Post by mrholmes on Oct 14, 2021 13:02:31 GMT -6
Thanks for stressing this plug in ... dan .
I had some spare time today to elaborate the TDR-Molot-GE more.
Its absolutely insane how versatile this plug in is. I can make it sound a lot like my 1176 HW, and it blows all 1176 simulations, including PA-Purple 76 and BRA-VLA-FET - out of the water. My mouth stood a while open ABing HW vs Molot GE.... even the distortions sound very similar, when the so-called "special 1176" simulations fall short.
I have no idea how they do this, but it works. I am happy because both of my HW 1176 are blocked in my latest project.
WoW...TDR...
Post by bossanova on Oct 14, 2021 13:11:57 GMT -6
Added chime in: thank you to Dan in general for passing along so much info on digital compression side chains and their relationship to oversampling and “true” fast attack and release times, I’ve been through many a digital compressor (and EQ) and wondered why my audio keeps coming out a mess at the end of most of them, especially with regard to “ice picks”. I’ve had Kotelnikov GE for 3-4 years and I’ve only used it once for general, non-bus compression (on a vocal, I've used it more often for gentle bus compression), but in that case it was able to grab peaks that other compressors kept missing and/or pumping. Now I have a better idea why.
Post by mcirish on Oct 14, 2021 13:40:51 GMT -6
I usually have the 1176 attack at 3 (10 oclock) and the release at 7 (five oclock). I'm thinking with those settings, the attack on Molot would be .540ms and the release would be 50ms. Seem about right? I don't have the GE edition; just the free version for now. How's the CPU hit? I usually find TDR plugins a bit heavy on resources.
Post by BenjaminAshlin on Oct 14, 2021 14:01:09 GMT -6
Added chime in: thank you to Dan in general for passing along so much info on digital compression side chains and their relationship to oversampling and “true” fast attack and release times, I’ve been through many a digital compressor (and EQ) and wondered why my audio keeps coming out a mess at the end of most of them, especially with regard to “ice picks”. I’ve had Kotelnikov GE for 3-4 years and I’ve only used it once for general, non-bus compression (on a vocal), but in that case it was able to grab peaks that other compressors kept missing and/or pumping. Now I have a better idea why. Yes, Dan has a passion for good sounding plugins and comes at it from a techinial point of view which i like. I don't remember the side chaining discussion. Could you point me in the correct directions?
Post by bossanova on Oct 14, 2021 18:59:52 GMT -6
Post by Deleted on Oct 17, 2021 10:02:06 GMT -6
Added chime in: thank you to Dan in general for passing along so much info on digital compression side chains and their relationship to oversampling and “true” fast attack and release times, I’ve been through many a digital compressor (and EQ) and wondered why my audio keeps coming out a mess at the end of most of them, especially with regard to “ice picks”. I’ve had Kotelnikov GE for 3-4 years and I’ve only used it once for general, non-bus compression (on a vocal), but in that case it was able to grab peaks that other compressors kept missing and/or pumping. Now I have a better idea why. Yes, Dan has a passion for good sounding plugins and comes at it from a techinial point of view which i like. I don't remember the side chaining discussion. Could you point me in the correct directions? Compressors are just devices that constantly modulate the signal based off of a rectified, clipped, and filtered copy of the signal. The basic theoretical stuff hasn't changed that much since the 50s and 60s. We just have some much better designs now and technology capable of doing it logarithmic in VCAs and then digital which took away the VCA noise and distortion. Rectified means DC instead of AC, all up instead of up and down. In digital this is absolute value of the sample. Unfortunately digital is limited by the Nyquist frequency and thus the sidechain is broken from the very start in most digital compressors. abs(the sample) does not work for obvious reasons. Think about it. The square root of the sample squared will distort. The 44.1/48khz compressor are starting to go wrong with just the samples. And the samples are not the sinc functions that compromise the signal. How could it work well? Oh and this produced odd order harmonics only. Even is produced by half wave rectifiers or mixed, which won't lead to as effective control. So the cool dirt box affect of many analog compressors already inhibits their control versus devices that add the dirt with input or makeup gain. MOLOT GE does this well where it is dirty input gain, dirty makeup gain, and a saturator, and clean makeup. The threshold is a clipper. The harder the knee, the more distortion in digital. Then attack and