Post by jaba on Nov 28, 2021 16:51:43 GMT -6
I've never used channel strips much - moons ago was using Waves SSL on kick and snare but that's about it. From there I just went with whatever EQ and compressor I was digging at the time and that was that.
I've been looking at ways to improve my workflow and when I saw that Fuse came out with a strip I thought I'd give it a go since I like his plugs.
In my first trials (using nothing but the VCS-1) I got songs in a good spot in no time. I loved having EQ, filters, compression/gate and saturation right there at all times where I could quickly move from one to the other and back, you know, like a console. When a track needs a certain extra something, I'll add whatever plug is needed. You know, like outboard. The end result also seemed to have a bit of "common tone" like working with a console.
I'm sure some of you figured this out eons ago but I'm curious how many people work with channel strips vs separate plugs for EQ/comp/saturation/etc. I'm looking forward to working with this new (to me) workflow and hoping it's a win.
Post by schmalzy on Nov 29, 2021 12:49:56 GMT -6
I'm using channel strips on almost everything.
Building familiarity with tools is great. It REALLY gets you moving more quickly making better decisions faster. Also, making fewer unnecessary decisions (which plugin should I use for EQ...for compression...if I'm going to filter the lows I should use a different EQ or add one, etc.) has been helpful for me.
I use the Console 1 system for mixing - it's basically a set of software channel strips you can manipulate with a hardware controller - but I do the same with rough mixes where I only grab one type of EQ, one type of compressor, and one type of saturation to get the rough mix to where it needs to be. I like the hardware controller but it's just because I worked live a fair bit and I get better results faster when I turn a knob and close my eyes than I do by clicking and dragging.
Post by jaba on Nov 29, 2021 15:05:29 GMT -6
Coming from analog consoles I hear you with regards to knobs but I've gotten more/less used to the trackball + DAW. Still, I do feel working in digital is slower for me and it was from reassessing my workflow that lead me to trying the strip. So far so good. Eliminating the clicks to open the EQ/comp/sat plug or move one out of the way is worth it alone. Those clicks add up!
Though the VCS-1 is new I'm finding it quite intuitive and if anything's slowing me down it's not the plug. Sounds good too though I don't have many channel strips to compare it to.
Post by Deleted on Nov 29, 2021 15:46:55 GMT -6
1) PSP Infinistrip 2) Fuse TSC-68 is cooler than any bx console or ssl plug 3) Fuse VSC-1 for me
Post by jaba on Nov 29, 2021 16:07:35 GMT -6
I never considered the Fuse 68 to be a channel strip but I guess it kind of is! Love that thing. Crazy good in way more situations than I'd expect, and I come from the Tascam cassette era.
Have never tried the PSP strip though I do like and use their stuff. I'll be sticking with the VCS-1 for now to a feel for it.
So far I'm quite liking having the general channel tools in the same family and inserting whatever other color I need case by case.
