022 3:49:51 GMT -6
Yes, it’s expensive , but, if it solves the problem, as a percentage of your total studio sound build price, $350 is nothing.
Post by Quint on Jan 22, 2022 9:28:40 GMT -6
Yes, it’s expensive , but, if it solves the problem, as a percentage of your total studio sound build price, $350 is nothing. I don't disagree. I just wanted to make sure I won't be trading one problem (ground loop) for another (latency, etc.). Based on the reply from Svart, it sounds like the answer is that it shouldn't add latency, though he did add a potential caveat which still makes me hesitant without gaining more info.
Post by kcatthedog on Jan 22, 2022 9:32:13 GMT -6
Ya, I get it !
It’s the only change I had to make, getting my m1 mini new tb3 cable, was running tb2-3 converter.
Post by earlevel on Jan 22, 2022 13:53:39 GMT -6
Yes, it’s expensive , but, if it solves the problem, as a percentage of your total studio sound build price, $350 is nothing. I don't disagree. I just wanted to make sure I won't be trading one problem (ground loop) for another (latency, etc.). Based on the reply from Svart, it sounds like the answer is that it shouldn't add latency, though he did add a potential caveat which still makes me hesitant without gaining more info. There will be no perceptible latency. The manufacturer says "low latency", but you need to understand the difference between actual latency and latency that can be perceived. Now, I don't know these cables, but but my education is in electrical engineering, so I'm making pretty reasonable assumptions: The conversion to the optical signal will have some minuscule latency, then the "light" might also have addition rise time, and the detector likely has a threshold—it something is rising "slowly", and the thing watching it has a threshold, there will be latency for the detector to determine a rise. But how much? We don't know, but consider this: the digital signal being transported over the cable is changing at a rate FAR faster that audio samples change. After all, that thunderbolt cable can send hundred of audio channels at the same time, each of which is 24-bit (or whatever), so the bit rate of transceivers is extremely high compared with the sample rate. If that latency is slower than a fraction of the bit rate, this whole concept will not work. (And think about it—a FIFO is not going to help, since the cables are supposed to work at a continuous rate.) So, "low latency" is only meaningful for digital transfers. You might as well say "no latency" when talking about audio.
Post by recordingengineer on Jan 22, 2022 14:28:56 GMT -6
The studio I work out of has a 100ft Thunderbolt 3 optical from iMac Pro in the control room to the external chassis with a PT HD card in the machine room, where the I/Os and clock are. Works great!
Post by Quint on Jan 22, 2022 16:09:34 GMT -6
I don't disagree. I just wanted to make sure I won't be trading one problem (ground loop) for another (latency, etc.). Based on the reply from Svart, it sounds like the answer is that it shouldn't add latency, though he did add a potential caveat which still makes me hesitant without gaining more info. There will be no perceptible latency. The manufacturer says "low latency", but you need to understand the difference between actual latency and latency that can be perceived. Now, I don't know these cables, but but my education is in electrical engineering, so I'm making pretty reasonable assumptions: The conversion to the optical signal will have some minuscule latency, then the "light" might also have addition rise time, and the detector likely has a threshold—it something is rising "slowly", and the thing watching it has a threshold, there will be latency for the detector to determine a rise. But how much? We don't know, but consider this: the digital signal being transported over the cable is changing at a rate FAR faster that audio samples change. After all, that thunderbolt cable can send hundred of audio channels at the same time, each of which is 24-bit (or whatever), so the bit rate of transceivers is extremely high compared with the sample rate. If that latency is slower than a fraction of the bit rate, this whole concept will not work. (And think about it—a FIFO is not going to help, since the cables are supposed to work at a continuous rate.) So, "low latency" is only meaningful for digital transfers. You might as well say "no latency" when talking about audio. Those are good points. I had already suspected that latency was a non-issue, but I figured it was still worth asking about, since the optical cables do involve additional things in the signal path beyond that found in a copper cable. In any case, your explanation makes a lot of sense and that's probably good enough for me to not worry about it anymore.
Post by sirthought on Jan 22, 2022 16:28:57 GMT -6
The optical version of Thunderbolt was the original proposition when the protocol was being developed. The designers thought the price of fiber optic cable would be going down, but it actually went up. It should perform better all around than any metal wire.
The fact that a wire TB cable can't run longer than 2 meters is really disappointing. But the length issue is the only possible reason I could see for paying for the optic cable version. I personally have never experienced what you are talking about, so I guess depending on the level of noice I might consider that too.
Post by yewtreemagic on Jan 22, 2022 18:00:32 GMT -6
For that price I'd try to run down the ground loop first. Very often it is sheilding between the 2 units.Have you tried another cable? Is the cable sheilded? Is the sheild connected at both ends? Are the sheilds connected on both units? All of my audio interconnections already have the shields on the input end lifted. Also, everything in my racks is isolated from one another, so there's no path for ground loops there either. I have no idea about the specificities of shielding on my TB cable. I just know that, when I unplug it, the ground loop stops. Unfortunately, it just comes down to the TB connection. So I'm really just focused on trying to determine if there are any pitfalls with optical TB cable, such as added latency or things of that nature. In that case, apologies for my previous post suggesting audio isolating transformers - if you've got shields lifted at the input end of your balanced audio cables and rack metalwork from each unit isolated then only the Optical TB cable will do the trick. Good luck Quint!
Post by Quint on Jan 22, 2022 21:10:46 GMT -6
All of my audio interconnections already have the shields on the input end lifted. Also, everything in my racks is isolated from one another, so there's no path for ground loops there either. I have no idea about the specificities of shielding on my TB cable. I just know that, when I unplug it, the ground loop stops. Unfortunately, it just comes down to the TB connection. So I'm really just focused on trying to determine if there are any pitfalls with optical TB cable, such as added latency or things of that nature. In that case, apologies for my previous post suggesting audio isolating transformers - if you've got shields lifted at the input end of your balanced audio cables and rack metalwork from each unit isolated then only the Optical TB cable will do the trick. Good luck Quint! No worries. I've gone to pretty great lengths to preemptively eliminate ground loops, so it's extra annoying when they happen. The funny thing is that I think this ground loop has been there for a while and I just never noticed. It's relatively low in volume and I only noticed when I was recently doing some gainstaging of new equipment and had the volume on my monitors turned up really high to check for noise. It apparently hasn't been a problem yet, but it's the sort of thing that, if I ignore it, will come back sooner than later to bite me in the ass. I'm confident the optical cable will take care of it. It sounds like I also don't have to worry about creating any new issues either. Now, to get up the gumption to spend $350 on one damn cable...
Post by reddirt on Jan 22, 2022 22:41:29 GMT -6
Can't borrow a lesser priced cable? Cheers, Ross
Post by prene1 on Jan 23, 2022 16:11:04 GMT -6
I got mines from b&h. I paid a bit more 2 years ago. Worked like a charm.
Sold it off when I went OTB. It just WORKED!
Post by ericn on Jan 25, 2022 10:34:24 GMT -6
If it works yeah worth every penny.