release are just coefficients of a low pass filter being switched between. You're going to need a high sample rate for this, especially for something like fast attack to slow release like Fairchild, 1176, and SSL bus. Oh and even if you make it clean enough (a challenge in both analog and digital) it will still sound like shit because modulating the signal like that will wreck things as everyone with a cheap VCA compressor has found out using them on tracks not made by drum machines or locked to the grid in a daw. Now you're really changing the "time" of the audio signal as Jack Joseph Puig claimed good compressors do (they have multiple releases with charge times, feedback, and other dependencies to prevent you from truly doing this) and it will sound like shit because you're mangling everything. The original solution to this was multiple release constants and feedback. So the compressor that splits and modulates the signal also modulates it's own modulator. And this turns out to be equivalent to a feedforward compressor tying the filter coefficients to input level but Rein Narma couldn't have known or built that on a kitchen table in the 50s. www.aes.org/e-lib/browse.cfm?elib=12380So these are all pretty much crazy complex stuff and the Waves CLA Comps are worse control devices than the ancient Bomb Factory plugs that come with Pro Tools. There's not a lot of compressors that run at 44.1 khz the whole way through and sound good. Waves Ren Comp and Oxford Dynamics are about it but they can be imposing on the signal like an even worse version of the cheap VCA comp. They also don't do anything above 1 and 4 khz respectively. They sound good tonally by simply not doing anything and having program dependent holds. Even the aliasing warmth function on the Oxford Dyanmics can sound good on bass with huge aliasing and like under 5% on a snare. Then you have the ones that run at 192 khz or so that can sound okay but you can break them like the UAD and Fuse comps. Fuse models stuff that is designed to be broken though and what he claims to have modeled, the compressors pretty much do. The VCL-25 oscillates like crazy, the VCL-373 pumps like hell. Then ones with more program dependency like Presswerk where you can just use lookahead and adaptive release to make it not break but it's still very imposing compared to Molot GE in feedback mode or Kotelnikov GE. And with analog, the late 80s onward designs tend to be really fucking good. GML, Aphex, Daking, Drawmer, Crane Song, etc. They're much better at controlling the signal than an 1176, LA2A, DBX 160, and SSL bus comp. THey just don't have the signature sound. But a lot of stuff never worked on anything resembling those compressors and you had to peak limit/clip/saturate it and fader ride it manually. Now you can shove a vocal or weird drum into kotelnikov GE and it will level it. You can even out a performance really well with modern analog too. Chop the peaks off without splatting it forward like an 1176 or chopping into the body like a bad vca comp or old digital. And the plugin world is full of junk. Why the hell should you have to choose the program dependencies of a compressor meticulously? It's supposed to modulate the signal for you in a positive way with the turn of a couple knobs, saving you time. Compassion and Unisum are some sick joke. Meanwhile the SSL Bus has an "AUTO" button and Presswork as an "ADAPT" knob. And they sound better and do more 90% of the time. Kotelnikov GE is all under the hood. You choose the threshold for the RMS, the peak threshold above that, attack of the peak, play around with the releases a bit, and IT ALWAYS SOUNDS GOOD AND PROGRESSES YOU FURTHER by squishing stuff. There is no futzing and fidgeting to make it not sound like a clipper like Arousor or trying to not make it pump up breaths like an LA2A, distort like LA3A, or fuzz out like LA4 or sound irradiated like a Blue Stripe 1176 or a Distressor. The irradiation is optional and tied to the sidechain being only halfwave at certain frequencies. they copied that from the Crane Song STC 8. Screw cloning, steal the coolest features of everything good and make something that does their job better. Kotelnikov took from the GML 8900, Weiss DS-1, Waves Renaissance Compressor, and Crane Song STC-8 and they gave it away for free. And let you pay to get working fast attack for peak portion and more features/cool distortion. The Drawmer 1978 stole not just from the 1178 but from the Orban stuff, API 2500, Compex, and their own 1968 to be a super cool drum bus controller. Yet people would still rather get two Behringer or Warm products instead. The ART limiter and Aphex 651 are great too for less than the cost of a KT 76. They do what even the real thing can't. The TDR Bundle is 200 Euros. Puts almost all cheap or old hardware and every UAD compressor to shame.
