Post by kcatthedog on May 12, 2021 1:55:29 GMT -6
@drew , so there is the computer’s processing, Apollo and satellite: what does what tracking and mixing in Luna ? Thx.
Post by sirthought on May 12, 2021 2:58:17 GMT -6
They are really clear that when you are tracking in Luna, you use DSP to make the low latency work—so any track that uses ARM is DSP. When you are mixing, the Luna extensions use the CPU. UAD plugins use DSP like always.
I knew this before you posted, but it was clearly typed out in the link you posted.
Post by Guitar on May 12, 2021 3:52:58 GMT -6
They are really clear that when you are tracking in Luna, you use DSP to make the low latency work—so any track that uses ARM is DSP. When you are mixing, the Luna extensions use the CPU. UAD plugins use DSP like always. I knew this before you posted, but it was clearly typed out in the link you posted.
Same "similar" as Pro Tools Carbon DSP with Pro Tools in this way, but hey, it's the "value" option even though that's just relative in this case.
Post by sirthought on May 12, 2021 4:16:36 GMT -6
They are really clear that when you are tracking in Luna, you use DSP to make the low latency work—so any track that uses ARM is DSP. When you are mixing, the Luna extensions use the CPU. UAD plugins use DSP like always. I knew this before you posted, but it was clearly typed out in the link you posted. Same "similar" as Pro Tools Carbon DSP with Pro Tools in this way, but hey, it's the "value" option even though that's just relative in this case.
I think UAD can be a great value if the price point is right. It's just that better price point usually only comes in December when it's part of a bundle. In this case, I'm just annoyed that they want me to spend $150 for the updated channel strip. Should be $50-$75 tops for current owners. And for the exact same sound and general functionality, except the GUI is in console format, I'd need to spend $350. I might look past that even if I didn't already own something giving me the same results, just perhaps a different workflow. I'm so use to calling up plugin windows now. I can hold off on this until the right opportunity comes around. Luna is still an experiment to me, tracking full bands.
Post by Drew @ UA on May 12, 2021 6:58:06 GMT -6
The new version isn't the exact same sound. There's new output section modeling and the 560 sounds different fitted into the strip as opposed to the 500 series version.
Post by Deleted on May 12, 2021 7:22:07 GMT -6
The new version isn't the exact same sound. There's new output section modeling and the 560 sounds different fitted into the strip as opposed to the 500 series version. “(Apollo-Mac) Audio is now sample-aligned when different models are multi-unit cascaded” This is killer and Is this true on Windows too? Any plans to implement it for additional inputs too?
Post by Quint on May 12, 2021 7:54:46 GMT -6
The new version isn't the exact same sound. There's new output section modeling and the 560 sounds different fitted into the strip as opposed to the 500 series version. “(Apollo-Mac) Audio is now sample-aligned when different models are multi-unit cascaded” This is killer and Is this true on Windows too? Any plans to implement it for additional inputs too? Ditto. I always wondered why all of the Apollo line couldn't all be sample aligned. So, yeah, what about Windows? Surely that doesn't have to be Mac specific feature?
Post by Drew @ UA on May 12, 2021 7:57:20 GMT -6
Coming soon to Windows. Just missed this release due to a late breaking issue. Thanks for your patience.
Post by Quint on May 12, 2021 8:32:45 GMT -6
Coming soon to Windows. Just missed this release due to a late breaking issue. Thanks for your patience. Good news. I had been thinking about picking up an eight channel Apollo to go with my x16. This is for all Apollo's, correct? Silverface, Blackface, X series?
Post by Johnkenn on May 12, 2021 9:11:10 GMT -6
The new version isn't the exact same sound. There's new output section modeling and the 560 sounds different fitted into the strip as opposed to the 500 series version. “(Apollo-Mac) Audio is now sample-aligned when different models are multi-unit cascaded” This is killer and Is this true on Windows too? Any plans to implement it for additional inputs too? Uh...what does that mean?
Post by Drew @ UA on May 12, 2021 9:13:33 GMT -6
Coming soon to Windows. Just missed this release due to a late breaking issue. Thanks for your patience. Good news. I had been thinking about picking up an eight channel Apollo to go with my x16. This is for all Apollo's, correct? Silverface, Blackface, X series? All Apollos.
