Post by reddirt on Jan 8, 2022 19:27:39 GMT -6
Guys, you may be able to help; it's as if i've hit a setting and don't know what or why but protools on the song i'm working on at the mo is placing any tracks i'm overdubbing around 130 msecs late.
If I record from one already recorded track to another it's fine .
This is only happening on this one song as I've checked another song and all is fine so that theoretically takes the interface out of the equation and points to a song specific setting (I think)
Any ideas?
Cheers, Ross
Post by indiehouse on Jan 8, 2022 22:05:01 GMT -6
I feel like I’ve had this problem before. Anything on the master buss causing latency? Room correction?
Post by kcatthedog on Jan 9, 2022 5:01:26 GMT -6
Does PT have an open previous session ability like Logic?
Post by Ward on Jan 9, 2022 18:29:54 GMT -6
Delete/trash your old preferences (but don't empty the trash just yet) and start over.
Start from a blank template. Copy nothing from any other session.
And see if the problem goes away.
Post by reddirt on Jan 9, 2022 22:56:16 GMT -6
Ward, it's all good on other songs - just this one. Cheers, Ross
Post by reddirt on Jan 10, 2022 4:40:07 GMT -6
Just consolidated all the takes I wanted, made a new song (V2) and imported all the relevant files minus any crap tracks and hey presto new takes record and lay down normally time wise , - who knows? Cheers, Ross
Post by Ward on Jan 10, 2022 9:23:47 GMT -6
Just consolidated all the takes I wanted, made a new song (V2) and imported all the relevant files minus any crap tracks and hey presto new takes record and lay down normally time wise , - who knows? Cheers, Ross Bug found and eradicated! HOO-RAH!! So just a big in that file, not in the preferences. (Incidentally, I had one for a bit in the preferences, kept every file defaulting to a start time at 219th measure, 3rd beat.
Had to use the old zapper and get rid of all the pests.)
Post by svart on Jan 10, 2022 9:34:31 GMT -6
Accidentally turned on/off plugin compensation for a track or something?
Post by drbill on Jan 10, 2022 11:54:44 GMT -6
Ward, it's all good on other songs - just this one. Cheers, Ross It's been awhile, but every once in awhile I've had sessions themselves get corrupted. It's hard to tell exactly WHAT inside it was corrupted though. I'd start with a brand new session, and start track importing bit by bit. You should be able to build it back up fairly quickly, and when you hit the "problem" go back and recreate that particular track from scratch. Good luck. {EDIT} : HA! See you already found it using the method I mentioned. I should have kept reading. Good for you!! Mix away!