Post by Guitar on Oct 18, 2021 6:58:10 GMT -6
That's some pretty stunning insight. I wish I was reading the same books, haha.
On this punk thing I'm mixing I got a stereo track of drums. So my hands are tied with the drum sound. I used Nova GE to compress the high end, (crazy cymbal smashing,) and to upward compress (boost) mids when the snare hits and lows when the kick hits.
I tried more compressors after that, including Molot GE, but it made everything too small. When you get enough dynamic EQ going on, you're sort of in compressor territory already, in this case.
I ended up taking the compressors off the bass, drums, and guitar, and this material sounds a lot better. Some punk stuff like that, when you control everything, it just becomes a wall of unmoving mud. All this thickness with no dynamic to it. Just a big wide open sounding "Hmmmmmmm" with no energy. I figured out you have to make the excitement live in the high end from 1K to 10K. It's painful to mix for more than an hour or two. So I even high passed the bass guitar.
The vocal has a big HF boost from MDWEQ6 and not one but two exciters, Aphex and Slate Fresh Air. Otherwise it gets lost under the shred-fest.
Don't know if anyone has punk rock mixing advice but these are my small insights after fighting with it for a month or so, finally getting somewhere. I had to do less of what I usually do to mid-tempo rock stuff. Cut the fat. Let it be kind of harsh. A delicate balancing act in the treble.
Post by jaba on Oct 18, 2021 7:30:52 GMT -6
Another shout-out to Dan for not only the good ears for recommending plugs, but the technical dets to back it up. If nothing else his posts led me to Fuse, fantastic compliments to the TDR stuff of which I was already a big fan.
Post by Deleted on Oct 18, 2021 14:15:25 GMT -6
That's some pretty stunning insight. I wish I was reading the same books, haha. On this punk thing I'm mixing I got a stereo track of drums. So my hands are tied with the drum sound. I used Nova GE to compress the high end, (crazy cymbal smashing,) and to upward compress (boost) mids when the snare hits and lows when the kick hits. I tried more compressors after that, including Molot GE, but it made everything too small. When you get enough dynamic EQ going on, you're sort of in compressor territory already, in this case. I ended up taking the compressors off the bass, drums, and guitar, and this material sounds a lot better. Some punk stuff like that, when you control everything, it just becomes a wall of unmoving mud. All this thickness with no dynamic to it. Just a big wide open sounding "Hmmmmmmm" with no energy. I figured out you have to make the excitement live in the high end from 1K to 10K. It's painful to mix for more than an hour or two. So I even high passed the bass guitar. The vocal has a big HF boost from MDWEQ6 and not one but two exciters, Aphex and Slate Fresh Air. Otherwise it gets lost under the shred-fest. Don't know if anyone has punk rock mixing advice but these are my small insights after fighting with it for a month or so, finally getting somewhere. I had to do less of what I usually do to mid-tempo rock stuff. Cut the fat. Let it be kind of harsh. A delicate balancing act in the treble. Molot GE insane mode, 100% sigma, 100% hard knee, less than 1 db off for nice transient improvement. Just drum bus preset and turn feedback compression on if it’s too imposing. Turn off the mid eq unless it makes it sound better. Same with saturation. Instant or relaxed to taste. otherwise if it’s wildly varying in level, Kotelnikov and dig in a bit. Not too much because the auto attack and auto hold in the rms portion will flatline it if you have a fast attack on the peak. Theres also drum leveler for steadier beats and Presswerk for insane glue. Do not be afraid to chop up me mult the drums too. I did a black metal master this year where I multed the track a ton of times to eq it separately and then glued it all together with gluey, driven Neold v76u73. Oh and the Fuse drum remixer is made for your needs if the levels Of the drums are weird and bounced down to a stereo track Izotope is better for separating out vocals, drums, guitar, from a stereo track to relevel. You have a ton of powerful tools to use itb.
