Post by theshea on Aug 13, 2021 12:57:44 GMT -6
changing the drumbalance for a intro or bridge radically seems common. but are you also changing it from a verse to a refrain? and i don‘t mean just some volume automation. i mean some rather radically change. eg boosting the room tracks or muting everything except the close mics or using the „wurst“ mic with big time distortion ... and if you do, how do you do the transition? slowly ramp or total cut before a beat?
Post by Deleted on Aug 13, 2021 13:25:33 GMT -6
A lot of it is just the drums having more room in the mix and not being smushed down as much by the bus compressor.
Post by jeremygillespie on Aug 13, 2021 14:15:56 GMT -6
Jason wrote mute automation on the ssl to open the room mics on every snare hit on this tune. I remember him saying it was sent to a publison fx unit to get the sound he got.
Post by svart on Aug 13, 2021 19:16:10 GMT -6
Do it a lot now. Usually I'm automating up and down snare or certain cymbal hits if there's a lot of vocals or other instruments I want to let take the front. I'll add clean room hits via samples for snare when I want it to explode.
I'll usually let reaper add the normal fades in and out on sample cuts. I'll just put the cut as close to the front of the natural hit as possible to keep noise to a minimum and I'll adjust the length of the fade as needed if there's noise.
Post by drumsound on Aug 15, 2021 15:05:57 GMT -6
I'll do things like add a parallel snare with compression and EQ, sometimes a the same with BD. Then those will come in as things get bigger in the arrangement. Sometimes something like an effect on the bridge, or changing the room mic relationship. Other times the playing covers the change. I'll simply automate the drum parallel if needed.
Post by bgrotto on Aug 15, 2021 15:16:19 GMT -6
I play with ambience a LOT over the course of a mix. I'm also often bringing up/pulling down parallel smashers and distorters. Another nice trick is laying a sample in (eg - a big ass snare sample in the chorus to fatten up the section). I also automate the daylights out of the width of the kit, typically opening it up for choruses, and narrowing it for verses. Last, but not least, is extending or reducing the frequency extremes to add or reduce apparent size.
Also worth noting I tend to do more and more of this stuff when I'm working on music that's going to be louder. Less available dynamic range means finding other ways to create the illusion of loud/soft and big/small.
Post by Guitar on Aug 15, 2021 15:44:23 GMT -6
Almost never but hey, I am learning from these great answers.
Post by theshea on Aug 16, 2021 2:09:16 GMT -6
Almost never but hey, I am learning from these great answers. yeah me too. i mostly used to just bring up/down the room mic for section and automating the overheads for certain cymbal hits. maybe make the whole drumbus quieter for verses. but i „know“ there‘s mixes where there‘s a whole lot more going on and i especially like to hear some bridges where some radical distorted or different drumsound comes in. and i simply wonder what the beautiful people in this beautiful forum do. because here are some very classy mixers present and thankfully they share there wisdom with us.
Post by drumsound on Aug 16, 2021 12:15:39 GMT -6
Almost never but hey, I am learning from these great answers. Honestly, the things I mention are options that I sometimes use. Many times I don't feel the need to do anything beyond making the drums make sense.
Post by Guitar on Aug 16, 2021 12:41:17 GMT -6
Almost never but hey, I am learning from these great answers. Honestly, the things I mention are options that I sometimes use. Many times I don't feel the need to do anything beyond making the drums make sense. This thread and the Pop music thread are making me want to be a more inventive/skillful mixer. To be able to transform sounds rather than just present them as great sounding tracks. I'm probably going to need to dust off the FX folder instead of this "natural" thing I've been on for seemingly a year now.
Post by schmalzy on Aug 16, 2021 21:12:20 GMT -6
I do a lot of automation:
Kick or snare up/down for different sections depending on the rhythmic content of the other instruments - most of the time one shell moves one way and the other shell the other way. Sometimes it feels better to lean into a rhythm and "agree" with it and sometimes if feels better to "disagree" with it. Oftentimes this sort of disagreement is in the verse when it's a little imbalanced or intentionally unsettled anyway.
I'll automate kick low end down on double-kick sections - it helps keep the double-kick from sounding like the most intense section of a song (if it isn't supposed to be - it's often being used for tension or momentum). It also leaves a little low end in reserve to bang on a important downbeat. I'll push kicks up on important hits.
Snares get automated up on fills a lot of times. Same with toms. Similarly I'll automate toms fill-to-fill in order to make sure they do/don't stand out in the way that make the most emotional sense. Also, I'll automate low end down in a tom ride section so I can get more apparent rhythm and less rumble out of it...then bring to boom boom back for the transition.
Overheads get pushed up on big crash moments. I find I bring them down if the drummer is playing an energy that is out-of-balance with the other stuff in a section of a song. Sometimes that's good. Sometimes that's bad. I have to deal with it either way. Sometimes I'll automate a little width a little wider into bigger sections where more things are competing for the middle and the soft-pan positions.
I like to have two or three different "sets" of room mics. If I'm tracking it's often a stereo medium room, a mono close room, and a mono far room. Sometimes people hand me two pairs of stereo rooms. I can live with whatever as long as it's cool. I like to work the balance of those vs the close mics to change the size/intensity of the section. To me, the drums always feel like they're being hit harder if the ambience becomes more apparent. Taking the ambience away feels like it gets smaller. Favoring mono or stereo rooms depends on the rest of the arrangement. I often like to push more stereo sources when a song gets bigger. Sometimes the right decision isn't to push a close mic up during a fill but instead to push a room mic up to give the impression of more intensity out of the drummer.