Post by Quint on May 12, 2021 9:14:22 GMT -6
“(Apollo-Mac) Audio is now sample-aligned when different models are multi-unit cascaded” This is killer and Is this true on Windows too? Any plans to implement it for additional inputs too? Uh...what does that mean? The RTL on different units has always been slightly different. As I understand it, UA has now created a firmware update to make them all the same. This is nice for when cascading different models, so that everything lines up the same.
Post by Mister Chase on May 12, 2021 9:15:46 GMT -6
Neve and ssl, must be in the wings, and perhaps Trident , Helios, etc.? I've been hoping for the whole Harrison board for a long time.
Post by Mister Chase on May 12, 2021 9:19:05 GMT -6
My price for the API Vision strip is $149 instead of $299 since I already own the legacy version. I'll probably grab it when I have a coupon, too.
Post by Deleted on May 12, 2021 9:19:27 GMT -6
Uh...what does that mean? The RTL on different units has always been slightly different. As I understand it, UA has now created a firmware update to make them all the same. This is nice for when cascading different models, so that everything lines up the same. And it will compensate on the computer for the slight latency inbetween units! Very important. This is where adat fails hard
Post by soundintheround on May 12, 2021 10:19:23 GMT -6
Good news. I had been thinking about picking up an eight channel Apollo to go with my x16. This is for all Apollo's, correct? Silverface, Blackface, X series? All Apollos. Now we’re talking! This is pretty huge. I wish you could do it for my ADAT lynx converters but I understand that isn’t possible.
Post by Johnkenn on May 12, 2021 10:23:10 GMT -6
Neve and ssl, must be in the wings, and perhaps Trident , Helios, etc.? I've been hoping for the whole Harrison board for a long time. Doubt we will ever see that - that's what their DAW is for...
Post by Johnkenn on May 12, 2021 10:25:32 GMT -6
I have just pulled up the GUI for JUST the new Vision strip in Pro Tools. There's no way I'm gonna be able to resist this. Damnit.
So somebody help me out here - if I buy the Vision Emu Bundle, do I get the upgraded vision strip too? It's everything except the EQ's, right?
Post by drumrec on May 12, 2021 10:42:44 GMT -6
So somebody help me out here - if I buy the Vision Emu Bundle, do I get the upgraded vision strip too? It's everything except the EQ's, right? That's something I wonder over too? If so, then I pull the trigger on ”Vision Emu Bundle” 👍
Post by ragan on May 12, 2021 10:44:50 GMT -6
I have just pulled up the GUI for JUST the new Vision strip in Pro Tools. There's no way I'm gonna be able to resist this. Damnit. So somebody help me out here - if I buy the Vision Emu Bundle, do I get the upgraded vision strip too? It's everything except the EQ's, right? Are you saying you're digging just the GUI that much? Or loving the sonics
Post by kcatthedog on May 12, 2021 10:50:58 GMT -6
From ua plug in blurb:
“The API Vision Console Emulation Bundle also includes UAD plug‑in versions of the API Preamp, Vision Channel Strip Collection, and API 2500 Bus Compressor, letting you track and mix in real time with Apollo and your favorite DAW.“
Post by Johnkenn on May 12, 2021 11:11:31 GMT -6
I have just pulled up the GUI for JUST the new Vision strip in Pro Tools. There's no way I'm gonna be able to resist this. Damnit. So somebody help me out here - if I buy the Vision Emu Bundle, do I get the upgraded vision strip too? It's everything except the EQ's, right? Are you saying you're digging just the GUI that much? Or loving the sonics No - just the GUI lol. I pulled it up and started thinking about using it in Luna and got all hot and bothered. But after using the CS on a Drumbus and really pushing - it's pretty fabulous.
Post by Johnkenn on May 12, 2021 11:14:31 GMT -6
I could feel the hype melting my brain resistance.
Post by ragan on May 12, 2021 11:28:21 GMT -6
I could feel the hype melting my brain resistance. Happens to the best of us
Post by kcatthedog on May 12, 2021 12:01:18 GMT -6
Resistance is futile, until you sell your Apollo