Post by mrholmes on Oct 19, 2021 14:18:38 GMT -6
That's some pretty stunning insight. I wish I was reading the same books, haha. On this punk thing I'm mixing I got a stereo track of drums. So my hands are tied with the drum sound. I used Nova GE to compress the high end, (crazy cymbal smashing,) and to upward compress (boost) mids when the snare hits and lows when the kick hits. I tried more compressors after that, including Molot GE, but it made everything too small. When you get enough dynamic EQ going on, you're sort of in compressor territory already, in this case. I ended up taking the compressors off the bass, drums, and guitar, and this material sounds a lot better. Some punk stuff like that, when you control everything, it just becomes a wall of unmoving mud. All this thickness with no dynamic to it. Just a big wide open sounding "Hmmmmmmm" with no energy. I figured out you have to make the excitement live in the high end from 1K to 10K. It's painful to mix for more than an hour or two. So I even high passed the bass guitar. The vocal has a big HF boost from MDWEQ6 and not one but two exciters, Aphex and Slate Fresh Air. Otherwise it gets lost under the shred-fest. Don't know if anyone has punk rock mixing advice but these are my small insights after fighting with it for a month or so, finally getting somewhere. I had to do less of what I usually do to mid-tempo rock stuff. Cut the fat. Let it be kind of harsh. A delicate balancing act in the treble. You have a ton of powerful tools to use itb.
Yes I just had the pleasure to use the Klanghelm DC8C3. Another ITB compressor, which can do any type of compression you want it to make. Sounded that good that the HW compressor is taken down from the LV, even though it needed 4 times OS to sound that way.
Post by mrholmes on Oct 19, 2021 15:54:20 GMT -6
BTW dan this video helps a lot to understand molot
Post by BenjaminAshlin on Oct 19, 2021 17:05:54 GMT -6
That's some pretty stunning insight. I wish I was reading the same books, haha. On this punk thing I'm mixing I got a stereo track of drums. So my hands are tied with the drum sound. I used Nova GE to compress the high end, (crazy cymbal smashing,) and to upward compress (boost) mids when the snare hits and lows when the kick hits. I tried more compressors after that, including Molot GE, but it made everything too small. When you get enough dynamic EQ going on, you're sort of in compressor territory already, in this case. I ended up taking the compressors off the bass, drums, and guitar, and this material sounds a lot better. Some punk stuff like that, when you control everything, it just becomes a wall of unmoving mud. All this thickness with no dynamic to it. Just a big wide open sounding "Hmmmmmmm" with no energy. I figured out you have to make the excitement live in the high end from 1K to 10K. It's painful to mix for more than an hour or two. So I even high passed the bass guitar. The vocal has a big HF boost from MDWEQ6 and not one but two exciters, Aphex and Slate Fresh Air. Otherwise it gets lost under the shred-fest. Don't know if anyone has punk rock mixing advice but these are my small insights after fighting with it for a month or so, finally getting somewhere. I had to do less of what I usually do to mid-tempo rock stuff. Cut the fat. Let it be kind of harsh. A delicate balancing act in the treble. Molot GE insane mode, 100% sigma, 100% hard knee, less than 1 db off for nice transient improvement. Just drum bus preset and turn feedback compression on if it’s too imposing. Turn off the mid eq unless it makes it sound better. Same with saturation. Instant or relaxed to taste. otherwise if it’s wildly varying in level, Kotelnikov and dig in a bit. Not too much because the auto attack and auto hold in the rms portion will flatline it if you have a fast attack on the peak. Theres also drum leveler for steadier beats and Presswerk for insane glue. Do not be afraid to chop up me mult the drums too. I did a black metal master this year where I multed the track a ton of times to eq it separately and then glued it all together with gluey, driven Neold v76u73. Oh and the Fuse drum remixer is made for your needs if the levels Of the drums are weird and bounced down to a stereo track Izotope is better for separating out vocals, drums, guitar, from a stereo track to relevel. You have a ton of powerful tools to use itb. Have you analized the slate compressors?
