Post by yotonic on Sept 14, 2021 17:41:19 GMT -6
I’m having a difficult time running my TC Reverb 4000 as an I/O into Logic. I’m using the AES in-out from my Symphony and the unit is clipping too easily. Frustratingly it doesn’t have a manual wet/dry mix on it (it does it internally) and when I push up the fader on my reverb bus it clips very early. I have tried adjusting my send level on my vox channel, I’ve tried dialing back the digital input. I’m at a loss.
I can’t figure out if it’s something about the unit or the way I am using the I/O in Logic.
Post by gravesnumber9 on Sept 14, 2021 19:00:33 GMT -6
Have you had success with this in another DAW?
Post by yotonic on Sept 14, 2021 20:05:27 GMT -6
Good idea. I will try it in PT or Performer.
Post by Martin John Butler on Sept 14, 2021 20:16:56 GMT -6
I know it can work, but I've never had a separate reverb to try. I'd love to get the Eventide H9, but it's just too pricey. One day I'll grab a Lexicon PCM 70, just for fun.
Post by jmoose on Sept 14, 2021 20:31:08 GMT -6
Reverb sends need to be full wet on the FX box... I've used a TC m2000 for eons without problems. Clipping? Never if anything it needs a gain bump on the output side.
Used it via SPDIF loop with a Focusrite & windows no problems.
These days with Logic I default send 1 & 2 to outputs 15 & 16... feeds the analog ins which return to a pair of channels on the SSL... console summing here not a true ITB loop but still never clips. Not unless I get stupid.
Check your IO settings again. And the wer dry mix. If the mix isn't 100% wet it could clip and also create phasing issues...
Post by ericn on Sept 14, 2021 20:49:32 GMT -6
Reverb sends need to be full wet on the FX box... I've used a TC m2000 for eons without problems. Clipping? Never if anything it needs a gain bump on the output side. Used it via SPDIF loop with a Focusrite & windows no problems. These days with Logic I default send 1 & 2 to outputs 15 & 16... feeds the analog ins which return to a pair of channels on the SSL... console summing here not a true ITB loop but still never clips. Not unless I get stupid. Check your IO settings again. And the wer dry mix. If the mix isn't 100% wet it could clip and also create phasing issues... Damn it I hate it when he beats me to it! 😎 All I will add to what the moose said is a limiter on the send is seldom a bad thing! Also an RTA on the send to see where your clipping can teach you a lot. The first thing I do when I find that I am either clipping or distorting is reach for sound tools on the iPhone to find out where I’m clipping, it makes tracking down the why easy.
Post by kcatthedog on Sept 15, 2021 4:52:10 GMT -6
Logic also has a 1k signal to test gain staging in the utility drop down maybe test level too ?
Post by mrholmes on Sept 15, 2021 9:40:04 GMT -6
Logic also has a 1k signal to test gain staging in the utility drop down maybe test level too ? Yes the sound generator is a god send in LogicX.
Post by yotonic on Sept 18, 2021 16:48:27 GMT -6
For some reason when I use an external reverb I’m getting a feedback loop on the vox reverb bus. When I use a plug-in that doesn’t happen.
Post by mrholmes on Sept 18, 2021 16:56:30 GMT -6
May there is something routed the wrong way internal your interface's routing matrix? I used external verbs with logic for 4 years before I went 95% ITB, and it always worked flawless with the I/O plug in.
It's simple.
HW REVERB OUT -> INTERFACE IN INTERFACE OUTPUT -> HARDWARE REVERB IN
Open the I/O plug in on an aux object.
Set the right in and output in the I/O plug-in, make sure the parallel knob is not engaged. Ping the latency dry.
Set the HW verb to 100% wet. Have fun... using the HW verb like a plug in.
Post by yotonic on Sept 18, 2021 23:05:03 GMT -6
Reverb sends need to be full wet on the FX box... I've used a TC m2000 for eons without problems. Clipping? Never if anything it needs a gain bump on the output side. Used it via SPDIF loop with a Focusrite & windows no problems. These days with Logic I default send 1 & 2 to outputs 15 & 16... feeds the analog ins which return to a pair of channels on the SSL... console summing here not a true ITB loop but still never clips. Not unless I get stupid. Check your IO settings again. And the wer dry mix. If the mix isn't 100% wet it could clip and also create phasing issues... Damn it I hate it when he beats me to it! 😎 All I will add to what the moose said is a limiter on the send is seldom a bad thing! Also an RTA on the send to see where your clipping can teach you a lot. The first thing I do when I find that I am either clipping or distorting is reach for sound tools on the iPhone to find out where I’m clipping, it makes tracking down the why easy. The limiter did the trick. I was using a reverb with a long decay. Thanks
