Post by Mister Chase on Nov 29, 2021 17:43:45 GMT -6
We were talking about these in another thread. They are discounted everywhere it seems. I just got a 2TB for 200 on Amazon.
Going to put all my verb impulses and sample banks on it to save my M1 mini drive space.
Post by kcatthedog on Nov 29, 2021 17:49:35 GMT -6
it’s USB-c not Thunderbolt, speeds will be fast enough ?
Post by kcatthedog on Nov 29, 2021 17:50:29 GMT -6
M1 mini is USB-a so will you need a converter ?
Post by Mister Chase on Nov 29, 2021 18:08:57 GMT -6
it’s USB-c not Thunderbolt, speeds will be fast enough ? 10gb/s bus speed for USB-c which still exceeds the M1 SSD read/write max of around 4gb/s total.
OWC had a drive that touted 2000 mb/s but it was much more expensive. This drive is over 1000 mb/s R/W. Which is approx the same as my Samsung internal SSD's that I ran VI's off for some years.
Post by Mister Chase on Nov 29, 2021 18:10:47 GMT -6
M1 mini is USB-a so will you need a converter ? M1 mini is, in addition to the USB-A ports, USB-C(USB4)/TB 3 which are both 40gb/s. They are dual purpose ports. I have a usb C drive connected to one for my backup of the OS and my TB interface on the other.
Post by aremos on Nov 29, 2021 18:23:04 GMT -6
Guess that won't work with USB-2?
Post by Mister Chase on Nov 29, 2021 18:35:17 GMT -6
Guess that won't work with USB-2? USB is generally very good about being backward compatible. 2.0 speed maxes at 480 mb/s which is slower than the drives throughput i/e a bottleneck. If it's only reading from the drive, you'll only lose 70 ish mb/s read speed, on paper. But it should be compatible with a simple usb C to A connector. Some drives come with both cables, I don't know about this one...
EDIT: this drive comes with a USB-C cable with an A type adapter. So it can run USB 3.2 or C. If it connects to a 2.0 port, it should work, just slower.
Post by kcatthedog on Nov 29, 2021 18:40:09 GMT -6
Great info: thx!
Post by mike on Nov 29, 2021 19:14:53 GMT -6
These look good I thought too, after John mentioned it earlier and I researched my choices a little to fit the M1 Pro I plan to buy after January 1.
I was tempted to try the Assemble the super fast SSD ones yourself in a enclosure but decided to let more time pass and options evolve for one of those between warranty length and potential heat concerns......and I chose instead the 2TB Pro version of this that is supposed to be up to 2000MB/s for $299 5 yr warranty
Post by kcatthedog on Nov 29, 2021 19:23:00 GMT -6
Nice, prices up here are 1/3 more, am thinking about the 1tb as its only around $150 and I don’t have large libraries.
Post by Mister Chase on Nov 29, 2021 19:28:24 GMT -6
You know, in the spirit of the heavy discount, I just canx the extreme and went with the pro as well. 2TB at 2gb/s will last me for VI's and impulses for a long, long time.
Thanks.
Post by Mister Chase on Nov 29, 2021 19:31:59 GMT -6
Nice, prices up here are 1/3 more, am thinking about the 1tb as its only around $150 and I don’t have large libraries. I was *this* close to getting 1TB. I have shy of 200gb in libraries now, but that will grow with time.
EDIT, just changed my order to 1TB. I'm not THAT much of a VI user...
Post by prene1 on Nov 30, 2021 19:42:05 GMT -6
I have like 10 of those extreme portables. Great drives.
Post by Johnkenn on Nov 30, 2021 21:47:08 GMT -6
Damnit. Must have just missed it