Post by Deleted on Oct 19, 2021 19:47:38 GMT -6
Molot GE insane mode, 100% sigma, 100% hard knee, less than 1 db off for nice transient improvement. Just drum bus preset and turn feedback compression on if it’s too imposing. Turn off the mid eq unless it makes it sound better. Same with saturation. Instant or relaxed to taste. otherwise if it’s wildly varying in level, Kotelnikov and dig in a bit. Not too much because the auto attack and auto hold in the rms portion will flatline it if you have a fast attack on the peak. Theres also drum leveler for steadier beats and Presswerk for insane glue. Do not be afraid to chop up me mult the drums too. I did a black metal master this year where I multed the track a ton of times to eq it separately and then glued it all together with gluey, driven Neold v76u73. Oh and the Fuse drum remixer is made for your needs if the levels Of the drums are weird and bounced down to a stereo track Izotope is better for separating out vocals, drums, guitar, from a stereo track to relevel. You have a ton of powerful tools to use itb. Have you analized the slate compressors? No because I hate the sound of most of the Slate rack plugs. Thwack, thwack, thwack, and in your face pings. The sound has gotten better but the i initial early 2000s butt rock marketing and sound put me off. I love the PSP rack though. You can get some very unique lofi sounds at the touch of a button. The 60s pre sounds woody. Like how some 60s drums sound like practice pads. I love it. Inward put off by how lofi it was at first but it’s so cool and the de-esser is incredibly powerful. The way PSP laid Infinistrip out really makes you push it as a tool and it doesn’t sound bad or get that nasty. Another one that’s great is Tupe. You’ll really push it. Screw being precise. Push it hard. Same with Molot. The metering sucks intentionally. People on gearslutz whined about it but it’s still use your ears and now too fast but still just push that thing a little hard, and pull back if it’s too much or use a shelf. Sounds killer. I love using the input, makeup, saturation, and limiter (soft clipper). You really get a lot of hard to control control that does cool stuff and you’re just taming it into doing what you want to do!
Post by mrholmes on Oct 20, 2021 5:56:06 GMT -6
That's true, but the GUI of Molot / GE is not very intuitive to me.
Post by superwack on Oct 20, 2021 12:32:18 GMT -6
Agreed. I've watched Dan Worral's video a couple times but I'd love a PART 2 "Advanced" Video as all of the other videos/reviews on the internet are just people screwing around with controls trying to see what it can do. I love Molot and get good results but the complexity always makes me feel like I might be missing out on something. I sometimes use the compressor section of the TDR Limiter 6 GE for it's simple/straightforward interface but that plugin, even with everything else disabled, is really CPU intensive.
Post by mrholmes on Oct 20, 2021 13:10:26 GMT -6
If you can run AUs or VSTs try some Airwindows Compressors by zero complexity no fancy GUI but with a sweet sound. They are the reason why I droped some of my hardware compressors.
Buttercomp is so sweet sounding, or Pyewacket is just great for 60s-70s sound.
Also, his take on the SSL Bus-Comp Logical4 ....soo sweet
If you like it, don't forget to support Chirs via Patreon because most of his Plug Ins are free of charge.
Post by Guitar on Oct 20, 2021 13:32:44 GMT -6
BTW dan this video helps a lot to understand molot That's nuts. This compressor was designed exactly for someone like Dan Worrall. A true *chef's kiss* technical plugin geek, haha. I bet this plugin is top shelf over at KVR audio, those people eat this stuff up, brands like U-He as well that give you all the good things. But thank you, now I understand the diff. between alpha and sigma, which was the main thing that was escaping me. And there was a nice lesson about feed forward and feed back compression in that video, which was worth it just for that.