All of my drum mics go through a drum buss. That gets an automation pass in which I ride the drum bus volume up and down during the song in real time. I play it top to bottom and try to perform the drum volume mix the same way I'd vary the intensity of the drum performance if I were playing the drums.
These are not always every time sorts of things, either. Just as the spirit moves me and if the drums (or certain parts) are really pushing the energy of the track or if they're supposed to be serving other pieces of the song.
Post by svart on Aug 17, 2021 8:55:43 GMT -6
Almost never but hey, I am learning from these great answers. Automating the snare down during softer sections is a huge one. That's the primary thing I do now that really makes a difference.
Post by Guitar on Aug 17, 2021 13:10:08 GMT -6
Almost never but hey, I am learning from these great answers. Automating the snare down during softer sections is a huge one. That's the primary thing I do now that really makes a difference. Thanks, just used that in a tune I was working on, smart idea!
Post by svart on Aug 17, 2021 15:26:49 GMT -6
Automating the snare down during softer sections is a huge one. That's the primary thing I do now that really makes a difference. Thanks, just used that in a tune I was working on, smart idea! I used to think that it was unnecessary and that folks were just finding ways to build monuments to themselves by doing all these tiny little things that I didn't think anyone could hear Then I started doing it and was like "oh, ok". Lol
Post by kcatthedog on Aug 17, 2021 19:49:51 GMT -6
I always read this thread title as dumbbalance, which I always struggle with in every mix ! Guess, I need help in more ways than one !
Post by schmalzy on Aug 17, 2021 22:28:17 GMT -6
Thanks, just used that in a tune I was working on, smart idea! I used to think that it was unnecessary and that folks were just finding ways to build monuments to themselves by doing all these tiny little things that I didn't think anyone could hear Then I started doing it and was like "oh, ok". Lol This was exactly my thought, too. ...and then I forced myself to take a couple mixes AS FAR AS I COULD on the automation front. The artist noticed how much more alive that mix was than the previous even though I didn't say anything about it. So now I can't go back. I thought I was being self-important and conflating my significance in the process and then hearing my own confirmation bias. But those guys - a band of folks who aren't exactly eagle-eared - noticed how everything was much more exciting and everything sounded more present (probably because there were things constantly stepping forward into focus and then stepping backward to make room for something else). So now the idea of those drum balance changes happen all over most tracks in a song. It adds a literal two hours to each my mixes but it adds a pile of high fives and smiles to the artists and (presumably) the listeners.
Post by theshea on Aug 18, 2021 1:33:26 GMT -6
secondary question: i am thinking about mixing the drums from section to section. to explain further: cutting up the drums and than mixing the drums for the intro, the verse, the refrain etc. doing a balance totally for just the one section. with clip gain.
do you ever do something like this or do you pick the loudest part (the refrain) and mix your drums to sound good there? and than do volume automation for different parts.
i am wondering, sounds really exciting to me to mix every section individually. just ain‘t shure how those transitions will work out :-)
Post by Guitar on Aug 18, 2021 5:41:32 GMT -6
Clip gain all the time! Drums included, but not just drums. On the last song I was working on I did svart's snare drum thing in different sections, with clip gain.
Post by svart on Aug 18, 2021 7:22:15 GMT -6
secondary question: i am thinking about mixing the drums from section to section. to explain further: cutting up the drums and than mixing the drums for the intro, the verse, the refrain etc. doing a balance totally for just the one section. with clip gain. do you ever do something like this or do you pick the loudest part (the refrain) and mix your drums to sound good there? and than do volume automation for different parts. i am wondering, sounds really exciting to me to mix every section individually. just ain‘t shure how those transitions will work out :-) I always start a mix by listening to the most exciting part of it and starting there. I always apply peak normalizing to every raw track so that I know that the peaks are always at 0dB. I then do my editing, sometimes cutting up by sections, or by individual hits or whatever I need to do. If it's a lot of cuts I'll "glue" (Reaper function for creating a single new take out of many edited sections) them together and then sometimes edit this into sections. At this point I can either do raw gain changes on each section (Another Reaper function allows you to grab the volume of a particular section and adjust it independently, which is before the effects and analogous to Clip Gain) or use volume automation ( after the effects by default, and I usually use it on the busses). I'll then pull back the volumes on different things for the different sections if needed, or switch effects, etc, as needed. Sometimes the effects I use aren't the same ones for different sections. Sometimes you need a really loud and long reverb for a chorus but a short ambiance for the verse, so I'll automate mutes or sends or levels into each, etc. Usually it's just the pre-send level as that's generally enough to radically change the reverb's effect on the mix.
Post by robschnapf on Aug 18, 2021 13:10:11 GMT -6
Not to be contrary or state the obviouse But…. It’s so much better when the drummer plays with the proper dynamics. Or can be directed to think about that if they aren’t at time when tracking. I can’t stand hearing a hard hit snare turned down. It sounds loud quiet.
Post by mitchkricun on Aug 20, 2021 6:57:14 GMT -6
Not to be contrary or state the obviouse But…. It’s so much better when the drummer plays with the proper dynamics. Or can be directed to think about that if they aren’t at time when tracking. I can’t stand hearing a hard hit snare turned down. It sounds loud quiet. I love that last line. So true…