Post by mrholmes on Oct 20, 2021 14:22:44 GMT -6
RTFM BTW dan this video helps a lot to understand molot That's nuts. This compressor was designed exactly for someone like Dan Worrall. A true *chef's kiss* technical plugin geek, haha. I bet this plugin is top shelf over at KVR audio, those people eat this stuff up, brands like U-He as well that give you all the good things. But thank you, now I understand the diff. between alpha and sigma, which was the main thing that was escaping me. And there was a nice lesson about feed forward and feed back compression in that video, which was worth it just for that. RTFM is not bad too.....
Post by bossanova on Oct 20, 2021 15:09:21 GMT -6
Agreed. I've watched Dan Worral's video a couple times but I'd love a PART 2 "Advanced" Video as all of the other videos/reviews on the internet are just people screwing around with controls trying to see what it can do. I love Molot and get good results but the complexity always makes me feel like I might be missing out on something. I sometimes use the compressor section of the TDR Limiter 6 GE for it's simple/straightforward interface but that plugin, even with everything else disabled, is really CPU intensive. That’s how I feel about Kotelnikov. I get great use out of it by tweaking the presets (along with obvious things like attack and release, etc), but I have a poor grasp on the ramifications and potential of the deeper settings.
Post by mrholmes on Oct 20, 2021 16:23:03 GMT -6
I used the Molot GE more today and mh yes after my first WoW it's not my friend for lead vocals. But it likes percussion and drums a lot.
For LV it's still my HW 1176s or the SW equivalents by PA and LogicX. BTW when you set the LogiX 1176 by ear, and you ignore the stupid GR meter, toying around with the output saturation, it's very close to what I expect...
We are truly spoiled with tools....
Post by Deleted on Oct 20, 2021 19:36:33 GMT -6
Agreed. I've watched Dan Worral's video a couple times but I'd love a PART 2 "Advanced" Video as all of the other videos/reviews on the internet are just people screwing around with controls trying to see what it can do. I love Molot and get good results but the complexity always makes me feel like I might be missing out on something. I sometimes use the compressor section of the TDR Limiter 6 GE for it's simple/straightforward interface but that plugin, even with everything else disabled, is really CPU intensive. That’s how I feel about Kotelnikov. I get great use out of it by tweaking the presets (along with obvious things like attack and release, etc), but I have a poor grasp on the ramifications and potential of the deeper settings. Kotelnikov is very easy to understand once it clicks. It’s an easy mode GML 8900 meets Weiss ds-1 with features from Crane Song STC-8 and Waves Renaissance Compressor. threshold is for RMS only peakcrest is the peak threshold above the rms. Same as GML 8900. Attack on rms however is automatic and it has auto holds to prevent pumping ratio and knee are self explanatory. So is gr limit. It acts as a fader ride after it is reached attack knob is only for the peak! release is simple but release peak speeds up and release rms slow down automatically yin and Yang offer half wave rectification over parts of the spectrum so both even and odd harmonics but Less control inertia and -inertia are opto and electro from waves Ren comp. it does not need lookahead like Weiss ds-1 or Presswerk. Have fun!
Post by Deleted on Oct 20, 2021 19:53:09 GMT -6
BTW dan this video helps a lot to understand molot He’s incorrect about the dual stage. It’s just a controllable dual release. Secondary attack time is the charge time for the secondary release. Attack mix bleeds that charge time into the main attack rate, changing the shape of the curve, which the alpha-sigma knob is already doing. It’s not two stages of compression at once or in a row, just crazy filters.
Post by Guitar on Oct 21, 2021 4:06:13 GMT -6
@ dan you're the man here's another one that seems relevant. I need to get a grip on Kotelnikov today. Yesterday I was compressing electric guitars with Kotelnikov and when I turned up Peak Crest I heard the sound opening up, that was a learning moment.
